[GRASS-SVN] r53853 - grass/branches/develbranch_6
svn_grass at osgeo.org
Sat Nov 17 03:32:14 PST 2012
Author: martinl
Date: 2012-11-17 03:32:13 -0800 (Sat, 17 Nov 2012)
New Revision: 53853
grass/branches/develbranch_6/configure
grass/branches/develbranch_6/configure.in
configure: fix ffmpeg switch - replace deprecated fns avcodec_init() and av_set_parameters()
see http://git.videolan.org/gitweb.cgi/ffmpeg.git/?a=commit;h=7221139ba0486c24afeac1f41ba97c75f58046b9
Modified: grass/branches/develbranch_6/configure
--- grass/branches/develbranch_6/configure 2012-11-17 11:27:34 UTC (rev 53852)
+++ grass/branches/develbranch_6/configure 2012-11-17 11:32:13 UTC (rev 53853)
@@ -10459,9 +10459,9 @@
-echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:10464: checking for avcodec_init in -lavcodec" >&5
-ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
+echo $ac_n "checking for avcodec_register in -lavcodec""... $ac_c" 1>&6
+echo "configure:10464: checking for avcodec_register in -lavcodec" >&5
+ac_lib_var=`echo avcodec'_'avcodec_register | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lavcodec $FFMPEGLIB $LIBS"
@@ -10471,10 +10471,10 @@
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
builtin and then its argument prototype would still apply. */
-char avcodec_init();
+char avcodec_register();
int main() {
-avcodec_init()
+avcodec_register()
; return 0; }
EOF
if { (eval echo configure:10481: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
@@ -10495,9 +10495,9 @@
else
echo "$ac_t""no" 1>&6
-echo "configure:10500: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10500: checking for avcodec_register in -lavcodec" >&5
LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
@@ -10507,10 +10507,10 @@
int main() {
-avcodec_init()
+avcodec_register()
; return 0; }
EOF
if { (eval echo configure:10517: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
@@ -10557,9 +10557,9 @@
-echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:10562: checking for av_set_parameters in -lavformat" >&5
-ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
+echo $ac_n "checking for avformat_write_header in -lavformat""... $ac_c" 1>&6
+echo "configure:10562: checking for avformat_write_header in -lavformat" >&5
+ac_lib_var=`echo avformat'_'avformat_write_header | sed 'y%./+-%__p_%'`
LIBS="-lavformat $FFMPEGLIB $LIBS"
@@ -10569,10 +10569,10 @@
-char av_set_parameters();
+char avformat_write_header();
int main() {
-av_set_parameters()
+avformat_write_header()
; return 0; }
EOF
if { (eval echo configure:10579: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
@@ -10593,9 +10593,9 @@
else
-echo "configure:10598: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10598: checking for avformat_write_header in -lavformat" >&5
LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
@@ -10605,10 +10605,10 @@
int main() {
; return 0; }
EOF
if { (eval echo configure:10615: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
Modified: grass/branches/develbranch_6/configure.in
--- grass/branches/develbranch_6/configure.in 2012-11-17 11:27:34 UTC (rev 53852)
+++ grass/branches/develbranch_6/configure.in 2012-11-17 11:32:13 UTC (rev 53853)
@@ -1090,8 +1090,8 @@
LOC_CHECK_LIB_PATH(ffmpeg, FFMPEG, FFMPEGLIBPATH)
LOC_CHECK_LIBS(avutil, av_free, FFMPEG, $FFMPEGLIBPATH, FFMPEGLIB,,,,$MATHLIB)
-LOC_CHECK_LIBS(avcodec, avcodec_init, FFMPEG, $FFMPEGLIBPATH, FFMPEGLIB, $FFMPEGLIB,,,$MATHLIB)
-LOC_CHECK_LIBS(avformat, av_set_parameters, FFMPEG, $FFMPEGLIBPATH, FFMPEGLIB, $FFMPEGLIB,,,$MATHLIB)
+LOC_CHECK_LIBS(avcodec, avcodec_register, FFMPEG, $FFMPEGLIBPATH, FFMPEGLIB, $FFMPEGLIB,,,$MATHLIB)
+LOC_CHECK_LIBS(avformat, avformat_write_header, FFMPEG, $FFMPEGLIBPATH, FFMPEGLIB, $FFMPEGLIB,,,$MATHLIB)
fi # $USE_FFMPEG
