[GRASS-SVN] r53952 - in grass/branches/develbranch_6/gui/wxpython: core gmodeler
Wed Nov 21 12:43:40 PST 2012
Author: martinl
Date: 2012-11-21 12:43:38 -0800 (Wed, 21 Nov 2012)
New Revision: 53952
   grass/branches/develbranch_6/gui/wxpython/core/workspace.py
   grass/branches/develbranch_6/gui/wxpython/gmodeler/model.py
wxGUI: use default locales for writing workspace and model files
Modified: grass/branches/develbranch_6/gui/wxpython/core/workspace.py
--- grass/branches/develbranch_6/gui/wxpython/core/workspace.py	2012-11-21 15:26:01 UTC (rev 53951)
+++ grass/branches/develbranch_6/gui/wxpython/core/workspace.py	2012-11-21 20:43:38 UTC (rev 53952)
@@ -17,11 +17,13 @@
 import os
+import locale
 import wx
 from core.utils     import normalize_whitespace
 from core.settings  import UserSettings
+from core.gcmd      import EncodeString
 from nviz.main      import NvizSettings
 class ProcessWorkspaceFile:
@@ -534,7 +536,8 @@
         self.indent = 0
         # write header
-        self.file.write('<?xml version="1.0" encoding="UTF-8"?>\n')
+        enc = locale.getdefaultlocale()[1]
+        self.file.write('<?xml version="1.0" encoding="%s"?>\n' % enc)
         self.file.write('<!DOCTYPE gxw SYSTEM "grass-gxw.dtd">\n')
         self.file.write('%s<gxw>\n' % (' ' * self.indent))
@@ -642,12 +645,12 @@
             if type == 'command':
                 cmd = mapTree.GetPyData(item)[0]['maplayer'].GetCmd(string=True)
                 self.file.write('%s<layer type="%s" name="%s" checked="%d">\n' % \
-                               (' ' * self.indent, type, cmd, checked));
+                               (' ' * self.indent, type, EncodeString(cmd), checked));
                 self.file.write('%s</layer>\n' % (' ' * self.indent));
             elif type == 'group':
                 name = mapTree.GetItemText(item)
                 self.file.write('%s<group name="%s" checked="%d">\n' % \
-                               (' ' * self.indent, name.encode('utf8'), checked));
+                               (' ' * self.indent, EncodeString(name), checked));
                 self.indent += 4
                 subItem = mapTree.GetFirstChild(item)[0]
                 self.__writeLayer(mapTree, subItem)
@@ -661,7 +664,7 @@
                 if opacity < 1:
                     name = name.split('(', -1)[0].strip()
                 self.file.write('%s<layer type="%s" name="%s" checked="%d" opacity="%f">\n' % \
-                                    (' ' * self.indent, type, name.encode('utf8'), checked, opacity));
+                                    (' ' * self.indent, type, EncodeString(name), checked, opacity));
                 self.indent += 4
                 # selected ?
Modified: grass/branches/develbranch_6/gui/wxpython/gmodeler/model.py
--- grass/branches/develbranch_6/gui/wxpython/gmodeler/model.py	2012-11-21 15:26:01 UTC (rev 53951)
+++ grass/branches/develbranch_6/gui/wxpython/gmodeler/model.py	2012-11-21 20:43:38 UTC (rev 53952)
@@ -31,6 +31,7 @@
 import re
 import mimetypes
 import time
+import locale
 try:
     import xml.etree.ElementTree as etree
 except ImportError:
@@ -1780,7 +1781,8 @@
     def _header(self):
         """!Write header"""
-        self.fd.write('<?xml version="1.0" encoding="UTF-8"?>\n')
+        self.fd.write('<?xml version="1.0" encoding="%s"?>\n' % enc)
         self.fd.write('<!DOCTYPE gxm SYSTEM "grass-gxm.dtd">\n')
         self.fd.write('%s<gxm>\n' % (' ' * self.indent))
         self.indent += 4
