[GRASS-SVN] r53764 - grass/trunk/vector/v.buffer
svn_grass at osgeo.org
Fri Nov 9 22:48:48 PST 2012
Author: mmetz
Date: 2012-11-09 22:48:48 -0800 (Fri, 09 Nov 2012)
New Revision: 53764
grass/trunk/vector/v.buffer/main.c
v.buffer: fix cats parsing
Modified: grass/trunk/vector/v.buffer/main.c
--- grass/trunk/vector/v.buffer/main.c 2012-11-10 06:48:28 UTC (rev 53763)
+++ grass/trunk/vector/v.buffer/main.c 2012-11-10 06:48:48 UTC (rev 53764)
@@ -191,7 +191,7 @@
/* parse filter options */
/* return cat list or NULL */
struct cat_list *parse_filter_options(struct Map_info *Map, int layer,
- char *where, char *cats)
+ char *where, char *catstr)
struct cat_list *list = NULL;
@@ -203,7 +203,7 @@
if (layer < 1)
G_fatal_error(_("'%s' must be > 0 for '%s'"), "layer", "where");
- if (cats)
+ if (catstr)
G_warning(_("'where' and 'cats' parameters were supplied, cat will be ignored"));
Fi = Vect_get_field(Map, layer);
@@ -248,15 +248,13 @@
if (cats)
G_free(cats);
- else if (cats) {
+ else if (catstr) {
if (layer < 1)
G_fatal_error(_("'%s' must be > 0 for '%s'"), "layer", GV_KEY_COLUMN);
list = Vect_new_cat_list();
- if (Vect_str_to_cat_list(cats, list) > 0) {
+ if (Vect_str_to_cat_list(catstr, list) > 0) {
G_warning(_("Problem loading category values"));
