[GRASS-SVN] r53983 - grass/branches/releasebranch_6_4/vector/v.kernel
svn_grass at osgeo.org
Fri Nov 23 05:30:25 PST 2012
Author: mmetz
Date: 2012-11-23 05:30:25 -0800 (Fri, 23 Nov 2012)
New Revision: 53983
grass/branches/releasebranch_6_4/vector/v.kernel/main.c
v.kernel speed-up
Modified: grass/branches/releasebranch_6_4/vector/v.kernel/main.c
--- grass/branches/releasebranch_6_4/vector/v.kernel/main.c 2012-11-23 13:30:09 UTC (rev 53982)
+++ grass/branches/releasebranch_6_4/vector/v.kernel/main.c 2012-11-23 13:30:25 UTC (rev 53983)
@@ -627,12 +627,11 @@
int nn, kk, nalines, aline;
double dist;
- struct line_pnts *APoints, *BPoints;
+ struct line_pnts *Points;
BOUND_BOX box;
struct ilist *List;
- APoints = Vect_new_line_struct();
- BPoints = Vect_new_line_struct();
+ Points = Vect_new_line_struct();
List = Vect_new_list();
nn = Vect_get_num_primitives(In, GV_POINTS);
@@ -646,14 +645,14 @@
G_debug(3, " aline = %d", aline);
- altype = Vect_read_line(In, APoints, NULL, aline);
+ altype = Vect_read_line(In, Points, NULL, aline);
if (!(altype & GV_POINTS))
continue;
- box.E = APoints->x[0] + dmax;
- box.W = APoints->x[0] - dmax;
- box.N = APoints->y[0] + dmax;
- box.S = APoints->y[0] - dmax;
+ box.E = Points->x[0] + dmax;
+ box.W = Points->x[0] - dmax;
+ box.N = Points->y[0] + dmax;
+ box.S = Points->y[0] - dmax;
box.T = PORT_DOUBLE_MAX;
box.B = -PORT_DOUBLE_MAX;
@@ -669,17 +668,18 @@
continue;
G_debug(3, " bline = %d", bline);
- Vect_read_line(In, BPoints, NULL, bline);
+ Vect_get_line_box(In, bline, &box);
+ G_debug(3, " SP: %f %f -> %f %f", Points->x[0], Points->y[0],
+ box.E, box.N);
ret =
- Vect_net_shortest_path_coor(Net, APoints->x[0], APoints->y[0],
- 0.0, BPoints->x[0], BPoints->y[0],
+ Vect_net_shortest_path_coor(Net, Points->x[0], Points->y[0],
+ 0.0, box.E, box.N,
0.0, netmax, netmax, &dist, NULL,
NULL, NULL, NULL, NULL, NULL);
- G_debug(3, " SP: %f %f -> %f %f", APoints->x[0], APoints->y[0],
- BPoints->x[0], BPoints->y[0]);
if (ret == 0) {
G_debug(3, "not reachable");
continue; /* Not reachable */
@@ -722,15 +722,11 @@
int i;
double dist, kernel;
- static struct line_pnts *Points = NULL;
static struct line_pnts *FPoints = NULL;
BOUND_BOX box;
static struct ilist *PointsList = NULL;
static struct ilist *NodesList = NULL;
- if (!Points)
- Points = Vect_new_line_struct();
if (!PointsList)
PointsList = Vect_new_list();
@@ -761,15 +757,13 @@
int line, ret;
line = PointsList->value[i];
- Vect_read_line(In, Points, NULL, line);
- G_debug(3, " SP: %f %f -> %f %f", x, y, Points->x[0], Points->y[0]);
- /*ret = Vect_net_shortest_path_coor(Net, x, y, 0.0, Points->x[0], */
- /*Points->y[0], 0.0, netmax, netmax, */
- /*&dist, NULL, NULL, NULL, NULL, NULL, */
- /*NULL); */
+ Vect_get_line_box(In, line, &box);
+ G_debug(3, " SP: %f %f -> %f %f", x, y, box.E, box.N);
ret = Vect_net_shortest_path_coor2(Net,
- Points->x[0], Points->y[0], 0.0,
+ box.E, box.N, 0.0,
x, y, 0.0, netmax, 1.0,
&dist, NULL,
NULL, NodesList, FPoints, NULL,
@@ -825,15 +819,12 @@
/* spatial index handling, borrowed from lib/vector/Vlib/find.c */
BOUND_BOX box;
static struct ilist *NList = NULL;
a[0] = E;
a[1] = N;
if (!NList)
NList = Vect_new_list();
- if (!Points)
/* create bounding box 2x2*dmax size from the current cell center */
box.N = N + dmax;
@@ -850,17 +841,14 @@
for (line = 0; line < nlines; line++) {
- Vect_read_line(In, Points, NULL, NList->value[line]);
+ Vect_get_line_box(In, NList->value[line], &box);
+ b[0] = box.E;
+ b[1] = box.N;
- b[0] = Points->x[0];
- b[1] = Points->y[0];
dist = euclidean_distance(a, b, 2);
if (dist <= dmax)
/* *gaussian += gaussianKernel(dist / sigma, term); */
*gaussian += kernelFunction(kernel_function, 2, sigma, dist);
