[GRASS-SVN] r53753 - in grass/trunk: . include/Make
svn_grass at osgeo.org
Fri Nov 9 06:52:34 PST 2012
Author: martinl
Date: 2012-11-09 06:52:34 -0800 (Fri, 09 Nov 2012)
New Revision: 53753
grass/trunk/configure
grass/trunk/configure.in
grass/trunk/include/Make/Platform.make.in
remove tcl/tk switch from configure (no TCL/TK dependency in G7)
Modified: grass/trunk/configure
--- grass/trunk/configure 2012-11-09 14:46:53 UTC (rev 53752)
+++ grass/trunk/configure 2012-11-09 14:52:34 UTC (rev 53753)
@@ -33,8 +33,6 @@
ac_help="$ac_help
--with-png support PNG functionality (default: yes)"
ac_help="$ac_help
- --with-tcltk support Tcl/Tk functionality (default: yes)"
-ac_help="$ac_help
--with-postgres support PostgreSQL functionality (default: no)"
ac_help="$ac_help
--with-mysql support MySQL functionality (default: no)"
@@ -118,11 +116,6 @@
ac_help="$ac_help
--with-png-libs=DIRS PNG library files are in DIRS"
ac_help="$ac_help
- --with-tcltk-includes=DIRS
- Tcl/Tk include files are in DIRS"
-ac_help="$ac_help
- --with-tcltk-libs=DIRS Tcl/Tk library files are in DIRS"
-ac_help="$ac_help
--with-postgres-includes=DIRS
PostgreSQL include files are in DIRS"
ac_help="$ac_help
@@ -750,7 +743,7 @@
fi
echo $ac_n "checking host system type""... $ac_c" 1>&6
-echo "configure:754: checking host system type" >&5
+echo "configure:747: checking host system type" >&5
host_alias=$host
case "$host_alias" in
@@ -773,7 +766,7 @@
# Extract the first word of "gcc", so it can be a program name with args.
set dummy gcc; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:777: checking for $ac_word" >&5
+echo "configure:770: checking for $ac_word" >&5
if test -n "$CC"; then
ac_cv_prog_CC="$CC" # Let the user override the test.
@@ -800,7 +793,7 @@
# Extract the first word of "cc", so it can be a program name with args.
set dummy cc; ac_word=$2
-echo "configure:804: checking for $ac_word" >&5
+echo "configure:797: checking for $ac_word" >&5
@@ -848,7 +841,7 @@
# Extract the first word of "cl", so it can be a program name with args.
set dummy cl; ac_word=$2
-echo "configure:852: checking for $ac_word" >&5
+echo "configure:845: checking for $ac_word" >&5
@@ -877,7 +870,7 @@
fi
echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:881: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
+echo "configure:874: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
ac_ext=c
# CFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -888,12 +881,12 @@
cat > conftest.$ac_ext << EOF
-#line 892 "configure"
+#line 885 "configure"
#include "confdefs.h"
main(){return(0);}
EOF
-if { (eval echo configure:897: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:890: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cc_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -919,19 +912,19 @@
{ echo "configure: error: installation or configuration problem: C compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:923: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:916: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cc_cross" 1>&6
cross_compiling=$ac_cv_prog_cc_cross
echo $ac_n "checking whether we are using GNU C""... $ac_c" 1>&6
-echo "configure:928: checking whether we are using GNU C" >&5
+echo "configure:921: checking whether we are using GNU C" >&5
cat > conftest.c <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:935: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:928: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gcc=yes
else
ac_cv_prog_gcc=no
@@ -949,7 +942,7 @@
ac_save_CFLAGS="$CFLAGS"
CFLAGS=
echo $ac_n "checking whether ${CC-cc} accepts -g""... $ac_c" 1>&6
-echo "configure:953: checking whether ${CC-cc} accepts -g" >&5
+echo "configure:946: checking whether ${CC-cc} accepts -g" >&5
echo 'void f(){}' > conftest.c
if test -z "`${CC-cc} -g -c conftest.c 2>&1`"; then
@@ -978,10 +971,10 @@
fi
echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:982: checking for Cygwin environment" >&5
+echo "configure:975: checking for Cygwin environment" >&5
cat > conftest.$ac_ext <<EOF
-#line 985 "configure"
+#line 978 "configure"
int main() {
@@ -992,7 +985,7 @@
return __CYGWIN__;
; return 0; }
EOF
-if { (eval echo configure:996: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:989: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_cygwin=yes
else
@@ -1008,17 +1001,17 @@
CYGWIN=
test "$ac_cv_cygwin" = yes && CYGWIN=yes
echo $ac_n "checking for mingw32 environment""... $ac_c" 1>&6
-echo "configure:1012: checking for mingw32 environment" >&5
+echo "configure:1005: checking for mingw32 environment" >&5
-#line 1015 "configure"
+#line 1008 "configure"
int main() {
return __MINGW32__;
; return 0; }
EOF
-if { (eval echo configure:1022: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1015: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_mingw32=yes
else
@@ -1036,7 +1029,7 @@
echo $ac_n "checking for executable suffix""... $ac_c" 1>&6
-echo "configure:1040: checking for executable suffix" >&5
+echo "configure:1033: checking for executable suffix" >&5
if test "$CYGWIN" = yes || test "$MINGW32" = yes; then
ac_cv_exeext=.exe
@@ -1055,23 +1048,23 @@
IEEEFLAG=
echo $ac_n "checking for full floating-point support""... $ac_c" 1>&6
-echo "configure:1059: checking for full floating-point support" >&5
+echo "configure:1052: checking for full floating-point support" >&5
if test "$cross_compiling" = yes; then
echo "$ac_t""unknown (cross-compiling)" 1>&6
echo $ac_n "checking whether "cc -mieee" works""... $ac_c" 1>&6
-echo "configure:1064: checking whether "cc -mieee" works" >&5
+echo "configure:1057: checking whether "cc -mieee" works" >&5
ac_save_cflags=${CFLAGS}
CFLAGS="$CFLAGS -mieee"
-#line 1068 "configure"
+#line 1061 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:1075: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1068: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
echo "$ac_t""yes" 1>&6
IEEEFLAG="-mieee"
@@ -1087,7 +1080,7 @@
else
-#line 1091 "configure"
+#line 1084 "configure"
#include <float.h>
@@ -1101,7 +1094,7 @@
EOF
-if { (eval echo configure:1105: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1098: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
@@ -1114,14 +1107,14 @@
CFLAGS=-mieee
echo $ac_n "checking for full floating-point support with -mieee""... $ac_c" 1>&6
-echo "configure:1118: checking for full floating-point support with -mieee" >&5
+echo "configure:1111: checking for full floating-point support with -mieee" >&5
{ echo "configure: error: *** INTERNAL CONFIGURE ERROR" 1>&2; exit 1; }
else
-#line 1125 "configure"
+#line 1118 "configure"
#include <float.h>
@@ -1135,7 +1128,7 @@
EOF
-if { (eval echo configure:1139: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1132: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
IEEEFLAG="-mieee"
@@ -1172,7 +1165,7 @@
# Extract the first word of "pwd", so it can be a program name with args.
set dummy pwd; ac_word=$2
-echo "configure:1176: checking for $ac_word" >&5
+echo "configure:1169: checking for $ac_word" >&5
case "$pwd" in
@@ -1210,7 +1203,7 @@
fi
echo $ac_n "checking for source directory""... $ac_c" 1>&6
-echo "configure:1214: checking for source directory" >&5
+echo "configure:1207: checking for source directory" >&5
if test -z "$srcdir" ; then
SRCDIR=`$pwd`
@@ -1221,7 +1214,7 @@
echo "$ac_t"""$SRCDIR"" 1>&6
echo $ac_n "checking for build directory""... $ac_c" 1>&6
-echo "configure:1225: checking for build directory" >&5
+echo "configure:1218: checking for build directory" >&5
DSTDIR=`$pwd`
WINDSTDIR=`$winpwd`
@@ -1289,7 +1282,7 @@
# Extract the first word of "svnversion", so it can be a program name with args.
set dummy svnversion; ac_word=$2
-echo "configure:1293: checking for $ac_word" >&5
+echo "configure:1286: checking for $ac_word" >&5
case "$SVN_VERSION" in
@@ -1348,7 +1341,7 @@
echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1352: checking for MacOSX App" >&5
+echo "configure:1345: checking for MacOSX App" >&5
case "$enable_macosx_app" in
yes) MACOSX_APP=1 ;;
no) MACOSX_APP= ;;
@@ -1360,7 +1353,7 @@
# Check for MacOSX archs
echo $ac_n "checking for MacOSX architectures""... $ac_c" 1>&6
-echo "configure:1364: checking for MacOSX architectures" >&5
+echo "configure:1357: checking for MacOSX architectures" >&5
MACOSX_ARCHS=
@@ -1389,7 +1382,7 @@
# Check for MacOSX SDK
echo $ac_n "checking for MacOSX SDK""... $ac_c" 1>&6
-echo "configure:1393: checking for MacOSX SDK" >&5
+echo "configure:1386: checking for MacOSX SDK" >&5
MACOSX_SDK=
@@ -1399,7 +1392,7 @@
ac_safe=`echo "$with_macosx_sdk/SDKSettings.plist" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $with_macosx_sdk/SDKSettings.plist""... $ac_c" 1>&6
-echo "configure:1403: checking for $with_macosx_sdk/SDKSettings.plist" >&5
+echo "configure:1396: checking for $with_macosx_sdk/SDKSettings.plist" >&5
{ echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -1443,7 +1436,7 @@
echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1447: checking how to build libraries" >&5
+echo "configure:1440: checking how to build libraries" >&5
# Check whether --enable-shared or --disable-shared was given.
if test "${enable_shared+set}" = set; then
enableval="$enable_shared"
@@ -1635,16 +1628,6 @@
-# Check whether --with-tcltk or --without-tcltk was given.
-if test "${with_tcltk+set}" = set; then
- withval="$with_tcltk"
-else
- with_tcltk=yes
-fi
# Check whether --with-postgres or --without-postgres was given.
if test "${with_postgres+set}" = set; then
withval="$with_postgres"
@@ -1943,23 +1926,6 @@
-# Check whether --with-tcltk-includes or --without-tcltk-includes was given.
-if test "${with_tcltk_includes+set}" = set; then
- withval="$with_tcltk_includes"
-fi
-# Check whether --with-tcltk-libs or --without-tcltk-libs was given.
-if test "${with_tcltk_libs+set}" = set; then
- withval="$with_tcltk_libs"
-fi
# Check whether --with-postgres-includes or --without-postgres-includes was given.
if test "${with_postgres_includes+set}" = set; then
withval="$with_postgres_includes"
@@ -2264,7 +2230,7 @@
# Done checking fortran
echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:2268: checking for additional include dirs" >&5
+echo "configure:2234: checking for additional include dirs" >&5
case "$with_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -2287,7 +2253,7 @@
# With libs option
echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:2291: checking for additional library dirs" >&5
+echo "configure:2257: checking for additional library dirs" >&5
case "$with_libs" in
{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -2321,7 +2287,7 @@
# SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
# ./install, which can be erroneously created by make from ./install.sh.
echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:2325: checking for a BSD compatible install" >&5
+echo "configure:2291: checking for a BSD compatible install" >&5
if test -z "$INSTALL"; then
IFS="${IFS= }"; ac_save_IFS="$IFS"; IFS=":"
@@ -2374,7 +2340,7 @@
# Extract the first word of "flex", so it can be a program name with args.
set dummy flex; ac_word=$2
-echo "configure:2378: checking for $ac_word" >&5
+echo "configure:2344: checking for $ac_word" >&5
if test -n "$LEX"; then
ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -2405,13 +2371,13 @@
*) ac_lib=l ;;
esac
echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:2409: checking for yywrap in -l$ac_lib" >&5
+echo "configure:2375: checking for yywrap in -l$ac_lib" >&5
ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-l$ac_lib $LIBS"
-#line 2415 "configure"
+#line 2381 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -2422,7 +2388,7 @@
yywrap()
; return 0; }
EOF
-if { (eval echo configure:2426: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2392: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -2447,7 +2413,7 @@
# Extract the first word of "lex", so it can be a program name with args.
set dummy lex; ac_word=$2
-echo "configure:2451: checking for $ac_word" >&5
+echo "configure:2417: checking for $ac_word" >&5
case "$LEXPATH" in
@@ -2487,7 +2453,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-echo "configure:2491: checking for $ac_word" >&5
+echo "configure:2457: checking for $ac_word" >&5
if test -n "$YACC"; then
ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -2518,7 +2484,7 @@
# Extract the first word of "yacc", so it can be a program name with args.
set dummy yacc; ac_word=$2
-echo "configure:2522: checking for $ac_word" >&5
+echo "configure:2488: checking for $ac_word" >&5
case "$YACCPATH" in
@@ -2556,7 +2522,7 @@
# Extract the first word of "ranlib", so it can be a program name with args.
set dummy ranlib; ac_word=$2
-echo "configure:2560: checking for $ac_word" >&5
+echo "configure:2526: checking for $ac_word" >&5
if test -n "$RANLIB"; then
ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -2585,7 +2551,7 @@
-echo "configure:2589: checking for $ac_word" >&5
+echo "configure:2555: checking for $ac_word" >&5
if test -n "$AR"; then
ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -2616,7 +2582,7 @@
-echo "configure:2620: checking for $ac_word" >&5
+echo "configure:2586: checking for $ac_word" >&5
if test -n "$ENV"; then
ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -2645,7 +2611,7 @@
# Extract the first word of "perl", so it can be a program name with args.
set dummy perl; ac_word=$2
-echo "configure:2649: checking for $ac_word" >&5
+echo "configure:2615: checking for $ac_word" >&5
case "$PERL" in
@@ -2676,7 +2642,7 @@
fi
echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:2680: checking how to run the C preprocessor" >&5
+echo "configure:2646: checking how to run the C preprocessor" >&5
# On Suns, sometimes $CPP names a directory.
if test -n "$CPP" && test -d "$CPP"; then
CPP=
@@ -2689,13 +2655,13 @@
# On the NeXT, cc -E runs the code through the compiler's parser,
# not just through cpp.
-#line 2693 "configure"
+#line 2659 "configure"
#include <assert.h>
Syntax Error
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:2699: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2665: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
@@ -2706,13 +2672,13 @@
rm -rf conftest*
CPP="${CC-cc} -E -traditional-cpp"
-#line 2710 "configure"
+#line 2676 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:2716: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2682: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2723,13 +2689,13 @@
rm -rf conftest*
CPP="${CC-cc} -nologo -E"
-#line 2727 "configure"
+#line 2693 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:2733: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2699: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2753,10 +2719,10 @@
echo "$ac_t""$CPP" 1>&6
echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:2757: checking for ANSI C header files" >&5
+echo "configure:2723: checking for ANSI C header files" >&5
-#line 2760 "configure"
+#line 2726 "configure"
#include <stdlib.h>
#include <stdarg.h>
@@ -2764,7 +2730,7 @@
#include <float.h>
EOF
-{ (eval echo configure:2768: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2734: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2781,7 +2747,7 @@
if test $ac_cv_header_stdc = yes; then
# SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 2785 "configure"
+#line 2751 "configure"
#include <string.h>
EOF
@@ -2799,7 +2765,7 @@
# ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 2803 "configure"
+#line 2769 "configure"
#include <stdlib.h>
EOF
@@ -2820,7 +2786,7 @@
else
-#line 2824 "configure"
+#line 2790 "configure"
#include <ctype.h>
#define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -2831,7 +2797,7 @@
exit (0); }
EOF
-if { (eval echo configure:2835: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:2801: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
else
@@ -2858,15 +2824,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:2862: checking for $ac_hdr" >&5
+echo "configure:2828: checking for $ac_hdr" >&5
-#line 2865 "configure"
+#line 2831 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:2870: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2836: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2895,15 +2861,15 @@
do
-echo "configure:2899: checking for $ac_hdr" >&5
+echo "configure:2865: checking for $ac_hdr" >&5
-#line 2902 "configure"
+#line 2868 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:2907: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2873: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2932,15 +2898,15 @@
do
-echo "configure:2936: checking for $ac_hdr" >&5
+echo "configure:2902: checking for $ac_hdr" >&5
-#line 2939 "configure"
+#line 2905 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:2944: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2910: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2969,15 +2935,15 @@
do
-echo "configure:2973: checking for $ac_hdr" >&5
+echo "configure:2939: checking for $ac_hdr" >&5
-#line 2976 "configure"
+#line 2942 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:2981: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2947: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3006,15 +2972,15 @@
do
-echo "configure:3010: checking for $ac_hdr" >&5
+echo "configure:2976: checking for $ac_hdr" >&5
-#line 3013 "configure"
+#line 2979 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3018: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2984: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3040,10 +3006,10 @@
done
echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:3044: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:3010: checking whether time.h and sys/time.h may both be included" >&5
-#line 3047 "configure"
+#line 3013 "configure"
#include <sys/types.h>
#include <sys/time.h>
@@ -3052,7 +3018,7 @@
struct tm *tp;
; return 0; }
EOF
-if { (eval echo configure:3056: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3022: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_header_time=yes
else
@@ -3072,10 +3038,10 @@
fi
echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:3076: checking for off_t" >&5
+echo "configure:3042: checking for off_t" >&5
-#line 3079 "configure"
+#line 3045 "configure"
#if STDC_HEADERS
@@ -3102,10 +3068,10 @@
fi
echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:3106: checking for uid_t in sys/types.h" >&5
+echo "configure:3072: checking for uid_t in sys/types.h" >&5
-#line 3109 "configure"
+#line 3075 "configure"
EOF
@@ -3133,10 +3099,10 @@
fi
echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:3137: checking return type of signal handlers" >&5
+echo "configure:3103: checking return type of signal handlers" >&5
-#line 3140 "configure"
+#line 3106 "configure"
#include <signal.h>
@@ -3153,7 +3119,7 @@
int i;
; return 0; }
EOF
-if { (eval echo configure:3157: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3123: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_type_signal=void
else
@@ -3171,10 +3137,10 @@
-echo "configure:3175: checking for Cygwin environment" >&5
+echo "configure:3141: checking for Cygwin environment" >&5
-#line 3178 "configure"
+#line 3144 "configure"
int main() {
@@ -3185,7 +3151,7 @@
return __CYGWIN__;
; return 0; }
EOF
-if { (eval echo configure:3189: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3155: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_cygwin=yes
else
@@ -3203,10 +3169,10 @@
for ac_func in ftime gethostname gettimeofday lseek nice time uname
do
echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:3207: checking for $ac_func" >&5
+echo "configure:3173: checking for $ac_func" >&5
-#line 3210 "configure"
+#line 3176 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char $ac_func(); below. */
@@ -3229,7 +3195,7 @@
; return 0; }
EOF
-if { (eval echo configure:3233: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3199: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_$ac_func=yes"
else
@@ -3255,10 +3221,10 @@
for ac_func in seteuid setpriority setreuid setruid
do
-echo "configure:3259: checking for $ac_func" >&5
+echo "configure:3225: checking for $ac_func" >&5
-#line 3262 "configure"
+#line 3228 "configure"
@@ -3281,7 +3247,7 @@
; return 0; }
EOF
-if { (eval echo configure:3285: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3251: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3307,10 +3273,10 @@
for ac_func in drand48
do
-echo "configure:3311: checking for $ac_func" >&5
+echo "configure:3277: checking for $ac_func" >&5
-#line 3314 "configure"
+#line 3280 "configure"
@@ -3333,7 +3299,7 @@
; return 0; }
EOF
-if { (eval echo configure:3337: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3303: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3359,10 +3325,10 @@
for ac_func in putenv setenv
do
-echo "configure:3363: checking for $ac_func" >&5
+echo "configure:3329: checking for $ac_func" >&5
-#line 3366 "configure"
+#line 3332 "configure"
@@ -3385,7 +3351,7 @@
; return 0; }
EOF
-if { (eval echo configure:3389: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3355: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3411,10 +3377,10 @@
for ac_func in nanosleep
do
-echo "configure:3415: checking for $ac_func" >&5
+echo "configure:3381: checking for $ac_func" >&5
-#line 3418 "configure"
+#line 3384 "configure"
@@ -3437,7 +3403,7 @@
; return 0; }
EOF
-if { (eval echo configure:3441: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3407: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3462,13 +3428,13 @@
if test "$cross_compiling" != "yes" ; then
echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:3466: checking whether setpgrp takes no argument" >&5
+echo "configure:3432: checking whether setpgrp takes no argument" >&5
{ echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
else
-#line 3472 "configure"
+#line 3438 "configure"
#ifdef HAVE_UNISTD_H
@@ -3488,7 +3454,7 @@
EOF
-if { (eval echo configure:3492: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:3458: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
ac_cv_func_setpgrp_void=no
else
@@ -3516,16 +3482,16 @@
fi
echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:3520: checking for long long int" >&5
+echo "configure:3486: checking for long long int" >&5
-#line 3522 "configure"
+#line 3488 "configure"
int main() {
long long int x;
; return 0; }
EOF
-if { (eval echo configure:3529: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3495: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
@@ -3545,7 +3511,7 @@
rm -f conftest*
echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:3549: checking for W11" >&5
+echo "configure:3515: checking for W11" >&5
case "$enable_w11" in
yes|no) echo "$ac_t"""$enable_w11"" 1>&6 ;;
*) { echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; } ;;
@@ -3573,7 +3539,7 @@
# Uses ac_ vars as temps to allow command line to override cache and checks.
# --without-x overrides everything else, but does not touch the cache.
echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:3577: checking for X" >&5
+echo "configure:3543: checking for X" >&5
# Check whether --with-x or --without-x was given.
if test "${with_x+set}" = set; then
@@ -3633,12 +3599,12 @@
# First, try using that file with no special directory specified.
-#line 3637 "configure"
+#line 3603 "configure"
#include <$x_direct_test_include>
EOF
-{ (eval echo configure:3642: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3608: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3707,14 +3673,14 @@
LIBS="-l$x_direct_test_library $LIBS"
-#line 3711 "configure"
+#line 3677 "configure"
int main() {
${x_direct_test_function}()
; return 0; }
EOF
-if { (eval echo configure:3718: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3684: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
LIBS="$ac_save_LIBS"
# We can link X programs with no special library path.
@@ -3819,17 +3785,17 @@
case "`(uname -sr) 2>/dev/null`" in
"SunOS 5"*)
echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:3823: checking whether -R must be followed by a space" >&5
+echo "configure:3789: checking whether -R must be followed by a space" >&5
ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 3826 "configure"
+#line 3792 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:3833: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3799: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_nospace=yes
else
@@ -3845,14 +3811,14 @@
else
LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 3849 "configure"
+#line 3815 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:3856: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3822: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_space=yes
else
@@ -3884,13 +3850,13 @@
# libraries were built with DECnet support. And karl at cs.umb.edu says
# the Alpha needs dnet_stub (dnet does not exist).
echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:3888: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:3854: checking for dnet_ntoa in -ldnet" >&5
ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet $LIBS"
-#line 3894 "configure"
+#line 3860 "configure"
@@ -3901,7 +3867,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:3905: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3871: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3922,13 +3888,13 @@
if test $ac_cv_lib_dnet_dnet_ntoa = no; then
echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:3926: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:3892: checking for dnet_ntoa in -ldnet_stub" >&5
ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet_stub $LIBS"
-#line 3932 "configure"
+#line 3898 "configure"
@@ -3939,7 +3905,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:3943: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3909: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3967,10 +3933,10 @@
# The nsl library prevents programs from opening the X display
# on Irix 5.2, according to dickey at clark.net.
echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:3971: checking for gethostbyname" >&5
+echo "configure:3937: checking for gethostbyname" >&5
-#line 3974 "configure"
+#line 3940 "configure"
which can conflict with char gethostbyname(); below. */
@@ -3993,7 +3959,7 @@
; return 0; }
EOF
-if { (eval echo configure:3997: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3963: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gethostbyname=yes"
else
@@ -4013,13 +3979,13 @@
if test $ac_cv_func_gethostbyname = no; then
echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:4017: checking for gethostbyname in -lnsl" >&5
+echo "configure:3983: checking for gethostbyname in -lnsl" >&5
ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 4023 "configure"
+#line 3989 "configure"
@@ -4030,7 +3996,7 @@
gethostbyname()
; return 0; }
EOF
-if { (eval echo configure:4034: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4000: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4059,10 +4025,10 @@
# -lsocket must be given before -lnsl if both are needed.
# We assume that if connect needs -lnsl, so does gethostbyname.
echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:4063: checking for connect" >&5
+echo "configure:4029: checking for connect" >&5
-#line 4066 "configure"
+#line 4032 "configure"
which can conflict with char connect(); below. */
@@ -4085,7 +4051,7 @@
; return 0; }
EOF
-if { (eval echo configure:4089: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4055: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_connect=yes"
else
@@ -4105,13 +4071,13 @@
if test $ac_cv_func_connect = no; then
echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:4109: checking for connect in -lsocket" >&5
+echo "configure:4075: checking for connect in -lsocket" >&5
ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 4115 "configure"
+#line 4081 "configure"
@@ -4122,7 +4088,7 @@
connect()
; return 0; }
EOF
-if { (eval echo configure:4126: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4092: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4145,10 +4111,10 @@
# gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:4149: checking for remove" >&5
+echo "configure:4115: checking for remove" >&5
-#line 4152 "configure"
+#line 4118 "configure"
which can conflict with char remove(); below. */
@@ -4171,7 +4137,7 @@
; return 0; }
EOF
-if { (eval echo configure:4175: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4141: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_remove=yes"
else
@@ -4191,13 +4157,13 @@
if test $ac_cv_func_remove = no; then
echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:4195: checking for remove in -lposix" >&5
+echo "configure:4161: checking for remove in -lposix" >&5
ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
LIBS="-lposix $LIBS"
-#line 4201 "configure"
+#line 4167 "configure"
@@ -4208,7 +4174,7 @@
remove()
; return 0; }
EOF
-if { (eval echo configure:4212: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4178: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4231,10 +4197,10 @@
# BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:4235: checking for shmat" >&5
+echo "configure:4201: checking for shmat" >&5
-#line 4238 "configure"
+#line 4204 "configure"
which can conflict with char shmat(); below. */
@@ -4257,7 +4223,7 @@
; return 0; }
EOF
-if { (eval echo configure:4261: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4227: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_shmat=yes"
else
@@ -4277,13 +4243,13 @@
if test $ac_cv_func_shmat = no; then
echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:4281: checking for shmat in -lipc" >&5
+echo "configure:4247: checking for shmat in -lipc" >&5
ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
LIBS="-lipc $LIBS"
-#line 4287 "configure"
+#line 4253 "configure"
@@ -4294,7 +4260,7 @@
shmat()
; return 0; }
EOF
-if { (eval echo configure:4298: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4264: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4326,13 +4292,13 @@
# libraries we check for below, so use a different variable.
# --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:4330: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:4296: checking for IceConnectionNumber in -lICE" >&5
ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 4336 "configure"
+#line 4302 "configure"
@@ -4343,7 +4309,7 @@
IceConnectionNumber()
; return 0; }
EOF
-if { (eval echo configure:4347: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4313: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4383,12 +4349,12 @@
LIBS=""
echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:4387: checking for library containing cuserid" >&5
+echo "configure:4353: checking for library containing cuserid" >&5
ac_func_search_save_LIBS="$LIBS"
ac_cv_search_cuserid="no"
-#line 4392 "configure"
+#line 4358 "configure"
@@ -4399,7 +4365,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:4403: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4369: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="none required"
else
@@ -4410,7 +4376,7 @@
test "$ac_cv_search_cuserid" = "no" && for i in compat; do
LIBS="-l$i $ac_func_search_save_LIBS"
-#line 4414 "configure"
+#line 4380 "configure"
@@ -4421,7 +4387,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:4425: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4391: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="-l$i"
break
@@ -4447,10 +4413,10 @@
for ac_func in asprintf
do
-echo "configure:4451: checking for $ac_func" >&5
+echo "configure:4417: checking for $ac_func" >&5
-#line 4454 "configure"
+#line 4420 "configure"
@@ -4473,7 +4439,7 @@
; return 0; }
EOF
-if { (eval echo configure:4477: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4443: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4500,10 +4466,10 @@
# Test if mathlib needs -lm flag or is included with libc
echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:4504: checking for atan" >&5
+echo "configure:4470: checking for atan" >&5
-#line 4507 "configure"
+#line 4473 "configure"
which can conflict with char atan(); below. */
@@ -4526,7 +4492,7 @@
; return 0; }
EOF
-if { (eval echo configure:4530: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4496: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_atan=yes"
else
@@ -4544,13 +4510,13 @@
echo "$ac_t""no" 1>&6
echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:4548: checking for atan in -lm" >&5
+echo "configure:4514: checking for atan in -lm" >&5
ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
LIBS="-lm $LIBS"
-#line 4554 "configure"
+#line 4520 "configure"
@@ -4561,7 +4527,7 @@
atan()
; return 0; }
EOF
-if { (eval echo configure:4565: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4531: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4588,10 +4554,10 @@
echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:4592: checking for dlsym" >&5
+echo "configure:4558: checking for dlsym" >&5
-#line 4595 "configure"
+#line 4561 "configure"
which can conflict with char dlsym(); below. */
@@ -4614,7 +4580,7 @@
; return 0; }
EOF
-if { (eval echo configure:4618: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4584: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dlsym=yes"
else
@@ -4632,13 +4598,13 @@
echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:4636: checking for dlsym in -ldl" >&5
+echo "configure:4602: checking for dlsym in -ldl" >&5
ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
LIBS="-ldl $LIBS"
-#line 4642 "configure"
+#line 4608 "configure"
@@ -4649,7 +4615,7 @@
dlsym()
; return 0; }
EOF
-if { (eval echo configure:4653: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4619: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4676,10 +4642,10 @@
echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:4680: checking for iconv" >&5
+echo "configure:4646: checking for iconv" >&5
-#line 4683 "configure"
+#line 4649 "configure"
which can conflict with char iconv(); below. */
@@ -4702,7 +4668,7 @@
; return 0; }
EOF
-if { (eval echo configure:4706: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4672: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_iconv=yes"
else
@@ -4720,13 +4686,13 @@
echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:4724: checking for iconv in -liconv" >&5
+echo "configure:4690: checking for iconv in -liconv" >&5
ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-liconv $LIBS"
-#line 4730 "configure"
+#line 4696 "configure"
@@ -4737,7 +4703,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:4741: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4707: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4756,13 +4722,13 @@
echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:4760: checking for iconv in -lgiconv" >&5
+echo "configure:4726: checking for iconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-lgiconv $LIBS"
-#line 4766 "configure"
+#line 4732 "configure"
@@ -4773,7 +4739,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:4777: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4743: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4792,10 +4758,10 @@
echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:4796: checking for libiconv" >&5
+echo "configure:4762: checking for libiconv" >&5
-#line 4799 "configure"
+#line 4765 "configure"
which can conflict with char libiconv(); below. */
@@ -4818,7 +4784,7 @@
; return 0; }
EOF
-if { (eval echo configure:4822: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4788: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_libiconv=yes"
else
@@ -4836,13 +4802,13 @@
echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:4840: checking for libiconv in -liconv" >&5
+echo "configure:4806: checking for libiconv in -liconv" >&5
ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 4846 "configure"
+#line 4812 "configure"
@@ -4853,7 +4819,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:4857: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4823: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4872,13 +4838,13 @@
echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:4876: checking for libiconv in -lgiconv" >&5
+echo "configure:4842: checking for libiconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 4882 "configure"
+#line 4848 "configure"
@@ -4889,7 +4855,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:4893: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4859: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4926,10 +4892,10 @@
have_socket=1
echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:4930: checking for socket" >&5
+echo "configure:4896: checking for socket" >&5
-#line 4933 "configure"
+#line 4899 "configure"
which can conflict with char socket(); below. */
@@ -4952,7 +4918,7 @@
; return 0; }
EOF
-if { (eval echo configure:4956: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4922: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_socket=yes"
else
@@ -4970,13 +4936,13 @@
echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:4974: checking for socket in -lsocket" >&5
+echo "configure:4940: checking for socket in -lsocket" >&5
ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
LIBS="-lsocket $LIBS"
-#line 4980 "configure"
+#line 4946 "configure"
@@ -4987,7 +4953,7 @@
socket()
; return 0; }
EOF
-if { (eval echo configure:4991: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4957: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5035,7 +5001,7 @@
echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:5039: checking for location of zlib includes" >&5
+echo "configure:5005: checking for location of zlib includes" >&5
case "$with_zlib_includes" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -5061,15 +5027,15 @@
do
-echo "configure:5065: checking for $ac_hdr" >&5
+echo "configure:5031: checking for $ac_hdr" >&5
-#line 5068 "configure"
+#line 5034 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5073: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5039: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5103,7 +5069,7 @@
echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:5107: checking for location of zlib library" >&5
+echo "configure:5073: checking for location of zlib library" >&5
case "$with_zlib_libs" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -5128,13 +5094,13 @@
echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:5132: checking for deflate in -lz" >&5
+echo "configure:5098: checking for deflate in -lz" >&5
ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
LIBS="-lz $LIBS"
-#line 5138 "configure"
+#line 5104 "configure"
@@ -5145,7 +5111,7 @@
deflate()
; return 0; }
EOF
-if { (eval echo configure:5149: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5115: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5193,7 +5159,7 @@
echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:5197: checking for location of External PROJ.4 includes" >&5
+echo "configure:5163: checking for location of External PROJ.4 includes" >&5
case "$with_proj_includes" in
{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -5219,15 +5185,15 @@
do
-echo "configure:5223: checking for $ac_hdr" >&5
+echo "configure:5189: checking for $ac_hdr" >&5
-#line 5226 "configure"
+#line 5192 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5231: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5197: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5264,7 +5230,7 @@
else
echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:5268: checking External PROJ.4 version" >&5
+echo "configure:5234: checking External PROJ.4 version" >&5
ac_save_cppflags="$CPPFLAGS"
CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -5272,7 +5238,7 @@
else
-#line 5276 "configure"
+#line 5242 "configure"
#include <stdio.h>
@@ -5284,7 +5250,7 @@
EOF
-if { (eval echo configure:5288: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:5254: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
proj_ver=`cat conftestdata`
echo "$ac_t""$proj_ver" 1>&6
@@ -5309,7 +5275,7 @@
echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:5313: checking for location of External PROJ.4 library" >&5
+echo "configure:5279: checking for location of External PROJ.4 library" >&5
case "$with_proj_libs" in
{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -5334,13 +5300,13 @@
echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:5338: checking for pj_get_def in -lproj" >&5
+echo "configure:5304: checking for pj_get_def in -lproj" >&5
ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
LIBS="-lproj $LIBS"
-#line 5344 "configure"
+#line 5310 "configure"
@@ -5351,7 +5317,7 @@
pj_get_def()
; return 0; }
EOF
-if { (eval echo configure:5355: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5321: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5385,7 +5351,7 @@
echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:5389: checking for location of External PROJ.4 data files" >&5
+echo "configure:5355: checking for location of External PROJ.4 data files" >&5
case "$with_proj_share" in
{ echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -5409,14 +5375,14 @@
# LOC_CHECK_SHARE does not work when cross compiling
if test "$cross_compiling" = "yes" ; then
echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:5413: checking for epsg" >&5
+echo "configure:5379: checking for epsg" >&5
else
ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:5420: checking for $PROJSHARE/epsg" >&5
+echo "configure:5386: checking for $PROJSHARE/epsg" >&5
@@ -5448,7 +5414,7 @@
# Extract the first word of "nad2bin", so it can be a program name with args.
set dummy nad2bin; ac_word=$2
-echo "configure:5452: checking for $ac_word" >&5
+echo "configure:5418: checking for $ac_word" >&5
case "$NAD2BIN" in
@@ -5488,7 +5454,7 @@
echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:5492: checking whether to use regex" >&5
+echo "configure:5458: checking whether to use regex" >&5
echo "$ac_t"""$with_regex"" 1>&6
case "$with_regex" in
"no") USE_REGEX= ;;
@@ -5508,7 +5474,7 @@
echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:5512: checking for location of regex includes" >&5
+echo "configure:5478: checking for location of regex includes" >&5
case "$with_regex_includes" in
{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -5534,15 +5500,15 @@
do
-echo "configure:5538: checking for $ac_hdr" >&5
+echo "configure:5504: checking for $ac_hdr" >&5
-#line 5541 "configure"
+#line 5507 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5546: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5512: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5576,7 +5542,7 @@
echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:5580: checking for location of regex library" >&5
+echo "configure:5546: checking for location of regex library" >&5
case "$with_regex_libs" in
{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -5601,10 +5567,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:5605: checking for regcomp" >&5
+echo "configure:5571: checking for regcomp" >&5
-#line 5608 "configure"
+#line 5574 "configure"
which can conflict with char regcomp(); below. */
@@ -5627,7 +5593,7 @@
; return 0; }
EOF
-if { (eval echo configure:5631: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5597: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_regcomp=yes"
else
@@ -5654,13 +5620,13 @@
echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:5658: checking for regcomp in -lregex" >&5
+echo "configure:5624: checking for regcomp in -lregex" >&5
ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
LIBS="-lregex $LIBS"
-#line 5664 "configure"
+#line 5630 "configure"
@@ -5671,7 +5637,7 @@
regcomp()
; return 0; }
EOF
-if { (eval echo configure:5675: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5641: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5721,7 +5687,7 @@
echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:5725: checking whether to use Readline" >&5
+echo "configure:5691: checking whether to use Readline" >&5
echo "$ac_t"""$with_readline"" 1>&6
case "$with_readline" in
"no") USE_READLINE= ;;
@@ -5742,7 +5708,7 @@
echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:5746: checking for location of Readline includes" >&5
+echo "configure:5712: checking for location of Readline includes" >&5
case "$with_readline_includes" in
{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -5768,15 +5734,15 @@
do
-echo "configure:5772: checking for $ac_hdr" >&5
+echo "configure:5738: checking for $ac_hdr" >&5
-#line 5775 "configure"
+#line 5741 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5780: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5746: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5812,15 +5778,15 @@
do
-echo "configure:5816: checking for $ac_hdr" >&5
+echo "configure:5782: checking for $ac_hdr" >&5
-#line 5819 "configure"
+#line 5785 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5824: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5790: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5854,7 +5820,7 @@
echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:5858: checking for location of Readline library" >&5
+echo "configure:5824: checking for location of Readline library" >&5
case "$with_readline_libs" in
{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -5879,13 +5845,13 @@
echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:5883: checking for readline in -lreadline" >&5
+echo "configure:5849: checking for readline in -lreadline" >&5
ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
LIBS="-lreadline $LIBS"
-#line 5889 "configure"
+#line 5855 "configure"
@@ -5896,7 +5862,7 @@
readline()
; return 0; }
EOF
-if { (eval echo configure:5900: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5866: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5931,13 +5897,13 @@
echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:5935: checking for add_history in -lhistory" >&5
+echo "configure:5901: checking for add_history in -lhistory" >&5
ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
LIBS="-lhistory $LIBS"
-#line 5941 "configure"
+#line 5907 "configure"
@@ -5948,7 +5914,7 @@
add_history()
; return 0; }
EOF
-if { (eval echo configure:5952: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5918: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5990,7 +5956,7 @@
# GDAL option
echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:5994: checking whether to use GDAL" >&5
+echo "configure:5960: checking whether to use GDAL" >&5
GDAL_LIBS=
GDAL_CFLAGS=
@@ -6008,7 +5974,7 @@
# Extract the first word of "gdal-config", so it can be a program name with args.
set dummy gdal-config; ac_word=$2
-echo "configure:6012: checking for $ac_word" >&5
+echo "configure:5978: checking for $ac_word" >&5
case "$GDAL_CONFIG" in
@@ -6063,14 +6029,14 @@
LIBS="$LIBS $GDAL_LIBS"
CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 6067 "configure"
+#line 6033 "configure"
#include <gdal.h>
int main() {
GDALOpen("foo", GA_ReadOnly);
; return 0; }
EOF
-if { (eval echo configure:6074: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6040: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
echo "configure: failed program was:" >&5
@@ -6079,14 +6045,14 @@
LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 6083 "configure"
+#line 6049 "configure"
#include <gdal.h>
int main() {
; return 0; }
EOF
-if { (eval echo configure:6090: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6056: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
else
@@ -6118,7 +6084,7 @@
# libLAS option
echo $ac_n "checking whether to use libLAS""... $ac_c" 1>&6
-echo "configure:6122: checking whether to use libLAS" >&5
+echo "configure:6088: checking whether to use libLAS" >&5
LIBLAS_LIBS=
LIBLAS_CFLAGS=
@@ -6135,7 +6101,7 @@
# Extract the first word of "liblas-config", so it can be a program name with args.
set dummy liblas-config; ac_word=$2
-echo "configure:6139: checking for $ac_word" >&5
+echo "configure:6105: checking for $ac_word" >&5
case "$LIBLAS_CONFIG" in
@@ -6183,14 +6149,14 @@
LIBS="$LIBS $LIBLAS_LIBS"
CFLAGS="$CFLAGS $LIBLAS_CFLAGS"
-#line 6187 "configure"
+#line 6153 "configure"
#include <liblas/capi/liblas.h>
int main() {
LASReader_Create("foo");
; return 0; }
EOF
-if { (eval echo configure:6194: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6160: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
@@ -6198,14 +6164,14 @@
rm -rf conftest*
-#line 6202 "configure"
+#line 6168 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:6209: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6175: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
LAS_LIBS="$LAS_LIBS"
else
@@ -6237,7 +6203,7 @@
# NetCDF option
echo $ac_n "checking whether to use NetCDF""... $ac_c" 1>&6
-echo "configure:6241: checking whether to use NetCDF" >&5
+echo "configure:6207: checking whether to use NetCDF" >&5
NETCDF_LIBS=
NETCDF_CFLAGS=
@@ -6254,7 +6220,7 @@
# Extract the first word of "nc-config", so it can be a program name with args.
set dummy nc-config; ac_word=$2
-echo "configure:6258: checking for $ac_word" >&5
+echo "configure:6224: checking for $ac_word" >&5
case "$NETCDF_CONFIG" in
@@ -6301,14 +6267,14 @@
LIBS="$LIBS $NETCDF_LIBS"
CFLAGS="$CFLAGS $NETCDF_CFLAGS"
-#line 6305 "configure"
+#line 6271 "configure"
#include <netcdf.h>
int main() {
nc_create("foo", NC_CLOBBER, NULL);
; return 0; }
EOF
-if { (eval echo configure:6312: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6278: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
@@ -6316,14 +6282,14 @@
rm -rf conftest*
-#line 6320 "configure"
+#line 6286 "configure"
#include <netcdf.h>
int main() {
; return 0; }
EOF
-if { (eval echo configure:6327: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6293: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
NETCDF_LIBS="$NETCDF_LIBS"
else
@@ -6354,7 +6320,7 @@
# GEOS option
echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:6358: checking whether to use GEOS" >&5
+echo "configure:6324: checking whether to use GEOS" >&5
GEOS_LIBS=
GEOS_CFLAGS=
@@ -6372,7 +6338,7 @@
# Extract the first word of "geos-config", so it can be a program name with args.
set dummy geos-config; ac_word=$2
-echo "configure:6376: checking for $ac_word" >&5
+echo "configure:6342: checking for $ac_word" >&5
case "$GEOS_CONFIG" in
@@ -6420,15 +6386,15 @@
do
-echo "configure:6424: checking for $ac_hdr" >&5
+echo "configure:6390: checking for $ac_hdr" >&5
-#line 6427 "configure"
+#line 6393 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6432: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6398: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6464,13 +6430,13 @@
echo $ac_n "checking for initGEOS in -lgeos_c_i""... $ac_c" 1>&6
-echo "configure:6468: checking for initGEOS in -lgeos_c_i" >&5
+echo "configure:6434: checking for initGEOS in -lgeos_c_i" >&5
ac_lib_var=`echo geos_c_i'_'initGEOS | sed 'y%./+-%__p_%'`
LIBS="-lgeos_c_i $LIBS"
-#line 6474 "configure"
+#line 6440 "configure"
@@ -6481,7 +6447,7 @@
initGEOS()
; return 0; }
EOF
-if { (eval echo configure:6485: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6451: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6517,13 +6483,13 @@
echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:6521: checking for initGEOS in -lgeos_c" >&5
+echo "configure:6487: checking for initGEOS in -lgeos_c" >&5
ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
LIBS="-lgeos_c $LIBS"
-#line 6527 "configure"
+#line 6493 "configure"
@@ -6534,7 +6500,7 @@
initGEOS()
; return 0; }
EOF
-if { (eval echo configure:6538: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6504: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6578,7 +6544,7 @@
echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:6582: checking whether to use TIFF" >&5
+echo "configure:6548: checking whether to use TIFF" >&5
echo "$ac_t"""$with_tiff"" 1>&6
case "$with_tiff" in
"no") USE_TIFF= ;;
@@ -6598,7 +6564,7 @@
echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:6602: checking for location of TIFF includes" >&5
+echo "configure:6568: checking for location of TIFF includes" >&5
case "$with_tiff_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -6624,15 +6590,15 @@
do
-echo "configure:6628: checking for $ac_hdr" >&5
+echo "configure:6594: checking for $ac_hdr" >&5
-#line 6631 "configure"
+#line 6597 "configure"
#include "confdefs.h"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6636: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6602: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6666,7 +6632,7 @@
echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:6670: checking for location of TIFF library" >&5
+echo "configure:6636: checking for location of TIFF library" >&5
case "$with_tiff_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -6697,13 +6663,13 @@
echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:6701: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6667: checking for TIFFOpen in -ltiff" >&5
ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
LIBS="-ltiff $LIBS"
-#line 6707 "configure"
+#line 6673 "configure"
@@ -6714,7 +6680,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6718: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6684: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6733,13 +6699,13 @@
-echo "configure:6737: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6703: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $MATHLIB $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 6743 "configure"
+#line 6709 "configure"
@@ -6750,7 +6716,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6754: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6720: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6769,13 +6735,13 @@
-echo "configure:6773: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6739: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $LIBS"
-#line 6779 "configure"
+#line 6745 "configure"
@@ -6786,7 +6752,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6790: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6756: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6805,13 +6771,13 @@
-echo "configure:6809: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6775: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 6815 "configure"
+#line 6781 "configure"
@@ -6822,7 +6788,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6826: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6792: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6841,13 +6807,13 @@
-echo "configure:6845: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6811: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $LIBS"
-#line 6851 "configure"
+#line 6817 "configure"
@@ -6858,7 +6824,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6862: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6828: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6877,13 +6843,13 @@
-echo "configure:6881: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6847: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $MATHLIB $LIBS"
-#line 6887 "configure"
+#line 6853 "configure"
@@ -6894,7 +6860,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6898: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6864: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6913,13 +6879,13 @@
-echo "configure:6917: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6883: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $ZLIB $LIBS"
-#line 6923 "configure"
+#line 6889 "configure"
@@ -6930,7 +6896,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6934: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6900: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6949,13 +6915,13 @@
-echo "configure:6953: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6919: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $ZLIB $MATHLIB $LIBS"
-#line 6959 "configure"
+#line 6925 "configure"
@@ -6966,7 +6932,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6970: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6936: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7064,7 +7030,7 @@
echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:7068: checking whether to use PNG" >&5
+echo "configure:7034: checking whether to use PNG" >&5
echo "$ac_t"""$with_png"" 1>&6
case "$with_png" in
"no") USE_PNG= ;;
@@ -7083,7 +7049,7 @@
echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:7087: checking for location of PNG includes" >&5
+echo "configure:7053: checking for location of PNG includes" >&5
case "$with_png_includes" in
{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -7109,15 +7075,15 @@
do
-echo "configure:7113: checking for $ac_hdr" >&5
+echo "configure:7079: checking for $ac_hdr" >&5
-#line 7116 "configure"
+#line 7082 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7121: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7087: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7151,7 +7117,7 @@
echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:7155: checking for location of PNG library" >&5
+echo "configure:7121: checking for location of PNG library" >&5
case "$with_png_libs" in
{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -7176,13 +7142,13 @@
echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:7180: checking for png_read_image in -lpng" >&5
+echo "configure:7146: checking for png_read_image in -lpng" >&5
ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 7186 "configure"
+#line 7152 "configure"
@@ -7193,7 +7159,7 @@
png_read_image()
; return 0; }
EOF
-if { (eval echo configure:7197: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7163: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7235,7 +7201,7 @@
echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:7239: checking whether to use PostgreSQL" >&5
+echo "configure:7205: checking whether to use PostgreSQL" >&5
echo "$ac_t"""$with_postgres"" 1>&6
case "$with_postgres" in
"no") USE_POSTGRES= ;;
@@ -7262,7 +7228,7 @@
echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:7266: checking for location of PostgreSQL includes" >&5
+echo "configure:7232: checking for location of PostgreSQL includes" >&5
case "$with_postgres_includes" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -7288,15 +7254,15 @@
do
-echo "configure:7292: checking for $ac_hdr" >&5
+echo "configure:7258: checking for $ac_hdr" >&5
-#line 7295 "configure"
+#line 7261 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7300: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7266: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7334,7 +7300,7 @@
echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:7338: checking for location of PostgreSQL library" >&5
+echo "configure:7304: checking for location of PostgreSQL library" >&5
case "$with_postgres_libs" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -7363,13 +7329,13 @@
echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:7367: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7333: checking for PQsetdbLogin in -lpq" >&5
ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 7373 "configure"
+#line 7339 "configure"
@@ -7380,7 +7346,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7384: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7350: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7399,13 +7365,13 @@
-echo "configure:7403: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7369: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 7409 "configure"
+#line 7375 "configure"
@@ -7416,7 +7382,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7420: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7386: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7435,13 +7401,13 @@
-echo "configure:7439: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7405: checking for PQsetdbLogin in -lpq" >&5
ac_save_LIBS="$LIBS"
LIBS="-lpq -lcrypt $LIBS"
-#line 7445 "configure"
+#line 7411 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -7452,7 +7418,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7456: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7422: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -7471,13 +7437,13 @@
-echo "configure:7475: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7441: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 7481 "configure"
+#line 7447 "configure"
@@ -7488,7 +7454,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7492: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7458: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7545,13 +7511,13 @@
ac_save_ldflags="$LDFLAGS"
LDFLAGS="$LDFLAGS $PQLIBPATH"
echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:7549: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7515: checking for PQcmdTuples in -lpq" >&5
ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 7555 "configure"
+#line 7521 "configure"
@@ -7562,7 +7528,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:7566: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7532: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7584,13 +7550,13 @@
-echo "configure:7588: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7554: checking for PQcmdTuples in -lpq" >&5
-#line 7594 "configure"
+#line 7560 "configure"
@@ -7601,7 +7567,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:7605: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7571: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7644,7 +7610,7 @@
echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:7648: checking whether to use MySQL" >&5
+echo "configure:7614: checking whether to use MySQL" >&5
echo "$ac_t"""$with_mysql"" 1>&6
case "$with_mysql" in
"no") USE_MYSQL= ;;
@@ -7664,7 +7630,7 @@
echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:7668: checking for location of MySQL includes" >&5
+echo "configure:7634: checking for location of MySQL includes" >&5
case "$with_mysql_includes" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -7690,15 +7656,15 @@
do
-echo "configure:7694: checking for $ac_hdr" >&5
+echo "configure:7660: checking for $ac_hdr" >&5
-#line 7697 "configure"
+#line 7663 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7702: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7668: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -7735,7 +7701,7 @@
echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:7739: checking for location of MySQL library" >&5
+echo "configure:7705: checking for location of MySQL library" >&5
case "$with_mysql_libs" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -7766,13 +7732,13 @@
echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:7770: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7736: checking for mysql_query in -lmysqlclient" >&5
ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
LIBS="-lmysqlclient $LIBS"
-#line 7776 "configure"
+#line 7742 "configure"
@@ -7783,7 +7749,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7787: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7753: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7802,13 +7768,13 @@
-echo "configure:7806: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7772: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 7812 "configure"
+#line 7778 "configure"
@@ -7819,7 +7785,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7823: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7789: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7838,13 +7804,13 @@
-echo "configure:7842: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7808: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 7848 "configure"
+#line 7814 "configure"
@@ -7855,7 +7821,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7859: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7825: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7874,13 +7840,13 @@
-echo "configure:7878: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7844: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 7884 "configure"
+#line 7850 "configure"
@@ -7891,7 +7857,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7895: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7861: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7910,13 +7876,13 @@
-echo "configure:7914: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7880: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 7920 "configure"
+#line 7886 "configure"
@@ -7927,7 +7893,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7931: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7897: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7946,13 +7912,13 @@
-echo "configure:7950: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7916: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 7956 "configure"
+#line 7922 "configure"
@@ -7963,7 +7929,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7967: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7933: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7982,13 +7948,13 @@
-echo "configure:7986: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7952: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 7992 "configure"
+#line 7958 "configure"
@@ -7999,7 +7965,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8003: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7969: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8018,13 +7984,13 @@
-echo "configure:8022: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7988: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 8028 "configure"
+#line 7994 "configure"
@@ -8035,7 +8001,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8039: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8005: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8125,7 +8091,7 @@
# Extract the first word of "mysql_config", so it can be a program name with args.
set dummy mysql_config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:8129: checking for $ac_word" >&5
+echo "configure:8095: checking for $ac_word" >&5
case "$MYSQLD_CONFIG" in
@@ -8174,10 +8140,10 @@
LIBS="$MYSQLDLIB $LIBS"
echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:8178: checking for mysql_server_init" >&5
+echo "configure:8144: checking for mysql_server_init" >&5
-#line 8181 "configure"
+#line 8147 "configure"
which can conflict with char mysql_server_init(); below. */
@@ -8203,7 +8169,7 @@
; return 0; }
EOF
-if { (eval echo configure:8207: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8173: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_mysql_server_init=yes"
else
@@ -8255,7 +8221,7 @@
echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:8259: checking whether to use SQLite" >&5
+echo "configure:8225: checking whether to use SQLite" >&5
echo "$ac_t"""$with_sqlite"" 1>&6
case "$with_sqlite" in
"no") USE_SQLITE= ;;
@@ -8275,7 +8241,7 @@
echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:8279: checking for location of SQLite includes" >&5
+echo "configure:8245: checking for location of SQLite includes" >&5
case "$with_sqlite_includes" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -8301,15 +8267,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:8305: checking for $ac_hdr" >&5
+echo "configure:8271: checking for $ac_hdr" >&5
-#line 8308 "configure"
+#line 8274 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8313: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8279: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8352,7 +8318,7 @@
echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:8356: checking for location of SQLite library" >&5
+echo "configure:8322: checking for location of SQLite library" >&5
case "$with_sqlite_libs" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -8381,13 +8347,13 @@
echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:8385: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8351: checking for sqlite3_open in -lsqlite3" >&5
ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
LIBS="-lsqlite3 $LIBS"
-#line 8391 "configure"
+#line 8357 "configure"
@@ -8398,7 +8364,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8402: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8368: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8417,13 +8383,13 @@
-echo "configure:8421: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8387: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $DLLIB $LIBS"
-#line 8427 "configure"
+#line 8393 "configure"
@@ -8434,7 +8400,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8438: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8404: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8453,13 +8419,13 @@
-echo "configure:8457: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8423: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 8463 "configure"
+#line 8429 "configure"
@@ -8470,7 +8436,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8474: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8440: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8489,13 +8455,13 @@
-echo "configure:8493: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8459: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
-#line 8499 "configure"
+#line 8465 "configure"
@@ -8506,7 +8472,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8510: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8476: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8575,7 +8541,7 @@
echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:8579: checking whether to use FFMPEG" >&5
+echo "configure:8545: checking whether to use FFMPEG" >&5
echo "$ac_t"""$with_ffmpeg"" 1>&6
case "$with_ffmpeg" in
"no") USE_FFMPEG= ;;
@@ -8595,7 +8561,7 @@
echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:8599: checking for location of FFMPEG includes" >&5
+echo "configure:8565: checking for location of FFMPEG includes" >&5
case "$with_ffmpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -8621,15 +8587,15 @@
do
-echo "configure:8625: checking for $ac_hdr" >&5
+echo "configure:8591: checking for $ac_hdr" >&5
-#line 8628 "configure"
+#line 8594 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8633: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8599: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8665,15 +8631,15 @@
do
-echo "configure:8669: checking for $ac_hdr" >&5
+echo "configure:8635: checking for $ac_hdr" >&5
-#line 8672 "configure"
+#line 8638 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8677: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8643: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8709,15 +8675,15 @@
do
-echo "configure:8713: checking for $ac_hdr" >&5
+echo "configure:8679: checking for $ac_hdr" >&5
-#line 8716 "configure"
+#line 8682 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8721: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8687: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8760,7 +8726,7 @@
echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:8764: checking for location of FFMPEG library" >&5
+echo "configure:8730: checking for location of FFMPEG library" >&5
case "$with_ffmpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -8787,13 +8753,13 @@
echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:8791: checking for av_free in -lavutil" >&5
+echo "configure:8757: checking for av_free in -lavutil" >&5
ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
LIBS="-lavutil $LIBS"
-#line 8797 "configure"
+#line 8763 "configure"
@@ -8804,7 +8770,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:8808: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8774: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8823,13 +8789,13 @@
-echo "configure:8827: checking for av_free in -lavutil" >&5
+echo "configure:8793: checking for av_free in -lavutil" >&5
LIBS="-lavutil $MATHLIB $LIBS"
-#line 8833 "configure"
+#line 8799 "configure"
@@ -8840,7 +8806,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:8844: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8810: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8885,13 +8851,13 @@
echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:8889: checking for avcodec_init in -lavcodec" >&5
+echo "configure:8855: checking for avcodec_init in -lavcodec" >&5
ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
LIBS="-lavcodec $FFMPEGLIB $LIBS"
-#line 8895 "configure"
+#line 8861 "configure"
@@ -8902,7 +8868,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:8906: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8872: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8921,13 +8887,13 @@
-echo "configure:8925: checking for avcodec_init in -lavcodec" >&5
+echo "configure:8891: checking for avcodec_init in -lavcodec" >&5
LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 8931 "configure"
+#line 8897 "configure"
@@ -8938,7 +8904,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:8942: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8908: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8983,13 +8949,13 @@
echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:8987: checking for av_set_parameters in -lavformat" >&5
+echo "configure:8953: checking for av_set_parameters in -lavformat" >&5
ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
LIBS="-lavformat $FFMPEGLIB $LIBS"
-#line 8993 "configure"
+#line 8959 "configure"
@@ -9000,7 +8966,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:9004: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8970: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9019,13 +8985,13 @@
-echo "configure:9023: checking for av_set_parameters in -lavformat" >&5
+echo "configure:8989: checking for av_set_parameters in -lavformat" >&5
LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 9029 "configure"
+#line 8995 "configure"
@@ -9036,7 +9002,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:9040: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9006: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9095,7 +9061,7 @@
OPENGL_WINDOWS=
echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:9099: checking whether to use OpenGL" >&5
+echo "configure:9065: checking whether to use OpenGL" >&5
echo "$ac_t"""$with_opengl"" 1>&6
case "$with_opengl" in
n|no)
@@ -9129,7 +9095,7 @@
echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:9133: checking for location of OpenGL includes" >&5
+echo "configure:9099: checking for location of OpenGL includes" >&5
case "$with_opengl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -9155,15 +9121,15 @@
do
-echo "configure:9159: checking for $ac_hdr" >&5
+echo "configure:9125: checking for $ac_hdr" >&5
-#line 9162 "configure"
+#line 9128 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9167: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9133: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9197,7 +9163,7 @@
echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:9201: checking for location of OpenGL library" >&5
+echo "configure:9167: checking for location of OpenGL library" >&5
case "$with_opengl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -9226,13 +9192,13 @@
echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:9230: checking for glBegin in -lGL" >&5
+echo "configure:9196: checking for glBegin in -lGL" >&5
ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 9236 "configure"
+#line 9202 "configure"
@@ -9243,7 +9209,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9247: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9213: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9262,13 +9228,13 @@
-echo "configure:9266: checking for glBegin in -lGL" >&5
+echo "configure:9232: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 9272 "configure"
+#line 9238 "configure"
@@ -9279,7 +9245,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9283: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9249: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9298,13 +9264,13 @@
-echo "configure:9302: checking for glBegin in -lGL" >&5
+echo "configure:9268: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 9308 "configure"
+#line 9274 "configure"
@@ -9315,7 +9281,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9319: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9285: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9334,13 +9300,13 @@
-echo "configure:9338: checking for glBegin in -lGL" >&5
+echo "configure:9304: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 9344 "configure"
+#line 9310 "configure"
@@ -9351,7 +9317,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9355: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9321: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9413,13 +9379,13 @@
echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:9417: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9383: checking for gluBeginCurve in -lGLU" >&5
ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 9423 "configure"
+#line 9389 "configure"
@@ -9430,7 +9396,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:9434: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9400: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9449,13 +9415,13 @@
-echo "configure:9453: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9419: checking for gluBeginCurve in -lGLU" >&5
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 9459 "configure"
+#line 9425 "configure"
@@ -9466,7 +9432,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:9470: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9436: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9513,10 +9479,10 @@
LIBS=" $OPENGLLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:9517: checking for glXCreatePbuffer" >&5
+echo "configure:9483: checking for glXCreatePbuffer" >&5
-#line 9520 "configure"
+#line 9486 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char glXCreatePbuffer(); below. */
@@ -9539,7 +9505,7 @@
; return 0; }
EOF
-if { (eval echo configure:9543: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9509: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreatePbuffer=yes"
else
@@ -9576,10 +9542,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:9580: checking for glXCreateGLXPixmap" >&5
+echo "configure:9546: checking for glXCreateGLXPixmap" >&5
-#line 9583 "configure"
+#line 9549 "configure"
which can conflict with char glXCreateGLXPixmap(); below. */
@@ -9602,7 +9568,7 @@
; return 0; }
EOF
-if { (eval echo configure:9606: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9572: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreateGLXPixmap=yes"
else
@@ -9645,7 +9611,7 @@
echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:9649: checking for location of OpenGL framework" >&5
+echo "configure:9615: checking for location of OpenGL framework" >&5
case "$with_opengl_framework" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -9669,15 +9635,15 @@
do
-echo "configure:9673: checking for $ac_hdr" >&5
+echo "configure:9639: checking for $ac_hdr" >&5
-#line 9676 "configure"
+#line 9642 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9681: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9647: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9713,10 +9679,10 @@
LIBS="-framework OpenGL -framework AGL -framework ApplicationServices $LIBS"
LDFLAGS="$OPENGLPATH $LDFLAGS"
echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:9717: checking for glBegin" >&5
+echo "configure:9683: checking for glBegin" >&5
-#line 9720 "configure"
+#line 9686 "configure"
which can conflict with char glBegin(); below. */
@@ -9739,7 +9705,7 @@
; return 0; }
EOF
-if { (eval echo configure:9743: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9709: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glBegin=yes"
else
@@ -9776,10 +9742,10 @@
echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:9780: checking for gluBeginCurve" >&5
+echo "configure:9746: checking for gluBeginCurve" >&5
-#line 9783 "configure"
+#line 9749 "configure"
which can conflict with char gluBeginCurve(); below. */
@@ -9802,7 +9768,7 @@
; return 0; }
EOF
-if { (eval echo configure:9806: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9772: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gluBeginCurve=yes"
else
@@ -9850,7 +9816,7 @@
-echo "configure:9854: checking for location of OpenGL includes" >&5
+echo "configure:9820: checking for location of OpenGL includes" >&5
@@ -9876,15 +9842,15 @@
do
-echo "configure:9880: checking for $ac_hdr" >&5
+echo "configure:9846: checking for $ac_hdr" >&5
-#line 9883 "configure"
+#line 9849 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9888: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9854: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9918,7 +9884,7 @@
-echo "configure:9922: checking for location of OpenGL library" >&5
+echo "configure:9888: checking for location of OpenGL library" >&5
@@ -9943,18 +9909,18 @@
ac_save_libs="$LIBS"
echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:9947: checking for OpenGL library" >&5
+echo "configure:9913: checking for OpenGL library" >&5
LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
LIBS="-lopengl32 "
-#line 9951 "configure"
+#line 9917 "configure"
#include <GL/gl.h>
int main() {
glEnd();
; return 0; }
EOF
-if { (eval echo configure:9958: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9924: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
echo "$ac_t""found" 1>&6
@@ -9978,18 +9944,18 @@
echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:9982: checking for GLU library" >&5
+echo "configure:9948: checking for GLU library" >&5
LIBS="-lglu32 $OPENGLLIB "
-#line 9986 "configure"
+#line 9952 "configure"
#include <GL/glu.h>
int main() {
gluNewQuadric();
; return 0; }
EOF
-if { (eval echo configure:9993: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9959: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -10034,932 +10000,11 @@
# Done checking OpenGL
-# Enable TCLTK option
-echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:10042: checking whether to use Tcl/Tk" >&5
-echo "$ac_t"""$with_tcltk"" 1>&6
-case "$with_tcltk" in
- "no") USE_TCLTK= ;;
- "yes") USE_TCLTK="1" ;;
- *) { echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; } ;;
-esac
-TCLINCDIR=
-TCLTKLIBPATH=
-TCLTKLIBS=
-if test -n "$USE_TCLTK"; then
-# With Tcl/Tk includes directory
-echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:10062: checking for location of Tcl/Tk includes" >&5
-case "$with_tcltk_includes" in
-y | ye | yes | n | no)
- { echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
-esac
-echo "$ac_t""$with_tcltk_includes" 1>&6
-if test -n "$with_tcltk_includes" ; then
- for dir in $with_tcltk_includes; do
- if test -d "$dir"; then
- TCLINCDIR="$TCLINCDIR -I$dir"
- else
- { echo "configure: error: *** Tcl/Tk includes directory $dir does not exist." 1>&2; exit 1; }
- fi
- done
-fi
-ac_save_cppflags="$CPPFLAGS"
-CPPFLAGS="$TCLINCDIR $CPPFLAGS"
-for ac_hdr in tcl.h
-do
-ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
-echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:10088: checking for $ac_hdr" >&5
-cat > conftest.$ac_ext <<EOF
-#line 10091 "configure"
-#include "confdefs.h"
-#include <$ac_hdr>
-EOF
-ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:10096: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
-ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
-if test -z "$ac_err"; then
- rm -rf conftest*
- eval "ac_cv_header_$ac_safe=yes"
-else
- echo "$ac_err" >&5
- echo "configure: failed program was:" >&5
- cat conftest.$ac_ext >&5
- rm -rf conftest*
- eval "ac_cv_header_$ac_safe=no"
-fi
-rm -f conftest*
-if eval "test \"`echo '$ac_cv_header_'$ac_safe`\" = yes"; then
- echo "$ac_t""yes" 1>&6
- ac_tr_hdr=HAVE_`echo $ac_hdr | sed 'y%abcdefghijklmnopqrstuvwxyz./-%ABCDEFGHIJKLMNOPQRSTUVWXYZ___%'`
- cat >> confdefs.h <<EOF
-#define $ac_tr_hdr 1
-EOF
-else
- echo "$ac_t""no" 1>&6
-{ echo "configure: error: *** Unable to locate Tcl includes." 1>&2; exit 1; }
-fi
-done
-CPPFLAGS=$ac_save_cppflags
-CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
-for ac_hdr in tk.h
-do
-echo "configure:10133: checking for $ac_hdr" >&5
-#line 10136 "configure"
-#include <$ac_hdr>
-EOF
-{ (eval echo configure:10141: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
- rm -rf conftest*
-else
- rm -rf conftest*
-fi
-rm -f conftest*
-EOF
-else
-{ echo "configure: error: *** Unable to locate Tk includes." 1>&2; exit 1; }
-fi
-done
-# Tcl/Tk version checks
-echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:10175: checking Tcl version" >&5
-if test "$cross_compiling" = yes; then
- tcl_ver=UNKNOWN
- echo "$ac_t""unknown (cross-compiling)" 1>&6
-else
- cat > conftest.$ac_ext <<EOF
-#line 10183 "configure"
-#include <stdio.h>
-#include <tcl.h>
-int main(void) {
- FILE *fp = fopen("conftestdata","w");
- fputs(TCL_VERSION, fp);
- return 0;
-EOF
-if { (eval echo configure:10195: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
-then
- tcl_ver=`cat conftestdata`
- echo "$ac_t""$tcl_ver" 1>&6
-else
- rm -fr conftest*
- { echo "configure: error: *** Could not determine Tcl version." 1>&2; exit 1; }
-fi
-rm -fr conftest*
-fi
-echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:10213: checking Tk version" >&5
- tk_ver=UNKNOWN
-else
-#line 10221 "configure"
-#include <stdio.h>
-#include <tk.h>
-int main(void) {
- fputs(TK_VERSION, fp);
- return 0;
-EOF
-if { (eval echo configure:10233: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
-then
- tk_ver=`cat conftestdata`
- echo "$ac_t""$tk_ver" 1>&6
-else
- rm -fr conftest*
- { echo "configure: error: *** Could not determine Tk version." 1>&2; exit 1; }
-fi
-rm -fr conftest*
-fi
-if test "$tcl_ver" = "$tk_ver" ; then
- tcltk_ver="$tcl_ver"
-else
- { echo "configure: error: *** Tcl/Tk version mismatch." 1>&2; exit 1; }
-fi
-# FreeBSD and CygWin don't have a "dot" between major/minor version number
-tcltk_ver2=`echo "$tcltk_ver" | sed 's/\.//g'`
-# With Tcl/Tk library directory
-echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:10262: checking for location of Tcl/Tk library" >&5
-case "$with_tcltk_libs" in
- { echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
-esac
-echo "$ac_t""$with_tcltk_libs" 1>&6
-if test -n "$with_tcltk_libs"; then
- for dir in $with_tcltk_libs; do
- TCLTKLIBPATH="$TCLTKLIBPATH -L$dir"
- else
- { echo "configure: error: *** Tcl/Tk library directory $dir does not exist." 1>&2; exit 1; }
- fi
- done
-fi
-TCLLIB=
-TKLIB=
-MACOSX_ARCHS_TCLTK=
-# Can't test tcl/tk libs on 64bit OSX Aqua for now
-# assume that if OpenGL Aqua, then user specifies TclTk Aqua
-if test "$OPENGL_AQUA" = 1 ; then
- save_CFLAGS="$CFLAGS"
- CFLAGS="`echo \"$CFLAGS\" | sed -E 's/-arch +x86_64//g' | sed -E 's/-arch +ppc64//g'`"
- save_LDFLAGS="$LDFLAGS"
- LDFLAGS="`echo \"$LDFLAGS\" | sed -E 's/-arch +x86_64//g' | sed -E 's/-arch +ppc64//g'`"
-fi
-ac_save_ldflags="$LDFLAGS"
-LDFLAGS="$TCLTKLIBPATH $LDFLAGS"
-echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:10302: checking for Tcl_Init in -ltcl" >&5
-ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
-ac_save_LIBS="$LIBS"
-LIBS="-ltcl $MATHLIB $LIBS"
-#line 10308 "configure"
-/* Override any gcc2 internal prototype to avoid an error. */
-/* We use char because int might match the return type of a gcc2
- builtin and then its argument prototype would still apply. */
-char Tcl_Init();
-int main() {
-Tcl_Init()
-; return 0; }
-EOF
-if { (eval echo configure:10319: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
- rm -rf conftest*
- eval "ac_cv_lib_$ac_lib_var=yes"
-else
- rm -rf conftest*
- eval "ac_cv_lib_$ac_lib_var=no"
-fi
-rm -f conftest*
-LIBS="$ac_save_LIBS"
-if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
- TCLLIB="$TCLLIB -ltcl $MATHLIB"
-else
-echo "configure:10338: checking for Tcl_Init in -ltcl" >&5
-LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 10344 "configure"
-char Tcl_Init();
-int main() {
-Tcl_Init()
-; return 0; }
-EOF
-if { (eval echo configure:10355: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
- rm -rf conftest*
-else
- rm -rf conftest*
-fi
-rm -f conftest*
- TCLLIB="$TCLLIB -ltcl $MATHLIB $DLLIB"
-else
-LDFLAGS=${ac_save_ldflags}
-echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:10382: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
-ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
-LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 10388 "configure"
-char Tcl_Init();
-int main() {
-Tcl_Init()
-; return 0; }
-EOF
-if { (eval echo configure:10399: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
- rm -rf conftest*
-else
- rm -rf conftest*
-fi
-rm -f conftest*
- TCLLIB="$TCLLIB -ltcl$tcltk_ver $MATHLIB"
-else
-echo "configure:10418: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
-LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 10424 "configure"
-char Tcl_Init();
-int main() {
-Tcl_Init()
-; return 0; }
-EOF
-if { (eval echo configure:10435: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
- rm -rf conftest*
-else
- rm -rf conftest*
-fi
-rm -f conftest*
- TCLLIB="$TCLLIB -ltcl$tcltk_ver $MATHLIB $DLLIB"
-else
-echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:10462: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
-ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
-LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 10468 "configure"
-char Tcl_Init();
-int main() {
-Tcl_Init()
-; return 0; }
-EOF
-if { (eval echo configure:10479: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
- rm -rf conftest*
-else
- rm -rf conftest*
-fi
-rm -f conftest*
- TCLLIB="$TCLLIB -ltcl$tcltk_ver2 $MATHLIB"
-else
-echo "configure:10498: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
-LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 10504 "configure"
-char Tcl_Init();
-int main() {
-Tcl_Init()
-; return 0; }
-EOF
-if { (eval echo configure:10515: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
- rm -rf conftest*
-else
- rm -rf conftest*
-fi
-rm -f conftest*
- TCLLIB="$TCLLIB -ltcl$tcltk_ver2 $MATHLIB $DLLIB"
-else
- { echo "configure: error: *** Unable to locate Tcl library." 1>&2; exit 1; }
-fi
-fi
-fi
-fi
-fi
-fi
-echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:10593: checking for Tk_MainWindow in -ltk" >&5
-ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
-LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 10599 "configure"
-char Tk_MainWindow();
-int main() {
-Tk_MainWindow()
-; return 0; }
-EOF
-if { (eval echo configure:10610: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
- rm -rf conftest*
-else
- rm -rf conftest*
-fi
-rm -f conftest*
- TKLIB="$TKLIB -ltk $MATHLIB"
-else
-echo "configure:10629: checking for Tk_MainWindow in -ltk" >&5
-LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 10635 "configure"
-int main() {
-Tk_MainWindow()
-; return 0; }
-EOF
-if { (eval echo configure:10646: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
- rm -rf conftest*
-else
- rm -rf conftest*
-fi
-rm -f conftest*
- TKLIB="$TKLIB -ltk $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS"
-else
-echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:10673: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
-ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
-LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 10679 "configure"
-int main() {
-Tk_MainWindow()
-; return 0; }
-EOF
-if { (eval echo configure:10690: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
- rm -rf conftest*
-else
- rm -rf conftest*
-fi
-rm -f conftest*
- TKLIB="$TKLIB -ltk$tcltk_ver $MATHLIB"
-else
-echo "configure:10709: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
-LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 10715 "configure"
-int main() {
-Tk_MainWindow()
-; return 0; }
-EOF
-if { (eval echo configure:10726: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
- rm -rf conftest*
-else
- rm -rf conftest*
-fi
-rm -f conftest*
- TKLIB="$TKLIB -ltk$tcltk_ver $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS"
-else
-echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:10753: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
-ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
-LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 10759 "configure"
-int main() {
-Tk_MainWindow()
-; return 0; }
-EOF
-if { (eval echo configure:10770: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
- rm -rf conftest*
-else
- rm -rf conftest*
-fi
-rm -f conftest*
- TKLIB="$TKLIB -ltk$tcltk_ver2 $MATHLIB"
-else
-echo "configure:10789: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
-LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 10795 "configure"
-int main() {
-Tk_MainWindow()
-; return 0; }
-EOF
-if { (eval echo configure:10806: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
- rm -rf conftest*
-else
- rm -rf conftest*
-fi
-rm -f conftest*
- TKLIB="$TKLIB -ltk$tcltk_ver2 $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS"
-else
- { echo "configure: error: *** Unable to locate Tk library." 1>&2; exit 1; }
-fi
-fi
-fi
-fi
-fi
-fi
-# restore CFLAGS/LDLFAGS from Aqua 64bit strip
-# only Tcl/Tk-based makefiles will strip 64bit out during compile
- CFLAGS="$save_CFLAGS"
- LDFLAGS="$save_LDFLAGS"
-fi
-TCLTKLIBS="$TKLIB $TCLLIB"
-# check for available OSX archs in TclTk
-if test -n "$MACOSX_ARCHS" ; then
- LDFLAGS=
- CFLAGS=
- tlib=`echo "$TCLLIB" | sed -e 's/-l//' -e 's/^ *//' -e 's/ *$//'`
- for a in i386 ppc x86_64 ppc64
- do
- # add only if in MACOSX_ARCHS
- echo $ac_n "checking for Tcl_Init in -l$tlib""... $ac_c" 1>&6
-echo "configure:10896: checking for Tcl_Init in -l$tlib" >&5
-ac_lib_var=`echo $tlib'_'Tcl_Init | sed 'y%./+-%__p_%'`
-LIBS="-l$tlib -arch $a $MACOSX_SDK $TCLTKLIBPATH $LIBS"
-#line 10902 "configure"
-char Tcl_Init();
-int main() {
-Tcl_Init()
-; return 0; }
-EOF
-if { (eval echo configure:10913: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
- rm -rf conftest*
-else
- rm -rf conftest*
-fi
-rm -f conftest*
- if test -n "`echo "$MACOSX_ARCHS" | grep $a`" ; then
- MACOSX_ARCHS_TCLTK="$MACOSX_ARCHS_TCLTK -arch $a"
- fi
-else
-fi
- done
-fi
-cat >> confdefs.h <<\EOF
-#define HAVE_TCLTK 1
-EOF
-fi # $USE_TCLTK
-TKINCDIR=$TCLINCDIR
-# Done checking Tcl/Tk
# Enable ODBC option
echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:10963: checking whether to use ODBC" >&5
+echo "configure:10008: checking whether to use ODBC" >&5
echo "$ac_t"""$with_odbc"" 1>&6
case "$with_odbc" in
"no") USE_ODBC= ;;
@@ -10978,7 +10023,7 @@
echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:10982: checking for location of ODBC includes" >&5
+echo "configure:10027: checking for location of ODBC includes" >&5
case "$with_odbc_includes" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -11004,15 +10049,15 @@
do
-echo "configure:11008: checking for $ac_hdr" >&5
+echo "configure:10053: checking for $ac_hdr" >&5
-#line 11011 "configure"
+#line 10056 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11016: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10061: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11046,7 +10091,7 @@
echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:11050: checking for location of ODBC library" >&5
+echo "configure:10095: checking for location of ODBC library" >&5
case "$with_odbc_libs" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -11071,13 +10116,13 @@
echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:11075: checking for SQLConnect in -lodbc" >&5
+echo "configure:10120: checking for SQLConnect in -lodbc" >&5
ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-lodbc $ICONVLIB $LIBS"
-#line 11081 "configure"
+#line 10126 "configure"
@@ -11088,7 +10133,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:11092: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10137: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11113,13 +10158,13 @@
echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:11117: checking for SQLConnect in -liodbc" >&5
+echo "configure:10162: checking for SQLConnect in -liodbc" >&5
ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-liodbc $LIBS"
-#line 11123 "configure"
+#line 10168 "configure"
@@ -11130,7 +10175,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:11134: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11155,11 +10200,11 @@
echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:11159: checking for ODBC library" >&5
+echo "configure:10204: checking for ODBC library" >&5
LDFLAGS="$ODBCLIB $LDFLAGS"
LIBS="-lodbc32 "
-#line 11163 "configure"
+#line 10208 "configure"
#include <windows.h>
#include <sql.h>
@@ -11167,7 +10212,7 @@
SQLAllocEnv((SQLHENV *)0);
; return 0; }
EOF
-if { (eval echo configure:11171: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10216: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -11216,7 +10261,7 @@
echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:11220: checking whether to use FFTW" >&5
+echo "configure:10265: checking whether to use FFTW" >&5
echo "$ac_t"""$with_fftw"" 1>&6
case "$with_fftw" in
"no") USE_FFTW= ;;
@@ -11235,7 +10280,7 @@
echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:11239: checking for location of FFTW includes" >&5
+echo "configure:10284: checking for location of FFTW includes" >&5
case "$with_fftw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -11261,15 +10306,15 @@
do
-echo "configure:11265: checking for $ac_hdr" >&5
+echo "configure:10310: checking for $ac_hdr" >&5
-#line 11268 "configure"
+#line 10313 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11273: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10318: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11297,15 +10342,15 @@
do
-echo "configure:11301: checking for $ac_hdr" >&5
+echo "configure:10346: checking for $ac_hdr" >&5
-#line 11304 "configure"
+#line 10349 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11309: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10354: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11333,15 +10378,15 @@
do
-echo "configure:11337: checking for $ac_hdr" >&5
+echo "configure:10382: checking for $ac_hdr" >&5
-#line 11340 "configure"
+#line 10385 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11345: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10390: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11387,7 +10432,7 @@
echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:11391: checking for location of FFTW library" >&5
+echo "configure:10436: checking for location of FFTW library" >&5
case "$with_fftw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -11412,13 +10457,13 @@
echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:11416: checking for fftw_execute in -lfftw3" >&5
+echo "configure:10461: checking for fftw_execute in -lfftw3" >&5
ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 11422 "configure"
+#line 10467 "configure"
@@ -11429,7 +10474,7 @@
fftw_execute()
; return 0; }
EOF
-if { (eval echo configure:11433: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10478: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11454,13 +10499,13 @@
echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:11458: checking for fftwnd_one in -lfftw" >&5
+echo "configure:10503: checking for fftwnd_one in -lfftw" >&5
ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-lfftw $MATHLIB $LIBS"
-#line 11464 "configure"
+#line 10509 "configure"
@@ -11471,7 +10516,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:11475: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10520: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11496,13 +10541,13 @@
echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:11500: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:10545: checking for fftwnd_one in -ldfftw" >&5
ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-ldfftw $MATHLIB $LIBS"
-#line 11506 "configure"
+#line 10551 "configure"
@@ -11513,7 +10558,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:11517: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10562: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11570,7 +10615,7 @@
echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:11574: checking whether to use BLAS" >&5
+echo "configure:10619: checking whether to use BLAS" >&5
echo "$ac_t"""$with_blas"" 1>&6
case "$with_blas" in
"no") USE_BLAS= ;;
@@ -11591,7 +10636,7 @@
echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:11595: checking for location of BLAS includes" >&5
+echo "configure:10640: checking for location of BLAS includes" >&5
case "$with_blas_includes" in
{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -11611,7 +10656,7 @@
echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:11615: checking for location of BLAS library" >&5
+echo "configure:10660: checking for location of BLAS library" >&5
case "$with_blas_libs" in
{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -11637,15 +10682,15 @@
do
-echo "configure:11641: checking for $ac_hdr" >&5
+echo "configure:10686: checking for $ac_hdr" >&5
-#line 11644 "configure"
+#line 10689 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11649: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10694: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11680,13 +10725,13 @@
echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:11684: checking for dnrm2_ in -lblas" >&5
+echo "configure:10729: checking for dnrm2_ in -lblas" >&5
ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $MATHLIB $LIBS"
-#line 11690 "configure"
+#line 10735 "configure"
@@ -11697,7 +10742,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:11701: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10746: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11716,13 +10761,13 @@
-echo "configure:11720: checking for dnrm2_ in -lblas" >&5
+echo "configure:10765: checking for dnrm2_ in -lblas" >&5
LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 11726 "configure"
+#line 10771 "configure"
@@ -11733,7 +10778,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:11737: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10782: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11777,13 +10822,13 @@
LDFLAGS="$BLASLIB $LDFLAGS"
echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:11781: checking for ATL_xerbla in -latlas" >&5
+echo "configure:10826: checking for ATL_xerbla in -latlas" >&5
ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
LIBS="-latlas $LIBS"
-#line 11787 "configure"
+#line 10832 "configure"
@@ -11794,7 +10839,7 @@
ATL_xerbla()
; return 0; }
EOF
-if { (eval echo configure:11798: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10843: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11809,13 +10854,13 @@
echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:11813: checking for sgemm_ in -lf77blas" >&5
+echo "configure:10858: checking for sgemm_ in -lf77blas" >&5
ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lf77blas -latlas $LIBS"
-#line 11819 "configure"
+#line 10864 "configure"
@@ -11826,7 +10871,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11830: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10875: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11841,13 +10886,13 @@
echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:11845: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:10890: checking for cblas_dgemm in -lcblas" >&5
ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 11851 "configure"
+#line 10896 "configure"
@@ -11858,7 +10903,7 @@
cblas_dgemm()
; return 0; }
EOF
-if { (eval echo configure:11862: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10907: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11904,16 +10949,16 @@
save_LIBS="$LIBS"
LIBS="$vlib_flags $LIBS"
echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:11908: checking for sgemm in $vlib_flags" >&5
+echo "configure:10953: checking for sgemm in $vlib_flags" >&5
-#line 11910 "configure"
+#line 10955 "configure"
int main() {
sgemm
; return 0; }
EOF
-if { (eval echo configure:11917: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10962: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
blas_ok=yes; BLASLIB="$vlib_flags"
else
@@ -11931,13 +10976,13 @@
# BLAS in PhiPACK libraries? (requires generic BLAS, too)
if test $blas_ok = no; then
echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:11935: checking for sgemm_ in -lblas" >&5
+echo "configure:10980: checking for sgemm_ in -lblas" >&5
ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $LIBS"
-#line 11941 "configure"
+#line 10986 "configure"
@@ -11948,7 +10993,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11952: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10997: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11963,13 +11008,13 @@
echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:11967: checking for dgemm_ in -ldgemm" >&5
+echo "configure:11012: checking for dgemm_ in -ldgemm" >&5
ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
LIBS="-ldgemm -lblas $LIBS"
-#line 11973 "configure"
+#line 11018 "configure"
@@ -11980,7 +11025,7 @@
dgemm_()
; return 0; }
EOF
-if { (eval echo configure:11984: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11029: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11995,13 +11040,13 @@
echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:11999: checking for sgemm_ in -lsgemm" >&5
+echo "configure:11044: checking for sgemm_ in -lsgemm" >&5
ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsgemm -lblas $LIBS"
-#line 12005 "configure"
+#line 11050 "configure"
@@ -12012,7 +11057,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12016: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11061: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12046,13 +11091,13 @@
if test "x$GCC" != xyes; then # only works with Sun CC
echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:12050: checking for acosp in -lsunmath" >&5
+echo "configure:11095: checking for acosp in -lsunmath" >&5
ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
LIBS="-lsunmath $LIBS"
-#line 12056 "configure"
+#line 11101 "configure"
@@ -12063,7 +11108,7 @@
acosp()
; return 0; }
EOF
-if { (eval echo configure:12067: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11112: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12078,13 +11123,13 @@
echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:12082: checking for sgemm_ in -lsunperf" >&5
+echo "configure:11127: checking for sgemm_ in -lsunperf" >&5
ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsunperf -lsunmath $LIBS"
-#line 12088 "configure"
+#line 11133 "configure"
@@ -12095,7 +11140,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12099: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11144: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12125,13 +11170,13 @@
# Generic BLAS library
-echo "configure:12129: checking for sgemm_ in -lblas" >&5
+echo "configure:11174: checking for sgemm_ in -lblas" >&5
LIBS="-lblas $LIBS"
-#line 12135 "configure"
+#line 11180 "configure"
@@ -12142,7 +11187,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12146: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11191: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12181,7 +11226,7 @@
echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:12185: checking whether to use LAPACK" >&5
+echo "configure:11230: checking whether to use LAPACK" >&5
echo "$ac_t"""$with_lapack"" 1>&6
case "$with_lapack" in
"no") USE_LAPACK= ;;
@@ -12206,7 +11251,7 @@
echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:12210: checking for location of LAPACK includes" >&5
+echo "configure:11255: checking for location of LAPACK includes" >&5
case "$with_lapack_includes" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -12226,7 +11271,7 @@
echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:12230: checking for location of LAPACK library" >&5
+echo "configure:11275: checking for location of LAPACK library" >&5
case "$with_lapack_libs" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -12252,15 +11297,15 @@
do
-echo "configure:12256: checking for $ac_hdr" >&5
+echo "configure:11301: checking for $ac_hdr" >&5
-#line 12259 "configure"
+#line 11304 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12264: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11309: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12292,10 +11337,10 @@
save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:12296: checking for dsegv_" >&5
+echo "configure:11341: checking for dsegv_" >&5
-#line 12299 "configure"
+#line 11344 "configure"
which can conflict with char dsegv_(); below. */
@@ -12318,7 +11363,7 @@
; return 0; }
EOF
-if { (eval echo configure:12322: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11367: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dsegv_=yes"
else
@@ -12345,13 +11390,13 @@
save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:12349: checking for desgv_ in -llapack" >&5
+echo "configure:11394: checking for desgv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $FLIBS $LIBS"
-#line 12355 "configure"
+#line 11400 "configure"
@@ -12362,7 +11407,7 @@
desgv_()
; return 0; }
EOF
-if { (eval echo configure:12366: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11411: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12394,13 +11439,13 @@
echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:12398: checking for dgesv_ in -llapack" >&5
+echo "configure:11443: checking for dgesv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $BLASLIB $MATHLIB $LIBS"
-#line 12404 "configure"
+#line 11449 "configure"
@@ -12411,7 +11456,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:12415: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11460: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12430,13 +11475,13 @@
-echo "configure:12434: checking for dgesv_ in -llapack" >&5
+echo "configure:11479: checking for dgesv_ in -llapack" >&5
LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 12440 "configure"
+#line 11485 "configure"
@@ -12447,7 +11492,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:12451: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11496: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12503,7 +11548,7 @@
echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:12507: checking whether to use Cairo" >&5
+echo "configure:11552: checking whether to use Cairo" >&5
echo "$ac_t"""$with_cairo"" 1>&6
case "$with_cairo" in
"no") USE_CAIRO= ;;
@@ -12535,7 +11580,7 @@
echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:12539: checking for location of cairo includes" >&5
+echo "configure:11584: checking for location of cairo includes" >&5
case "$with_cairo_includes" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -12561,15 +11606,15 @@
do
-echo "configure:12565: checking for $ac_hdr" >&5
+echo "configure:11610: checking for $ac_hdr" >&5
-#line 12568 "configure"
+#line 11613 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12573: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11618: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12605,7 +11650,7 @@
echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:12609: checking for location of cairo library" >&5
+echo "configure:11654: checking for location of cairo library" >&5
case "$with_cairo_libs" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -12625,7 +11670,7 @@
echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:12629: checking for cairo linking flags" >&5
+echo "configure:11674: checking for cairo linking flags" >&5
case "$with_cairo_ldflags" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -12641,10 +11686,10 @@
LIBS=" $CAIROLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:12645: checking for cairo_create" >&5
+echo "configure:11690: checking for cairo_create" >&5
-#line 12648 "configure"
+#line 11693 "configure"
which can conflict with char cairo_create(); below. */
@@ -12667,7 +11712,7 @@
; return 0; }
EOF
-if { (eval echo configure:12671: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11716: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_create=yes"
else
@@ -12701,10 +11746,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:12705: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:11750: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 12708 "configure"
+#line 11753 "configure"
which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below. */
@@ -12727,7 +11772,7 @@
; return 0; }
EOF
-if { (eval echo configure:12731: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11776: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
else
@@ -12760,10 +11805,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:12764: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:11809: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 12767 "configure"
+#line 11812 "configure"
which can conflict with char cairo_xlib_surface_get_xrender_format(); below. */
@@ -12786,7 +11831,7 @@
; return 0; }
EOF
-if { (eval echo configure:12790: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11835: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
else
@@ -12828,7 +11873,7 @@
echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:12832: checking whether to use FreeType" >&5
+echo "configure:11877: checking whether to use FreeType" >&5
echo "$ac_t"""$with_freetype"" 1>&6
case "$with_freetype" in
"no") USE_FREETYPE= ;;
@@ -12847,7 +11892,7 @@
echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:12851: checking for location of FreeType includes" >&5
+echo "configure:11896: checking for location of FreeType includes" >&5
case "$with_freetype_includes" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -12873,15 +11918,15 @@
do
-echo "configure:12877: checking for $ac_hdr" >&5
+echo "configure:11922: checking for $ac_hdr" >&5
-#line 12880 "configure"
+#line 11925 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12885: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11930: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12915,7 +11960,7 @@
echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:12919: checking for location of FreeType library" >&5
+echo "configure:11964: checking for location of FreeType library" >&5
case "$with_freetype_libs" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -12940,13 +11985,13 @@
echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:12944: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:11989: checking for FT_Init_FreeType in -lfreetype" >&5
ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
LIBS="-lfreetype $LIBS"
-#line 12950 "configure"
+#line 11995 "configure"
@@ -12957,7 +12002,7 @@
FT_Init_FreeType()
; return 0; }
EOF
-if { (eval echo configure:12961: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12006: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12998,7 +12043,7 @@
echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:13002: checking whether to use NLS" >&5
+echo "configure:12047: checking whether to use NLS" >&5
echo "$ac_t"""$with_nls"" 1>&6
case "$with_nls" in
"no") USE_NLS= ;;
@@ -13018,10 +12063,10 @@
echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:13022: checking for gettext" >&5
+echo "configure:12067: checking for gettext" >&5
-#line 13025 "configure"
+#line 12070 "configure"
which can conflict with char gettext(); below. */
@@ -13044,7 +12089,7 @@
; return 0; }
EOF
-if { (eval echo configure:13048: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12093: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gettext=yes"
else
@@ -13062,13 +12107,13 @@
echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:13066: checking for gettext in -lintl" >&5
+echo "configure:12111: checking for gettext in -lintl" >&5
ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
LIBS="-lintl $LIBS"
-#line 13072 "configure"
+#line 12117 "configure"
@@ -13079,7 +12124,7 @@
gettext()
; return 0; }
EOF
-if { (eval echo configure:13083: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12128: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13114,7 +12159,7 @@
echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:13118: checking whether to use C++" >&5
+echo "configure:12163: checking whether to use C++" >&5
echo "$ac_t"""$with_cxx"" 1>&6
case "$with_cxx" in
"no") USE_CXX= ;;
@@ -13130,7 +12175,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:13134: checking for $ac_word" >&5
+echo "configure:12179: checking for $ac_word" >&5
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -13159,7 +12204,7 @@
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:13163: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:12208: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
ac_ext=C
# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -13170,12 +12215,12 @@
cat > conftest.$ac_ext << EOF
-#line 13174 "configure"
+#line 12219 "configure"
int main(){return(0);}
EOF
-if { (eval echo configure:13179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12224: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cxx_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -13201,19 +12246,19 @@
{ echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:13205: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:12250: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
cross_compiling=$ac_cv_prog_cxx_cross
echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:13210: checking whether we are using GNU C++" >&5
+echo "configure:12255: checking whether we are using GNU C++" >&5
cat > conftest.C <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:13217: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:12262: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gxx=yes
else
ac_cv_prog_gxx=no
@@ -13231,7 +12276,7 @@
ac_save_CXXFLAGS="$CXXFLAGS"
CXXFLAGS=
echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:13235: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:12280: checking whether ${CXX-g++} accepts -g" >&5
echo 'void f(){}' > conftest.cc
if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -13272,7 +12317,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:13276: checking whether to use openDWG" >&5
+echo "configure:12321: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -13292,7 +12337,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:13296: checking for location of openDGW includes" >&5
+echo "configure:12341: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -13318,15 +12363,15 @@
do
-echo "configure:13322: checking for $ac_hdr" >&5
+echo "configure:12367: checking for $ac_hdr" >&5
-#line 13325 "configure"
+#line 12370 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13330: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12375: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13360,7 +12405,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:13364: checking for location of openDWG library" >&5
+echo "configure:12409: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -13401,7 +12446,7 @@
echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:13405: checking whether to use POSIX threads" >&5
+echo "configure:12450: checking whether to use POSIX threads" >&5
echo "$ac_t"""$with_pthread"" 1>&6
case "$with_pthread" in
"no") USE_PTHREAD= ;;
@@ -13421,7 +12466,7 @@
echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:13425: checking for location of POSIX threads includes" >&5
+echo "configure:12470: checking for location of POSIX threads includes" >&5
case "$with_pthread_includes" in
{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -13447,15 +12492,15 @@
do
-echo "configure:13451: checking for $ac_hdr" >&5
+echo "configure:12496: checking for $ac_hdr" >&5
-#line 13454 "configure"
+#line 12499 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13459: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12504: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13489,7 +12534,7 @@
echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:13493: checking for location of POSIX threads library" >&5
+echo "configure:12538: checking for location of POSIX threads library" >&5
case "$with_pthread_libs" in
{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -13514,10 +12559,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:13518: checking for pthread_create" >&5
+echo "configure:12563: checking for pthread_create" >&5
-#line 13521 "configure"
+#line 12566 "configure"
which can conflict with char pthread_create(); below. */
@@ -13540,7 +12585,7 @@
; return 0; }
EOF
-if { (eval echo configure:13544: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12589: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_pthread_create=yes"
else
@@ -13567,13 +12612,13 @@
echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:13571: checking for pthread_create in -lpthread" >&5
+echo "configure:12616: checking for pthread_create in -lpthread" >&5
ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
LIBS="-lpthread $LIBS"
-#line 13577 "configure"
+#line 12622 "configure"
@@ -13584,7 +12629,7 @@
pthread_create()
; return 0; }
EOF
-if { (eval echo configure:13588: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12633: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13634,7 +12679,7 @@
echo $ac_n "checking whether to use OpenMP""... $ac_c" 1>&6
-echo "configure:13638: checking whether to use OpenMP" >&5
+echo "configure:12683: checking whether to use OpenMP" >&5
echo "$ac_t"""$with_openmp"" 1>&6
case "$with_openmp" in
"no") USE_OPENMP= ;;
@@ -13655,7 +12700,7 @@
echo $ac_n "checking for location of OpenMP includes""... $ac_c" 1>&6
-echo "configure:13659: checking for location of OpenMP includes" >&5
+echo "configure:12704: checking for location of OpenMP includes" >&5
case "$with_openmp_includes" in
{ echo "configure: error: *** You must supply a directory to --with-openmp-includes." 1>&2; exit 1; }
@@ -13681,15 +12726,15 @@
do
-echo "configure:13685: checking for $ac_hdr" >&5
+echo "configure:12730: checking for $ac_hdr" >&5
-#line 13688 "configure"
+#line 12733 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13693: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12738: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13727,7 +12772,7 @@
echo $ac_n "checking for location of OpenMP library""... $ac_c" 1>&6
-echo "configure:13731: checking for location of OpenMP library" >&5
+echo "configure:12776: checking for location of OpenMP library" >&5
case "$with_gomp_libs" in
{ echo "configure: error: *** You must supply a directory to --with-gomp-libs." 1>&2; exit 1; }
@@ -13752,10 +12797,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for GOMP_parallel_start""... $ac_c" 1>&6
-echo "configure:13756: checking for GOMP_parallel_start" >&5
+echo "configure:12801: checking for GOMP_parallel_start" >&5
-#line 13759 "configure"
+#line 12804 "configure"
which can conflict with char GOMP_parallel_start(); below. */
@@ -13778,7 +12823,7 @@
; return 0; }
EOF
-if { (eval echo configure:13782: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12827: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_GOMP_parallel_start=yes"
else
@@ -13805,13 +12850,13 @@
echo $ac_n "checking for GOMP_parallel_start in -lgomp""... $ac_c" 1>&6
-echo "configure:13809: checking for GOMP_parallel_start in -lgomp" >&5
+echo "configure:12854: checking for GOMP_parallel_start in -lgomp" >&5
ac_lib_var=`echo gomp'_'GOMP_parallel_start | sed 'y%./+-%__p_%'`
LIBS="-lgomp $LIBS"
-#line 13815 "configure"
+#line 12860 "configure"
@@ -13822,7 +12867,7 @@
; return 0; }
EOF
-if { (eval echo configure:13826: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12871: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13901,7 +12946,7 @@
if test "$enable_largefile" = yes; then
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:13905: checking for special C compiler options needed for large files" >&5
+echo "configure:12950: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -13909,7 +12954,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 13913 "configure"
+#line 12958 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -13925,7 +12970,7 @@
; return 0; }
EOF
-if { (eval echo configure:13929: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12974: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
@@ -13934,7 +12979,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 13938 "configure"
+#line 12983 "configure"
@@ -13950,7 +12995,7 @@
; return 0; }
EOF
-if { (eval echo configure:13954: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12999: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -13970,11 +13015,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:13974: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:13019: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 13978 "configure"
+#line 13023 "configure"
@@ -13990,14 +13035,14 @@
; return 0; }
EOF
-if { (eval echo configure:13994: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13039: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 14001 "configure"
+#line 13046 "configure"
#define _FILE_OFFSET_BITS 64
@@ -14015,7 +13060,7 @@
; return 0; }
EOF
-if { (eval echo configure:14019: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13064: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -14034,11 +13079,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:14038: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:13083: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 14042 "configure"
+#line 13087 "configure"
@@ -14054,14 +13099,14 @@
; return 0; }
EOF
-if { (eval echo configure:14058: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13103: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 14065 "configure"
+#line 13110 "configure"
#define _LARGE_FILES 1
@@ -14079,7 +13124,7 @@
; return 0; }
EOF
-if { (eval echo configure:14083: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13128: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -14098,25 +13143,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:14102: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13147: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 14106 "configure"
+#line 13151 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:14113: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13158: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 14120 "configure"
+#line 13165 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -14125,7 +13170,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:14129: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13174: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -14146,25 +13191,25 @@
fi
-echo "configure:14150: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13195: checking for _LARGEFILE_SOURCE value needed for large files" >&5
-#line 14154 "configure"
+#line 13199 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:14161: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13206: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 14168 "configure"
+#line 13213 "configure"
#include <stdio.h>
@@ -14173,7 +13218,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:14177: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13222: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
else
@@ -14196,18 +13241,18 @@
# If you want fseeko and ftello with glibc, upgrade to a fixed glibc.
echo $ac_n "checking for fseeko""... $ac_c" 1>&6
-echo "configure:14200: checking for fseeko" >&5
+echo "configure:13245: checking for fseeko" >&5
ac_cv_func_fseeko=no
-#line 14204 "configure"
+#line 13249 "configure"
#include <stdio.h>
int main() {
return fseeko && fseeko (stdin, 0, 0);
; return 0; }
EOF
-if { (eval echo configure:14211: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13256: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_func_fseeko=yes
else
@@ -14224,10 +13269,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:14228: checking if system supports Large Files at all" >&5
+echo "configure:13273: checking if system supports Large Files at all" >&5
-#line 14231 "configure"
+#line 13276 "configure"
#include <stdio.h>
@@ -14259,7 +13304,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:14263: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13308: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -14288,7 +13333,7 @@
# Enable wxWidgets support (for wxGUI)
echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:14292: checking whether to use wxWidgets" >&5
+echo "configure:13337: checking whether to use wxWidgets" >&5
WXVERSION=
WXWIDGETSCXXFLAGS=
@@ -14309,7 +13354,7 @@
# Extract the first word of "wx-config", so it can be a program name with args.
set dummy wx-config; ac_word=$2
-echo "configure:14313: checking for $ac_word" >&5
+echo "configure:13358: checking for $ac_word" >&5
case "$WX_CONFIG" in
@@ -14357,7 +13402,7 @@
REQWX="2.8.1"
echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:14361: checking wxWidgets version" >&5
+echo "configure:13406: checking wxWidgets version" >&5
if WXVERSION=`"$WX_CONFIG" --version`; then
echo "$ac_t""$WXVERSION" 1>&6
else
@@ -14380,15 +13425,15 @@
do
-echo "configure:14384: checking for $ac_hdr" >&5
+echo "configure:13429: checking for $ac_hdr" >&5
-#line 14387 "configure"
+#line 13432 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14392: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13437: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14687,12 +13732,6 @@
s%@OPENGLINC@%$OPENGLINC%g
s%@OPENGLLIB@%$OPENGLLIB%g
s%@OPENGLULIB@%$OPENGLULIB%g
-s%@USE_TCLTK@%$USE_TCLTK%g
-s%@TCLINCDIR@%$TCLINCDIR%g
-s%@TKINCDIR@%$TKINCDIR%g
-s%@TCLTKLIBPATH@%$TCLTKLIBPATH%g
-s%@TCLTKLIBS@%$TCLTKLIBS%g
-s%@MACOSX_ARCHS_TCLTK@%$MACOSX_ARCHS_TCLTK%g
s%@ODBCINC@%$ODBCINC%g
s%@ODBCLIB@%$ODBCLIB%g
s%@FFTWINC@%$FFTWINC%g
@@ -14962,12 +14001,7 @@
# Display configuration status
-USE_TOGL=
-if test -n "${USE_TCLTK}" -a -n "${USE_OPENGL}" ; then
- USE_TOGL="1"
-fi
echo ""
@@ -14977,29 +14011,28 @@
echo ""
-echo " Source directory: ${SRCDIR}"
+echo " Source directory: ${SRCDIR}"
-echo " Build directory: ${DSTDIR}"
+echo " Build directory: ${DSTDIR}"
-echo " Installation directory: ${INSTDIR}"
+echo " Installation directory: ${INSTDIR}"
-echo " Startup script in directory: ${bindir}"
+echo " Startup script in directory:${bindir}"
-echo " C compiler: ${CC} ${CFLAGS}"
+echo " C compiler: ${CC} ${CFLAGS}"
-echo " C++ compiler: ${CXX} ${CXXFLAGS}"
+echo " C++ compiler: ${CXX} ${CXXFLAGS}"
-#LOC_MSG([ FORTRAN compiler: ${F77} ${FFLAGS}])
-echo " Building shared libraries: ${shared_ok}"
+echo " Building shared libraries: ${shared_ok}"
-echo " OpenGL platform: ${OPENGL_TYPE}"
+echo " OpenGL platform: ${OPENGL_TYPE}"
echo ""
@@ -15016,11 +14049,6 @@
echo ""
-echo " Tcl/Tk NVIZ: `if test -n "${USE_TOGL}" ; then echo yes ; else echo no ; fi`"
-echo ""
echo " BLAS support: `if test -n "${USE_BLAS}" ; then echo yes ; else echo no ; fi`"
echo " C++ support: `if test -n "${USE_CXX}" ; then echo yes ; else echo no ; fi`"
@@ -15073,8 +14101,6 @@
echo " TIFF support: `if test -n "${USE_TIFF}" ; then echo yes ; else echo no ; fi`"
-echo " Tcl/Tk support: `if test -n "${USE_TCLTK}" ; then echo yes ; else echo no ; fi`"
echo " wxWidgets support: `if test -n "${USE_WXWIDGETS}" ; then echo yes ; else echo no ; fi`"
echo " X11 support: `if test -n "${USE_X11}" ; then echo yes ; else echo no ; fi`"
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in 2012-11-09 14:46:53 UTC (rev 53752)
+++ grass/trunk/configure.in 2012-11-09 14:52:34 UTC (rev 53753)
@@ -8,7 +8,7 @@
# PURPOSE: This configure runs all the tests to determine what components
# are installed on the current system. It also defines certain
# configuration variables for compilation and installation.
-# COPYRIGHT: (C) 2000-2009, 2011 by the GRASS Development Team
+# COPYRIGHT: (C) 2000-2009, 2011-2012 by the GRASS Development Team
# This program is free software under the GNU General
# Public License (>=v2). Read the file COPYING that
@@ -246,7 +246,6 @@
compile with a system SDK on MacOSX. (default: no)],, with_macosx_sdk="no")
LOC_ARG_WITH(tiff, TIFF)
LOC_ARG_WITH(png, PNG)
-LOC_ARG_WITH(tcltk, Tcl/Tk)
LOC_ARG_WITH(postgres, PostgreSQL, no)
LOC_ARG_WITH(mysql, MySQL, no)
LOC_ARG_WITH(sqlite, SQLite, no)
@@ -314,9 +313,6 @@
LOC_ARG_WITH_INC(png, PNG)
LOC_ARG_WITH_LIB(png, PNG)
-LOC_ARG_WITH_INC(tcltk, Tcl/Tk)
-LOC_ARG_WITH_LIB(tcltk, Tcl/Tk)
LOC_ARG_WITH_INC(postgres, PostgreSQL)
LOC_ARG_WITH_LIB(postgres, PostgreSQL)
@@ -1274,114 +1270,6 @@
# Done checking OpenGL
-# Enable TCLTK option
-LOC_CHECK_USE(tcltk,Tcl/Tk,USE_TCLTK)
-TCLINCDIR=
-TCLTKLIBPATH=
-TCLTKLIBS=
-if test -n "$USE_TCLTK"; then
-# With Tcl/Tk includes directory
-LOC_CHECK_INC_PATH(tcltk,Tcl/Tk,TCLINCDIR)
-LOC_CHECK_INCLUDES(tcl.h,Tcl,$TCLINCDIR)
-LOC_CHECK_INCLUDES(tk.h,Tk,$TCLINCDIR $X_CFLAGS)
-LOC_CHECK_VERSION_STRING(tcl.h,TCL_VERSION,Tcl,tcl_ver,$TCLINCDIR,UNKNOWN)
-LOC_CHECK_VERSION_STRING(tk.h,TK_VERSION,Tk,tk_ver,$TCLINCDIR $X_CFLAGS,UNKNOWN)
-else
- AC_MSG_ERROR([*** Tcl/Tk version mismatch.])
-fi
-LOC_CHECK_LIB_PATH(tcltk,Tcl/Tk,TCLTKLIBPATH)
-TCLLIB=
-TKLIB=
-fi
-LOC_CHECK_LIBS(tcl, Tcl_Init,Tcl,$TCLTKLIBPATH,TCLLIB,,$MATHLIB,[
-LOC_CHECK_LIBS(tcl$tcltk_ver, Tcl_Init,Tcl,$TCLTKLIBPATH,TCLLIB,,$MATHLIB,[
-LOC_CHECK_LIBS(tcl$tcltk_ver2,Tcl_Init,Tcl,$TCLTKLIBPATH,TCLLIB,,$MATHLIB,[
-],$DLLIB)
-],$DLLIB)
-],$DLLIB)
-LOC_CHECK_LIBS(tk, Tk_MainWindow,Tk,$TCLTKLIBPATH,TKLIB,$TCLLIB,$MATHLIB,[
-LOC_CHECK_LIBS(tk$tcltk_ver, Tk_MainWindow,Tk,$TCLTKLIBPATH,TKLIB,$TCLLIB,$MATHLIB,[
-LOC_CHECK_LIBS(tk$tcltk_ver2,Tk_MainWindow,Tk,$TCLTKLIBPATH,TKLIB,$TCLLIB,$MATHLIB,[
-],$X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS)
-fi
- LDFLAGS=
- CFLAGS=
- do
- AC_CHECK_LIB($tlib, Tcl_Init, [
- fi
- ],, -arch $a $MACOSX_SDK $TCLTKLIBPATH)
- done
-fi
-AC_DEFINE(HAVE_TCLTK)
-fi # $USE_TCLTK
-AC_SUBST(USE_TCLTK)
-AC_SUBST(TCLINCDIR)
-AC_SUBST(TKINCDIR)
-AC_SUBST(TCLTKLIBPATH)
-AC_SUBST(TCLTKLIBS)
-AC_SUBST(MACOSX_ARCHS_TCLTK)
LOC_CHECK_USE(odbc,ODBC,USE_ODBC)
@@ -1986,30 +1874,22 @@
-USE_TOGL=
- USE_TOGL="1"
-fi
LOC_MSG()
LOC_MSG([GRASS is now configured for: ${host}])
LOC_MSG()
-LOC_MSG([ Source directory: ${SRCDIR}])
-LOC_MSG([ Build directory: ${DSTDIR}])
-LOC_MSG([ Installation directory: ${INSTDIR}])
-LOC_MSG([ Startup script in directory: ${bindir}])
-LOC_MSG([ C compiler: ${CC} ${CFLAGS}])
-LOC_MSG([ C++ compiler: ${CXX} ${CXXFLAGS}])
-LOC_MSG([ Building shared libraries: ${shared_ok}])
-LOC_MSG([ OpenGL platform: ${OPENGL_TYPE}])
+LOC_MSG([ Source directory: ${SRCDIR}])
+LOC_MSG([ Build directory: ${DSTDIR}])
+LOC_MSG([ Installation directory: ${INSTDIR}])
+LOC_MSG([ Startup script in directory:${bindir}])
+LOC_MSG([ C compiler: ${CC} ${CFLAGS}])
+LOC_MSG([ C++ compiler: ${CXX} ${CXXFLAGS}])
+LOC_MSG([ Building shared libraries: ${shared_ok}])
+LOC_MSG([ OpenGL platform: ${OPENGL_TYPE}])
LOC_MSG()
LOC_MSG_USE(MacOSX application,MACOSX_APP)
LOC_MSG([ MacOSX architectures: ${MACOSX_ARCHS}])
LOC_MSG([ MacOSX SDK: ${MACOSX_SDK}])
LOC_MSG()
-LOC_MSG_USE(Tcl/Tk NVIZ,USE_TOGL)
-LOC_MSG()
LOC_MSG_USE(BLAS support,USE_BLAS)
LOC_MSG_USE(C++ support,USE_CXX)
LOC_MSG_USE(Cairo support,USE_CAIRO)
@@ -2036,7 +1916,6 @@
LOC_MSG_USE(Regex support,USE_REGEX)
LOC_MSG_USE(SQLite support,USE_SQLITE)
LOC_MSG_USE(TIFF support,USE_TIFF)
-LOC_MSG_USE(Tcl/Tk support,USE_TCLTK)
LOC_MSG_USE(wxWidgets support,USE_WXWIDGETS)
LOC_MSG_USE(X11 support,USE_X11)
LOC_MSG()
Modified: grass/trunk/include/Make/Platform.make.in
--- grass/trunk/include/Make/Platform.make.in 2012-11-09 14:46:53 UTC (rev 53752)
+++ grass/trunk/include/Make/Platform.make.in 2012-11-09 14:52:34 UTC (rev 53753)
@@ -149,14 +149,6 @@
OPENGL_WINDOWS = @OPENGL_WINDOWS@
USE_OPENGL = @USE_OPENGL@
-#tcl/tk stuff
-TCLINCDIR = @TCLINCDIR@
-TKINCDIR = @TKINCDIR@
-TCLTKLIBPATH = @TCLTKLIBPATH@
-TCLTKLIBS = @TCLTKLIBS@
-USE_TCLTK = @USE_TCLTK@
-MACOSX_ARCHS_TCLTK = @MACOSX_ARCHS_TCLTK@
#FFTW:
FFTWINC = @FFTWINC@
FFTWLIB = @FFTWLIB@
