[GRASS-SVN] r53955 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Wed Nov 21 12:56:52 PST 2012
Author: mmetz
Date: 2012-11-21 12:56:52 -0800 (Wed, 21 Nov 2012)
New Revision: 53955
grass/trunk/lib/vector/Vlib/sindex.c
Vlib: optimize Vect_select_lines_by_box()
Modified: grass/trunk/lib/vector/Vlib/sindex.c
--- grass/trunk/lib/vector/Vlib/sindex.c 2012-11-21 20:50:33 UTC (rev 53954)
+++ grass/trunk/lib/vector/Vlib/sindex.c 2012-11-21 20:56:52 UTC (rev 53955)
@@ -34,7 +34,7 @@
Vect_select_lines_by_box(struct Map_info *Map, const struct bound_box *Box,
int type, struct boxlist *list)
- int i, line, nlines;
+ int i, line, nlines, ntypes, mtype;
struct Plus_head *plus;
struct P_line *Line;
static struct boxlist *LocList = NULL;
@@ -45,6 +45,45 @@
plus = &(Map->plus);
list->n_values = 0;
+ ntypes = mtype = 0;
+ /* count the number of different primitives in Map */
+ if (plus->n_plines != 0) {
+ ntypes++;
+ mtype |= GV_POINT;
+ if (plus->n_llines != 0) {
+ ntypes++;
+ mtype |= GV_LINE;
+ if (plus->n_blines != 0) {
+ ntypes++;
+ mtype |= GV_BOUNDARY;
+ if (plus->n_clines != 0) {
+ ntypes++;
+ mtype |= GV_CENTROID;
+ if (plus->n_flines != 0) {
+ ntypes++;
+ mtype |= GV_FACE;
+ if (plus->n_klines != 0) {
+ ntypes++;
+ mtype |= GV_KERNEL;
+ if (ntypes == 1) {
+ /* there is only one type in Map */
+ if (mtype & type)
+ return dig_select_lines(plus, Box, list);
+ return 0;
+ if (ntypes == 0)
+ /* empty vector */
+ return 0;
if (!LocList) {
LocList = (struct boxlist *)G_malloc(sizeof(struct boxlist));
dig_init_boxlist(LocList, 1);
