[GRASS-SVN] r53981 - grass/trunk/vector/v.out.postgis
svn_grass at osgeo.org
Fri Nov 23 05:27:05 PST 2012
Author: martinl
Date: 2012-11-23 05:27:04 -0800 (Fri, 23 Nov 2012)
New Revision: 53981
grass/trunk/vector/v.out.postgis/options.c
v.out.postgis: more guisections
Modified: grass/trunk/vector/v.out.postgis/options.c
--- grass/trunk/vector/v.out.postgis/options.c 2012-11-23 13:23:48 UTC (rev 53980)
+++ grass/trunk/vector/v.out.postgis/options.c 2012-11-23 13:27:04 UTC (rev 53981)
@@ -28,12 +28,13 @@
_("Name for output PostGIS layer");
params->olayer->description =
_("If not specified, input name is used");
+ params->olayer->guisection = _("Output settings");
params->olink = G_define_standard_option(G_OPT_V_OUTPUT);
params->olink->key = "olink";
params->olink->required = NO;
params->olink->label =
- _("Name for vector map defined as a link to the output PostGIS feature table");
+ _("Name for output vector map defined as a link to the PostGIS feature table");
params->olink->description =
_("If not specified, the vector link is not created. "
"The link can be also manually created by 'v.external' module.");
@@ -49,15 +50,18 @@
params->opts->multiple = YES;
params->opts->type = TYPE_STRING;
params->opts->key_desc = "key=value";
+ params->opts->guisection = _("Output settings");
flags->table = G_define_flag();
flags->table->key = 't';
flags->table->description =
_("Don't export attribute table");
+ flags->table->guisection = _("Output settings");
flags->topo = G_define_flag();
flags->topo->key = 'l';
flags->topo->description =
_("Export PostGIS topology instead of simple features");
+ flags->topo->guisection = _("Output settings");
