[GRASS-SVN] r53689 - grass/trunk/lib/vector/Vlib
Mon Nov 5 04:45:07 PST 2012
Author: mmetz
Date: 2012-11-05 04:45:07 -0800 (Mon, 05 Nov 2012)
New Revision: 53689
   grass/trunk/lib/vector/Vlib/break_lines.c
Vlib: Vect_break_lines_list() speed-up
Modified: grass/trunk/lib/vector/Vlib/break_lines.c
--- grass/trunk/lib/vector/Vlib/break_lines.c	2012-11-05 12:43:38 UTC (rev 53688)
+++ grass/trunk/lib/vector/Vlib/break_lines.c	2012-11-05 12:45:07 UTC (rev 53689)
@@ -115,6 +115,29 @@
     return break_lines(Map, List_break, List_ref, type, Err, 1);
+static int cmp(const void *a, const void *b)
+    int ai = *(int *)a;
+    int bi = *(int *)b;
+    return (ai < bi ? -1 : ai > bi);
+static void sort_ilist(struct ilist *List, int (*cmp_ilist)(const void *, const void *))
+    int i, is_sorted = 1;
+    for (i = 1; i < List->n_values; i++) {
+	if (cmp_ilist(&List->value[i - 1], &List->value[i]) == 1) {
+	    is_sorted = 0;
+	    break;
+    if (!is_sorted)
+	qsort(List->value, List->n_values, sizeof(int), cmp);
 int
 break_lines(struct Map_info *Map, struct ilist *List_break,
 		      struct ilist *List_ref, int type,
@@ -169,6 +192,9 @@
      * the file, and process next line (remaining lines overlapping box are skipped)
     nbreaks = 0;
+    if (List_ref)
+	sort_ilist(List_ref, cmp);
     for (iline = 0; iline < nlines; iline++) {
 	G_percent(iline, nlines, 1);
@@ -179,7 +205,8 @@
 	    aline = iline + 1;
-	if (List_ref && !Vect_val_in_list(List_ref, aline))
+	if (List_ref &&
+	    !bsearch(&aline, List_ref->value, List_ref->n_values, sizeof(int), cmp))
 	    continue;
 	G_debug(3, "aline =  %d", aline);
@@ -232,8 +259,13 @@
 	    /* check intersection of aline with bline only once */
-	    if (bline > aline)
-		continue;
+	    if (bline > aline) {
+		if (!List_ref)
+		    continue;
+		else if (bsearch(&bline, List_ref->value, List_ref->n_values,
+		            sizeof(int), cmp))
+		    continue;
 	    G_debug(3, "  j = %d bline = %d", j, bline);
@@ -335,17 +367,18 @@
 		    /* line may collapse, don't write zero length lines */
 		    Vect_line_prune(AXLines[k]);
 		    if ((atype & GV_POINTS) || AXLines[k]->n_points > 1) {
-			if (!check)
+			if (!check) {
 			    ret = Vect_write_line(Map, atype, AXLines[k],
 			                          ACats);
-			if (List_ref) {
-			    Vect_list_append(List_ref, ret);
+			    if (List_ref) {
+				G_ilist_add(List_ref, ret);
+			    G_debug(3, "Line %d written, npoints = %d", ret,
+				    AXLines[k]->n_points);
+			    if (List_break) {
+				Vect_list_append(List_break, ret);
-			G_debug(3, "Line %d written, npoints = %d", ret,
-				AXLines[k]->n_points);
-			if (List_break) {
-			    Vect_list_append(List_break, ret);
 		    /* Write intersection points */
@@ -373,13 +406,14 @@
 			Vect_line_prune(BXLines[k]);
 			if ((btype & GV_POINTS) || BXLines[k]->n_points > 1) {
-			    if (!check)
+			    if (!check) {
 				ret =
 				    Vect_write_line(Map, btype, BXLines[k],
 						    BCats);
-			    G_debug(5, "Line %d written", ret);
-			    if (List_break) {
+				G_debug(5, "Line %d written", ret);
+				if (List_break) {
