[GRASS-SVN] r53857 - grass/branches/releasebranch_6_4
Sat Nov 17 04:11:23 PST 2012
Author: martinl
Date: 2012-11-17 04:11:22 -0800 (Sat, 17 Nov 2012)
New Revision: 53857
   grass/branches/releasebranch_6_4/configure
   grass/branches/releasebranch_6_4/configure.in
configure: fix ffmpeg switch - replace deprecated fns avcodec_init() and av_set_parameters()
           see http://git.videolan.org/gitweb.cgi/ffmpeg.git/?a=commit;h=7221139ba0486c24afeac1f41ba97c75f58046b9
Modified: grass/branches/releasebranch_6_4/configure
--- grass/branches/releasebranch_6_4/configure	2012-11-17 12:10:52 UTC (rev 53856)
+++ grass/branches/releasebranch_6_4/configure	2012-11-17 12:11:22 UTC (rev 53857)
@@ -10460,9 +10460,9 @@
-echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:10465: checking for avcodec_init in -lavcodec" >&5
-ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
+echo $ac_n "checking for avcodec_register in -lavcodec""... $ac_c" 1>&6
+echo "configure:10465: checking for avcodec_register in -lavcodec" >&5
+ac_lib_var=`echo avcodec'_'avcodec_register | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lavcodec $FFMPEGLIB  $LIBS"
@@ -10472,10 +10472,10 @@
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
     builtin and then its argument prototype would still apply.  */
-char avcodec_init();
+char avcodec_register();
 int main() {
-avcodec_init()
+avcodec_register()
 ; return 0; }
 EOF
 if { (eval echo configure:10482: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
@@ -10496,9 +10496,9 @@
 else
   echo "$ac_t""no" 1>&6
-echo "configure:10501: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10501: checking for avcodec_register in -lavcodec" >&5
 LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
@@ -10508,10 +10508,10 @@
 int main() {
-avcodec_init()
+avcodec_register()
 ; return 0; }
 EOF
 if { (eval echo configure:10518: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
@@ -10558,9 +10558,9 @@
-echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:10563: checking for av_set_parameters in -lavformat" >&5
-ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
+echo $ac_n "checking for avformat_write_header in -lavformat""... $ac_c" 1>&6
+echo "configure:10563: checking for avformat_write_header in -lavformat" >&5
+ac_lib_var=`echo avformat'_'avformat_write_header | sed 'y%./+-%__p_%'`
 LIBS="-lavformat $FFMPEGLIB  $LIBS"
@@ -10570,10 +10570,10 @@
-char av_set_parameters();
+char avformat_write_header();
 int main() {
-av_set_parameters()
+avformat_write_header()
 ; return 0; }
 EOF
 if { (eval echo configure:10580: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
@@ -10594,9 +10594,9 @@
 else
-echo "configure:10599: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10599: checking for avformat_write_header in -lavformat" >&5
 LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
@@ -10606,10 +10606,10 @@
 int main() {
 ; return 0; }
 EOF
 if { (eval echo configure:10616: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
@@ -15612,58 +15612,7 @@
   fi
 fi
-for ac_declaration in \
-   '#include <stdlib.h>' \
-   'extern "C" void std::exit (int) throw (); using std::exit;' \
-   'extern "C" void std::exit (int); using std::exit;' \
-   'extern "C" void exit (int) throw ();' \
-   'extern "C" void exit (int);' \
-   'void exit (int);'
-do
-  cat > conftest.$ac_ext <<EOF
-#line 15626 "configure"
-#include "confdefs.h"
-#include <stdlib.h>
-$ac_declaration
-int main() {
-exit (42);
-; return 0; }
-EOF
-if { (eval echo configure:15634: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
-  echo "configure: failed program was:" >&5
-  cat conftest.$ac_ext >&5
-  rm -rf conftest*
-  continue
-fi
-rm -f conftest*
-#line 15644 "configure"
-$ac_declaration
-int main() {
-exit (42);
-; return 0; }
-EOF
-if { (eval echo configure:15651: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
-  rm -rf conftest*
-  break
-else
-fi
-rm -f conftest*
-done
-if test -n "$ac_declaration"; then
-  echo '#ifdef __cplusplus' >>confdefs.h
-  echo $ac_declaration      >>confdefs.h
-  echo '#endif'             >>confdefs.h
-fi
-else
 	CXX=
 	CXXFLAGS=
@@ -15676,7 +15625,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:15680: checking whether to use openDWG" >&5
+echo "configure:15629: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -15696,7 +15645,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:15700: checking for location of openDGW includes" >&5
+echo "configure:15649: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -15722,15 +15671,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:15726: checking for $ac_hdr" >&5
+echo "configure:15675: checking for $ac_hdr" >&5
-#line 15729 "configure"
+#line 15678 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:15734: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15683: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -15764,7 +15713,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:15768: checking for location of openDWG library" >&5
+echo "configure:15717: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -15811,7 +15760,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:15815: checking for special C compiler options needed for large files" >&5
+echo "configure:15764: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -15819,7 +15768,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 15823 "configure"
+#line 15772 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -15835,7 +15784,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15839: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15788: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
@@ -15844,7 +15793,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 15848 "configure"
+#line 15797 "configure"
@@ -15860,7 +15809,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15864: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15813: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -15880,11 +15829,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:15884: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:15833: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 15888 "configure"
+#line 15837 "configure"
@@ -15900,14 +15849,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15904: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15853: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15911 "configure"
+#line 15860 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -15925,7 +15874,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15929: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15878: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -15944,11 +15893,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:15948: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:15897: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 15952 "configure"
+#line 15901 "configure"
@@ -15964,14 +15913,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15968: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15917: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15975 "configure"
+#line 15924 "configure"
 #define _LARGE_FILES 1
@@ -15989,7 +15938,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15993: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15942: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -16008,25 +15957,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:16012: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:15961: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 16016 "configure"
+#line 15965 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:16023: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15972: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 16030 "configure"
+#line 15979 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -16035,7 +15984,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:16039: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15988: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -16056,10 +16005,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:16060: checking if system supports Large Files at all" >&5
+echo "configure:16009: checking if system supports Large Files at all" >&5
-#line 16063 "configure"
+#line 16012 "configure"
 #include <stdio.h>
@@ -16091,7 +16040,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:16095: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16044: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -16120,7 +16069,7 @@
 # Python check
 echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:16124: checking whether to use Python" >&5
+echo "configure:16073: checking whether to use Python" >&5
 PYTHONINC=
 PYTHONCFLAGS=
@@ -16140,7 +16089,7 @@
   # Extract the first word of "python-config", so it can be a program name with args.
 set dummy python-config; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:16144: checking for $ac_word" >&5
+echo "configure:16093: checking for $ac_word" >&5
 case "$PY_CONFIG" in
@@ -16182,15 +16131,15 @@
 do
-echo "configure:16186: checking for $ac_hdr" >&5
+echo "configure:16135: checking for $ac_hdr" >&5
-#line 16189 "configure"
+#line 16138 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:16194: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16143: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -16260,7 +16209,7 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:16264: checking whether to use wxWidgets" >&5
+echo "configure:16213: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
@@ -16281,7 +16230,7 @@
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
-echo "configure:16285: checking for $ac_word" >&5
+echo "configure:16234: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -16329,7 +16278,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:16333: checking wxWidgets version" >&5
+echo "configure:16282: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -16352,15 +16301,15 @@
 do
-echo "configure:16356: checking for $ac_hdr" >&5
+echo "configure:16305: checking for $ac_hdr" >&5
-#line 16359 "configure"
+#line 16308 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:16364: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16313: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
Modified: grass/branches/releasebranch_6_4/configure.in
--- grass/branches/releasebranch_6_4/configure.in	2012-11-17 12:10:52 UTC (rev 53856)
+++ grass/branches/releasebranch_6_4/configure.in	2012-11-17 12:11:22 UTC (rev 53857)
@@ -1091,8 +1091,8 @@
 LOC_CHECK_LIB_PATH(ffmpeg, FFMPEG, FFMPEGLIBPATH)
 LOC_CHECK_LIBS(avutil, av_free, FFMPEG, $FFMPEGLIBPATH, FFMPEGLIB,,,,$MATHLIB)
-LOC_CHECK_LIBS(avcodec, avcodec_init, FFMPEG, $FFMPEGLIBPATH, FFMPEGLIB, $FFMPEGLIB,,,$MATHLIB)
-LOC_CHECK_LIBS(avformat, av_set_parameters, FFMPEG, $FFMPEGLIBPATH, FFMPEGLIB, $FFMPEGLIB,,,$MATHLIB)
+LOC_CHECK_LIBS(avcodec, avcodec_register, FFMPEG, $FFMPEGLIBPATH, FFMPEGLIB, $FFMPEGLIB,,,$MATHLIB)
+LOC_CHECK_LIBS(avformat, avformat_write_header, FFMPEG, $FFMPEGLIBPATH, FFMPEGLIB, $FFMPEGLIB,,,$MATHLIB)
 fi # $USE_FFMPEG
