[GRASS-SVN] r53697 - grass/trunk/lib/cdhc
svn_grass at osgeo.org
Tue Nov 6 05:02:17 PST 2012
Author: neteler
Date: 2012-11-06 05:02:16 -0800 (Tue, 06 Nov 2012)
New Revision: 53697
Added:
grass/trunk/lib/cdhc/test.c
grass/trunk/lib/cdhc/test_numbers.csv
Removed:
grass/trunk/lib/cdhc/c-drive.c.txt
grass/trunk/lib/cdhc/Makefile
activated automated test
Modified: grass/trunk/lib/cdhc/Makefile
--- grass/trunk/lib/cdhc/Makefile 2012-11-06 12:55:09 UTC (rev 53696)
+++ grass/trunk/lib/cdhc/Makefile 2012-11-06 13:02:16 UTC (rev 53697)
@@ -1,7 +1,24 @@
MODULE_TOPDIR = ../..
+include $(MODULE_TOPDIR)/include/Make/Vars.make
+MOD_OBJS := $(filter-out test.o port_test.o,$(AUTO_OBJS))
LIB = CDHC
include $(MODULE_TOPDIR)/include/Make/Lib.make
default: lib
+ @echo "==============TEST============="
+ifeq ($(strip $(CROSS_COMPILING)),)
+ $(MAKE) test
+endif
+test: $(OBJDIR)/test$(EXE)
+ cd $(OBJDIR) && $(call run_grass,./test < ../test_numbers.csv)
+# Test functions
+$(OBJDIR)/test$(EXE): $(OBJDIR)/test.o $(CDHCDEP)
+ $(call linker)
+$(OBJDIR)/test$(EXE): LIBES = $(CDHCLIB)
Deleted: grass/trunk/lib/cdhc/c-drive.c.txt
--- grass/trunk/lib/cdhc/c-drive.c.txt 2012-11-06 12:55:09 UTC (rev 53696)
+++ grass/trunk/lib/cdhc/c-drive.c.txt 2012-11-06 13:02:16 UTC (rev 53697)
@@ -1,48 +0,0 @@
-#include <stdio.h>
-#include <stdlib.h>
-#include <grass/cdhc.h>
-int main(int argc, char **argv)
- double x[1000];
- double *y;
- int n = 0;
- while (scanf("%lf", &x[n++]) != EOF) ;
- n--;
- fprintf(stdout, "N=%d\n", n);
- fprintf(stdout, "*y=%ld\n", y);
- y = omnibus_moments(x, n);
- y = geary_test(x, n);
- y = dagostino_d(x, n);
- fprintf(stdout, "y=%g\n", y[1]);
- y = kuipers_v(x, n);
- y = watson_u2(x, n);
- y = durbins_exact(x, n);
- y = anderson_darling(x, n);
- y = cramer_von_mises(x, n);
- /* for ks and lillefors, the discrepancy seems to come
- in in computing the sum of x*x */
- y = kolmogorov_smirnov(x, n);
- y = chi_square(x, n);
- y = shapiro_wilk(x, n);
- y = shapiro_francia(x, n);
- y = shapiro_wilk_exp(x, n);
- y = cramer_von_mises_exp(x, n);
- y = kolmogorov_smirnov_exp(x, n);
- y = kuipers_v_exp(x, n);
- y = watson_u2_exp(x, n);
- y = anderson_darling_exp(x, n);
- y = chi_square_exp(x, n);
- y = mod_maxlik_ratio(x, n);
- y = coeff_variation(x, n);
- y = kotz_families(x, n);
- return EXIT_SUCCESS;
Copied: grass/trunk/lib/cdhc/test.c (from rev 53692, grass/trunk/lib/cdhc/c-drive.c.txt)
--- grass/trunk/lib/cdhc/test.c (rev 0)
+++ grass/trunk/lib/cdhc/test.c 2012-11-06 13:02:16 UTC (rev 53697)
@@ -0,0 +1,51 @@
+#include <stdio.h>
+#include <stdlib.h>
+#include <grass/cdhc.h>
+int main(int argc, char **argv)
+ double x[1000];
+ double *y;
+ int n = 0;
+ while (scanf("%lf", &x[n++]) != EOF) ;
+ n--;
+ fprintf(stdout, "N=%d\n", n);
+ fprintf(stdout, "*y=%ld\n", y);
+ y = omnibus_moments(x, n);
+ y = geary_test(x, n);
+ y = dagostino_d(x, n);
+ fprintf(stdout, "y=%g\n", y[1]);
+ y = kuipers_v(x, n);
+ y = watson_u2(x, n);
+ y = durbins_exact(x, n);
+ y = anderson_darling(x, n);
+ y = cramer_von_mises(x, n);
+ /* for ks and lillefors, the discrepancy seems to come
+ in in computing the sum of x*x */
+ y = kolmogorov_smirnov(x, n);
+ y = chi_square(x, n);
+ y = shapiro_wilk(x, n);
+ y = shapiro_francia(x, n);
+ y = shapiro_wilk_exp(x, n);
+ y = cramer_von_mises_exp(x, n);
+ y = kolmogorov_smirnov_exp(x, n);
+ y = kuipers_v_exp(x, n);
+ y = watson_u2_exp(x, n);
+ y = anderson_darling_exp(x, n);
+ y = chi_square_exp(x, n);
+/* missing from source code:
+ y = mod_maxlik_ratio(x, n);
+ y = coeff_variation(x, n);
+ y = kotz_families(x, n);
+ return EXIT_SUCCESS;
Added: grass/trunk/lib/cdhc/test_numbers.csv
--- grass/trunk/lib/cdhc/test_numbers.csv (rev 0)
+++ grass/trunk/lib/cdhc/test_numbers.csv 2012-11-06 13:02:16 UTC (rev 53697)
@@ -0,0 +1,7 @@
+1234.2
+3454
+23423
+234
+23423
+3678
+67873.5
