[GRASS-SVN] r53808 - in grass/trunk/gui/wxpython: lmgr modules
    svn_grass at osgeo.org
    Wed Nov 14 08:00:31 PST 2012
Author: martinl
Date: 2012-11-14 08:00:31 -0800 (Wed, 14 Nov 2012)
New Revision: 53808
   grass/trunk/gui/wxpython/lmgr/frame.py
   grass/trunk/gui/wxpython/lmgr/layertree.py
   grass/trunk/gui/wxpython/modules/colorrules.py
wxGUI/layertree: show color rules dialog
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py	2012-11-14 15:31:51 UTC (rev 53807)
+++ grass/trunk/gui/wxpython/lmgr/frame.py	2012-11-14 16:00:31 UTC (rev 53808)
@@ -1231,16 +1231,17 @@
     def OnRasterRules(self, event):
         """!Launches dialog for raster color rules
-        ctable = RasterColorTable(self)
+        ctable = RasterColorTable(self, layerTree = self.GetLayerTree())
+        ctable.Show()
         ctable.CentreOnScreen()
-        ctable.Show()
     def OnVectorRules(self, event):
         """!Launches dialog for vector color rules
-        ctable = VectorColorTable(self, attributeType = 'color')
+        ctable = VectorColorTable(self, layerTree = self.GetLayerTree(),
+                                  attributeType = 'color')
+        ctable.Show()
-        ctable.Show()
     def OnEditImageryGroups(self, event, cmd = None):
         """!Show dialog for creating and editing groups.
Modified: grass/trunk/gui/wxpython/lmgr/layertree.py
--- grass/trunk/gui/wxpython/lmgr/layertree.py	2012-11-14 15:31:51 UTC (rev 53807)
+++ grass/trunk/gui/wxpython/lmgr/layertree.py	2012-11-14 16:00:31 UTC (rev 53808)
@@ -43,6 +43,7 @@
 from core.gcmd           import GWarning, GError
 from gui_core.toolbars   import BaseIcons
 from icons.icon          import MetaIcon
+from modules.colorrules  import RasterColorTable
 TREE_ITEM_HEIGHT = 25
@@ -587,8 +588,10 @@
     def OnRasterColorTable(self, event):
         """!Set color table for raster map"""
         name = self.GetPyData(self.layer_selected)[0]['maplayer'].GetName()
-        GUI(parent = self, centreOnParent = False).ParseCommand(['r.colors',
-        'map=%s' % name])
+        ctable = RasterColorTable(self, layerTree = self)
+        ctable.SetMap(name)
+        ctable.Show()
+        ctable.CentreOnScreen()
     def OnVectorColorTable(self, event):
         """!Set color table for vector map"""
Modified: grass/trunk/gui/wxpython/modules/colorrules.py
--- grass/trunk/gui/wxpython/modules/colorrules.py	2012-11-14 15:31:51 UTC (rev 53807)
+++ grass/trunk/gui/wxpython/modules/colorrules.py	2012-11-14 16:00:31 UTC (rev 53808)
@@ -12,13 +12,13 @@
  - colorrules::ThematicVectorTable
  - colorrules::BufferedWindow
-(C) 2008, 2010-2011 by the GRASS Development Team
+(C) 2008, 2010-2012 by the GRASS Development Team
 This program is free software under the GNU General Public License
 (>=v2). Read the file COPYING that comes with GRASS for details.
 @author Michael Barton (Arizona State University)
- at author Martin Landa <landa.martin gmail.com> (various updates)
+ at author Martin Landa <landa.martin gmail.com> (various updates, pre-defined color table)
 @author Anna Kratochvilova <kratochanna gmail.com> (split to base and derived classes)
@@ -311,7 +311,7 @@
         return sqlrule
 class ColorTable(wx.Frame):
-    def __init__(self, parent, title, id = wx.ID_ANY,
+    def __init__(self, parent, title, layerTree = None, id = wx.ID_ANY,
                  style = wx.DEFAULT_FRAME_STYLE | wx.RESIZE_BORDER,
                  **kwargs):
         """!Dialog for interactively entering rules for map management
@@ -320,7 +320,9 @@
         @param raster True to raster otherwise vector
         @param nviz True if ColorTable is called from nviz thematic mapping
-        self.parent = parent # GMFrame
+        self.parent = parent        # GMFrame ?
+        self.layerTree = layerTree  # LayerTree or None
         wx.Frame.__init__(self, parent, id, title, style = style, **kwargs)
         self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass.ico'), wx.BITMAP_TYPE_ICO))
@@ -332,8 +334,10 @@
         # input map to change
         self.inmap = ''
         # reference to layer with preview
-        self.layer = None
+        self.layer = None
         # layout
         self._doLayout()
@@ -354,15 +358,15 @@
         # set map layer from layer tree, first selected,
         # if not the right type, than select another
         try:
-            sel = self.parent.GetLayerTree().layer_selected
-            if sel and self.parent.GetLayerTree().GetPyData(sel)[0]['type'] == self.mapType:
+            sel = self.layerTree.layer_selected
+            if sel and self.layerTree.GetPyData(sel)[0]['type'] == self.mapType:
                 layer = sel
             else:
-                layer = self.parent.GetLayerTree().FindItemByData(key = 'type', value = self.mapType)
+                layer = self.layerTree.FindItemByData(key = 'type', value = self.mapType)
         except:
             layer = None
         if layer:
-            mapLayer = self.parent.GetLayerTree().GetPyData(layer)[0]['maplayer']
+            mapLayer = self.layerTree.GetPyData(layer)[0]['maplayer']
             name = mapLayer.GetName()
             type = mapLayer.GetType()
             self.selectionInput.SetValue(name)
@@ -553,7 +557,7 @@
         else:
             # re-render preview and current map window
             self.OnPreview(None)
-            display = self.parent.GetLayerTree().GetMapDisplay()
+            display = self.layerTree.GetMapDisplay()
             if display and display.IsAutoRendered():
                 display.GetWindow().UpdateMap(render = True)
@@ -758,6 +762,10 @@
                    quiet = True,
                    parent = self,
                    entry = cmd)
+    def SetMap(self, name):
+        """!Set map name and update dialog"""
+        self.selectionInput.SetValue(name)
     def _IsNumber(self, s):
         """!Check if 's' is a number"""
@@ -767,7 +775,6 @@
         except ValueError:
             return False
 class RasterColorTable(ColorTable):
     def __init__(self, parent, **kwargs):
         """!Dialog for interactively entering color rules for raster maps"""
@@ -790,10 +797,7 @@
         # self.SetMinSize(self.GetSize())
         self.SetMinSize((650, 700))
-        self.CentreOnScreen()
-        self.Show()
     def _doLayout(self):
         """!Do main layout"""
         sizer = wx.BoxSizer(wx.VERTICAL)
@@ -835,19 +839,18 @@
         """!Raster map selected"""
         if event:
             self.inmap = event.GetString()
         self.loadRules.SetValue('')
         self.saveRules.SetValue('')
         if self.inmap:
             if not grass.find_file(name = self.inmap, element = 'cell')['file']:
                 self.inmap = None
         if not self.inmap:
-            self.btnPreview.Enable(False)
-            self.btnOK.Enable(False)
-            self.btnApply.Enable(False)
-            self.btnDefault.Enable(False)
-            self.btnSet.Enable(False)
+            for btn in (self.btnPreview, self.btnOK,
+                        self.btnApply, self.btnDefault, self.btnSet):
+                btn.Enable(False)
             self.LoadTable()
             return
@@ -860,11 +863,9 @@
         else:
             self.inmap = ''
             self.properties['min'] = self.properties['max'] = None
+                btn.Enable(False)
             self.preview.EraseMap()
             self.cr_label.SetLabel(_('Enter raster category values or percents'))
             return
@@ -877,13 +878,11 @@
                                  { 'range' : mapRange,
                                    'min' : self.properties['min'],
                                    'max' : self.properties['max'] })
-        self.btnPreview.Enable()
-        self.btnOK.Enable()
-        self.btnApply.Enable()
-        self.btnDefault.Enable()
-        self.btnSet.Enable()
+            btn.Enable()
     def OnPreview(self, tmp = True):
         """!Update preview (based on computational region)"""
         if not self.inmap:
@@ -1591,13 +1590,13 @@
     def UseAttrColumn(self, useAttrColumn):
         """!Find layers and apply the changes in d.vect command"""
-        layers = self.parent.GetLayerTree().FindItemByData(key = 'name', value = self.inmap)
+        layers = self.layerTree.FindItemByData(key = 'name', value = self.inmap)
         if not layers:
             return
         for layer in layers:
-            if self.parent.GetLayerTree().GetPyData(layer)[0]['type'] != 'vector':
+            if self.layerTree.GetPyData(layer)[0]['type'] != 'vector':
                 continue
-            cmdlist = self.parent.GetLayerTree().GetPyData(layer)[0]['maplayer'].GetCmd()
+            cmdlist = self.layerTree.GetPyData(layer)[0]['maplayer'].GetCmd()
             if self.attributeType == 'color':
                 if useAttrColumn:
@@ -1611,7 +1610,7 @@
                 cmdlist[1].update({'size_column': self.properties['storeColumn']})
             elif self.attributeType == 'width':
                 cmdlist[1].update({'width_column' :self.properties['storeColumn']})
-            self.parent.GetLayerTree().GetPyData(layer)[0]['cmd'] = cmdlist
+            self.layerTree.GetPyData(layer)[0]['cmd'] = cmdlist
     def CreateColorTable(self, tmp = False):
         """!Create color rules (color table or color column)"""
