[GRASS-SVN] r53708 - grass/branches/develbranch_6/gui/wxpython/wxplot
Tue Nov 6 07:24:19 PST 2012
Author: martinl
Date: 2012-11-06 07:24:18 -0800 (Tue, 06 Nov 2012)
New Revision: 53708
   grass/branches/develbranch_6/gui/wxpython/wxplot/base.py
   grass/branches/develbranch_6/gui/wxpython/wxplot/dialogs.py
   grass/branches/develbranch_6/gui/wxpython/wxplot/profile.py
wxGUI/profiler: fix CVS export
		(merge r53696 & r53706 from relbr64)
Modified: grass/branches/develbranch_6/gui/wxpython/wxplot/base.py
--- grass/branches/develbranch_6/gui/wxpython/wxplot/base.py	2012-11-06 15:19:51 UTC (rev 53707)
+++ grass/branches/develbranch_6/gui/wxpython/wxplot/base.py	2012-11-06 15:24:18 UTC (rev 53708)
@@ -453,14 +453,13 @@
         """!Set custom text values for profile title and axis labels.
         dlg = TextDialog(parent = self, id = wx.ID_ANY,
-                                 plottype = self.plottype,
-                                 title = _('Histogram text settings'))
+                         plottype = self.plottype,
+                         title = _('Text settings'))
         btnval = dlg.ShowModal()
         if btnval == wx.ID_SAVE or btnval == wx.ID_OK or btnval == wx.ID_CANCEL:
             dlg.Destroy()
     def PlotOptions(self, event):
         """!Set various profile options, including: line width, color,
         style; marker size, color, fill, and style; grid and legend
Modified: grass/branches/develbranch_6/gui/wxpython/wxplot/dialogs.py
--- grass/branches/develbranch_6/gui/wxpython/wxplot/dialogs.py	2012-11-06 15:19:51 UTC (rev 53707)
+++ grass/branches/develbranch_6/gui/wxpython/wxplot/dialogs.py	2012-11-06 15:24:18 UTC (rev 53708)
@@ -11,7 +11,7 @@
  - dialogs::TextDialog
  - dialogs::OptDialog
-(C) 2011 by the GRASS Development Team
+(C) 2011-2012 by the GRASS Development Team
 This program is free software under the GNU General Public License
 (>=v2). Read the file COPYING that comes with GRASS for details.
@@ -872,4 +872,4 @@
     def OnCancel(self, event):
         """!Button 'Cancel' pressed"""
         self.Close()
\ No newline at end of file
Modified: grass/branches/develbranch_6/gui/wxpython/wxplot/profile.py
--- grass/branches/develbranch_6/gui/wxpython/wxplot/profile.py	2012-11-06 15:19:51 UTC (rev 53707)
+++ grass/branches/develbranch_6/gui/wxpython/wxplot/profile.py	2012-11-06 15:24:18 UTC (rev 53708)
@@ -7,7 +7,7 @@
  - profile::ProfileFrame
  - profile::ProfileToolbar
@@ -22,7 +22,6 @@
 import wx
 import wx.lib.plot as plot
-from core.gcmd import GWarning
 import grass.script as grass
 try:
@@ -38,7 +37,7 @@
 from wxplot.base       import BasePlotFrame, PlotIcons
 from gui_core.toolbars import BaseToolbar, BaseIcons
 from wxplot.dialogs    import ProfileRasterDialog, PlotStatsFrame
-from core.gcmd         import RunCommand
+from core.gcmd         import RunCommand, GWarning, GError, GMessage
 class ProfileFrame(BasePlotFrame):
     """!Mainframe for displaying profile of one or more raster maps. Uses wx.lib.plot.
@@ -330,31 +329,48 @@
     def SaveProfileToFile(self, event):
         """!Save r.profile data to a csv file
-        wildcard = _("Comma separated value (*.csv)|*.csv")
         dlg = wx.FileDialog(parent = self,
-                            message = _("Path and prefix (for raster name) to save profile values..."),
+                            message = _("Choose prefix for file(s) where to save profile values..."),
                             defaultDir = os.getcwd(),
-                            defaultFile = "",  wildcard = wildcard, style = wx.SAVE)
+                            wildcard = _("Comma separated value (*.csv)|*.csv"), style = wx.SAVE)
+        pfile = []
         if dlg.ShowModal() == wx.ID_OK:
             path = dlg.GetPath()
             for r in self.rasterList:
-                pfile = path+'_'+str(r['name'])+'.csv'
+                pfile.append(path + '_' + str(r.replace('@', '_')) + '.csv')
+                if os.path.exists(pfile[-1]):
+                    dlgOv = wx.MessageDialog(self,
+                                             message = _("File <%s> already exists. "
+                                                         "Do you want to overwrite this file?") % pfile[-1],
+                                             caption = _("Overwrite file?"),
+                                             style = wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
+                    if dlgOv.ShowModal() != wx.ID_YES:
+                        pfile.pop()
+                        dlgOv.Destroy()
+                        continue
                 try:
-                    file = open(pfile, "w")
-                except IOError:
-                    wx.MessageBox(parent = self,
-                                  message = _("Unable to open file <%s> for writing.") % pfile,
-                                  caption = _("Error"), style = wx.OK | wx.ICON_ERROR | wx.CENTRE)
-                    return False
+                    fd = open(pfile[-1], "w")
+                except IOError, e:
+                    GError(parent = self,
+                           message = _("Unable to open file <%s> for writing.\n"
+                                       "Reason: %s") % (pfile[-1], e))
+                    dlg.Destroy()
+                    return
                 for datapair in self.raster[r]['datalist']:
-                    file.write('%d,%d\n' % (float(datapair[0]),float(datapair[1])))
-                file.close()
+                    fd.write('%d,%d\n' % (float(datapair[0]),float(datapair[1])))
+                fd.close()
         dlg.Destroy()
+        if pfile:
+            message = _("%d files created:\n%s") % (len(pfile), '\n'.join(pfile))
+        else:
+            message = _("No files generated.")
+        GMessage(parent = self, message = message)
     def OnStats(self, event):
         """!Displays regression information in messagebox
