[GRASS-SVN] r53730 - grass/trunk/locale/po
svn_grass at osgeo.org
Wed Nov 7 14:10:07 PST 2012
Author: neteler
Date: 2012-11-07 14:10:06 -0800 (Wed, 07 Nov 2012)
New Revision: 53730
grass/trunk/locale/po/grasswxpy_pl.po
Milena Nowotarska: cont'ed
Modified: grass/trunk/locale/po/grasswxpy_pl.po
--- grass/trunk/locale/po/grasswxpy_pl.po 2012-11-07 22:09:40 UTC (rev 53729)
+++ grass/trunk/locale/po/grasswxpy_pl.po 2012-11-07 22:10:06 UTC (rev 53730)
@@ -46,7 +46,7 @@
#: ../gui/wxpython/nviz/tools.py:219
msgid "Control View"
-msgstr ""
+msgstr "Kontrola widoku"
#: ../gui/wxpython/nviz/tools.py:240
msgid "Adjusts the viewer's angle of view"
@@ -583,11 +583,11 @@
#: ../gui/wxpython/nviz/tools.py:1748
msgid "Adjusts the light height"
-msgstr ""
+msgstr "Ustawia wysokość źródła światła"
#: ../gui/wxpython/nviz/tools.py:1772
msgid "Light color and intensity"
-msgstr ""
+msgstr "Kolor i intensywność oświetlenia"
#: ../gui/wxpython/nviz/tools.py:1786 ../gui/wxpython/nviz/preferences.py:306
msgid "Brightness:"
@@ -595,7 +595,7 @@
#: ../gui/wxpython/nviz/tools.py:1788
msgid "Adjusts the brightness of the light"
-msgstr ""
+msgstr "Ustawia jasność światła"
#: ../gui/wxpython/nviz/tools.py:1797 ../gui/wxpython/nviz/preferences.py:320
msgid "Ambient:"
@@ -603,7 +603,7 @@
#: ../gui/wxpython/nviz/tools.py:1799
msgid "Adjusts the ambient light"
-msgstr ""
+msgstr "Ustawia oświetlenie otoczenia"
#: ../gui/wxpython/nviz/tools.py:1860
msgid "Edges with fringe"
@@ -3725,7 +3725,7 @@
#: ../gui/wxpython/gui_core/ghelp.py:274
msgid "You must run this command from the menu or command line"
-msgstr ""
+msgstr "Uruchom polecenie z menu lub wiersza poleceń"
#: ../gui/wxpython/gui_core/ghelp.py:329
#: ../gui/wxpython/gui_core/goutput.py:718
@@ -3805,7 +3805,7 @@
#: ../gui/wxpython/gui_core/ghelp.py:628 ../gui/wxpython/gui_core/ghelp.py:690
#, python-format
msgid "Error when reading file '%s'."
-msgstr ""
+msgstr "Błąd odczytu pliku '%s'."
#: ../gui/wxpython/gui_core/ghelp.py:629 ../gui/wxpython/gui_core/ghelp.py:691
msgid "Lines:"
@@ -3908,7 +3908,7 @@
#: ../gui/wxpython/gui_core/forms.py:519
msgid "Close dialog when command is successfully finished. Change this settings in Preferences dialog ('Command' tab)."
-msgstr ""
+msgstr "Zamknij okno po pomyślnym zakończeniu polecenia. Zmień ustawienia w oknie dialogowym Preferencje ('Command' tab)."
#: ../gui/wxpython/gui_core/forms.py:699
#, python-format
@@ -3992,7 +3992,7 @@
#: ../gui/wxpython/gui_core/forms.py:2089
#, python-format
msgid "%(cmd)s: parameter '%(key)s' not available"
-msgstr ""
+msgstr "%(cmd)s: parametr '%(key)s' jest niedostępny"
#: ../gui/wxpython/gui_core/forms.py:2185
msgid "Try to set up GRASS_ADDON_PATH or GRASS_ADDON_BASE variable."
@@ -4160,7 +4160,7 @@
#: ../gui/wxpython/gui_core/goutput.py:874
#, fuzzy
msgid "Please note that the data are left in inconsistent state and may be corrupted"
-msgstr "Zauważ, że dane są pozostawione w niespójnym stanie i mogą zostać uszkodzone"
+msgstr "Zauważ, że dane są pozostawione w niespójnym stanie i mogą zostać uszkodzone"
#: ../gui/wxpython/gui_core/goutput.py:876
msgid "Command aborted"
@@ -4173,12 +4173,12 @@
#: ../gui/wxpython/gui_core/goutput.py:1365
#: ../gui/wxpython/gmodeler/frame.py:179
msgid "Python script contains local modifications"
-msgstr ""
+msgstr "Skrypt pythona zawiera zmiany"
#: ../gui/wxpython/gui_core/mapdisp.py:109 ../gui/wxpython/core/render.py:412
#, python-format
msgid "GRASS module '%s' not found. Unable to start map display window."
-msgstr ""
+msgstr "Nie znaleziono modułu '%s'. Nie można uruchomić okna wyświetlania mapy."
#: ../gui/wxpython/gui_core/dialogs.py:118
msgid "Type of element:"
@@ -4787,7 +4787,7 @@
#: ../gui/wxpython/menustrings.py:59
msgid "Unpacks a raster map packed with r.pack."
-msgstr ""
+msgstr "Rozpakowuje mapę rastrową spakowaną r.pack."
#: ../gui/wxpython/menustrings.py:61
msgid "Common import formats"
@@ -5397,7 +5397,7 @@
#: ../gui/wxpython/menustrings.py:215 ../gui/wxpython/menustrings.py:217
msgid "Manages the boundary definitions for the geographic region."
-msgstr "Definiowanie granic geograficznych obszaru roboczego."
+msgstr "Zarządza zasięgiem obszaru geograficznego."
#: ../gui/wxpython/menustrings.py:216
msgid "Set region"
@@ -5520,24 +5520,24 @@
#: ../gui/wxpython/menustrings.py:249
msgid "Installs new extension from GRASS AddOns SVN repository."
-msgstr "Pobierz rozszerzenie z repozytorium."
+msgstr "Pobierz wtyczkę z repozytorium."
#: ../gui/wxpython/menustrings.py:250
msgid "Update installed extensions"
-msgstr "Aktualizuj rozszerzenia"
+msgstr "Aktualizuj wtyczki"
#: ../gui/wxpython/menustrings.py:251
msgid "Rebuilds all locally installed GRASS Addons extensions."
-msgstr "Przebuduj wszystkie zainstalowane rozszerzenia."
+msgstr "Przebudowuje wszystkie zainstalowane wtyczki."
#: ../gui/wxpython/menustrings.py:252
#: ../gui/wxpython/modules/extensions.py:463
msgid "Remove extension"
-msgstr "Usuń rozszerzenie"
+msgstr "Usuń wtyczkę"
#: ../gui/wxpython/menustrings.py:253
msgid "Removes installed GRASS AddOns extension."
-msgstr "Usuń zainstalowane rozszerzenia."
+msgstr "Usuwa zainstalowane wtyczki."
#: ../gui/wxpython/menustrings.py:254 ../gui/wxpython/menustrings.py:932
msgid "Preferences"
@@ -7534,12 +7534,12 @@
#: ../gui/wxpython/menustrings.py:773
msgid "Modis quality control"
-msgstr ""
+msgstr "Kontrola jakości Modis"
#: ../gui/wxpython/menustrings.py:774
#, fuzzy
msgid "Extracts quality control parameters from Modis QC layers."
-msgstr "Ekstrahuje parametry terenu z DEM."
+msgstr "Ekstrahuje parametry kontroli jakości z warstw Modis QC."
#: ../gui/wxpython/menustrings.py:775
msgid "Atmospheric correction"
@@ -7547,7 +7547,7 @@
#: ../gui/wxpython/menustrings.py:776
msgid "Performs atmospheric correction using the 6S algorithm."
-msgstr ""
+msgstr "Przeprowadza korekcję atmosferyczną przy użyciiu algorytmu 6S."
#: ../gui/wxpython/menustrings.py:777
msgid "LatLong map"
@@ -7732,7 +7732,7 @@
#: ../gui/wxpython/menustrings.py:821
#, fuzzy
msgid "Explicitly create the 3D NULL-value bitmap file."
-msgstr "Utwórz plik bitmapy wartości NULL 3D"
+msgstr "Tworzy plik bitmapy wartości NULL 3D."
#: ../gui/wxpython/menustrings.py:822
msgid "Manage timestamp"
@@ -7769,7 +7769,7 @@
#: ../gui/wxpython/menustrings.py:832
#, fuzzy
msgid "Establishes the current working 3D raster mask."
-msgstr "Nie można utworzyć profilu dla mapy rastrowej."
+msgstr "Ustanawia bieżącą maskę rastrową 3D."
#: ../gui/wxpython/menustrings.py:833
msgid "Volume calculator"
@@ -7818,9 +7818,8 @@
msgstr "Statystyki 3D"
#: ../gui/wxpython/menustrings.py:845
-#, fuzzy
msgid "Generates volume statistics for 3D raster maps."
-msgstr "Obliczenia statystyk dla map rastrowych 3D."
+msgstr "Oblicza statystyki dla map rastrowych 3D."
#: ../gui/wxpython/menustrings.py:846
msgid "Univariate statistics for volumes"
@@ -7854,9 +7853,8 @@
msgstr "Lista sterowników"
#: ../gui/wxpython/menustrings.py:853
-#, fuzzy
msgid "Lists all database drivers."
-msgstr "Wyświetl listę wszystkich sterowników bazy danych."
+msgstr "Wyświetla listę wszystkich sterowników baz danych."
#: ../gui/wxpython/menustrings.py:854
msgid "List tables"
@@ -8120,12 +8118,12 @@
#: ../gui/wxpython/menustrings.py:935
#, fuzzy
msgid "Add command"
-msgstr "Dodaj komendę"
+msgstr "Dodaj polecenie"
#: ../gui/wxpython/menustrings.py:936
#, fuzzy
msgid "Add action (GRASS command) to model"
-msgstr "Dodaj akcję (moduł GRASS) do modelu"
+msgstr "Dodaj akcję (polecenie GRASS) do modelu"
#: ../gui/wxpython/menustrings.py:937
msgid "Add data"
@@ -8133,7 +8131,7 @@
#: ../gui/wxpython/menustrings.py:938
msgid "Add data item to model"
-msgstr "Dodaj dane"
+msgstr "Dodaj dane do modelu"
#: ../gui/wxpython/menustrings.py:939
msgid "Define relation"
@@ -9600,7 +9598,7 @@
#: ../gui/wxpython/modules/colorrules.py:288
msgid "Bad color format. Use color format '0:0:0'"
-msgstr ""
+msgstr "Niewłaściwy format koloru. Użyj '0:0:0'"
#: ../gui/wxpython/modules/colorrules.py:373
#: ../gui/wxpython/wxplot/dialogs.py:355
@@ -9830,7 +9828,7 @@
#: ../gui/wxpython/modules/extensions.py:42
msgid "Fetch & install extension from GRASS Addons"
-msgstr "Pobierz i zainstaluj rozszerzenie"
+msgstr "Pobierz i zainstaluj wtyczki z GRASS AddOns"
#: ../gui/wxpython/modules/extensions.py:52
msgid "Repository"
@@ -9838,15 +9836,15 @@
#: ../gui/wxpython/modules/extensions.py:54
msgid "List of extensions"
-msgstr "Lista rozszerzeń"
+msgstr "Lista wtyczek"
#: ../gui/wxpython/modules/extensions.py:58
msgid "Fetch full info including description and keywords"
-msgstr ""
+msgstr "Pobierz pełen opis i słowa kluczowe"
#: ../gui/wxpython/modules/extensions.py:94
msgid "&Fetch"
-msgstr ""
+msgstr "&Pobierz"
#: ../gui/wxpython/modules/extensions.py:95
msgid "Fetch list of available modules from GRASS Addons SVN repository"
@@ -9879,12 +9877,11 @@
#: ../gui/wxpython/modules/extensions.py:388
msgid "Uninstall GRASS Addons extensions"
-msgstr "Odinstaluj rozszerzenia"
+msgstr "Odinstaluj wtyczki"
#: ../gui/wxpython/modules/extensions.py:397
-#, fuzzy
msgid "List of installed extensions"
-msgstr "Lista zainstalowanych rozszerzeń"
+msgstr "Lista zainstalowanych wtyczek"
#: ../gui/wxpython/modules/extensions.py:403
msgid "&Uninstall"
@@ -9892,7 +9889,7 @@
#: ../gui/wxpython/modules/extensions.py:404
msgid "Uninstall selected AddOns extensions"
-msgstr "Odinstaluj wybrane rozszerzenia"
+msgstr "Odinstaluj wybraną wtyczkę"
#: ../gui/wxpython/modules/extensions.py:451
msgid "No extension selected for removal. Operation canceled."
@@ -12768,9 +12765,8 @@
#: ../gui/wxpython/gmodeler/frame.py:181
#: ../gui/wxpython/gmodeler/frame.py:1601
-#, fuzzy
msgid "Python script is up-to-date"
-msgstr "Skrypt pythona (*.py)|*.py"
+msgstr "Skrypt pythona jest aktualny"
#: ../gui/wxpython/gmodeler/frame.py:196
msgid "Redrawing model..."
@@ -12953,7 +12949,7 @@
#: ../gui/wxpython/gmodeler/frame.py:1294
msgid "Add new variable to the model"
-msgstr ""
+msgstr "Dodaj nową zmienną do modelu"
#: ../gui/wxpython/gmodeler/frame.py:1414
msgid "List of items - right-click to delete"
@@ -13018,7 +13014,7 @@
#: ../gui/wxpython/gmodeler/frame.py:1577
msgid "Python script is locally modificated. Refresh will discard all changes. Do you really want to continue?"
-msgstr ""
+msgstr "Skrypt pythona jest miejscami zmieniony. Odświeżenie odrzuci zmiany. Czy chcesz odrzucić zmiany?"
#: ../gui/wxpython/gmodeler/frame.py:1580
#, fuzzy
@@ -14014,6 +14010,9 @@
msgid "Unable to switch to mapset <%s>."
msgstr "Nie można przełączyć na mapset <%s>."
+msgid "Duplicate attributes"
+msgstr "Duplikuj atrybuty"
#~ msgid "Delete last"
#~ msgstr "Usuń ostatni"
@@ -14303,9 +14302,6 @@
#~ msgid "Color table already exists. Check out 'replace existing color table' to overwrite it."
#~ msgstr "Plik regionu <%s> już istnieje.Chcesz go nadpisać?"
-#~ msgid "Duplicate attributes"
-#~ msgstr "Duplikuj atrybuty"
#, fuzzy
#~ msgid "Close current"
#~ msgstr "Zwiń wszystkie za wyjątkiem bieżącej"
@@ -15054,3 +15050,43 @@
#, fuzzy
#~ msgid "Scale"
#~ msgstr "Skala:"
+#, fuzzy
+#~ msgid "GRASS version"
+#~ msgstr "Rozpocznij sesję GRASS-a"
+#, fuzzy
+#~ msgid "GRASS SVN Revision"
+#~ msgstr "Rewizja SVN:"
+#, fuzzy
+#~ msgid "GIS Library Revision"
+#~ msgstr "Rewizja biblioteki GIS:"
+#, fuzzy
+#~ msgid "SVN Revision"
+#~ msgid "Addons extensions"
+#~ msgstr "Wtyczki"
+#~ msgid "Install extension from addons"
+#~ msgstr "Zainstaluj wtyczki"
+#, fuzzy
+#~ msgid "Prints system information"
+#~ msgstr "Informacje"
+#, fuzzy
+#~ msgid "Unable to open file '%s'\n"
+#~ msgstr ""
+#~ "Nie można otworzyć pliku\n"
+#~ "%s"
+#, fuzzy
+#~ msgid "Duplicated key: %s\n"
+#~ msgstr "Duplikuj atrybuty"
+#, fuzzy
+#~ msgid "Unable to create file '%s'\n"
+#~ msgstr "Nie można przeczytać pliku %s."
