[GRASS-SVN] r53888 - in grass/trunk: . locale
Sun Nov 18 04:18:23 PST 2012
Author: marisn
Date: 2012-11-18 04:18:23 -0800 (Sun, 18 Nov 2012)
New Revision: 53888
   grass/trunk/SUBMITTING
   grass/trunk/locale/Makefile
   grass/trunk/locale/README
Ability to add comments for GRASS translators with GTC keyword in code comments
Modified: grass/trunk/SUBMITTING
--- grass/trunk/SUBMITTING	2012-11-18 11:28:19 UTC (rev 53887)
+++ grass/trunk/SUBMITTING	2012-11-18 12:18:23 UTC (rev 53888)
@@ -142,6 +142,14 @@
     Always use the gettext macros with _("") for user messages,
     example:
       G_fatal_error(_("Vector map <%s> not found"), name);
+    It is suggested to add a comment line before translatable user message
+    to give a hint to translators about meaning or use of
+    cumbersome or obscure message. First word in the comment must be GTC
+    - GRASS translation comment,
+    example:
+        /* GTC A name of a projection */
+        G_message(_("State Plane"));
+    See locale/README for details.
     Pipe/file data output:
Modified: grass/trunk/locale/Makefile
--- grass/trunk/locale/Makefile	2012-11-18 11:28:19 UTC (rev 53887)
+++ grass/trunk/locale/Makefile	2012-11-18 12:18:23 UTC (rev 53888)
@@ -47,11 +47,11 @@
 		exit 1 ; \
 	fi
 	@echo "Generating $(LIBDOMAIN)..."
-	xgettext -k_ -o ./templates/$(LIBDOMAIN).pot `$(LIB_POTFILES)`
+	xgettext -k_ -cGTC -o ./templates/$(LIBDOMAIN).pot `$(LIB_POTFILES)`
 	@echo "Generating $(MODDOMAIN)..."
-	xgettext -k_ -o ./templates/$(MODDOMAIN).pot `$(MOD_POTFILES)`
+	xgettext -k_ -cGTC -o ./templates/$(MODDOMAIN).pot `$(MOD_POTFILES)`
 	@echo "Generating $(WXPYDOMAIN)..."
-	xgettext -k_ -o ./templates/$(WXPYDOMAIN).pot `$(WXPY_POTFILES)`
+	xgettext -k_ -cGTC -o ./templates/$(WXPYDOMAIN).pot `$(WXPY_POTFILES)`
 #merge already existing translations with new messages in POT template file and create new po files:
 update-po:
Modified: grass/trunk/locale/README
--- grass/trunk/locale/README	2012-11-18 11:28:19 UTC (rev 53887)
+++ grass/trunk/locale/README	2012-11-18 12:18:23 UTC (rev 53888)
@@ -48,12 +48,19 @@
 NOTE2: Also the parameters/flags of each module needs the
        macro _().
+NOTE3: Notices to translators can be added by placing
+       a comment line starting with GTC tag just above
+       message to be translated:
+        /* GTC A comma separated keyword list.
+           Should not contain spaces! */
+        keywords = _("first,second,third");
 All these messages strings will be then automatically
 extracted into the message files.
 See for example ./vector/v.what.rast/main.c
-NOTE3: Such lines
+NOTE4: Such lines
         fprintf (stdout,"\n");
   do not need a change as no translation is needed.
