[GRASS-SVN] r53830 - grass/trunk/raster3d/r3.out.ascii
svn_grass at osgeo.org
Thu Nov 15 00:34:35 PST 2012
Author: huhabla
Date: 2012-11-15 00:34:34 -0800 (Thu, 15 Nov 2012)
New Revision: 53830
grass/trunk/raster3d/r3.out.ascii/r3.out.ascii.html
Better description of the output ordering.
Modified: grass/trunk/raster3d/r3.out.ascii/r3.out.ascii.html
--- grass/trunk/raster3d/r3.out.ascii/r3.out.ascii.html 2012-11-14 18:37:17 UTC (rev 53829)
+++ grass/trunk/raster3d/r3.out.ascii/r3.out.ascii.html 2012-11-15 08:34:34 UTC (rev 53830)
@@ -40,42 +40,28 @@
north -> south for rows
bottom -> top for depths
</pre></div>
+The header is followed by cell values in <em>floating point</em> format.
+Cell values are exported as a series of horizontal slices in row-major
+order. The data starts with the upper left corner (NW) at the bottom of the data set:
-This order is compatible with the <em>r.in.ascii</em> row -> column ordering. The column
-order can not be changed but the row and depth order. Supported orders are:
+<div class="code"><pre>
+(x, y + rows, z), (x + 1, y + rows, z), ... (x + cols, y + rows, z)
+(x, y + rows, z), (x + 1, y + rows - 1, z), ... (x + cols, y + rows - 1, z)
+(x, y, z + depths), (x + 1, y, z + depths), ... (x + cols, y, z + depths)
+</pre></div>
+This order is compatible with the <em>r.in.ascii</em> row -> column ordering.
+<p>
+Supported orders are:
<ul>
<li><b>nsbt</b>: north -> south and bottom -> top ordering which is the default (no flags)</li>
<li><b>snbt</b>: south -> north and bottom -> top ordering using <em>-r</em> flag</li>
<li><b>nstb</b>: north -> south and top -> bottom ordering using <em>-d</em> flag</li>
<li><b>sntb</b>: south -> north and top -> bottom ordering using <em>-rd</em> flag</li>
</ul>
-The header is followed by cell values in <em>floating point</em> format.
-Cell values are output as a series of horizontal slices in row-major
-order. That is in case of the default north -> south and bottom -> top (nsbt) ordering:
-<div class="code"><pre>
- (x, y, z) (x + 1, y, z) ... (x + cols, y, z)
-(x, y + 1, z) (x + 1, y + 1, z) ... (x + cols, y + 1, z)
-(x, y + rows, z) (x + 1, y + rows, z) ... (x + cols, y + rows, z)
- (x, y, z + 1) (x + 1, y, z + 1) ... (x + cols, y, z + 1)
-(x, y + 1, z + 1) (x + 1, y + 1, z + 1) ... (x + cols, y + 1, z + 1)
-(x, y + rows, z + 1) (x + 1, y + rows, z + 1) ... (x + cols, y + rows, z + 1)
-and so on.
-</pre></div>
-The data starts with the upper left corner (NW) at the bottom of the data set.
<p>One level maps can be imported with <em>r.in.ascii</em> (2D raster) using
the default <b>nsbt</b> order and removing the header lines "version",
"order", "top", "bottom" and "levels".
