[GRASS-SVN] r53933 - in grass/trunk/gui/wxpython: core gmodeler gui_core lmgr
svn_grass at osgeo.org
Tue Nov 20 02:53:12 PST 2012
Author: wenzeslaus
Date: 2012-11-20 02:53:11 -0800 (Tue, 20 Nov 2012)
New Revision: 53933
grass/trunk/gui/wxpython/core/events.py
grass/trunk/gui/wxpython/gmodeler/frame.py
grass/trunk/gui/wxpython/gui_core/forms.py
grass/trunk/gui/wxpython/gui_core/goutput.py
grass/trunk/gui/wxpython/lmgr/frame.py
wxGUI/GConsole: decoupling LayerManager and TaskForm/ModuleForm (co-author: annakrat)
Modified: grass/trunk/gui/wxpython/core/events.py
--- grass/trunk/gui/wxpython/core/events.py 2012-11-20 08:38:00 UTC (rev 53932)
+++ grass/trunk/gui/wxpython/core/events.py 2012-11-20 10:53:11 UTC (rev 53933)
@@ -23,3 +23,8 @@
# The message attribute contains the text of the message (plain text)
gShowNotification, EVT_SHOW_NOTIFICATION = NewCommandEvent()
+# Occurs event when some map is created or updated by a module.
+# attributes: name: map name, ltype: map type,
+# add: if map should be added to layer tree (questionable attribute)
+gMapCreated, EVT_MAP_CREATED = NewCommandEvent()
Modified: grass/trunk/gui/wxpython/gmodeler/frame.py
--- grass/trunk/gui/wxpython/gmodeler/frame.py 2012-11-20 08:38:00 UTC (rev 53932)
+++ grass/trunk/gui/wxpython/gmodeler/frame.py 2012-11-20 10:53:11 UTC (rev 53933)
@@ -36,6 +36,7 @@
from gui_core.widgets import GNotebook
from gui_core.goutput import GConsole, \
EVT_CMD_RUN, EVT_CMD_DONE, EVT_CMD_PREPARE, EVT_OUTPUT_TEXT
+from core.events import EVT_MAP_CREATED
from core.debug import Debug
from core.gcmd import GMessage, GException, GWarning, GError, RunCommand
from gui_core.dialogs import GetImageHandlers
@@ -110,6 +111,7 @@
self.Bind(EVT_CMD_RUN, self.OnCmdRun)
self.Bind(EVT_CMD_DONE, self.OnCmdDone)
self.Bind(EVT_CMD_PREPARE, self.OnCmdPrepare)
+ self.Bind(EVT_MAP_CREATED, self.OnMapCreated)
self.notebook.AddPage(page = self.canvas, text=_('Model'), name = 'model')
self.notebook.AddPage(page = self.itemPanel, text=_('Items'), name = 'items')
@@ -226,7 +228,15 @@
action.Update(running = True)
except IndexError:
pass
+ def OnMapCreated(self, event):
+ """!Map was created but we don't want to add it to layer tree.
+ # remove this method if you want to add it to layer tree
+ # or see gui_core.forms.TaskFrame.OnMapCreated
+ event.add = False
+ event.Skip()
def OnCloseWindow(self, event):
"""!Close window"""
if self.modelChanged and \
Modified: grass/trunk/gui/wxpython/gui_core/forms.py
--- grass/trunk/gui/wxpython/gui_core/forms.py 2012-11-20 08:38:00 UTC (rev 53932)
+++ grass/trunk/gui/wxpython/gui_core/forms.py 2012-11-20 10:53:11 UTC (rev 53933)
@@ -90,6 +90,7 @@
from core import gcmd
from core import utils
from core.settings import UserSettings
from gui_core.widgets import FloatValidator, GNotebook, FormNotebook, FormListbook
wxUpdateDialog, EVT_DIALOG_UPDATE = NewEvent()
@@ -533,9 +534,10 @@
guisizer.Add(item = self.closebox, proportion = 0,
flag = wx.EXPAND | wx.LEFT | wx.RIGHT | wx.BOTTOM,
border = 5)
+ # bindings
self.Bind(wx.EVT_CLOSE, self.OnCancel)
self.Bind(wx.EVT_KEY_UP, self.OnKeyUp)
# do layout
# called automatically by SetSizer()
@@ -606,34 +608,34 @@
@param returncode command's return code (0 for success)
- if not self.parent or returncode != 0:
- return
- if self.parent.GetName() not in ('LayerTree', 'LayerManager'):
- return
- if self.parent.GetName() == 'LayerTree':
- display = self.parent.GetMapDisplay()
- else: # Layer Manager
- display = self.parent.GetLayerTree().GetMapDisplay()
- if not display or not display.IsAutoRendered():
- return
- mapLayers = map(lambda x: x.GetName(),
- display.GetMap().GetListOfLayers(l_type = 'raster') +
- display.GetMap().GetListOfLayers(l_type = 'vector'))
- task = GUI(show = None).ParseCommand(cmd)
- for p in task.get_options()['params']:
- if p.get('prompt', '') not in ('raster', 'vector'):
- continue
- mapName = p.get('value', '')
- if '@' not in mapName:
- mapName = mapName + '@' + grass.gisenv()['MAPSET']
- if mapName in mapLayers:
- display.GetWindow().UpdateMap(render = True)
- return
+ if hasattr(self, "btn_cancel"):
+ self.btn_cancel.Enable(True)
+ if hasattr(self, "btn_clipboard"):
+ self.btn_clipboard.Enable(True)
+ if hasattr(self, "btn_help"):
+ self.btn_help.Enable(True)
+ if hasattr(self, "btn_run"):
+ self.btn_run.Enable(True)
+ if hasattr(self, "get_dcmd") and \
+ self.get_dcmd is None and \
+ hasattr(self, "closebox") and \
+ self.closebox.IsChecked() and \
+ (returncode == 0):
+ # was closed also when aborted but better is leave it open
+ wx.FutureCall(2000, self.Close)
+ if hasattr(self, "addbox") and self.addbox.IsChecked():
+ event.add = True
+ else:
+ event.add = False
+ event.Skip()
def OnOK(self, event):
"""!OK button pressed"""
cmd = self.OnApply(event)
Modified: grass/trunk/gui/wxpython/gui_core/goutput.py
--- grass/trunk/gui/wxpython/gui_core/goutput.py 2012-11-20 08:38:00 UTC (rev 53932)
+++ grass/trunk/gui/wxpython/gui_core/goutput.py 2012-11-20 10:53:11 UTC (rev 53933)
@@ -39,11 +39,11 @@
from core import globalvar
from core.gcmd import CommandThread, GMessage, GError, GException, EncodeString
-from core.events import gShowNotification
+from core.events import gShowNotification, gMapCreated
from gui_core.forms import GUI
from gui_core.prompt import GPromptSTC
-from core.settings import UserSettings, GetDisplayVectSettings
+from core.settings import UserSettings
from gui_core.widgets import SearchModuleWidget, EVT_MODULE_SELECTED
from core.modulesdata import ModulesData
@@ -866,112 +866,32 @@
if event.cmd[0] == 'g.gisenv':
Debug.SetLevel()
self.Redirect()
- if self.frame.GetName() == "LayerManager":
- self.btnCmdAbort.Enable(False)
- if event.cmd[0] not in globalvar.grassCmd or \
- event.cmd[0] == 'r.mapcalc':
- return
+ # do nothing when no map added
+ if event.returncode != 0 or event.aborted:
+ event.Skip()
+ return
+ # find which maps were created
+ try:
+ task = GUI(show = None).ParseCommand(event.cmd)
+ except GException, e:
+ print >> sys.stderr, e
+ task = None
+ return
- tree = self.frame.GetLayerTree()
- display = None
- if tree:
- display = tree.GetMapDisplay()
- return
- try:
- task = GUI(show = None).ParseCommand(event.cmd)
- except GException, e:
- print >> sys.stderr, e
- task = None
- return
- continue
- return
- elif self.frame.GetName() == 'Modeler':
- pass
- else: # standalone dialogs
- dialog = self.frame
- if hasattr(dialog, "btn_abort"):
- dialog.btn_abort.Enable(False)
- if hasattr(dialog, "btn_cancel"):
- dialog.btn_cancel.Enable(True)
- if hasattr(dialog, "btn_clipboard"):
- dialog.btn_clipboard.Enable(True)
- if hasattr(dialog, "btn_help"):
- dialog.btn_help.Enable(True)
- if hasattr(dialog, "btn_run"):
- dialog.btn_run.Enable(True)
- if event.returncode == 0 and not event.aborted:
- try:
- winName = self.frame.parent.GetName()
- except AttributeError:
- winName = ''
- if winName == 'LayerManager':
- mapTree = self.frame.parent.GetLayerTree()
- elif winName == 'LayerTree':
- elif winName: # GConsole
- mapTree = self.frame.parent.parent.GetLayerTree()
- else:
- mapTree = None
- cmd = dialog.notebookpanel.createCmd(ignoreErrors = True)
- if hasattr(dialog, "addbox") and dialog.addbox.IsChecked():
- # add created maps into layer tree
- for p in dialog.task.get_options()['params']:
- prompt = p.get('prompt', '')
- if prompt in ('raster', 'vector', '3d-raster') and \
- p.get('age', 'old') == 'new' and \
- p.get('value', None):
- name, found = utils.GetLayerNameFromCmd(cmd, fullyQualified = True,
- param = p.get('name', ''))
- if mapTree.GetMap().GetListOfLayers(l_name = name):
- display = mapTree.GetMapDisplay()
- if display and display.IsAutoRendered():
- continue
- if prompt == 'raster':
- lcmd = ['d.rast',
- 'map=%s' % name]
- elif prompt == '3d-raster':
- lcmd = ['d.rast3d',
- 'map=%s' % name]
- else:
- defaultParams = GetDisplayVectSettings()
- lcmd = ['d.vect',
- 'map=%s' % name] + defaultParams
- mapTree.AddLayer(ltype = prompt,
- lcmd = lcmd,
- lname = name)
- if hasattr(dialog, "get_dcmd") and \
- dialog.get_dcmd is None and \
- hasattr(dialog, "closebox") and \
- dialog.closebox.IsChecked() and \
- (event.returncode == 0 or event.aborted):
- self.cmdOutput.Update()
- time.sleep(2)
- dialog.Close()
+ for p in task.get_options()['params']:
+ prompt = p.get('prompt', '')
+ if prompt in ('raster', 'vector', '3d-raster') and \
+ p.get('age', 'old') == 'new' and \
+ p.get('value', None):
+ name = p.get('value')
+ if '@' not in name:
+ name = name + '@' + grass.gisenv()['MAPSET']
+ mapEvent = gMapCreated(self.GetId(),
+ name = name, ltype = prompt, add = None)
+ wx.PostEvent(self, mapEvent)
event.Skip()
def OnProcessPendingOutputWindowEvents(self, event):
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py 2012-11-20 08:38:00 UTC (rev 53932)
+++ grass/trunk/gui/wxpython/lmgr/frame.py 2012-11-20 10:53:11 UTC (rev 53933)
@@ -42,7 +42,7 @@
from core.gcmd import RunCommand, GError, GMessage
from core.utils import SetAddOnPath
-from core.events import EVT_SHOW_NOTIFICATION
+from core.events import EVT_SHOW_NOTIFICATION, EVT_MAP_CREATED
from gui_core.preferences import MapsetAccess, PreferencesDialog, EVT_SETTINGS_CHANGED
from lmgr.layertree import LayerTree, LMIcons
from lmgr.menudata import LayerManagerMenuData
@@ -157,6 +157,7 @@
self.Bind(wx.EVT_KEY_DOWN, self.OnKeyDown)
self.Bind(EVT_SHOW_NOTIFICATION,
lambda event: self.SetStatusText(event.message))
# minimal frame size
self.SetMinSize((globalvar.GM_WINDOW_SIZE[0], 400))
@@ -1552,8 +1553,14 @@
def OnApplyMapLayers(self, event):
self.AddMaps(mapLayers = event.mapLayers, ltype = event.ltype)
- def AddMaps(self, mapLayers, ltype):
- """!Add map layers to layer tree."""
+ def AddMaps(self, mapLayers, ltype, check = False):
+ """!Add map layers to layer tree.
+ @param mapLayers list of map names
+ @param ltype layer type ('rast', 'rast3d', 'vect')
+ @param check @c True if new layers should be checked in layer tree
+ @c False otherwise
# start new map display if no display is available
if not self.currentPage:
self.NewDisplay()
@@ -1577,10 +1584,48 @@
newItem = maptree.AddLayer(ltype = wxType,
lname = layerName,
- lchecked = False,
+ lchecked = check,
lopacity = 1.0,
lcmd = cmd,
lgroup = None)
+ if event.add is None:
+ if UserSettings.Get(group = 'cmd',
+ key = 'addNewLayer', subkey = 'enabled'):
+ self.AddOrUpdateMap(event.name, event.ltype)
+ elif event.add:
+ def AddOrUpdateMap(self, mapName, ltype):
+ """!Add map layer or update"""
+ # start new map display if no display is available
+ # TODO: standardize type identifiers
+ convertType = {'raster': 'rast',
+ '3d-raster': 'rast3d',
+ 'vector': 'vect'}
+ try:
+ grassType = convertType[ltype]
+ except KeyError:
+ if ltype in convertType.values():
+ grassType = ltype
+ else:
+ GError(parent = self,
+ message = _("Unsupported map layer type <%s>.") % ltype)
+ return
+ if not self.currentPage:
+ self.AddMaps([mapName], grassType, check = True)
+ else:
+ display = self.GetLayerTree().GetMapDisplay()
+ mapLayers = map(lambda x: x.GetName(),
+ display.GetMap().GetListOfLayers(l_type = ltype))
+ if mapName in mapLayers:
+ display.GetWindow().UpdateMap(render = True)
+ else:
def OnAddRaster(self, event):
"""!Add raster map layer"""
