[GRASS-SVN] r53935 - in grass/trunk: include/defs lib/vector/Vlib
    svn_grass at osgeo.org
    Tue Nov 20 07:39:45 PST 2012
Author: mmetz
Date: 2012-11-20 07:39:45 -0800 (Tue, 20 Nov 2012)
New Revision: 53935
   grass/trunk/include/defs/vector.h
   grass/trunk/lib/vector/Vlib/snap.c
Vlib: new snapping fn
Modified: grass/trunk/include/defs/vector.h
--- grass/trunk/include/defs/vector.h	2012-11-20 12:10:53 UTC (rev 53934)
+++ grass/trunk/include/defs/vector.h	2012-11-20 15:39:45 UTC (rev 53935)
@@ -352,6 +352,8 @@
 void Vect_snap_lines(struct Map_info *, int, double, struct Map_info *);
 void Vect_snap_lines_list(struct Map_info *, const struct ilist *, double,
                           struct Map_info *);
+void Vect_snap_lines_list2(struct Map_info *, struct ilist *, int,
+                           double, struct Map_info *);
 void Vect_remove_dangles(struct Map_info *, int, double, struct Map_info *);
 void Vect_chtype_dangles(struct Map_info *, double, struct Map_info *);
 void Vect_select_dangles(struct Map_info *, int, double, struct ilist *);
Modified: grass/trunk/lib/vector/Vlib/snap.c
--- grass/trunk/lib/vector/Vlib/snap.c	2012-11-20 12:10:53 UTC (rev 53934)
+++ grass/trunk/lib/vector/Vlib/snap.c	2012-11-20 15:39:45 UTC (rev 53935)
@@ -22,8 +22,6 @@
 #include <grass/vector.h>
 #include <grass/glocale.h>
-/* function prototypes */
-static int sort_new(const void *pa, const void *pb);
 /* Vertex */
 typedef struct
@@ -40,6 +38,30 @@
     double along;
 } NEW;
+/* for qsort */
+static int sort_new(const void *pa, const void *pb)
+    NEW *p1 = (NEW *) pa;
+    NEW *p2 = (NEW *) pb;
+    return (p1->along < p2->along ? -1 : 1);
+    if (p1->along < p2->along)
+	return -1;
+    if (p1->along > p2->along)
+	return 1;
+    return 1;
+/* This function is called by RTreeSearch() to find a vertex */
+static int find_item(int id, const struct RTree_Rect *rect, struct ilist *list)
+    G_ilist_add(list, id);
+    return 0;
 /* This function is called by RTreeSearch() to add selected node/line/area/isle to the list */
 static int add_item(int id, const struct RTree_Rect *rect, struct ilist *list)
@@ -47,27 +69,34 @@
     return 1;
+/* for ilist qsort'ing and bsearch'ing */
+int cmp_int(const void *a, const void *b)
+    int ai = *(int *)a;
+    int bi = *(int *)b;
+    return (ai < bi ? -1 : (ai > bi));
-  \brief Snap selected lines to existing vertex in threshold.
-  Snap selected lines to existing vertices.
-  \warning Lines are not necessarily snapped to nearest vertex, but to vertex in threshold!
-  Lines showing how vertices were snapped may be optionally written to error map.
-  Input map must be opened on level 2 for update at least on GV_BUILD_BASE.
-  As mentioned above, lines are not necessarily snapped to nearest vertex! For example:
-  <pre>
-   | 1         line 3 is snapped to line 1,
-   |           then line 2 is not snapped to common node at lines 1 and 3,
-   because it is already outside of threshold
-   ----------- 3
+   \brief Snap selected lines to existing vertex in threshold.
+   Snap selected lines to existing vertices of other selected lines.
+   Lines showing how vertices were snapped may be optionally written to error map.
+   Input map must be opened on level 2 for update at least on GV_BUILD_BASE.
+   As mentioned above, lines are not necessarily snapped to nearest vertex! For example:
+   <pre>
+    | 1         line 3 is snapped to line 1,
+    |           then line 2 is not snapped to common node at lines 1 and 3,
+    because it is already outside of threshold
+    ----------- 3
-   | 2
+    | 2
    </pre>
    The algorithm selects anchor vertices and snaps non-anchor vertices
@@ -165,7 +194,7 @@
 	    /* Already registered ? */
 	    Vect_reset_list(List);
-	    RTreeSearch(RTree, &rect, (void *)add_item, List);
+	    RTreeSearch(RTree, &rect, (void *)find_item, List);
 	    G_debug(3, "List : nvalues =  %d", List->n_values);
 	    if (List->n_values == 0) {	/* Not found */
@@ -419,7 +448,7 @@
 	if (changed) {		/* rewrite the line */
 	    Vect_line_prune(NPoints);	/* remove duplicates */
-	    if (NPoints->n_points > 1 || ltype & GV_LINES) {
+	    if (NPoints->n_points > 1 || !(ltype & GV_LINES)) {
 		Vect_rewrite_line(Map, line, ltype, NPoints, Cats);
 	    else {
@@ -446,30 +475,431 @@
     G_verbose_message(_("New vertices: %d"), ncreated);
-/* for qsort */
+   Snap selected lines to existing vertices of lines of type type.
+   Lines in the list will only be snapped to lines not in the list.
+   If a list is given, new snapped lines are added to the list.
+   If no list is given, all lines of type type are snapped to lines of
+   type type.
+   \param Map input map where vertices will be snapped
+   \param List_lines list of lines to snap
+   \param type type of lines where lines in list will be snapped to
+   \param thresh threshold in which snap vertices
+   \param[out] Err vector map where lines representing snap are written or NULL
+   \return void
+void
+Vect_snap_lines_list2(struct Map_info *Map, struct ilist *List_lines,
+		     int type, double thresh, struct Map_info *Err)
-    NEW *p1 = (NEW *) pa;
-    NEW *p2 = (NEW *) pb;
+    struct line_pnts *Points, *NPoints;
+    struct line_cats *Cats;
+    int line, ltype, line_idx, nlines, new_line, val;
+    double thresh2;
-    if (p1->along < p2->along)
-	return -1;
-    if (p1->along > p2->along)
-	return 1;
-    return 1;
+    int point;			/* index in points array */
+    int nanchors, ntosnap;	/* number of anchors and number of points to be snapped */
+    int nsnapped, ncreated;	/* number of snapped verices, number of new vertices (on segments) */
+    int apoints, npoints, nvertices;	/* number of allocated points, registered points, vertices */
+    XPNT *XPnts;		/* Array of points */
+    NEW *New = NULL;		/* Array of new points */
+    int anew = 0, nnew;		/* allocated new points , number of new points */
+    struct ilist *List;
+    int *Index = NULL;		/* indexes of anchors for vertices */
+    int aindex = 0;		/* allocated Index */
+    struct RTree *RTree;
+    int rtreefd = -1;
+    struct RTree_Rect rect;
+    rect.boundary = G_malloc(6 * sizeof(RectReal));
+    if (List_lines) {
+	nlines = List_lines->n_values;
+	if (nlines < 1)
+	    return;
+	qsort(List_lines->value, nlines, sizeof(int), cmp_int);
+    Points = Vect_new_line_struct();
+    NPoints = Vect_new_line_struct();
+    Cats = Vect_new_cats_struct();
+    List = Vect_new_list();
+    if (getenv("GRASS_VECTOR_LOWMEM")) {
+	char *filename = G_tempfile();
+	rtreefd = open(filename, O_RDWR | O_CREAT | O_EXCL, 0600);
+	remove(filename);
+    RTree = RTreeCreateTree(rtreefd, 0, 2);
+    thresh2 = thresh * thresh;
+    /* Go through all lines in vector, and add each point to structure of points */
+    apoints = 0;
+    point = 1;			/* index starts from 1 ! */
+    nvertices = 0;
+    XPnts = NULL;
+    nlines = Vect_get_num_lines(Map);
+    G_verbose_message(_("Snap vertices Pass 1: select points"));
+    for (line = 1; line <= nlines; line++) {
+	int v;
+	G_percent(line, nlines, 2);
+	G_debug(3, "line =  %d", line);
+	if (!Vect_line_alive(Map, line))
+	    continue;
+	ltype = Vect_read_line(Map, Points, Cats, line);
+	val = -1;
+	if (List_lines) {
+	    if (bsearch(&line, List_lines->value, List_lines->n_values,
+			sizeof(int), cmp_int)) {
+		/* snap this line to other lines,
+		 * don't make its vertices anchor points */
+		val = -2;
+	    else {
+		if (!(ltype & type))
+		    continue;
+	else {
+		continue;
+	for (v = 0; v < Points->n_points; v++) {
+	    G_debug(3, "  vertex v = %d", v);
+	    nvertices++;
+	    /* Box */
+	    rect.boundary[0] = Points->x[v];
+	    rect.boundary[3] = Points->x[v];
+	    rect.boundary[1] = Points->y[v];
+	    rect.boundary[4] = Points->y[v];
+	    rect.boundary[2] = 0;
+	    rect.boundary[5] = 0;
+	    /* Already registered ? */
+	    Vect_reset_list(List);
+	    G_debug(3, "List : nvalues =  %d", List->n_values);
+	    if (List->n_values == 0) {	/* Not found */
+		/* Add to tree and to structure */
+		RTreeInsertRect(&rect, point, RTree);
+		if ((point - 1) == apoints) {
+		    apoints += 10000;
+		    XPnts =
+			(XPNT *) G_realloc(XPnts,
+					   (apoints + 1) * sizeof(XPNT));
+		XPnts[point].x = Points->x[v];
+		XPnts[point].y = Points->y[v];
+		XPnts[point].anchor = val;
+		point++;
+    npoints = point - 1;
+    /* Go through all registered points and if not yet marked mark it as anchor and assign this anchor
+     * to all not yet marked points in threshold */
+    G_verbose_message(_("Snap vertices Pass 2: assign anchor vertices"));
+    nanchors = ntosnap = 0;
+    for (point = 1; point <= npoints; point++) {
+	int i;
+	G_percent(point, npoints, 2);
+	G_debug(3, "  point = %d", point);
+	/* also skip vertices of lines to snap */
+	if (XPnts[point].anchor >= 0 || XPnts[point].anchor == -2)
+	    continue;
+	XPnts[point].anchor = 0;	/* make it anchor */
+	nanchors++;
+	/* Find points in threshold */
+	rect.boundary[0] = XPnts[point].x - thresh;
+	rect.boundary[3] = XPnts[point].x + thresh;
+	rect.boundary[1] = XPnts[point].y - thresh;
+	rect.boundary[4] = XPnts[point].y + thresh;
+	RTreeSearch(RTree, &rect, (void *)add_item, List);
+	G_debug(4, "  %d points in threshold box", List->n_values);
+	for (i = 0; i < List->n_values; i++) {
+	    int pointb;
+	    double dx, dy, dist2;
+	    pointb = List->value[i];
+	    if (pointb == point)
+		continue;
+	    dx = XPnts[pointb].x - XPnts[point].x;
+	    dy = XPnts[pointb].y - XPnts[point].y;
+	    dist2 = dx * dx + dy * dy;
+	    if (dist2 > thresh2) /* outside threshold */
+		continue;
+	    /* doesn't have an anchor yet */
+	    if (XPnts[pointb].anchor < 0) {
+		XPnts[pointb].anchor = point;
+		ntosnap++;
+	    else if (XPnts[pointb].anchor > 0) {   /* check distance to previously assigned anchor */
+		double dist2_a;
+		dx = XPnts[XPnts[pointb].anchor].x - XPnts[pointb].x;
+		dy = XPnts[XPnts[pointb].anchor].y - XPnts[pointb].y;
+		dist2_a = dx * dx + dy * dy;
+		/* replace old anchor */
+		if (dist2 < dist2_a) {
+    /* Go through all lines and:
+     *   1) for all vertices: if not anchor snap it to its anchor
+     *   2) for all segments: snap it to all anchors in threshold (except anchors of vertices of course) */
+    nsnapped = ncreated = 0;
+    G_verbose_message(_("Snap vertices Pass 3: snap to assigned points"));
+    if (List_lines)
+    else
+    for (line_idx = 0; line_idx < nlines; line_idx++) {
+	int v, spoint, anchor;
+	int changed = 0;
+	G_percent(line_idx, nlines, 2);
+	if (List_lines)
+	    line = List_lines->value[line_idx];
+	else
+	    line = line_idx;
+	    continue;
+	if (!List_lines && !(type & ltype))
+	    continue;
+	if (Points->n_points >= aindex) {
+	    aindex = Points->n_points;
+	    Index = (int *)G_realloc(Index, aindex * sizeof(int));
+	/* Snap all vertices */
+	    /* Box */
+	    /* Find point ( should always find one point ) */
+	    spoint = List->value[0];
+	    anchor = XPnts[spoint].anchor;
+	    if (anchor > 0) {	/* to be snapped */
+		Points->x[v] = XPnts[anchor].x;
+		Points->y[v] = XPnts[anchor].y;
+		nsnapped++;
+		changed = 1;
+		Index[v] = anchor;	/* point on new location */
+	    else {
+		Index[v] = spoint;	/* old point */
+	/* New points */
+	Vect_reset_line(NPoints);
+	/* Snap all segments to anchors in threshold */
+	for (v = 0; v < Points->n_points - 1; v++) {
+	    int i;
+	    double x1, x2, y1, y2, xmin, xmax, ymin, ymax;
+	    G_debug(3, "  segment = %d end anchors : %d  %d", v, Index[v],
+		    Index[v + 1]);
+	    x1 = Points->x[v];
+	    x2 = Points->x[v + 1];
+	    y1 = Points->y[v];
+	    y2 = Points->y[v + 1];
+	    Vect_append_point(NPoints, Points->x[v], Points->y[v],
+			      Points->z[v]);
+	    /* Box */
+	    if (x1 <= x2) {
+		xmin = x1;
+		xmax = x2;
+	    else {
+		xmin = x2;
+		xmax = x1;
+	    if (y1 <= y2) {
+		ymin = y1;
+		ymax = y2;
+	    else {
+		ymin = y2;
+		ymax = y1;
+	    rect.boundary[0] = xmin - thresh;
+	    rect.boundary[3] = xmax + thresh;
+	    rect.boundary[1] = ymin - thresh;
+	    rect.boundary[4] = ymax + thresh;
+	    /* Find points */
+	    G_debug(3, "  %d points in box", List->n_values);
+	    /* Snap to anchor in threshold different from end points */
+	    nnew = 0;
+		double dist2, along;
+		spoint = List->value[i];
+		G_debug(4, "    spoint = %d anchor = %d", spoint,
+			XPnts[spoint].anchor);
+		if (spoint == Index[v] || spoint == Index[v + 1])
+		    continue;	/* end point */
+		if (XPnts[spoint].anchor > 0)
+		    continue;	/* point is not anchor */
+		/* Check the distance */
+		dist2 =
+		    dig_distance2_point_to_line(XPnts[spoint].x,
+						XPnts[spoint].y, 0, x1, y1, 0,
+						x2, y2, 0, 0, NULL, NULL,
+						NULL, &along, NULL);
+		G_debug(4, "      distance = %lf", sqrt(dist2));
+		if (dist2 <= thresh2) {
+		    G_debug(4, "      anchor in thresh, along = %lf", along);
+		    if (nnew == anew) {
+			anew += 100;
+			New = (NEW *) G_realloc(New, anew * sizeof(NEW));
+		    New[nnew].anchor = spoint;
+		    New[nnew].along = along;
+		    nnew++;
+	    G_debug(3, "  nnew = %d", nnew);
+	    /* insert new vertices */
+	    if (nnew > 0) {
+		/* sort by distance along the segment */
+		qsort(New, sizeof(char) * nnew, sizeof(NEW), sort_new);
+		for (i = 0; i < nnew; i++) {
+		    anchor = New[i].anchor;
+		    /* Vect_line_insert_point ( Points, ++v, XPnts[anchor].x, XPnts[anchor].y, 0); */
+		    Vect_append_point(NPoints, XPnts[anchor].x,
+				      XPnts[anchor].y, 0);
+		    ncreated++;
+		changed = 1;
+	/* append end point */
+	v = Points->n_points - 1;
+	Vect_append_point(NPoints, Points->x[v], Points->y[v], Points->z[v]);
+	if (changed) {		/* rewrite the line */
+	    Vect_line_prune(NPoints);	/* remove duplicates */
+		new_line = Vect_rewrite_line(Map, line, ltype, NPoints, Cats);
+		if (List_lines)
+		    G_ilist_add(List_lines, new_line);
+	    else {
+		Vect_delete_line(Map, line);
+	    if (Err) {
+		Vect_write_line(Err, ltype, Points, Cats);
+    }				/* for each line */
+    G_percent(line_idx, nlines, 2); /* finish it */
+    Vect_destroy_line_struct(Points);
+    Vect_destroy_line_struct(NPoints);
+    Vect_destroy_cats_struct(Cats);
+    G_free(XPnts);
+    G_free(Index);
+    G_free(New);
+    RTreeDestroyTree(RTree);
+    if (rtreefd >= 0)
+	close(rtreefd);
+    G_free(rect.boundary);
+    G_verbose_message(_("Snapped vertices: %d"), nsnapped);
+    G_verbose_message(_("New vertices: %d"), ncreated);
- * \brief Snap lines in vector map to existing vertex in threshold.
- * For details see Vect_snap_lines_list()
- * \param[in] Map input map where vertices will be snapped
- * \param[in] type type of lines to snap
- * \param[in] thresh threshold in which snap vertices
- * \param[out] Err vector map where lines representing snap are written or NULL
- * \return void
+   \brief Snap lines in vector map to existing vertex in threshold.
+   For details see Vect_snap_lines_list()
+   \param[in] Map input map where vertices will be snapped
+   \param[in] type type of lines to snap
+   \param[in] thresh threshold in which snap vertices
+   \return void
 void
 Vect_snap_lines(struct Map_info *Map, int type, double thresh,
