[GRASS-SVN] r53795 - in grass/trunk/raster3d: . r3.out.bin
svn_grass at osgeo.org
Tue Nov 13 15:47:32 PST 2012
Author: huhabla
Date: 2012-11-13 15:47:32 -0800 (Tue, 13 Nov 2012)
New Revision: 53795
Added:
grass/trunk/raster3d/r3.out.bin/
grass/trunk/raster3d/r3.out.bin/Makefile
grass/trunk/raster3d/r3.out.bin/main.c
grass/trunk/raster3d/r3.out.bin/r3.out.bin.html
grass/trunk/raster3d/Makefile
New module to export a 3D raster map as binary array
Modified: grass/trunk/raster3d/Makefile
--- grass/trunk/raster3d/Makefile 2012-11-13 21:31:10 UTC (rev 53794)
+++ grass/trunk/raster3d/Makefile 2012-11-13 23:47:32 UTC (rev 53795)
@@ -10,6 +10,7 @@
r3.mkdspf \
r3.null \
r3.out.ascii \
+ r3.out.bin \
r3.out.netcdf \
r3.out.v5d \
r3.out.vtk \
Added: grass/trunk/raster3d/r3.out.bin/Makefile
--- grass/trunk/raster3d/r3.out.bin/Makefile (rev 0)
+++ grass/trunk/raster3d/r3.out.bin/Makefile 2012-11-13 23:47:32 UTC (rev 53795)
@@ -0,0 +1,10 @@
+MODULE_TOPDIR = ../..
+PGM = r3.out.bin
+LIBES = $(RASTERLIB) $(RASTER3DLIB) $(GISLIB)
+DEPENDENCIES = $(RASTERDEP) $(RASTER3DDEP) $(GISDEP)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Added: grass/trunk/raster3d/r3.out.bin/main.c
--- grass/trunk/raster3d/r3.out.bin/main.c (rev 0)
+++ grass/trunk/raster3d/r3.out.bin/main.c 2012-11-13 23:47:32 UTC (rev 53795)
@@ -0,0 +1,275 @@
+ * MODULE: r3.out.bin
+ * AUTHOR(S): Soeren Gebbert
+ * Based on r.out.bin from: Bob Covill and Glynn Clements
+ * PURPOSE: Exports a GRASS 3D raster map to a binary array.
+ * COPYRIGHT: (C) 2012 by the GRASS Development Team
+ * This program is free software under the GNU General Public
+ * License (>=v2). Read the file COPYING that comes with GRASS
+ * for details.
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/raster.h>
+#include <grass/raster3d.h>
+#include <grass/glocale.h>
+RASTER3D_Map *map;
+RASTER3D_Region region;
+static void swap_4(void *p) {
+ unsigned char *q = p;
+ unsigned char t;
+ t = q[0];
+ q[0] = q[3];
+ q[3] = t;
+ t = q[1];
+ q[1] = q[2];
+ q[2] = t;
+static void swap_8(void *p) {
+ unsigned char t;
+ t = q[0];
+ q[0] = q[7];
+ q[7] = t;
+ t = q[1];
+ q[1] = q[6];
+ q[6] = t;
+ t = q[2];
+ q[2] = q[5];
+ q[5] = t;
+ t = q[3];
+ q[3] = q[4];
+ q[4] = t;
+static void write_float(FILE *fp, int swap_flag, float x) {
+ if (swap_flag)
+ swap_4(&x);
+ if (fwrite(&x, 4, 1, fp) != 1)
+ G_fatal_error(_("Error writing data"));
+static void write_double(FILE *fp, int swap_flag, double x) {
+ if (swap_flag)
+ swap_8(&x);
+ if (fwrite(&x, 8, 1, fp) != 1)
+void raster3d_to_bin(FILE * fp, DCELL null_value, int byte_swap, int row_swap,
+ int depth_swap) {
+ DCELL dvalue;
+ FCELL fvalue;
+ int x, y, z;
+ int rows, cols, depths, typeIntern;
+ int col, row, depth;
+ rows = region.rows;
+ cols = region.cols;
+ depths = region.depths;
+ typeIntern = Rast3d_tile_type_map(map);
+ for (z = 0; z < depths; z++) {
+ G_percent(z, depths, 1);
+ for (y = 0; y < rows; y++) { /* g3d rows count from south to north */
+ for (x = 0; x < cols; x++) {
+ /* From west to east */
+ col = x;
+ /* The default is to write rows from north to south
+ to be r.in.ascii compatible
+ row = y;
+ /* From bottom to the top */
+ depth = z;
+ /* Write rows from south to north */
+ if (row_swap)
+ row = rows - y - 1;
+ /* write XY layer from top to bottom */
+ if (depth_swap)
+ depth = depths - z - 1;
+ if (typeIntern == FCELL_TYPE) {
+ Rast3d_get_value(map, col, row, depth, &fvalue, FCELL_TYPE);
+ if (Rast3d_is_null_value_num(&fvalue, FCELL_TYPE))
+ write_float(fp, byte_swap, (float)null_value);
+ else
+ write_float(fp, byte_swap, fvalue);
+ } else {
+ Rast3d_get_value(map, col, row, depth, &dvalue, DCELL_TYPE);
+ if (Rast3d_is_null_value_num(&dvalue, DCELL_TYPE))
+ write_double(fp, byte_swap, null_value);
+ else
+ write_double(fp, byte_swap, dvalue);
+ G_percent(1, 1, 1);
+ G_percent_reset();
+int main(int argc, char *argv[]) {
+ struct GModule *module;
+ struct {
+ struct Option *input;
+ struct Option *output;
+ struct Option *null;
+ struct Option *order;
+ } parm;
+ struct {
+ struct Flag *swap, *row, *depth;
+ } flag;
+ char *name;
+ char *outfile;
+ double null_val;
+ int do_stdout;
+ int order;
+ int swap_flag;
+ FILE *fp;
+ G_gisinit(argv[0]);
+ module = G_define_module();
+ G_add_keyword(_("3D raster"));
+ G_add_keyword(_("export"));
+ module->description = _("Exports a GRASS 3D raster map to a binary array.");
+ /* Define the different options */
+ parm.input = G_define_standard_option(G_OPT_R3_INPUT);
+ parm.output = G_define_standard_option(G_OPT_F_OUTPUT);
+ parm.null = G_define_option();
+ parm.null->key = "null";
+ parm.null->type = TYPE_DOUBLE;
+ parm.null->required = NO;
+ parm.null->answer = "0";
+ parm.null->description = _("Value to write out for null");
+ parm.order = G_define_option();
+ parm.order->key = "order";
+ parm.order->type = TYPE_STRING;
+ parm.order->required = NO;
+ parm.order->options = "big,little,native,swap";
+ parm.order->description = _("Output byte order");
+ parm.order->answer = "native";
+ flag.swap = G_define_flag();
+ flag.swap->key = 's';
+ flag.swap->description = _("Byte swap output");
+ flag.row = G_define_flag();
+ flag.row->key = 'r';
+ flag.row->description = _("Switch the row order in output from "
+ "north->south to south->north");
+ flag.depth = G_define_flag();
+ flag.depth->key = 'd';
+ flag.depth->description = _("Switch the depth order in output "
+ "from bottom->top to top->bottom");
+ if (G_parser(argc, argv))
+ exit(EXIT_FAILURE);
+ if (sscanf(parm.null->answer, "%lf", &null_val) != 1)
+ G_fatal_error(_("Invalid value for null (integers only)"));
+ name = parm.input->answer;
+ if (parm.output->answer)
+ outfile = parm.output->answer;
+ else {
+ outfile = G_malloc(strlen(name) + 4 + 1);
+ G_snprintf(outfile, sizeof(outfile), "%s.bin", name);
+ if (G_strcasecmp(parm.order->answer, "big") == 0)
+ order = 0;
+ else if (G_strcasecmp(parm.order->answer, "little") == 0)
+ order = 1;
+ else if (G_strcasecmp(parm.order->answer, "native") == 0)
+ order = G_is_little_endian() ? 1 : 0;
+ else if (G_strcasecmp(parm.order->answer, "swap") == 0)
+ order = G_is_little_endian() ? 0 : 1;
+ if (flag.swap->answer) {
+ if (strcmp(parm.order->answer, "native") != 0)
+ G_fatal_error(_("order= and -s are mutually exclusive"));
+ swap_flag = order == (G_is_little_endian() ? 0 : 1);
+ do_stdout = strcmp("-", outfile) == 0;
+ if (NULL == G_find_raster3d(parm.input->answer, ""))
+ Rast3d_fatal_error(_("3D raster map <%s> not found"),
+ parm.input->answer);
+ /* Initiate the default settings */
+ Rast3d_init_defaults();
+ /* Figure out the current region settings */
+ Rast3d_get_window(®ion);
+ /* Open the map and use XY cache mode */
+ map = Rast3d_open_cell_old(parm.input->answer,
+ G_find_raster3d(parm.input->answer, ""), ®ion,
+ RASTER3D_TILE_SAME_AS_FILE, RASTER3D_USE_CACHE_DEFAULT);
+ if (map == NULL)
+ Rast3d_fatal_error(_("Error opening 3d raster map <%s>"),
+ /* open bin file for writing */
+ if (do_stdout)
+ fp = stdout;
+ else if (NULL == (fp = fopen(outfile, "w")))
+ G_fatal_error(_("Unable to create file <%s>"), outfile);
+ G_verbose_message(_("Using the current region settings..."));
+ G_verbose_message(_("north=%f"), region.north);
+ G_verbose_message(_("south=%f"), region.south);
+ G_verbose_message(_("east=%f"), region.east);
+ G_verbose_message(_("west=%f"), region.west);
+ G_verbose_message(_("top=%f"), region.top);
+ G_verbose_message(_("bottom=%f"), region.bottom);
+ G_verbose_message(_("rows=%d"), region.rows);
+ G_verbose_message(_("cols=%d"), region.cols);
+ G_verbose_message(_("depths=%d"), region.depths);
+ raster3d_to_bin(fp, null_val, swap_flag, flag.row->answer,
+ flag.depth->answer);
+ Rast3d_close(map);
+ fclose(fp);
+ return EXIT_SUCCESS;
Added: grass/trunk/raster3d/r3.out.bin/r3.out.bin.html
--- grass/trunk/raster3d/r3.out.bin/r3.out.bin.html (rev 0)
+++ grass/trunk/raster3d/r3.out.bin/r3.out.bin.html 2012-11-13 23:47:32 UTC (rev 53795)
@@ -0,0 +1,23 @@
+<h2>DESCRIPTION</h2>
+The <em>r3.out.bin</em> program exports a GRASS 3D raster map to a binary array
+file. Optionally, output can be sent to standard output (stdout) for direct
+input (pipe) into other applications. Data is exported according to the
+original GRASS 3D raster type (float, double).
+<h2>NOTES</h2>
+The write order of the rows (north->south to south->north) and
+the write order of the depths (bottom->top to top->bottom) can be switched.
+<p>
+The region parameters are printed to stderr when setting the verbose flag.
+Export of little and big endian byte order is supported.
+<h2>SEE ALSO</h2>
+<em><a href="r.out.bin.html">r.out.bin</a>,
+<a href="r3.out.ascii.html">r3.out.bin</a></em>
+<h2>AUTHOR</h2>
+Sören Gebbert, based on r.out.bin from Bob Covill and Glynn Clements
