[GRASS-SVN] r53903 - grass/trunk/vector/v.out.postgis
Sun Nov 18 12:30:37 PST 2012
Author: martinl
Date: 2012-11-18 12:30:36 -0800 (Sun, 18 Nov 2012)
New Revision: 53903
   grass/trunk/vector/v.out.postgis/create.c
   grass/trunk/vector/v.out.postgis/v.out.postgis.html
v.out.postgis: add more examples to the manual page
               fix topology export
Modified: grass/trunk/vector/v.out.postgis/create.c
--- grass/trunk/vector/v.out.postgis/create.c	2012-11-18 19:22:13 UTC (rev 53902)
+++ grass/trunk/vector/v.out.postgis/create.c	2012-11-18 20:30:36 UTC (rev 53903)
@@ -67,7 +67,7 @@
     if (schema)
         G_set_key_value("schema", schema, key_val);
     if (topo)
-        G_set_key_value("topology", "on", key_val);
+        G_set_key_value("topology", "yes", key_val);
     /* extra options */
     if (options) {
Modified: grass/trunk/vector/v.out.postgis/v.out.postgis.html
--- grass/trunk/vector/v.out.postgis/v.out.postgis.html	2012-11-18 19:22:13 UTC (rev 53902)
+++ grass/trunk/vector/v.out.postgis/v.out.postgis.html	2012-11-18 20:30:36 UTC (rev 53903)
@@ -47,9 +47,20 @@
 areas) become polygons, isles become holes. Geometry of simple feature
 elements is stored in PostGIS feature table as column
 "geom". Default name of the geometry column can be changed
-by <b>options=</b><tt>GEOMETRY_NAME=<column></tt>.
+by <b>options=</b><tt>GEOMETRY_NAME=<column></tt>. Note that for
+exporting vector features as simple features can be alternatively
+used <a href="http://gdal.org/ogr/drv_pg.html">PostgreSQL driver</a>
+from <a href="http://gdal.org/ogr/">OGR</a> library
+through <em><a href="v.out.ogr.html">v.out.ogr</a></em> module.
 <p>
+Also note that it's allowed to store in the feature table only
+features of the same type, ie. mixing of points and lines is not
+possible. The feature type is determined for output feature table from
+the first read vector feature when accessing data sequentially. Vector
+features of other types are during export skipped.
+<p>
 <em>v.out.postgis</em> also allows to export vector features as
 <em>topological elements</em>
 in <a href="http://postgis.refractions.net/docs/Topology.html">PostGIS
@@ -80,8 +91,8 @@
 <h3>Export Simple Features</h3>
-Export vector map <i>urbanarea</i> as feature table <i>urbanarea</i>
-located in database <i>grass</i>, schema <i>public</i>. Note that this
+Export vector map "urbanarea" as feature table "urbanarea"
+located in database "grass", schema "public". Note that this
 database schema is automatically used when not defined by the user.
 <div class="code"><pre>
@@ -99,6 +110,21 @@
 ST_Polygon|657
 </pre></div>
+<i>Note:</i> same procedure can be done
+by <em><a href="v.out.ogr.html">v.out.ogr</a></em> module, eg.
+<div class="code"><pre>
+v.out.ogr input=urbanarea dsn="PG:dbname=grass" format=PostgreSQL
+</pre></div>
+In this case GRASS vector data are exported to PostGIS database using
+OGR library, namely using PostgreSQL driver. Contrary to
+the <em><a href="v.out.ogr.html">v.out.ogr</a></em>
+module, <em>v.out.postgis</em> is using directly PostGIS data provider
+which is part of GRASS vector engine. Beside
+that, <em>v.out.postgis</em> is optimized for PostGIS export including
+topological access to the data.
 <h3>Export data into specific database schema</h3>
 Database schema for storing exported data can be defined
@@ -126,7 +152,7 @@
 <h3>Link exported data</h3>
 Exported data can be linked as vector map created in the current
-mapset by specifing <b>olink</b> parameter. In the example below
+mapset by specifying <b>olink</b> parameter. In the example below
 vector map "busstopsall" from PERMANENT mapset is exported
 into "grass" PostGIS database. <em>v.out.postgis</em> after
 successful export also creates in the current mapset GRASS vector map
@@ -155,12 +181,35 @@
 </pre></div>
+<h3>Export data without attributes</h3>
+<em>v.out.postgis</em> allows to ignore attributes when exporting
+vector features by specifing <b>-t</b> flag.
+Command bellow exports vector features without attributes. The feature
+will contain only two columns, the fid and geometry column.
+v.out.postgis -t input=railroads dsn="PG:dbname=grass"
+</pre></div>
 <h3>Export topological data</h3>
+By default <em>v.out.postgis</em> exports data as simple
+features. Flag <b>-l</b> allows to export data as topological elements
+instead of simple features. Export topological elements is stored in
+PostGIS Topology schema.
+v.out.postgis -l input=busroutesall dsn="PG:dbname=grass"
+</pre></div>
 <h2>TODO</h2>
 <ul>
   <li>Multi-feature export</li>
+  <li>Allow mixed features (points, lines) - use
+  GeometryCollection</li>
 </ul>
 <h2>REFERENCES</h2>
