[GRASS-SVN] r53812 - in grass/branches/develbranch_6/gui/wxpython: core lmgr
svn_grass at osgeo.org
Wed Nov 14 09:11:25 PST 2012
Author: martinl
Date: 2012-11-14 09:11:25 -0800 (Wed, 14 Nov 2012)
New Revision: 53812
grass/branches/develbranch_6/gui/wxpython/core/render.py
grass/branches/develbranch_6/gui/wxpython/core/utils.py
grass/branches/develbranch_6/gui/wxpython/lmgr/layertree.py
wxGUI bugfix: support unnamed paramaters in command map layers
(merge r53811 from relbr64)
Modified: grass/branches/develbranch_6/gui/wxpython/core/render.py
--- grass/branches/develbranch_6/gui/wxpython/core/render.py 2012-11-14 17:04:56 UTC (rev 53811)
+++ grass/branches/develbranch_6/gui/wxpython/core/render.py 2012-11-14 17:11:25 UTC (rev 53812)
@@ -176,10 +176,10 @@
quiet = True,
**self.cmd[1])
- if msg:
+ if ret != 0:
sys.stderr.write(_("Command '%s' failed\n") % self.GetCmd(string = True))
- sys.stderr.write(_("Details: %s\n") % msg)
- if ret != 0:
+ if msg:
+ sys.stderr.write(_("Details: %s\n") % msg)
raise GException()
except GException:
@@ -309,7 +309,7 @@
for c in cmd:
self.cmd.append(utils.CmdToTuple(c))
else:
- self.cmd = utils.CmdToTuple(cmd)
+ self.cmd = utils.CmdToTuple(cmd)
Debug.msg(3, "Layer.SetCmd(): cmd='%s'" % self.GetCmd(string = True))
# for re-rendering
Modified: grass/branches/develbranch_6/gui/wxpython/core/utils.py
--- grass/branches/develbranch_6/gui/wxpython/core/utils.py 2012-11-14 17:04:56 UTC (rev 53811)
+++ grass/branches/develbranch_6/gui/wxpython/core/utils.py 2012-11-14 17:11:25 UTC (rev 53812)
@@ -495,7 +495,7 @@
"""!Convert command list to tuple for gcmd.RunCommand()"""
if len(cmd) < 1:
return None
dcmd = {}
for item in cmd[1:]:
if '=' in item: # params
@@ -505,13 +505,15 @@
flag = item[2:]
if flag in ('verbose', 'quiet', 'overwrite'):
dcmd[str(flag)] = True
- else: # -> flags
+ elif len(item) == 2 and item[0] == '-': # -> flags
if 'flags' not in dcmd:
dcmd['flags'] = ''
- dcmd['flags'] += item.replace('-', '')
- return (cmd[0],
- dcmd)
+ dcmd['flags'] += item[1]
+ else: # unnamed parameter
+ module = gtask.parse_interface(cmd[0])
+ dcmd[module.define_first()] = item
+ return (cmd[0], dcmd)
def PathJoin(*args):
"""!Check path created by os.path.join"""
Modified: grass/branches/develbranch_6/gui/wxpython/lmgr/layertree.py
--- grass/branches/develbranch_6/gui/wxpython/lmgr/layertree.py 2012-11-14 17:04:56 UTC (rev 53811)
+++ grass/branches/develbranch_6/gui/wxpython/lmgr/layertree.py 2012-11-14 17:11:25 UTC (rev 53812)
@@ -1192,14 +1192,13 @@
ctrl = event.GetEventObject().GetId()
cmd = event.GetString()
+ # find layer tree item by ctrl
layer = self.GetFirstVisibleItem()
while layer and layer.IsOk():
if self.GetPyData(layer)[0]['ctrl'] == ctrl:
break
layer = self.GetNextVisible(layer)
# change parameters for item in layers list in render.Map
self.ChangeLayer(layer)
@@ -1594,8 +1593,7 @@
self.mapdisplay.GetToolbar('vdigit').UpdateListOfLayers(updateTool = True)
# redraw map if auto-rendering is enabled
- self.rerender = True
- self.reorder = True
+ self.rerender = self.reorder = True
def OnCloseWindow(self, event):
pass
