[GRASS-SVN] r53855 - grass/branches/develbranch_6/lib/ogsf
svn_grass at osgeo.org
Sat Nov 17 04:09:26 PST 2012
Author: martinl
Date: 2012-11-17 04:09:26 -0800 (Sat, 17 Nov 2012)
New Revision: 53855
grass/branches/develbranch_6/lib/ogsf/gsd_img_mpeg.c
update ogsf for ffmpeg, replace deprecated fns
(merge r53854 from trunk)
Modified: grass/branches/develbranch_6/lib/ogsf/gsd_img_mpeg.c
--- grass/branches/develbranch_6/lib/ogsf/gsd_img_mpeg.c 2012-11-17 12:07:49 UTC (rev 53854)
+++ grass/branches/develbranch_6/lib/ogsf/gsd_img_mpeg.c 2012-11-17 12:09:26 UTC (rev 53855)
@@ -27,6 +27,7 @@
/* FFMPEG stuff */
#ifdef HAVE_FFMPEG
#include <avformat.h>
+#include <avio.h>
/* 5 seconds stream duration */
#define STREAM_DURATION 5.0
@@ -58,7 +59,7 @@
AVCodecContext *c;
AVStream *st;
- st = av_new_stream(oc, 0);
+ st = avformat_new_stream(oc, NULL);
if (!st) {
G_warning(_("Unable to allocate stream"));
return NULL;
@@ -97,7 +98,12 @@
c->flags |= CODEC_FLAG_GLOBAL_HEADER;
c->flags |= CODEC_FLAG_QSCALE;
- c->global_quality = st->quality = FF_QP2LAMBDA * 10;
+ /* Quality, as it has been removed from AVCodecContext and put in AVVideoFrame.
+ \todo use AVVideoFrame
+ c->global_quality = st->quality = FF_QP2LAMBDA * 10;
+ c->global_quality = FF_QP2LAMBDA * 10;
return st;
@@ -158,7 +164,7 @@
/* open the codec */
- if (avcodec_open(c, codec) < 0) {
+ if (avcodec_open2(c, codec, NULL) < 0) {
G_warning(_("Unable to open codec"));
return;
@@ -261,7 +267,7 @@
\param oc [unused]
\param st
-static void close_video(AVFormatContext * oc, AVStream * st)
+static void close_video(AVStream * st)
avcodec_close(st->codec);
av_free(picture->data[0]);
@@ -333,12 +339,12 @@
/* set the output parameters (must be done even if no parameters). */
- if (av_set_parameters(oc, NULL) < 0) {
+ if (avformat_write_header(oc, NULL) < 0) {
G_warning(_("Invalid output format parameters"));
return (-1);
- dump_format(oc, 0, filename, 1);
+ av_dump_format(oc, 0, filename, 1);
/* now that all the parameters are set, we can open the audio and
video codecs and allocate the necessary encode buffers */
@@ -347,14 +353,14 @@
/* open the output file, if needed */
if (!(fmt->flags & AVFMT_NOFILE)) {
- if (url_fopen(&oc->pb, filename, URL_WRONLY) < 0) {
+ if (avio_open(&oc->pb, filename, AVIO_FLAG_WRITE) < 0) {
G_warning(_("Unable to open <%s>"), filename);
return (-1);
/* write the stream header, if any */
- av_write_header(oc);
+ avformat_write_header(oc, NULL);
#else
@@ -374,8 +380,8 @@
int gsd_write_mpegframe(void)
#ifdef HAVE_FFMPEG
- unsigned int xsize, ysize;
- int x, y, xy, xy_uv;
+ unsigned int xsize, ysize, x;
+ int y, xy, xy_uv;
int yy, uu, vv;
unsigned char *pixbuf;
@@ -421,9 +427,9 @@
int gsd_close_mpeg(void)
#ifdef HAVE_FFMPEG
- int i;
+ unsigned int i;
- close_video(oc, video_st);
+ close_video(video_st);
/* write the trailer, if any */
av_write_trailer(oc);
@@ -436,11 +442,7 @@
/* close the output file */
-#if (LIBAVFORMAT_VERSION_INT>>16) < 52
- url_fclose(&oc->pb);
-#else
- url_fclose(oc->pb);
-#endif
+ avio_close(oc->pb);
/* free the stream */
