[GRASS-SVN] r53842 - in grass-addons/grass6/raster/mcda: r.in.drsa r.mcda.ahp r.mcda.electre r.mcda.regime r.mcda.roughset
Thu Nov 15 12:53:35 PST 2012
Author: gianluca
Date: 2012-11-15 12:53:34 -0800 (Thu, 15 Nov 2012)
New Revision: 53842
   grass-addons/grass6/raster/mcda/r.in.drsa/r.in.drsa.py
   grass-addons/grass6/raster/mcda/r.mcda.ahp/r.mcda.ahp.py
   grass-addons/grass6/raster/mcda/r.mcda.electre/dominance.c
   grass-addons/grass6/raster/mcda/r.mcda.regime/regime.c
   grass-addons/grass6/raster/mcda/r.mcda.roughset/r.mcda.roughset.py
Modified: grass-addons/grass6/raster/mcda/r.in.drsa/r.in.drsa.py
--- grass-addons/grass6/raster/mcda/r.in.drsa/r.in.drsa.py	2012-11-15 17:10:54 UTC (rev 53841)
+++ grass-addons/grass6/raster/mcda/r.in.drsa/r.in.drsa.py	2012-11-15 20:53:34 UTC (rev 53842)
@@ -1,15 +1,15 @@
 #!/usr/bin/env python
-# MODULE:       r.in.drsa
-# AUTHOR:       Gianluca Massei - Antonio Boggia
-# PURPOSE:      Import roles from *.rls file and apply those condition
-#               at geographics information system for generate a raster
-#               map classified under Dominance Rough Set Approach
-# COPYRIGHT:    c) 2010 Gianluca Massei, Antonio Boggia  and the GRASS
-#               Development Team. This program is free software under the
-#               GNU General PublicLicense (>=v2). Read the file COPYING
-#               that comes with GRASS for details.
+# MODULE:	   r.in.drsa
+# AUTHOR:	   Gianluca Massei - Antonio Boggia
+# PURPOSE:	  Import roles from *.rls file and apply those condition
+#			   at geographics information system for generate a raster
+#			   map classified under Dominance Rough Set Approach
+# COPYRIGHT:	c) 2010 Gianluca Massei, Antonio Boggia  and the GRASS
+#			   Development Team. This program is free software under the
+#			   GNU General PublicLicense (>=v2). Read the file COPYING
+#			   that comes with GRASS for details.
@@ -36,11 +36,17 @@
 #%flag
 #% key:k
 #% description:file *.rls from software 4eMka2
+#% answer:true
 #%end
 #%flag
 #% key:j
-#% description:file *.rls from software jMAF
+#% description:file *.rls from software jMAF (NOT YET IMPLEMENTED)
 #%end
+#%flag
+#% key: l
+#% description: do not remove single rules in vector format
+#% answer:false
+#%end
@@ -50,106 +56,124 @@
 import string
 def parser_4eMka2_rule(tags):
-    "parser file *.rls from 4eMka2 software and extract information for make new classified raster"
-    rule=dict()
-    rules_list=[]
-    for t in tags:
-        condition=[]
-        decision=[]
-        row=t.split()
-        if(len(row)>0 and row[0]=="Rule"):
-            #rules_list.append(row)
-            i=row.index("=>")
-            for j in range(2,i):
-                 if( row[j]!="&"):
-                     condition.append(row[j].strip('[,;]'))
-            for j in range(i+1,len(row)-2):
-                     decision.append(row[j].strip('[,;]'))
-            rule={'id_rule':row[1].strip('[.;]'),
-                  'condition':condition,
-                  'decision':string.join(decision),
-                  'support':int(row[-2].strip('[.,;]')),
-                  'strength':row[-1].strip('[,:]')}
-            rules_list.append(rule)
-    rls = open('rules',"w")
-    for l in rules_list:
-        factor=l['decision'].strip('()').split(' ')
-        rls.write('%s=%s %s \n' % (l['id_rule'],l['id_rule'], " ".join(factor)))
-    rls.close
-    return rules_list
+	"parser file *.rls from 4eMka2 software and extract information for make new classified raster"
+	rule=dict()
+	rules=[]
+	for t in tags:
+		condition=[]
+		decision=[]
+		row=t.split()
+		if(len(row)>0 and row[0]=="Rule"):
+			#rules_list.append(row)
+			i=row.index("=>")
+			for j in range(2,i):
+				 if( row[j]!="&"):
+					 condition.append(row[j].strip('[,;]'))
+			for j in range(i+1,len(row)-2):
+					 decision.append(row[j].strip('([,;])'))
+			rule={'id_rule':row[1].strip('[.;]'),
+				  'condition':condition,
+				  'decision':(decision[0]),
+				  'class':"_".join(decision[1:]),
+				  'support':int(row[-2].strip('[.,;]')),
+				  'strength':row[-1].strip('[,:]')}
+			rules.append(rule)
+	rls = open('rules',"w")
+	for l in rules:
+		factor=l['decision'].strip('()').split(' ')
+		rls.write('id_rule:%s - condition:%s - decision: %s - class:%s \n' % (l['id_rule'],l['condition'], l['decision'],l['class']))
+	rls.close
+	return rules
 def parser_JAMM_rule(tags):
-    "parser file *.rls from JAMM software and extract information for make new classified raster"
+	"parser file *.rls from JAMM software and extract information for make new classified raster"
 def parser_mapcalc(rules,i):
-    "parser to build a formula to be included  in mapcalc command"
-    mapalgebra="if("
-    for j in rules[i]['condition'][:-1]:
-        mapalgebra+= j + " && "
-    mapalgebra+=rules[i]['condition'][-1]+","+rules[i]['id_rule']+",null())"
-    return mapalgebra
+	"parser to build a formula to be included  in mapcalc command"
+	mapalgebra="if("
+	for j in rules[i]['condition'][:-1]:
+		mapalgebra+= j + " && "
+	mapalgebra+=rules[i]['condition'][-1]+","+rules[i]['id_rule']+",null())"
+	return mapalgebra
 def clean_rules(rules):
-    "cleans rules to no processed vaue from rules (eg = -> ==) "
-    for i in range(len(rules)):
-        for j in rules[i]['condition']:
-            if (j.find("<=")!=-1):
-                return 1
-            elif (j.find("<=")!=-1):
-                return 1
-            elif (j.find("=")!=-1):
-                j=j.replace("=","==")
-                return 0
-            else:
-                return -1
+	"cleans rules to no processed vaue from rules (eg = -> ==) "
+	for i in range(len(rules)):
+		for j in rules[i]['condition']:
+			if (j.find("<=")!=-1):
+				return 1
+			elif (j.find("<=")!=-1):
+				return 1
+			elif (j.find("=")!=-1):
+				j=j.replace("=","==")
+				return 0
+			else:
+				return -1
+def patch_georules(maps,outputMap):
+	labels=["_".join(m.split('_')[1:]) for m in maps]
+	labels=list(set(labels))
+	for l in labels:
+		print "mapping %s rule" % str(l)
+		map_synth=[]
+		for m in maps:
+			if l == "_".join(m.split('_')[1:]):
+				map_synth.append(m)
+		if len(map_synth)>1:
+			grass.run_command("r.patch", overwrite='True', input=(",".join(map_synth)), output=l )
+		else:
+			grass.run_command("g.copy",rast=(str(map_synth),l))
+		grass.run_command("r.to.vect", overwrite='True', flags='s', input=l, output=l, feature='area')
+		grass.run_command("v.db.addcol", map=l, columns='rule varchar(25)')
+		grass.run_command("v.db.update", map=l, column='rule', value=l)
+		grass.run_command("v.db.update", map=l, column='label', value=l)
+	mapstring=",".join(labels)
+	if len(maps)>1:
+		grass.run_command("v.patch", overwrite='True', flags='e', input=mapstring, output=outputMap)
+	else:
+		grass.run_command("g.copy",vect=(mapstring,outputMap))
 def main():
-    input_rules = options['input']
-    outputMap = options['output']
+	input_rules = options['input']
+	outputMap = options['output']
-    gregion = grass.region()
-    nrows = gregion['rows']
-    ncols = gregion['cols']
-    ewres=int(gregion['ewres'])
-    nsres=int(gregion['nsres'])
-    input_rules=open(input_rules,"r")
-    tags=input_rules.readlines()
-    rules=[]  #single rule (dictionary) in array
-    maps=[]
-    rules=parser_4eMka2_rule(tags)
-##    clean_rules(rules)
-        mappa="rule"+rules[i]['id_rule']
-        formula=parser_mapcalc(rules,i)
-        grass.mapcalc(mappa +"=" +formula)
-        maps.append(mappa)
-    mapstring=",".join(maps)
-    for m in maps:
-        grass.run_command("r.to.vect", overwrite='True', flags='s', input=m, output=m, feature='area')
-        grass.run_command("v.db.addcol", map=m, columns='rule varchar(25)')
-        grass.run_command("v.db.update", map=m, column='rule', value=m)
-    grass.run_command("v.patch", overwrite='True', flags='e', input=mapstring, output=outputMap)
-    grass.run_command("r.patch", input=maps,  flags='-o', output='rulesMap')
-    grass.run_command("r.reclass", input='rulesMap', flags='-o',  output='roughMAP', rules='rules')
-    grass.run_command("r.to.vect", input='roughMAP', flags='-o', output=outputMap, feature='area')
-    grass.run_command("g.remove",  rast=mapstring)
-    grass.run_command("g.remove",  vect=mapstring)
-    grass.run_command("g.remove",  vect="rulesMap,roughMAP")
-    input_rules.close()
+	gregion = grass.region()
+	nrows = gregion['rows']
+	ncols = gregion['cols']
+	ewres=int(gregion['ewres'])
+	nsres=int(gregion['nsres'])
+	input_rules=open(input_rules,"r")
+	tags=input_rules.readlines()
+	rules=[]  #single rule (dictionary) in array
+	maps=[]
+	rules=parser_4eMka2_rule(tags)
+##	clean_rules(rules)
+		mappa="r"+rules[i]['id_rule']+"_"+rules[i]['class']
+		formula=parser_mapcalc(rules,i)
+		grass.mapcalc(mappa +"=" +formula)
+		maps.append(mappa)
+	maplist=",".join(maps)
+	print maplist
+	patch_georules(maps,outputMap)
+	if not flags['l']:
+		grass.run_command("g.remove",flags="quiet", rast=maplist)
+		grass.run_command("g.remove",flags="quiet", vect=maplist)
+	input_rules.close()
+	return 0
 if __name__ == "__main__":
-    options, flags = grass.parser()
-    sys.exit(main())
+	options, flags = grass.parser()
+	sys.exit(main())
Modified: grass-addons/grass6/raster/mcda/r.mcda.ahp/r.mcda.ahp.py
--- grass-addons/grass6/raster/mcda/r.mcda.ahp/r.mcda.ahp.py	2012-11-15 17:10:54 UTC (rev 53841)
+++ grass-addons/grass6/raster/mcda/r.mcda.ahp/r.mcda.ahp.py	2012-11-15 20:53:34 UTC (rev 53842)
@@ -47,10 +47,12 @@
 import sys
 import grass.script as grass
 import numpy as np
+import warnings
 def calculateWeight(pairwise):
     "Define vector of weight based on eigenvector and eigenvalues"
     pairwise=np.genfromtxt(pairwise, delimiter=",")
+    warnings.simplefilter("ignore", np.ComplexWarning)
     eigenvalues, eigenvector=np.linalg.eig(pairwise)
     maxindex=np.argmax(eigenvalues)
     eigenvalues=np.float32(eigenvalues)
Modified: grass-addons/grass6/raster/mcda/r.mcda.electre/dominance.c
--- grass-addons/grass6/raster/mcda/r.mcda.electre/dominance.c	2012-11-15 17:10:54 UTC (rev 53841)
+++ grass-addons/grass6/raster/mcda/r.mcda.electre/dominance.c	2012-11-15 20:53:34 UTC (rev 53842)
@@ -52,11 +52,16 @@
     int row1, col1, row2, col2;
     int i, j, k, cont;
-    double *row_sum_conc = G_alloc_vector(nrows * ncols);
-    double *col_sum_conc = G_alloc_vector(nrows * ncols);
-    double *row_sum_disc = G_alloc_vector(nrows * ncols);
-    double *col_sum_disc = G_alloc_vector(nrows * ncols);
+	double *row_sum_conc;
+	double *col_sum_conc;
+	double *row_sum_disc;
+	double *col_sum_disc;
+	row_sum_conc=G_malloc(ncriteria * nrows * ncols * sizeof(double*));
+	col_sum_conc=G_malloc(ncriteria * nrows * ncols * sizeof(double*));
+	row_sum_disc=G_malloc(ncriteria * nrows * ncols * sizeof(double*));
+	col_sum_disc=G_malloc(ncriteria * nrows * ncols * sizeof(double*));
     k = 0;			/* make pairwise comparation and build concordance/discordance matrix */
     for (row1 = 0; row1 < nrows; row1++)
@@ -69,13 +74,11 @@
                 for (col2 = 0; col2 < ncols; col2++)
                     double conc = 0, disc = 0;
                     for (i = 0; i < ncriteria; i++)
-                        double d =
-                            decision_vol[row1][col1][i] -
-                            decision_vol[row2][col2][i];
-                        if (d >= 0)
+                        double d;
+			d = decision_vol[row1][col1][i] - decision_vol[row2][col2][i];
+                        if (d >= 0 )
                             conc += weight_vect[i];
                         if (d < disc)	/*WARNING: if(d>conc) */
                             /**/ disc = -d;
@@ -84,11 +87,12 @@
                     col_sum_conc[j] += conc;
                     row_sum_disc[k] += disc;
                     col_sum_disc[j] += disc;
                     j++;	/* increase rows index up to nrows*ncols */
-            k++;		/* increase columns index up to nrows*ncols */
+            k++;		/* increase columns index up to nrows*ncols */;
Modified: grass-addons/grass6/raster/mcda/r.mcda.regime/regime.c
--- grass-addons/grass6/raster/mcda/r.mcda.regime/regime.c	2012-11-15 17:10:54 UTC (rev 53841)
+++ grass-addons/grass6/raster/mcda/r.mcda.regime/regime.c	2012-11-15 20:53:34 UTC (rev 53842)
@@ -51,7 +51,9 @@
     int i, j, k, cont;
-    double *row_sum_regime = G_alloc_vector(nrows * ncols);
+    double *row_sum_regime;
+    row_sum_regime=G_malloc(ncriteria * nrows * ncols * sizeof(double*));
     j = 0;			/* make pairwise comparation and built regime matrix */
@@ -77,9 +79,9 @@
                     row_sum_regime[j] += reg;
+	    G_percent(j, nrows*ncols, 2);
-        G_percent(row1, nrows, 1);
     /*calculate concordance and discordance index and storage in decision_vol */
Modified: grass-addons/grass6/raster/mcda/r.mcda.roughset/r.mcda.roughset.py
--- grass-addons/grass6/raster/mcda/r.mcda.roughset/r.mcda.roughset.py	2012-11-15 17:10:54 UTC (rev 53841)
+++ grass-addons/grass6/raster/mcda/r.mcda.roughset/r.mcda.roughset.py	2012-11-15 20:53:34 UTC (rev 53842)
@@ -60,6 +60,7 @@
 #%flag
 #% key: l
+#% answer:false
 #%end
 #%flag
 #% key: n
@@ -71,8 +72,8 @@
 import copy
 import numpy as np
 from time import time, ctime
-##from grass.script import core as grass
+import grass.script.array as garray
 def BuildFileISF(attributes, preferences, decision, outputMap, outputTxt):
@@ -463,21 +464,6 @@
 	attributes=infosystem['attributes']
 	RULES=[]
-## *** AT LEAST {>= Class} - Type 1 rules *** "
-	for a in Lu[1:]:
-		B=a['objects']
-		E=Find_rules (B, infosystem, 'one')
-		for e in E:
-			for i in e:
-				i['class']=a['class']
-				i['label']=attributes[i['criterion']-1]['name']
-				i['type']='at_last'
-				if (attributes[i['criterion']-1]['preference']=='gain'):
-					i['sign']='>='
-				else:
-					i['sign']='<='
-			RULES.append(e)
 ##  *** AT MOST {<= Class} - Type 3 rules ***"
 	for b in Ld[:-1]:
@@ -493,20 +479,33 @@
 				else:
 					i['sign']='>='
 			RULES.append(e)
+## *** AT LEAST {>= Class} - Type 1 rules *** "
+	for a in Lu[1:]:
+		B=a['objects']
+		E=Find_rules (B, infosystem, 'one')
+		for e in E:
+			for i in e:
+				i['class']=a['class']
+				i['label']=attributes[i['criterion']-1]['name']
+				i['type']='at_least'
+				if (attributes[i['criterion']-1]['preference']=='gain'):
+					i['sign']='>='
+				else:
+					i['sign']='<='
+			RULES.append(e)
 	return RULES
 def Print_rules(RULES, outputTxt):
 	"Print rls output file"
 	i=1
 	outfile=open(outputTxt+".rls","w")
 	outfile.write('[RULES]\n')
 	for R in RULES:
 		outfile.write("%d: " % i, )
-		#"&".join(e)
 		for e in R:
 				outfile.write("( %s %s %.3f )" % (e['label'], e['sign'],e['condition'] ))
 		outfile.write("=> ( class %s , %s )\n" % ( e['type'], e['class'] ))
@@ -532,67 +531,79 @@
 		i+=1
-	print mapstring
-	for m in maps:
-		print "mappa:", m
-		grass.run_command("v.db.update", map=m, column='label', value=" ".join(m.split('_')[1:]))
+	#make one layer for each label rule
+	for l in labels:
+		map_synth=[]
+		for m in maps:
+		else:
+		print "__",str(map_synth),l
+	mapslabels=",".join(labels)
 	if len(maps)>1:
+		grass.run_command("v.patch", overwrite='True', flags='e', input=mapslabels, output=outputMap)
 	else:
-		grass.run_command("g.copy",vect=(mapstring,outputMap))
+		grass.run_command("g.copy",vect=(mapslabels,outputMap))
 	if not flags['l']:
+		grass.run_command("g.remove",  rast=mapstring)
 	return 0
 def main():
 	"main function for DOMLEM algorithm"
+	#try:
+	start=time()
+	attributes = options['criteria'].split(',')
+	preferences=options['preferences'].split(',')
+	decision=options['decision']
+	outputMap= options['outputMap']
+	outputTxt= options['outputTxt']
+	out=BuildFileISF(attributes, preferences, decision, outputMap, outputTxt)
+	infosystem=FileToInfoSystem(out)
+	UnionOfClasses(infosystem)
+	DownwardUnionClass=DownwardUnionsOfClasses(infosystem)
+	UpwardUnionClass=UpwardUnionsOfClasses(infosystem)
+	Dominating=DominatingSet(infosystem)
+	Dominated=DominatedSet(infosystem)
+##	upward union class
+	print "elaborate upward union"
+	Lu=LowerApproximation(UpwardUnionClass, Dominating) #lower approximation of upward union for type 1 rules
+	Uu=UpperApproximation(UpwardUnionClass,Dominated ) #upper approximation of upward union
+	UpwardBoundary=Boundaries(Uu, Lu)
+##	downward union class
+	print "elaborate downward union"
+	Ld=LowerApproximation(DownwardUnionClass, Dominated) # lower approximation of  downward union for type 3 rules
+	Ud=UpperApproximation(DownwardUnionClass,Dominating ) # upper approximation of  downward union
+	DownwardBoundary=Boundaries(Ud, Ld)
+	QualityOfQpproximation(DownwardBoundary,  infosystem)
+	print "RULES extraction (*)"
+	RULES=Domlem(Lu,Ld, infosystem)
+	Parser_mapcalc(RULES, outputMap)
+	Print_rules(RULES, outputTxt)
+	end=time()
+	print "Time computing-> %.4f s" % (end-start)
+	return 0
+	#except:
+		#print "ERROR! Rules does not generated!"
+		#sys.exit()
-	try:
-		start=time()
-		attributes = options['criteria'].split(',')
-		preferences=options['preferences'].split(',')
-		decision=options['decision']
-		outputMap= options['outputMap']
-		outputTxt= options['outputTxt']
-		out=BuildFileISF(attributes, preferences, decision, outputMap, outputTxt)
-		infosystem=FileToInfoSystem(out)
-		UnionOfClasses(infosystem)
-		DownwardUnionClass=DownwardUnionsOfClasses(infosystem)
-		UpwardUnionClass=UpwardUnionsOfClasses(infosystem)
-		Dominating=DominatingSet(infosystem)
-		Dominated=DominatedSet(infosystem)
-	##	upward union class
-		print "elaborate upward union"
-		Lu=LowerApproximation(UpwardUnionClass, Dominating) #lower approximation of upward union for type 1 rules
-		Uu=UpperApproximation(UpwardUnionClass,Dominated ) #upper approximation of upward union
-		UpwardBoundary=Boundaries(Uu, Lu)
-	##	downward union class
-		print "elaborate downward union"
-		Ld=LowerApproximation(DownwardUnionClass, Dominated) # lower approximation of  downward union for type 3 rules
-		Ud=UpperApproximation(DownwardUnionClass,Dominating ) # upper approximation of  downward union
-		DownwardBoundary=Boundaries(Ud, Ld)
-		QualityOfQpproximation(DownwardBoundary,  infosystem)
-		print "RULES extraction (*)"
-		RULES=Domlem(Lu,Ld, infosystem)
-		Parser_mapcalc(RULES, outputMap)
-		Print_rules(RULES, outputTxt)
-		end=time()
-		print "Time computing-> %.4f s" % (end-start)
-		return 0
-	except:
-		print "ERROR! Rules does not generated!"
-		sys.exit()
 	sys.exit(main())
