[GRASS-SVN] r53680 - grass/trunk/vector/v.extract
svn_grass at osgeo.org
Sun Nov 4 07:21:45 PST 2012
Author: neteler
Date: 2012-11-04 07:21:45 -0800 (Sun, 04 Nov 2012)
New Revision: 53680
grass/trunk/vector/v.extract/v.extract.html
doc update; fix for trac #1772
Modified: grass/trunk/vector/v.extract/v.extract.html
--- grass/trunk/vector/v.extract/v.extract.html 2012-11-04 15:05:21 UTC (rev 53679)
+++ grass/trunk/vector/v.extract/v.extract.html 2012-11-04 15:21:45 UTC (rev 53680)
@@ -7,7 +7,7 @@
Dissolving (optional) is based on the output categories. If 2 adjacent
areas have the same output category, the boundary is removed.
-<p>If <b>list</b>, <b>file</b>, <b>random</b> or <b>where</b> options are not
+<p>If <b>cats</b>, <b>file</b>, <b>random</b> or <b>where</b> options are not
specified, all features of given type and layer are
extracted. Categories are not changed in that case.
@@ -22,7 +22,7 @@
<h3>Extract areas by category number with dissolving #1:</h3>
<div class="code"><pre>
-v.extract -d list=1,2,3,4 input=soils output=soil_groupa type=area new=0
+v.extract -d cats=1,2,3,4 input=soils output=soil_groupa type=area new=0
</pre></div>
<p>produces a new vector <b>soil_groupa</b>, containing those areas from vector
@@ -31,7 +31,7 @@
<h3>Extract areas by category number with dissolving #2:</h3>
-v.extract -d list=1-4 input=soils output=soil_groupa type=area new=-1
+v.extract -d cats=1-4 input=soils output=soil_groupa type=area new=-1
</pre></div>
<p>produces a new vector map <b>soil_groupa</b> containing the areas from vector
<b>soils</b> which have categories <b>1 thru 4</b>. Any common boundaries are
@@ -70,10 +70,10 @@
Remove unreferenced stations from the GlobalSOD database:
# check what to delete:
-v.db.select gsod_stationlist where="latitude < -91"
+v.db.select gsod_stationlist where="latitude < -91"
# perform reverse selection
-v.extract -r gsod_stationlist out=gsod_stationlist_clean where="latitude < -91"
+v.extract -r gsod_stationlist out=gsod_stationlist_clean where="latitude < -91"
v.db.select gsod_stationlist_clean
</pre></div>
@@ -100,7 +100,7 @@
<h3>Remove islands from polygon map</h3>
-v.extract in=map_with_islands out=maps_without_islands list=1-99999
+v.extract in=map_with_islands out=maps_without_islands cats=1-99999
# and/or
v.extract -d in=map_with_islands out=maps_without_islands
</pre></div>
