[GRASS-SVN] r53704 - in grass-addons/grass6/postscript: . ps.atlas
svn_grass at osgeo.org
Tue Nov 6 06:21:33 PST 2012
Author: neteler
Date: 2012-11-06 06:21:32 -0800 (Tue, 06 Nov 2012)
New Revision: 53704
Added:
grass-addons/grass6/postscript/ps.atlas/
grass-addons/grass6/postscript/ps.atlas/Makefile
grass-addons/grass6/postscript/ps.atlas/description.html
grass-addons/grass6/postscript/ps.atlas/ps.atlas
Jachym Cepicky: added here from http://les-ejk.cz/programs/grass/ps.atlas
Added: grass-addons/grass6/postscript/ps.atlas/Makefile
--- grass-addons/grass6/postscript/ps.atlas/Makefile (rev 0)
+++ grass-addons/grass6/postscript/ps.atlas/Makefile 2012-11-06 14:21:32 UTC (rev 53704)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = ps.atlas
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass6/postscript/ps.atlas/description.html
--- grass-addons/grass6/postscript/ps.atlas/description.html (rev 0)
+++ grass-addons/grass6/postscript/ps.atlas/description.html 2012-11-06 14:21:32 UTC (rev 53704)
@@ -0,0 +1,12 @@
+<h2>DESCRIPTION</h2>
+<em>ps.atlas</em> is a shell script that makes more maps on current
+region according to input *.psmap file. General map can be stored as
+vector file. The resulting *.eps maps can be automatically converted
+to *.pdf files.
+<h2>AUTHOR</h2>
+Jachym Cepicky, 2009
+<p><i>Last changed: $Date$</i>
Property changes on: grass-addons/grass6/postscript/ps.atlas/description.html
___________________________________________________________________
Added: svn:mime-type
+ text/html
Added: svn:keywords
+ Author Date Id
Added: svn:eol-style
+ native
Added: grass-addons/grass6/postscript/ps.atlas/ps.atlas
--- grass-addons/grass6/postscript/ps.atlas/ps.atlas (rev 0)
+++ grass-addons/grass6/postscript/ps.atlas/ps.atlas 2012-11-06 14:21:32 UTC (rev 53704)
@@ -0,0 +1,338 @@
+#!/bin/sh
+# script: ps.atlas
+# author: Jachym Cepicky <jachym.cepicky at centrum.cz>
+# description: Makes "atlas of maps" of region for defined number of rows
+# and columns
+# date: 2005-07-12
+# copyright: This program is free software under the GNU General Public
+# License (>=v2).
+# needs: - sed
+# - grep
+# - awk
+# - bc
+# - ps2pdf
+if test "$GISBASE" = ""; then
+ echo "You must be in GRASS GIS to run this program." >&2
+ exit 1
+fi
+#%Module
+#% description: Prints atlas of maps with ps.map
+#%end
+#%option
+#% key: input
+#% type: string
+#% description: Mapfile for ps.map
+#% required : yes
+#%End
+#%option
+#% key: output
+#% type: string
+#% description: Prefix of output files
+#% required : yes
+#%End
+#%option
+#% key: rows
+#% type: integer
+#% description: Number of rows in region
+#% required : yes
+#% answer: 1
+#%End
+#%option
+#% key: cols
+#% type: integer
+#% description: Number of columns in region, maximum is 676
+#% required : yes
+#% answer: 1
+#%End
+#%option
+#% key: overlap
+#% type: integer
+#% description: Overlap in map units
+#% answer: 0
+#% required : no
+#%End
+#%option
+#% key: format
+#% type: string
+#% description: Format of the paper (a3, a4,...) (for ps2pdfwr).
+#% answer: a4
+#% required : no
+#%End
+#%flag
+#% key: p
+#% description: Create pdf
+#%end
+#%flag
+#% key: v
+#% description: Create vector file, which will contain the map boundaries
+#%end
+#%flag
+#% key: r
+#% description: Rotate plot
+#%End
+#%flag
+#% key: o
+#% description: Overwrite the vector file, if it exists
+#%End
+#%flag
+#% key: d
+#% description: Debuging - all messages are printed out.
+#%End
+## parser
+if [ "$1" != "@ARGS_PARSED@" ] ; then
+ exec g.parser "$0" "$@"
+fi
+# sed
+if [ -z "`which sed`" ] ; then
+ echo "ERROR: Script needs sed."
+ exit 1
+fi
+# grep
+if [ -z "`which grep`" ] ; then
+ echo "ERROR: Script needs grep."
+ exit 1
+fi
+# awk
+if [ -z "`which awk`" ] ; then
+ echo "ERROR: Script needs awk."
+ exit 1
+fi
+# bc
+if [ -z "`which bc`" ] ; then
+ echo "ERROR: Script needs bc."
+ exit 1
+fi
+# ps2pdfwr
+if [ -z "`which ps2pdfwr`" ] && [ $GIS_FLAG_p -eq 1 ]; then
+ echo "ERROR: Script needs ps2pdfwr."
+ exit 1
+fi
+# input file
+if [ ! -e "$GIS_OPT_INPUT" ]; then
+ echo "ERROR: Input file $GIS_OPT_INPUT does not exist."
+ exit 1;
+fi
+# there can be only 'A' to 'ZZ' columns
+if [ "$GIS_OPT_COLS" -gt "702" ]; then
+ echo "WARNING: Maximum number of columns is 676."
+ echo "WARNING: You desired $input of columns."
+ echo "WARNING: I will use 702 columns for this region."
+ GIS_OPT_cols=702;
+fi
+# redirecting messages to stdout or /dev/null
+if [ "$GIS_FLAG_D" -eq "1" ]; then
+ OUT="/dev/stdout"
+else
+ OUT="/dev/null"
+fi
+## vars
+eval `g.gisenv`
+: ${GISBASE?} ${GISDBASE?} ${LOCATION_NAME?} ${MAPSET?}
+input="$GIS_OPT_INPUT"
+out="$GIS_OPT_OUTPUT"
+rows="$GIS_OPT_ROWS"
+cols="$GIS_OPT_COLS"
+rotate=""
+overlap="$GIS_OPT_OVERLAP"
+oldregion="region_$$"
+newvector=$out"_atlas"
+TMP1="`g.tempfile pid=$$`"
+rows_x_cols=`echo $rows $cols|awk '{print $1*$2}'`;
+# removing vector, if exists
+# create vector && overwrite old && vector exists
+if [ "$GIS_FLAG_V" -eq "1" ] && [ "$GIS_FLAG_O" -eq "1" ] && [ -n "`g.mlist type=vect mapset=$MAPSET pattern=$newvector`" ]; then
+ echo "Vector exists, removing..."
+ g.remove vect=$newvector 1>$OUT
+else
+ # create vector && NOT overwrite old && vector exists
+ if [ "$GIS_FLAG_V" -eq "1" ] && [ -n "`g.mlist type=vect mapset=$MAPSET pattern=$newvector`" ] ; then
+ echo "ERROR: Vector file $newvector allready exists, remove it first!"
+ exit 1;
+ fi
+fi
+# rotate flag
+if [ $GIS_FLAG_R -eq 1 ]; then
+ rotate="-r";
+fi
+# informing
+echo "Running: ps.map -e $rotate in=$input out=$out.eps"
+# use only hlaf of overlaping
+overlap=`echo "$overlap"|awk '{printf("%f", $1/2);}'`;
+cleanup()
+ g.region $oldregion
+ rm -f $GISDBASE/$LOCATION_NAME/$MAPSET/windows/$oldregion
+ rm -f $TMP1
+# what to do in case of user break:
+exitprocedure()
+ echo "User break!"
+ echo "drop table $newvector"|db.execute
+ cleanup
+ exit 1
+# shell check for user break (signal list: trap -l)
+trap "exitprocedure" 2 3 15
+g.region save=$oldregion
+# must be because of awk and non-english locale
+export LANG=C
+# setign maxe, maxn, maxw and maxs variables with help of g.region
+eval `g.region -g| sed -e s/^/max/`;
+# be simple ps.map
+if [ -z "$cols" ]; then
+ cols=1;
+fi
+if [ -z "$rows" ]; then
+ rows=1;
+fi
+north=$maxn;
+west=$maxw;
+# size of steps
+estep=`echo $maxe $maxw $cols | awk '{printf("%f",($1-$2)/$3);}'`;
+nstep=`echo $maxn $maxs $rows | awk '{printf("%f",($1-$2)/$3);}'`;
+# setting first region
+south=`echo $north $nstep | awk '{printf("%f",$1-$2)}'`;
+east=`echo $west $estep | awk '{printf("%f",$1+$2)}'`;
+# number of region
+no_of_region=0;
+### ascii file and db. table
+if [ $GIS_FLAG_V -eq 1 ]; then
+ echo "Creating ascii file + vector table"
+ ### creating database
+ echo "CREATE TABLE $newvector (cat int, region int, label varchar(10), row int, col varchar(5), east double, north double, west double, south double);"| db.execute
+fi
+# inicialization
+currow=0;
+### rows N-S
+while [ "`echo $overlap $south $maxs |awk '{printf("%d", $2+$1 >= $3);}'`" -eq "1" ];
+do
+ echo "north->south" 1>$OUT # test
+ # number of current row
+ currow=`expr $currow + 1`;
+ # inicialization
+ curcol=0;
+ # columns W-E
+ while [ "`echo $east $maxe |awk '{printf("%d", $1 <= $2);}'`" -eq "1" ];
+ do
+ echo "west->east" 1>$OUT # test
+ # number of current column
+ curcol=`expr $curcol + 1`;
+ # charakter of current column
+ if [ "$curcol" -gt "26" ]; then
+ pre_alpha=`echo $curcol/26| bc`;
+ curcol_alpha=`echo $pre_alpha $curcol|awk '{printf("%c%c",$1+64, $2-26+64);}'`;
+ else
+ curcol_alpha=`echo $curcol|awk '{printf("%c",$1+64);}'`;
+ fi
+ # overlapping 10% = 5% on both sides
+ over_north=`echo $north $overlap|awk '{printf("%f", $1+$2);}'`;
+ over_west=`echo $west $overlap|awk '{printf("%f", $1-$2);}'`;
+ over_east=`echo $east $overlap|awk '{printf("%f", $1+$2);}'`;
+ over_south=`echo $south $overlap|awk '{printf("%f", $1-$2);}'`;
+ east_center=`echo "$over_east+(($over_west)-($over_east))/2" |bc `
+ north_center=`echo "$over_south+(($over_north)-($over_south))/2" |bc `
+ g.region n=$over_north s=$over_south w=$over_west e=$over_east;
+ west=$east
+ east=`echo "$west $estep" | awk '{print $1 + $2}'`;
+ no_of_region=`expr $no_of_region + 1`;
+ echo "-------------- REGION NUMBER $no_of_region OF $rows_x_cols ---------------" 1>$OUT
+ # storing coordinaes to ascii file
+ if [ $GIS_FLAG_v -eq 1 ]; then
+ echo "B 5" >> $TMP1
+ echo "$over_east $over_north" >> $TMP1
+ echo "$over_east $over_south" >> $TMP1
+ echo "$over_west $over_south" >> $TMP1
+ echo "$over_west $over_north" >> $TMP1
+ echo -e "C 1 1\n$east_center $north_center\n1 $no_of_region" >> $TMP1
+ echo "INSERT INTO $newvector (cat, region, col, row, label, north, east, south, west) VALUES ($no_of_region,$no_of_region, '$curcol_alpha', $currow, '$curcol_alpha$currow', $over_north, $over_east, $over_south, $over_west);"|db.execute
+ fi
+ # create ps & pdf
+ ps.map -e $rotate in=$input out=$out$no_of_region.eps 1>$OUT
+ if [ "$GIS_FLAG_p" = "1" ]; then
+ ps2pdfwr -sPAPERSIZE=$GIS_OPT_FORMAT $out$no_of_region.eps
+ fi
+ # print progres
+ echo "$no_of_region $rows_x_cols" | awk '{printf("\r%d%%",$1/$2*100);}' 1>&1
+ done
+ north=$south
+ south=`echo "$north $nstep" |awk '{print $1 - $2}'`;
+ # go back to west!
+ west=$maxw
+done;
+if [ $GIS_FLAG_v -eq 1 ]; then
+ # import the vector of regions
+ outtmp="$newvector"_tmp
+ v.in.ascii -n in=$TMP1 out=$outtmp format=standard 1>$OUT 2>&1
+ v.clean tool=break,rmdupl in=$outtmp out=$newvector 1>$OUT 2>&1
+ g.remove vect=$outtmp 1>$OUT 2>&1
+ v.db.connect map=$newvector table=$newvector 1>$OUT 2>&1
+fi
+### cleaning
+cleanup
Property changes on: grass-addons/grass6/postscript/ps.atlas/ps.atlas
Added: svn:executable
+ text/x-sh
+ native
