[GRASS-SVN] r53741 - grass/trunk/lib/cdhc
svn_grass at osgeo.org
Thu Nov 8 15:35:44 PST 2012
Author: neteler
Date: 2012-11-08 15:35:44 -0800 (Thu, 08 Nov 2012)
New Revision: 53741
grass/trunk/lib/cdhc/Makefile
grass/trunk/lib/cdhc/test.c
tests updated from v.normal code
Modified: grass/trunk/lib/cdhc/Makefile
--- grass/trunk/lib/cdhc/Makefile 2012-11-08 17:33:18 UTC (rev 53740)
+++ grass/trunk/lib/cdhc/Makefile 2012-11-08 23:35:44 UTC (rev 53741)
@@ -18,7 +18,7 @@
cd $(OBJDIR) && $(call run_grass,./test < ../test_numbers.csv)
# Test functions
-$(OBJDIR)/test$(EXE): $(OBJDIR)/test.o $(CDHCDEP)
+$(OBJDIR)/test$(EXE): $(OBJDIR)/test.o $(GISDEP) $(CDHCDEP)
$(call linker)
-$(OBJDIR)/test$(EXE): LIBES = $(CDHCLIB)
+$(OBJDIR)/test$(EXE): LIBES = $(GISLIB) $(CDHCLIB)
Modified: grass/trunk/lib/cdhc/test.c
--- grass/trunk/lib/cdhc/test.c 2012-11-08 17:33:18 UTC (rev 53740)
+++ grass/trunk/lib/cdhc/test.c 2012-11-08 23:35:44 UTC (rev 53741)
@@ -1,51 +1,98 @@
#include <stdio.h>
#include <stdlib.h>
+#include <grass/gis.h>
#include <grass/cdhc.h>
int main(int argc, char **argv)
- double x[1000];
- double *y;
+ double z[1000];
+ double *w;
int n = 0;
- while (scanf("%lf", &x[n++]) != EOF) ;
+ while (scanf("%lf", &z[n++]) != EOF) ;
n--;
- fprintf(stdout, "N=%d\n", n);
- fprintf(stdout, "*y=%ld\n", y);
- y = omnibus_moments(x, n);
- y = geary_test(x, n);
- y = dagostino_d(x, n);
- fprintf(stdout, "y=%g\n", y[1]);
- y = kuipers_v(x, n);
- y = watson_u2(x, n);
- y = durbins_exact(x, n);
- y = anderson_darling(x, n);
- y = cramer_von_mises(x, n);
+ fprintf(stdout, "TESTS:\n");
+ fprintf(stdout, "N: %d\n", n);
- /* for ks and lillefors, the discrepancy seems to come
- in in computing the sum of x*x */
+ fprintf(stdout, "Moments \\sqrt{b_1} and b_2: ");
+ w = omnibus_moments(z, n);
+ fprintf(stdout, "%g %g\n", w[0], w[1]);
- y = kolmogorov_smirnov(x, n);
- y = chi_square(x, n);
- y = shapiro_wilk(x, n);
- y = shapiro_francia(x, n);
- y = shapiro_wilk_exp(x, n);
- y = cramer_von_mises_exp(x, n);
- y = kolmogorov_smirnov_exp(x, n);
- y = kuipers_v_exp(x, n);
- y = watson_u2_exp(x, n);
- y = anderson_darling_exp(x, n);
- y = chi_square_exp(x, n);
+ fprintf(stdout, "Geary's a-statistic & an approx. normal: ");
+ w = geary_test(z, n);
-/* missing from source code:
- y = mod_maxlik_ratio(x, n);
- y = coeff_variation(x, n);
- y = kotz_families(x, n);
+ fprintf(stdout, "Extreme normal deviates: ");
+ w = extreme(z, n);
+ fprintf(stdout, "D'Agostino's D & an approx. normal: ");
+ w = dagostino_d(z, n);
+ fprintf(stdout, "Kuiper's V (regular & modified for normality): ");
+ w = kuipers_v(z, n);
+ fprintf(stdout, "%g %g\n", w[1], w[0]);
+ fprintf(stdout, "Watson's U^2 (regular & modified for normality): ");
+ w = watson_u2(z, n);
+ fprintf(stdout, "Durbin's Exact Test (modified Kolmogorov): ");
+ w = durbins_exact(z, n);
+ fprintf(stdout, "%g\n", w[0]);
+ fprintf(stdout,
+ "Anderson-Darling's A^2 (regular & modified for normality): ");
+ w = anderson_darling(z, n);
+ fprintf(stdout,
+ "Cramer-Von Mises W^2(regular & modified for normality): ");
+ w = cramer_von_mises(z, n);
+ fprintf(stdout,
+ "Kolmogorov-Smirnov's D (regular & modified for normality): ");
+ w = kolmogorov_smirnov(z, n);
+ fprintf(stdout, "Chi-Square stat (equal probability classes) and d.f.: ");
+ w = chi_square(z, n);
+ fprintf(stdout, "%g %d\n", w[0], (int)w[1]);
+ if (n > 50) {
+ G_warning("Shapiro-Wilk's W cannot be used for n > 50");
+ if (n < 99)
+ G_message("Use Weisberg-Binghams's W''");
+ else {
+ fprintf(stdout, "Shapiro-Wilk W: ");
+ w = shapiro_wilk(z, n);
+ if (n > 99 || n < 50)
+ G_warning
+ ("Weisberg-Bingham's W'' cannot be used for n < 50 or n > 99");
+ else {
+ fprintf(stdout, "Weisberg-Bingham's W'': ");
+ w = weisberg_bingham(z, n);
+ if (n > 2000)
+ G_warning("Royston only extended Shapiro-Wilk's W up to n = 2000");
+ else {
+ fprintf(stdout, "Shapiro-Wilk W'': ");
+ w = royston(z, n);
+ fprintf(stdout, "Kotz' T'_f (Lognormality vs. Normality): ");
+ w = kotz_families(z, n);
return EXIT_SUCCESS;
