[GRASS-SVN] r53699 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Tue Nov 6 05:32:17 PST 2012
Author: mmetz
Date: 2012-11-06 05:32:16 -0800 (Tue, 06 Nov 2012)
New Revision: 53699
grass/trunk/lib/vector/Vlib/remove_duplicates.c
Vlib: improve Vect_remove_duplicates()
Modified: grass/trunk/lib/vector/Vlib/remove_duplicates.c
--- grass/trunk/lib/vector/Vlib/remove_duplicates.c 2012-11-06 13:16:48 UTC (rev 53698)
+++ grass/trunk/lib/vector/Vlib/remove_duplicates.c 2012-11-06 13:32:16 UTC (rev 53699)
@@ -76,6 +76,14 @@
continue;
+ npoints = APoints->n_points;
+ Vect_line_prune(APoints);
+ if (npoints != APoints->n_points) {
+ Vect_rewrite_line(Map, i, atype, APoints, ACats);
+ nlines = Vect_get_num_lines(Map);
+ continue;
Vect_line_box(APoints, &ABox);
Vect_select_lines_by_box(Map, &ABox, type, List);
G_debug(3, " %d lines selected by box", List->n_values);
@@ -83,7 +91,9 @@
for (j = 0; j < List->n_values; j++) {
bline = List->id[j];
G_debug(3, " j = %d bline = %d", j, bline);
- if (i == bline)
+ /* check duplicate of bline only once */
+ if (i <= bline)
continue;
btype = Vect_read_line(Map, BPoints, BCats, bline);
