[GRASS-SVN] r53826 - in grass/branches/develbranch_6/gui/wxpython: gui_core mapdisp
svn_grass at osgeo.org
Wed Nov 14 10:26:16 PST 2012
Author: martinl
Date: 2012-11-14 10:26:15 -0800 (Wed, 14 Nov 2012)
New Revision: 53826
grass/branches/develbranch_6/gui/wxpython/gui_core/dialogs.py
grass/branches/develbranch_6/gui/wxpython/mapdisp/frame.py
grass/branches/develbranch_6/gui/wxpython/mapdisp/mapwindow.py
wxGUI/mapdisplay: add 'Save computational region to named region' to the zoom menu
(merge r53825 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_core/dialogs.py
--- grass/branches/develbranch_6/gui/wxpython/gui_core/dialogs.py 2012-11-14 18:21:09 UTC (rev 53825)
+++ grass/branches/develbranch_6/gui/wxpython/gui_core/dialogs.py 2012-11-14 18:26:15 UTC (rev 53826)
@@ -436,14 +436,14 @@
return dlg
class SavedRegion(wx.Dialog):
- def __init__(self, parent, id = wx.ID_ANY, title = "", loadsave = 'load',
+ def __init__(self, parent, title, id = wx.ID_ANY, loadsave = 'load',
**kwargs):
- """!Loading and saving of display extents to saved region file
+ """!Loading or saving of display extents to saved region file
@param loadsave load or save region?
wx.Dialog.__init__(self, parent, id, title, **kwargs)
self.loadsave = loadsave
self.wind = ''
@@ -465,12 +465,12 @@
selection.SetFocus()
selection.Bind(wx.EVT_TEXT, self.OnRegion)
- sizer.Add(item = box, proportion = 0, flag = wx.GROW|wx.ALIGN_CENTER_VERTICAL|wx.ALL,
+ sizer.Add(item = box, proportion = 0, flag = wx.GROW | wx.ALIGN_CENTER_VERTICAL | wx.ALL,
border = 5)
line = wx.StaticLine(parent = self, id = wx.ID_ANY, size = (20, -1), style = wx.LI_HORIZONTAL)
sizer.Add(item = line, proportion = 0,
- flag = wx.GROW|wx.ALIGN_CENTER_VERTICAL|wx.LEFT|wx.RIGHT, border = 5)
+ flag = wx.GROW | wx.ALIGN_CENTER_VERTICAL | wx.LEFT | wx.RIGHT, border = 5)
btnsizer = wx.StdDialogButtonSizer()
@@ -490,6 +490,10 @@
def OnRegion(self, event):
self.wind = event.GetString()
+ def GetName(self):
+ """!Return region name"""
+ return self.wind
class DecorationDialog(wx.Dialog):
Modified: grass/branches/develbranch_6/gui/wxpython/mapdisp/frame.py
--- grass/branches/develbranch_6/gui/wxpython/mapdisp/frame.py 2012-11-14 18:21:09 UTC (rev 53825)
+++ grass/branches/develbranch_6/gui/wxpython/mapdisp/frame.py 2012-11-14 18:26:15 UTC (rev 53826)
@@ -1233,40 +1233,34 @@
self.MapWindow.DisplayToWind()
- def SaveDisplayRegion(self, event):
+ def OnSaveDisplayRegion(self, event):
"""!Save display extents to named region file.
- self.MapWindow.SaveDisplayRegion()
+ self.MapWindow.SaveRegion(display = True)
+ def OnSaveWindRegion(self, event):
+ """!Save computational region to named region file.
+ self.MapWindow.SaveRegion(display = False)
def OnZoomMenu(self, event):
"""!Popup Zoom menu
point = wx.GetMousePosition()
zoommenu = wx.Menu()
- # Add items to the menu
- zoomwind = wx.MenuItem(zoommenu, wx.ID_ANY, _('Zoom to computational region (set with g.region)'))
- zoommenu.AppendItem(zoomwind)
- self.Bind(wx.EVT_MENU, self.OnZoomToWind, zoomwind)
- zoomdefault = wx.MenuItem(zoommenu, wx.ID_ANY, _('Zoom to default region'))
- zoommenu.AppendItem(zoomdefault)
- self.Bind(wx.EVT_MENU, self.OnZoomToDefault, zoomdefault)
- zoomsaved = wx.MenuItem(zoommenu, wx.ID_ANY, _('Zoom to saved region'))
- zoommenu.AppendItem(zoomsaved)
- self.Bind(wx.EVT_MENU, self.OnZoomToSaved, zoomsaved)
- savewind = wx.MenuItem(zoommenu, wx.ID_ANY, _('Set computational region from display extent'))
- zoommenu.AppendItem(savewind)
- self.Bind(wx.EVT_MENU, self.OnDisplayToWind, savewind)
- savezoom = wx.MenuItem(zoommenu, wx.ID_ANY, _('Save display geometry to named region'))
- zoommenu.AppendItem(savezoom)
- self.Bind(wx.EVT_MENU, self.SaveDisplayRegion, savezoom)
- # Popup the menu. If an item is selected then its handler
- # will be called before PopupMenu returns.
+ for label, handler in ((_('Zoom to computational region'), self.OnZoomToWind),
+ (_('Zoom to default region'), self.OnZoomToDefault),
+ (_('Zoom to saved region'), self.OnZoomToSaved),
+ (_('Set computational region from display extent'), self.OnDisplayToWind),
+ (_('Save display geometry to named region'), self.OnSaveDisplayRegion),
+ (_('Save computational region to named region'), self.OnSaveWindRegion)):
+ mid = wx.MenuItem(zoommenu, wx.ID_ANY, label)
+ zoommenu.AppendItem(mid)
+ self.Bind(wx.EVT_MENU, handler, mid)
+ # Popup the menu. If an item is selected then its handler will
+ # be called before PopupMenu returns.
self.PopupMenu(zoommenu)
zoommenu.Destroy()
Modified: grass/branches/develbranch_6/gui/wxpython/mapdisp/mapwindow.py
--- grass/branches/develbranch_6/gui/wxpython/mapdisp/mapwindow.py 2012-11-14 18:21:09 UTC (rev 53825)
+++ grass/branches/develbranch_6/gui/wxpython/mapdisp/mapwindow.py 2012-11-14 18:26:15 UTC (rev 53826)
@@ -1631,20 +1631,20 @@
dlg = SavedRegion(parent = self,
title = _("Zoom to saved region extents"),
- loadsave='load')
+ loadsave = 'load')
- if dlg.ShowModal() == wx.ID_CANCEL or not dlg.wind:
+ if dlg.ShowModal() == wx.ID_CANCEL or not dlg.GetName():
dlg.Destroy()
return
- if not grass.find_file(name = dlg.wind, element = 'windows')['name']:
+ if not grass.find_file(name = dlg.GetName(), element = 'windows')['name']:
wx.MessageBox(parent = self,
- message = _("Region <%s> not found. Operation canceled.") % dlg.wind,
+ message = _("Region <%s> not found. Operation canceled.") % dlg.GetName(),
caption = _("Error"), style = wx.ICON_ERROR | wx.OK | wx.CENTRE)
dlg.Destroy()
return
- self.Map.GetRegion(regionName = dlg.wind,
+ self.Map.GetRegion(regionName = dlg.GetName(),
update = True)
dlg.Destroy()
@@ -1656,34 +1656,54 @@
self.UpdateMap()
- def SaveDisplayRegion(self):
- """!Save display extents to named region file.
+ def SaveRegion(self, display = True):
+ """!Save display extents/compulational region to named region
+ file.
+ @param display True for display extends otherwise computational region
- dlg = SavedRegion(parent = self,
- title = _("Save display extents to region file"),
- loadsave='save')
+ if display:
+ title = _("Save display extents to region file")
+ else:
+ title = _("Save computational region to region file")
+ dlg = SavedRegion(parent = self, title = title, loadsave = 'save')
dlg.Destroy()
return
# test to see if it already exists and ask permission to overwrite
- if grass.find_file(name = dlg.wind, element = 'windows')['name']:
+ if grass.find_file(name = dlg.GetName(), element = 'windows')['name']:
overwrite = wx.MessageBox(parent = self,
message = _("Region file <%s> already exists. "
- "Do you want to overwrite it?") % (dlg.wind),
+ "Do you want to overwrite it?") % (dlg.GetName()),
caption = _("Warning"), style = wx.YES_NO | wx.CENTRE)
- if (overwrite == wx.YES):
- self.SaveRegion(dlg.wind)
+ if overwrite != wx.YES:
+ dlg.Destroy()
+ return
+ if display:
+ self._saveDisplayRegion(dlg.GetName())
else:
+ self._saveCompRegion(dlg.GetName())
dlg.Destroy()
+ def _saveCompRegion(self, name):
+ """!Save region settings to region file
- def SaveRegion(self, wind):
- """!Save region settings
+ @param name region name
+ RunCommand('g.region',
+ overwrite = True,
+ parent = self,
+ flags = 'u',
+ save = name)
- @param wind region name
+ def _saveDisplayRegion(self, name):
+ """!Save display extents to region file
new = self.Map.GetCurrentRegion()
@@ -1701,7 +1721,7 @@
w = new['w'],
rows = int(new['rows']),
cols = int(new['cols']),
- save = wind)
+ save = name)
if tmpreg:
os.environ["GRASS_REGION"] = tmpreg
