[GRASS-SVN] r53798 - grass/trunk/gui/wxpython
svn_grass at osgeo.org
Wed Nov 14 01:34:11 PST 2012
Author: martinl
Date: 2012-11-14 01:34:11 -0800 (Wed, 14 Nov 2012)
New Revision: 53798
grass/trunk/gui/wxpython/gis_set.py
wxGUI/gis_set: welcome screen - location or mapset doesn't exists
Modified: grass/trunk/gui/wxpython/gis_set.py
--- grass/trunk/gui/wxpython/gis_set.py 2012-11-14 07:20:30 UTC (rev 53797)
+++ grass/trunk/gui/wxpython/gis_set.py 2012-11-14 09:34:11 UTC (rev 53798)
@@ -39,7 +39,7 @@
import wx.lib.scrolledpanel as scrolled
from gui_core.ghelp import HelpFrame
-from core.gcmd import GMessage, GError, DecodeString, RunCommand
+from core.gcmd import GMessage, GError, DecodeString, RunCommand, GWarning
from core.utils import GetListOfLocations, GetListOfMapsets
from location_wizard.dialogs import RegionDef
@@ -215,29 +215,35 @@
if location == "<UNKNOWN>" or \
not os.path.isdir(os.path.join(self.gisdbase, location)):
location = None
- if location:
- # list of locations
- self.UpdateLocations(self.gisdbase)
+ # list of locations
+ self.UpdateLocations(self.gisdbase)
+ try:
+ self.lblocations.SetSelection(self.listOfLocations.index(location),
+ force = True)
+ self.lblocations.EnsureVisible(self.listOfLocations.index(location))
+ except ValueError:
+ sys.stderr.write(_("ERROR: Location <%s> not found\n") % self.GetRCValue("LOCATION_NAME"))
+ if len(self.listOfLocations) > 0:
+ self.lblocations.SetSelection(0, force = True)
+ self.lblocations.EnsureVisible(0)
+ location = self.listOfLocations[0]
+ else:
+ return
+ # list of mapsets
+ self.UpdateMapsets(os.path.join(self.gisdbase, location))
+ mapset = self.GetRCValue("MAPSET")
+ if mapset:
try:
- self.lblocations.SetSelection(self.listOfLocations.index(location),
- force = True)
- self.lblocations.EnsureVisible(self.listOfLocations.index(location))
+ self.lbmapsets.SetSelection(self.listOfMapsets.index(mapset),
+ force = True)
+ self.lbmapsets.EnsureVisible(self.listOfMapsets.index(mapset))
except ValueError:
- print >> sys.stderr, _("ERROR: Location <%s> not found") % location
- # list of mapsets
- self.UpdateMapsets(os.path.join(self.gisdbase, location))
- mapset = self.GetRCValue("MAPSET")
- if mapset:
- try:
- self.lbmapsets.SetSelection(self.listOfMapsets.index(mapset),
- force = True)
- self.lbmapsets.EnsureVisible(self.listOfMapsets.index(mapset))
- except ValueError:
- self.lbmapsets.Clear()
- print >> sys.stderr, _("ERROR: Mapset <%s> not found") % mapset
+ sys.stderr.write(_("ERROR: Mapset <%s> not found\n") % mapset)
+ self.lbmapsets.SetSelection(0, force = True)
+ self.lbmapsets.EnsureVisible(0)
def _do_layout(self):
sizer = wx.BoxSizer(wx.VERTICAL)
dbase_sizer = wx.BoxSizer(wx.HORIZONTAL)
