[GRASS-SVN] r53734 - grass/trunk/gui/wxpython/swipe
Thu Nov 8 05:27:20 PST 2012
Author: martinl
Date: 2012-11-08 05:27:20 -0800 (Thu, 08 Nov 2012)
New Revision: 53734
Added:
   grass/trunk/gui/wxpython/swipe/Makefile
   grass/trunk/gui/wxpython/swipe/g.gui.mapswipe.py
Removed:
   grass/trunk/gui/wxpython/swipe/main.py
wxGUI/MapSwipe: add Makefile for g.gui.mapswipe (part 1)
Added: grass/trunk/gui/wxpython/swipe/Makefile
--- grass/trunk/gui/wxpython/swipe/Makefile	                        (rev 0)
+++ grass/trunk/gui/wxpython/swipe/Makefile	2012-11-08 13:27:20 UTC (rev 53734)
@@ -0,0 +1,8 @@
+MODULE_TOPDIR = ../../..
+PGM = g.gui.mapswipe
+include $(MODULE_TOPDIR)/include/Make/Script.make
+include $(MODULE_TOPDIR)/include/Make/NoHtml.make
+default: script
Property changes on: grass/trunk/gui/wxpython/swipe/Makefile
___________________________________________________________________
Added: svn:mime-type
   + text/x-makefile
Added: svn:eol-style
   + native
Copied: grass/trunk/gui/wxpython/swipe/g.gui.mapswipe.py (from rev 53718, grass/trunk/gui/wxpython/swipe/main.py)
--- grass/trunk/gui/wxpython/swipe/g.gui.mapswipe.py	                        (rev 0)
+++ grass/trunk/gui/wxpython/swipe/g.gui.mapswipe.py	2012-11-08 13:27:20 UTC (rev 53734)
@@ -0,0 +1,89 @@
+#!/usr/bin/env python
+# MODULE:    Map Swipe
+# AUTHOR(S): Anna Kratochvilova
+# PURPOSE:   The Map Swipe is a wxGUI component which allows the user to
+#            interactively compare two maps
+# COPYRIGHT: (C) 2012 by Anna Kratochvilova, and the GRASS Development Team
+#  This program is free software; you can redistribute it and/or modify
+#  it under the terms of the GNU General Public License as published by
+#  the Free Software Foundation; either version 2 of the License, or
+#  (at your option) any later version.
+#  This program is distributed in the hope that it will be useful,
+#  but WITHOUT ANY WARRANTY; without even the implied warranty of
+#  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+#  GNU General Public License for more details.
+#%module
+#% description: Allows to interactively compare two maps by swiping.
+#%end
+#%option G_OPT_R_INPUT
+#% key: first
+#% description: First (top/right) raster map
+#% required: no
+#%end
+#% key: second
+#% description: Second (bottom/left) raster map
+#% required: no
+#%end
+import os
+import sys
+import  wx
+import gettext
+import grass.script as grass
+if __name__ == '__main__':
+    sys.path.append(os.path.join(os.environ['GISBASE'], "etc", "gui", "wxpython"))
+from core.settings  import UserSettings
+from mapswipe.frame import SwipeMapFrame
+def main():
+    gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
+    driver = UserSettings.Get(group = 'display', key = 'driver', subkey = 'type')
+    if driver == 'png':
+        os.environ['GRASS_RENDER_IMMEDIATE'] = 'png'
+    else:
+        os.environ['GRASS_RENDER_IMMEDIATE'] = 'cairo'
+    options, flags = grass.parser()
+    first = options['first']
+    second = options['second']
+    for mapName in [first, second]:
+        if mapName:
+            gfile = grass.find_file(name = mapName)
+            if not gfile['name']:
+                grass.fatal(_("Raster map <%s> not found") % mapName)
+    app = wx.PySimpleApp()
+    wx.InitAllImageHandlers()
+    frame = SwipeMapFrame()
+    if first:
+        frame.SetFirstRaster(first)
+    if second:
+        frame.SetSecondRaster(second)
+    frame.Show()
+    app.MainLoop()
+    main()
Deleted: grass/trunk/gui/wxpython/swipe/main.py
--- grass/trunk/gui/wxpython/swipe/main.py	2012-11-08 13:00:57 UTC (rev 53733)
+++ grass/trunk/gui/wxpython/swipe/main.py	2012-11-08 13:27:20 UTC (rev 53734)
@@ -1,89 +0,0 @@
-#!/usr/bin/env python
-# MODULE:    Map Swipe
-# AUTHOR(S): Anna Kratochvilova
-# PURPOSE:   The Map Swipe is a wxGUI component which allows the user to
-#            interactively compare two maps
-# COPYRIGHT: (C) 2012 by Anna Kratochvilova, and the GRASS Development Team
-#  This program is free software; you can redistribute it and/or modify
-#  it under the terms of the GNU General Public License as published by
-#  the Free Software Foundation; either version 2 of the License, or
-#  (at your option) any later version.
-#  This program is distributed in the hope that it will be useful,
-#  but WITHOUT ANY WARRANTY; without even the implied warranty of
-#  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-#  GNU General Public License for more details.
-#%module
-#% description: Allows to interactively compare two maps by swiping.
-#%end
-#%option G_OPT_R_INPUT
-#% key: first
-#% description: First (top/right) raster map
-#% required: no
-#%end
-#% key: second
-#% description: Second (bottom/left) raster map
-#% required: no
-#%end
-import os
-import sys
-import  wx
-import gettext
-import grass.script as grass
-if __name__ == '__main__':
-    sys.path.append(os.path.join(os.environ['GISBASE'], "etc", "gui", "wxpython"))
-from core.settings import UserSettings
-from frame import SwipeMapFrame
-def main():
-    gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
-    driver = UserSettings.Get(group = 'display', key = 'driver', subkey = 'type')
-    if driver == 'png':
-        os.environ['GRASS_RENDER_IMMEDIATE'] = 'png'
-    else:
-        os.environ['GRASS_RENDER_IMMEDIATE'] = 'cairo'
-    options, flags = grass.parser()
-    first = options['first']
-    second = options['second']
-    for mapName in [first, second]:
-        if mapName:
-            gfile = grass.find_file(name = mapName)
-            if not gfile['name']:
-                grass.fatal(_("Raster map <%s> not found") % mapName)
-    app = wx.PySimpleApp()
-    wx.InitAllImageHandlers()
-    frame = SwipeMapFrame()
-    if first:
-        frame.SetFirstRaster(first)
-    if second:
-        frame.SetSecondRaster(second)
-    frame.Show()
-    app.MainLoop()
-    main()
