[GRASS-SVN] r53923 - in grass/trunk/gui/wxpython: gui_core lmgr
Mon Nov 19 10:45:49 PST 2012
Author: annakrat
Date: 2012-11-19 10:45:48 -0800 (Mon, 19 Nov 2012)
New Revision: 53923
   grass/trunk/gui/wxpython/gui_core/widgets.py
   grass/trunk/gui/wxpython/lmgr/frame.py
wxGUI: move highlighting of command tab from lmgr to notebook
Modified: grass/trunk/gui/wxpython/gui_core/widgets.py
--- grass/trunk/gui/wxpython/gui_core/widgets.py	2012-11-19 18:11:23 UTC (rev 53922)
+++ grass/trunk/gui/wxpython/gui_core/widgets.py	2012-11-19 18:45:48 UTC (rev 53923)
@@ -72,9 +72,13 @@
         self.notebookPages = {}
         self.classObject = classObject
         self.widget = widget
-        # TODO: (...) should be only once in wxGUI
         self.highlightedTextEnd = _(" (...)")
+        self.BindPageChanged()
+    def BindPageChanged(self):
+        """!Binds page changed event."""
+        self.widget.Bind(wx.EVT_NOTEBOOK_PAGE_CHANGED, self.OnRemoveHighlight)
     def AddPage(self, **kwargs):
         """!Add a new page
@@ -131,13 +135,24 @@
         idx = self.GetPageIndexByName(page)
         if self.classObject.GetSelection(self.widget) != idx:
             self.classObject.SetSelection(self.widget, idx)
-            # FIXME: this code was not explicitly tested
-            # FIXME: remove this from function lmgr.frame.Frame.OnPageChanged
-            text = self.classObject.GetPageText(self.widget, idx)
-            if text.endswith(self.highlightedTextEnd):
-                text.replace(self.highlightedTextEnd, '')
-                self.classObject.SetPageText(self.widget, idx, text)
+            self.RemoveHighlight(idx)
+    def OnRemoveHighlight(self, event):
+        """!Highlighted tab name should be removed."""
+        page = event.GetSelection()
+        self.RemoveHighlight(page)
+    def RemoveHighlight(self, page):
+        """!Removes highlight string from notebook tab name if necessary.
+        @param page index
+        text = self.classObject.GetPageText(self.widget, page)
+        if text.endswith(self.highlightedTextEnd):
+            text = text.replace(self.highlightedTextEnd, '')
+            self.classObject.SetPageText(self.widget, page, text)
     def GetPageIndexByName(self, page):
         """!Get notebook page index
@@ -176,6 +191,9 @@
     def __init__(self, classObject, widget):
         NotebookController.__init__(self, classObject, widget)
+        self.widget.Bind(FN.EVT_FLATNOTEBOOK_PAGE_CHANGED, self.OnRemoveHighlight)
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py	2012-11-19 18:11:23 UTC (rev 53922)
+++ grass/trunk/gui/wxpython/lmgr/frame.py	2012-11-19 18:45:48 UTC (rev 53923)
@@ -477,8 +477,6 @@
         """!Page in notebook changed"""
         if page == self.notebook.GetPageIndexByName('output'):
-            # remove '(...)'
-            self.notebook.SetPageText(page, _("Command console"))
             wx.CallAfter(self.goutput.ResetFocus)
         self.SetStatusText('', 0)
