[GRASS-SVN] r53960 - grass-addons/grass6/raster/r.mess
svn_grass at osgeo.org
Wed Nov 21 13:20:27 PST 2012
Author: pvanbosgeo
Date: 2012-11-21 13:20:26 -0800 (Wed, 21 Nov 2012)
New Revision: 53960
grass-addons/grass6/raster/r.mess/r.mess.html
Extra explanation about input options
Modified: grass-addons/grass6/raster/r.mess/r.mess.html
--- grass-addons/grass6/raster/r.mess/r.mess.html 2012-11-21 21:11:26 UTC (rev 53959)
+++ grass-addons/grass6/raster/r.mess/r.mess.html 2012-11-21 21:20:26 UTC (rev 53960)
@@ -8,18 +8,22 @@
"The multivariate environmental similarity surface (MESS) calculation
represents how similar a point is to a reference set of points, with
respect to a set of predictor variables (V1, V2, ...). The values in
-the MESS are
-influenced by the full distribution of the reference points, so that
+the MESS are influenced by the full distribution of the reference points, so that
sites within the environmental range of the reference points but in
relatively unusual environments will have a smaller value than those in
very common environments."
<p>This module will also compute the individual environmental
similarity surfaces (IESS), which represents how similar a point is to
-a set of reference set of points for each of the input variable. MESS
+a set of reference points for each of the input variable. MESS
is then simply calculated as the minimum of its similarity with respect
-to each variable.
+to each variable.
+<p>Any sample of interest can be used for the reference set. For example,
+it can be occurrence records for the species; a sample of a region, or a sample of
+current climate conditions in a given area. The input layer representing the
+reference distribution can be a vector point layer or a raster layer.
<p>
The IESS can have negative values – these are sites where the variable
has a value that is outside the range in the reference set. A negative MESS
