[GRASS-SVN] r53985 - in grass/trunk/gui/wxpython: core gcp gmodeler gui_core iclass lmgr mapdisp mapswipe nviz vdigit
svn_grass at osgeo.org
Fri Nov 23 06:21:17 PST 2012
Author: annakrat
Date: 2012-11-23 06:21:17 -0800 (Fri, 23 Nov 2012)
New Revision: 53985
Added:
grass/trunk/gui/wxpython/core/giface.py
grass/trunk/gui/wxpython/lmgr/giface.py
grass/trunk/gui/wxpython/gcp/manager.py
grass/trunk/gui/wxpython/gcp/mapdisplay.py
grass/trunk/gui/wxpython/gmodeler/frame.py
grass/trunk/gui/wxpython/gmodeler/g.gui.gmodeler.py
grass/trunk/gui/wxpython/gmodeler/preferences.py
grass/trunk/gui/wxpython/gui_core/dialogs.py
grass/trunk/gui/wxpython/gui_core/mapdisp.py
grass/trunk/gui/wxpython/gui_core/mapwindow.py
grass/trunk/gui/wxpython/gui_core/preferences.py
grass/trunk/gui/wxpython/iclass/digit.py
grass/trunk/gui/wxpython/iclass/frame.py
grass/trunk/gui/wxpython/lmgr/frame.py
grass/trunk/gui/wxpython/lmgr/layertree.py
grass/trunk/gui/wxpython/mapdisp/frame.py
grass/trunk/gui/wxpython/mapdisp/mapwindow.py
grass/trunk/gui/wxpython/mapswipe/frame.py
grass/trunk/gui/wxpython/mapswipe/g.gui.mapswipe.py
grass/trunk/gui/wxpython/mapswipe/mapwindow.py
grass/trunk/gui/wxpython/nviz/mapwindow.py
grass/trunk/gui/wxpython/vdigit/mapwindow.py
wxGUI: unified grass interface (to be continued) (co-author: wenzeslaus)
Added: grass/trunk/gui/wxpython/core/giface.py
--- grass/trunk/gui/wxpython/core/giface.py (rev 0)
+++ grass/trunk/gui/wxpython/core/giface.py 2012-11-23 14:21:17 UTC (rev 53985)
@@ -0,0 +1,61 @@
+ at package core.giface
+ at brief GRASS interface for standalone application (without layer manager)
+Classes:
+ - giface::StandaloneGrassInterface
+(C) 2012 by the GRASS Development Team
+This program is free software under the GNU General Public License
+(>=v2). Read the file COPYING that comes with GRASS for details.
+ at author Anna Kratochvilova <kratochanna gmail.com>
+ at author Vaclav Petras <wenzeslaus gmail.com>
+from core.gcmd import RunCommand
+from core.utils import CmdToTuple
+import grass.script as grass
+class StandaloneGrassInterface():
+ def RunCmd(self, command,
+ onDone = None, onPrepare = None, userData = None, **kwargs):
+ if onPrepare:
+ onPrepare(userData)
+ cmdTuple = CmdToTuple(command)
+ returncode = RunCommand(cmdTuple[0], **cmdTuple[1])
+ if onDone:
+ onDone(cmd = command, returncode = returncode)
+ def Help(self, entry):
+ RunCommand('g.manual', quiet = True, entry = entry)
+ def WriteLog(self, text, wrap = None,
+ switchPage = False, priority = 1):
+ grass.message(text)
+ def WriteCmdLog(self, line, pid = None, switchPage = True):
+ def WriteWarning(self, line):
+ grass.warning(line)
+ def WriteError(self, line):
+ grass.error(line)
+ def GetLayerTree(self):
+ return None
+ def GetMapDisplay(self):
+ """!Get current map display.
+ return None
+ def GetAllMapDisplays(self):
+ """!Get list of all map displays.
+ return []
\ No newline at end of file
Property changes on: grass/trunk/gui/wxpython/core/giface.py
___________________________________________________________________
Added: svn:mime-type
+ text/x-python
Added: svn:eol-style
+ native
Modified: grass/trunk/gui/wxpython/gcp/manager.py
--- grass/trunk/gui/wxpython/gcp/manager.py 2012-11-23 13:53:03 UTC (rev 53984)
+++ grass/trunk/gui/wxpython/gcp/manager.py 2012-11-23 14:21:17 UTC (rev 53985)
@@ -84,8 +84,9 @@
Start wizard here and finish wizard here
- def __init__(self, parent):
+ def __init__(self, parent, giface):
self.parent = parent # GMFrame
+ self._giface = giface
# get environmental variables
@@ -222,9 +223,10 @@
# start GCP Manager
- self.gcpmgr = GCP(self.parent, grwiz=self, size=globalvar.MAP_WINDOW_SIZE,
- toolbars=["gcpdisp"],
- Map=self.SrcMap, lmgr=self.parent)
+ self.gcpmgr = GCP(self.parent, giface = self._giface,
+ grwiz=self, size=globalvar.MAP_WINDOW_SIZE,
+ toolbars=["gcpdisp"],
+ Map=self.SrcMap, lmgr=self.parent)
# load GCPs
self.gcpmgr.InitMapDisplay()
@@ -778,11 +780,12 @@
Manages ground control points for georectifying. Calculates RMS statistics.
Calls i.rectify or v.rectify to georectify map.
- def __init__(self, parent, grwiz = None, id = wx.ID_ANY,
+ def __init__(self, parent, giface, grwiz = None, id = wx.ID_ANY,
title = _("Manage Ground Control Points"),
size = (700, 300), toolbars = ["gcpdisp"], Map = None, lmgr = None):
self.grwiz = grwiz # GR Wizard
if tgt_map['raster'] == '' and tgt_map['vector'] == '':
self.show_target = False
@@ -790,7 +793,7 @@
self.show_target = True
#wx.Frame.__init__(self, parent, id, title, size = size, name = "GCPFrame")
- MapFrame.__init__(self, parent = parent, title = title, size = size,
+ MapFrame.__init__(self, parent = parent, giface = self._giface, title = title, size = size,
Map = Map, toolbars = toolbars, lmgr = lmgr, name = 'GCPMapWindow')
@@ -1235,7 +1238,7 @@
# if event != None save also to backup file
if event:
shutil.copy(self.file['points'], self.file['points_bak'])
- self.parent.goutput.WriteLog(_('POINTS file saved for group <%s>') % self.xygroup)
+ self._giface.WriteLog(_('POINTS file saved for group <%s>') % self.xygroup)
#self.SetStatusText(_('POINTS file saved'))
def ReadGCPs(self):
@@ -1421,8 +1424,7 @@
# georectify each vector in VREF using v.rectify
for vect in vectlist:
self.outname = str(vect.split('@')[0]) + self.extension
- print self.outname
- self.parent.goutput.WriteLog(text = _('Transforming <%s>...') % vect,
+ self._giface.WriteLog(text = _('Transforming <%s>...') % vect,
switchPage = True)
ret = msg = ''
@@ -1459,14 +1461,15 @@
self.VectGRList.append(self.outname)
print '*****vector list = ' + str(self.VectGRList)
else:
- self.parent.goutput.WriteError(_('Georectification of vector map <%s> failed') %
- self.outname)
+ self._giface.WriteError(_('Georectification of vector map <%s> failed') %
+ self.outname)
def OnSettings(self, event):
"""!GCP Manager settings"""
- dlg = GrSettingsDialog(parent=self, id=wx.ID_ANY, title=_('GCP Manager settings'))
+ dlg = GrSettingsDialog(parent=self, giface=self._giface,
+ id=wx.ID_ANY, title=_('GCP Manager settings'))
if dlg.ShowModal() == wx.ID_OK:
pass
@@ -1745,9 +1748,7 @@
def OnHelp(self, event):
"""!Show GCP Manager manual page"""
- cmdlist = ['g.manual', 'entry=wxGUI.GCP_Manager']
- self.parent.goutput.RunCmd(cmdlist, compReg=False,
- switchPage=False)
+ self._giface.Help(entry = 'wxGUI.GCP_Manager')
def OnUpdateActive(self, event):
@@ -2341,7 +2342,7 @@
return valuelist
class GrSettingsDialog(wx.Dialog):
- def __init__(self, parent, id, title, pos=wx.DefaultPosition, size=wx.DefaultSize,
+ def __init__(self, parent, id, giface, title, pos=wx.DefaultPosition, size=wx.DefaultSize,
style=wx.DEFAULT_DIALOG_STYLE):
wx.Dialog.__init__(self, parent, id, title, pos, size, style)
@@ -2826,7 +2827,7 @@
UserSettings.ReadSettingsFile(settings=fileSettings)
fileSettings['gcpman'] = UserSettings.Get(group='gcpman')
file = UserSettings.SaveToFile(fileSettings)
- self.parent.parent.goutput.WriteLog(_('GCP Manager settings saved to file \'%s\'.') % file)
+ self._giface.WriteLog(_('GCP Manager settings saved to file \'%s\'.') % file)
#self.Close()
def OnApply(self, event):
Modified: grass/trunk/gui/wxpython/gcp/mapdisplay.py
--- grass/trunk/gui/wxpython/gcp/mapdisplay.py 2012-11-23 13:53:03 UTC (rev 53984)
+++ grass/trunk/gui/wxpython/gcp/mapdisplay.py 2012-11-23 14:21:17 UTC (rev 53985)
@@ -42,7 +42,7 @@
"""!Main frame for map display window. Drawing takes place in
child double buffered drawing window.
- def __init__(self, parent=None, title=_("GRASS GIS Manage Ground Control Points"),
+ def __init__(self, parent, giface, title=_("GRASS GIS Manage Ground Control Points"),
toolbars=["gcpdisp"], tree=None, notebook=None, lmgr=None,
page=None, Map=None, auimgr=None, name = 'GCPMapWindow', **kwargs):
"""!Main map display window with toolbars, statusbar and
@@ -58,13 +58,14 @@
@param kwargs wx.Frame attribures
- SingleMapFrame.__init__(self, parent = parent, title = title,
+ SingleMapFrame.__init__(self, parent = parent, giface = giface, title = title,
Map = Map, auimgr = auimgr, name = name, **kwargs)
self._layerManager = lmgr # Layer Manager object
self.tree = tree # Layer Manager layer tree object
self.page = page # Notebook page holding the layer tree
self.layerbook = notebook # Layer Manager layer tree notebook
# Add toolbars
@@ -113,11 +114,11 @@
# Init map display (buffered DC & set default cursor)
self.grwiz.SwitchEnv('source')
- self.SrcMapWindow = BufferedWindow(self, id=wx.ID_ANY,
+ self.SrcMapWindow = BufferedWindow(parent=self, giface=self._giface, id=wx.ID_ANY,
Map=self.SrcMap, frame = self, tree=self.tree, lmgr=self._layerManager)
self.grwiz.SwitchEnv('target')
- self.TgtMapWindow = BufferedWindow(self, id=wx.ID_ANY,
+ self.TgtMapWindow = BufferedWindow(parent=self, giface=self._giface, id=wx.ID_ANY,
Map=self.TgtMap, frame = self, tree=self.tree, lmgr=self._layerManager)
self.MapWindow = self.SrcMapWindow
self.Map = self.SrcMap
Modified: grass/trunk/gui/wxpython/gmodeler/frame.py
--- grass/trunk/gui/wxpython/gmodeler/frame.py 2012-11-23 13:53:03 UTC (rev 53984)
+++ grass/trunk/gui/wxpython/gmodeler/frame.py 2012-11-23 14:21:17 UTC (rev 53985)
@@ -56,7 +56,7 @@
from grass.script import core as grass
class ModelFrame(wx.Frame):
- def __init__(self, parent, id = wx.ID_ANY,
+ def __init__(self, parent, giface, id = wx.ID_ANY,
title = _("GRASS GIS Graphical Modeler"), **kwargs):
"""!Graphical modeler main window
@@ -67,6 +67,7 @@
@param kwargs wx.Frames' arguments
self.searchDialog = None # module search dialog
self.baseTitle = title
self.modelFile = None # loaded model
@@ -275,7 +276,7 @@
def OnPreferences(self, event):
"""!Open preferences dialog"""
- dlg = PreferencesDialog(parent = self)
+ dlg = PreferencesDialog(parent = self, giface = self._giface)
dlg.CenterOnParent()
dlg.ShowModal()
@@ -283,15 +284,8 @@
"""!Show help"""
- if self.parent and self.parent.GetName() == 'LayerManager':
- log = self.parent.GetLogWindow()
- log.RunCmd(['g.manual',
- 'entry=wxGUI.Modeler'])
- else:
- RunCommand('g.manual',
- quiet = True,
- entry = 'wxGUI.Modeler')
+ self._giface.Help(entry = 'wxGUI.Modeler')
def OnModelProperties(self, event):
"""!Model properties dialog"""
dlg = PropertiesDialog(parent = self)
@@ -715,11 +709,6 @@
self.SetFocus()
self.Raise()
- def OnHelp(self, event):
- """!Display manual page"""
- grass.run_command('g.manual',
def OnAbout(self, event):
"""!Display About window"""
info = wx.AboutDialogInfo()
Modified: grass/trunk/gui/wxpython/gmodeler/g.gui.gmodeler.py
--- grass/trunk/gui/wxpython/gmodeler/g.gui.gmodeler.py 2012-11-23 13:53:03 UTC (rev 53984)
+++ grass/trunk/gui/wxpython/gmodeler/g.gui.gmodeler.py 2012-11-23 14:21:17 UTC (rev 53985)
@@ -41,6 +41,7 @@
sys.path.append(os.path.join(os.environ['GISBASE'], "etc", "gui", "wxpython"))
+from core.giface import StandaloneGrassInterface
from gmodeler.frame import ModelFrame
def main():
@@ -49,7 +50,7 @@
app = wx.PySimpleApp()
wx.InitAllImageHandlers()
- frame = ModelFrame(parent = None)
+ frame = ModelFrame(parent = None, giface = StandaloneGrassInterface())
if options['file']:
frame.LoadModelFile(options['file'])
frame.Show()
Modified: grass/trunk/gui/wxpython/gmodeler/preferences.py
--- grass/trunk/gui/wxpython/gmodeler/preferences.py 2012-11-23 13:53:03 UTC (rev 53984)
+++ grass/trunk/gui/wxpython/gmodeler/preferences.py 2012-11-23 14:21:17 UTC (rev 53985)
@@ -24,10 +24,10 @@
class PreferencesDialog(PreferencesBaseDialog):
"""!User preferences dialog"""
- def __init__(self, parent, settings = UserSettings,
+ def __init__(self, parent, giface, settings = UserSettings,
title = _("Modeler settings")):
- PreferencesBaseDialog.__init__(self, parent = parent, title = title,
+ PreferencesBaseDialog.__init__(self, parent = parent, giface = giface, title = title,
settings = settings)
# create notebook pages
Modified: grass/trunk/gui/wxpython/gui_core/dialogs.py
--- grass/trunk/gui/wxpython/gui_core/dialogs.py 2012-11-23 13:53:03 UTC (rev 53984)
+++ grass/trunk/gui/wxpython/gui_core/dialogs.py 2012-11-23 14:21:17 UTC (rev 53985)
@@ -1787,13 +1787,14 @@
pass
class GdalImportDialog(ImportDialog):
- def __init__(self, parent, ogr = False, link = False):
+ def __init__(self, parent, giface, ogr = False, link = False):
"""!Dialog for bulk import of various raster/vector data
@param parent parent window
@param ogr True for OGR (vector) otherwise GDAL (raster)
@param link True for linking data otherwise importing data
self.link = link
self.ogr = ogr
@@ -1899,8 +1900,7 @@
cmd.append('--overwrite')
# run in Layer Manager
- self.parent.goutput.RunCmd(cmd, switchPage = True,
- onDone = self.AddLayers)
+ self._giface.RunCmd(cmd, switchPage = True, onDone = self.AddLayers)
if popOGR:
os.environ.pop('GRASS_VECTOR_OGR')
@@ -2023,10 +2023,10 @@
class DxfImportDialog(ImportDialog):
"""!Dialog for bulk import of DXF layers"""
ImportDialog.__init__(self, parent, itype = 'dxf',
title = _("Import DXF layers"))
self.dsnInput = filebrowse.FileBrowseButton(parent = self.panel, id = wx.ID_ANY,
size = globalvar.DIALOG_GSELECT_SIZE, labelText = '',
dialogTitle = _('Choose DXF file to import'),
@@ -2069,8 +2069,7 @@
self.OnCancel()
Modified: grass/trunk/gui/wxpython/gui_core/mapdisp.py
--- grass/trunk/gui/wxpython/gui_core/mapdisp.py 2012-11-23 13:53:03 UTC (rev 53984)
+++ grass/trunk/gui/wxpython/gui_core/mapdisp.py 2012-11-23 14:21:17 UTC (rev 53985)
@@ -381,7 +381,7 @@
@note To access maps use getters only
(when using class or when writing class itself).
- def __init__(self, parent = None, id = wx.ID_ANY, title = None,
+ def __init__(self, parent = None, giface = None, id = wx.ID_ANY, title = None,
style = wx.DEFAULT_FRAME_STYLE,
Map = None,
auimgr = None, name = None, **kwargs):
Modified: grass/trunk/gui/wxpython/gui_core/mapwindow.py
--- grass/trunk/gui/wxpython/gui_core/mapwindow.py 2012-11-23 13:53:03 UTC (rev 53984)
+++ grass/trunk/gui/wxpython/gui_core/mapwindow.py 2012-11-23 14:21:17 UTC (rev 53985)
@@ -36,13 +36,14 @@
- Pixel2Cell
- Cell2Pixel (if it is possible)
- def __init__(self, parent, Map, frame,
+ def __init__(self, parent, giface, Map, frame,
id = wx.ID_ANY, tree = None, lmgr = None, **kwargs):
self.parent = parent # MapFrame
self.Map = Map
self.frame = frame
self.tree = tree
self.lmgr = lmgr
# mouse attributes -- position on the screen, begin and end of
# dragging, and type of drawing
Modified: grass/trunk/gui/wxpython/gui_core/preferences.py
--- grass/trunk/gui/wxpython/gui_core/preferences.py 2012-11-23 13:53:03 UTC (rev 53984)
+++ grass/trunk/gui/wxpython/gui_core/preferences.py 2012-11-23 14:21:17 UTC (rev 53985)
@@ -55,13 +55,14 @@
class PreferencesBaseDialog(wx.Dialog):
"""!Base preferences dialog"""
- def __init__(self, parent, settings, title = _("User settings"),
+ def __init__(self, parent, giface, settings, title = _("User settings"),
size = (500, 475),
style = wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER):
self.parent = parent # ModelerFrame
self.title = title
self.size = size
self.settings = settings
wx.Dialog.__init__(self, parent = parent, id = wx.ID_ANY, title = title,
style = style)
@@ -148,7 +149,7 @@
Posts event EVT_SETTINGS_CHANGED.
if self._updateSettings():
- self.parent.goutput.WriteLog(_('Settings applied to current session but not saved'))
+ self._giface.WriteLog(_('Settings applied to current session but not saved'))
event = wxSettingsChanged()
wx.PostEvent(self, event)
self.Close()
@@ -175,7 +176,7 @@
self.settings.Set(group = 'language', key = 'locale', subkey = 'lc_all', value = 'C')
lang = 'C'
self.settings.SaveToFile()
- self.parent.goutput.WriteLog(_('Settings saved to file \'%s\'.') % self.settings.filePath)
+ self._giface.WriteLog(_('Settings saved to file \'%s\'.') % self.settings.filePath)
if lang:
StoreEnvVariable(key = 'LANG', value = lang)
else:
@@ -243,8 +244,7 @@
size = self.parent.GetSize()
dim = '%d,%d,%d,%d' % (pos[0], pos[1], size[0], size[1])
# opened displays
- for page in range(0, self.parent.GetLayerNotebook().GetPageCount()):
- mapdisp = self.parent.GetLayerNotebook().GetPage(page).maptree.GetMapDisplay()
+ for mapdisp in self._giface.GetAllMapDisplays():
pos = mapdisp.GetPosition()
size = mapdisp.GetSize()
@@ -258,10 +258,9 @@
- def __init__(self, parent, title = _("GUI Settings"),
+ def __init__(self, parent, giface, title = _("GUI Settings"),
settings = UserSettings):
Modified: grass/trunk/gui/wxpython/iclass/digit.py
--- grass/trunk/gui/wxpython/iclass/digit.py 2012-11-23 13:53:03 UTC (rev 53984)
+++ grass/trunk/gui/wxpython/iclass/digit.py 2012-11-23 14:21:17 UTC (rev 53985)
@@ -28,7 +28,7 @@
class IClassVDigitWindow(VDigitWindow):
"""! Class similar to VDigitWindow but specialized for wxIClass."""
- def __init__(self, parent, map, frame):
+ def __init__(self, parent, giface, map, frame):
@a parent should has toolbar providing current class (category).
@@ -36,7 +36,7 @@
@param parent gui parent
@param map map renderer instance
- VDigitWindow.__init__(self, parent = parent, Map = map, frame = frame)
+ VDigitWindow.__init__(self, parent = parent, giface = giface, Map = map, frame = frame)
def _onLeftDown(self, event):
action = self.toolbar.GetAction()
Modified: grass/trunk/gui/wxpython/iclass/frame.py
--- grass/trunk/gui/wxpython/iclass/frame.py 2012-11-23 13:53:03 UTC (rev 53984)
+++ grass/trunk/gui/wxpython/iclass/frame.py 2012-11-23 14:21:17 UTC (rev 53985)
@@ -69,7 +69,7 @@
It is wxGUI counterpart of old i.class module.
- def __init__(self, parent = None, title = _("Supervised Classification Tool"),
+ def __init__(self, parent = None, giface = None, title = _("Supervised Classification Tool"),
toolbars = ["iClassMisc", "iClassMap", "vdigit", "iClass"],
size = (875, 600), name = 'IClassWindow', **kwargs):
@@ -82,9 +82,11 @@
name = name,
firstMap = Map(), secondMap = Map(),
**kwargs)
- self.firstMapWindow = IClassVDigitWindow(self, map = self.firstMap, frame = self)
- self.secondMapWindow = BufferedWindow(self, Map = self.secondMap, frame = self)
+ self.firstMapWindow = IClassVDigitWindow(parent = self, giface = self._giface,
+ map = self.firstMap, frame = self)
+ self.secondMapWindow = BufferedWindow(parent = self, giface = self._giface,
+ Map = self.secondMap, frame = self)
self.MapWindow = self.firstMapWindow # current by default
self._bindWindowsActivation()
@@ -188,8 +190,7 @@
"""!Show help page"""
- entry = 'wxGUI.IClass')
+ self._giface.Help(entry = 'wxGUI.IClass')
def CreateTempVector(self):
"""!Create temporary vector map for training areas"""
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py 2012-11-23 13:53:03 UTC (rev 53984)
+++ grass/trunk/gui/wxpython/lmgr/frame.py 2012-11-23 14:21:17 UTC (rev 53985)
@@ -66,6 +66,7 @@
from lmgr.toolbars import LMWorkspaceToolbar, LMDataToolbar, LMToolsToolbar
from lmgr.toolbars import LMMiscToolbar, LMVectorToolbar, LMNvizToolbar
from lmgr.pyshell import PyShellWindow
+from lmgr.giface import LayerManagerGrassInterface
from gui_core.forms import GUI
from gcp.manager import GCPWizard
from nviz.main import haveNviz
@@ -91,6 +92,8 @@
self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass.ico'), wx.BITMAP_TYPE_ICO))
+ self._giface = LayerManagerGrassInterface(self)
self._auimgr = wx.aui.AuiManager(self)
# initialize variables
@@ -390,11 +393,11 @@
def OnGCPManager(self, event):
"""!Launch georectifier module
- GCPWizard(self)
+ GCPWizard(self, self._giface)
def OnGModeler(self, event):
"""!Launch Graphical Modeler"""
- win = ModelFrame(parent = self)
+ win = ModelFrame(parent = self, giface = self._giface)
win.CentreOnScreen()
win.Show()
@@ -577,11 +580,11 @@
return
if layertype == 'barscale':
- self.GetLayerTree().GetMapDisplay().OnAddBarscale(None)
+ self.GetMapDisplay().OnAddBarscale(None)
elif layertype == 'rastleg':
- self.GetLayerTree().GetMapDisplay().OnAddLegend(None)
+ self.GetMapDisplay().OnAddLegend(None)
elif layertype == 'redraw':
- self.GetLayerTree().GetMapDisplay().OnRender(None)
+ self.GetMapDisplay().OnRender(None)
else:
# add layer into layer tree
lname, found = GetLayerNameFromCmd(command, fullyQualified = True,
@@ -625,9 +628,7 @@
mlist.append(self.notebookLayers.GetPage(idx).maptree.GetMapDisplay())
return mlist
- return None
def GetLogWindow(self):
"""!Get widget for command output"""
return self.goutput
@@ -1282,10 +1283,7 @@
"""!Close all open map display windows
displays = list()
- for page in range(0, self.notebookLayers.GetPageCount()):
- displays.append(self.notebookLayers.GetPage(page).maptree.GetMapDisplay())
- for display in displays:
+ for display in self.GetMapDisplay(onlyCurrent = False):
display.OnCloseWindow(event)
def OnRenameDisplay(self, event):
@@ -1340,7 +1338,7 @@
"""!General GUI preferences/settings
if not self.dialogs['preferences']:
self.dialogs['preferences'] = dlg
self.dialogs['preferences'].CenterOnScreen()
@@ -1436,31 +1434,31 @@
def OnImportDxfFile(self, event, cmd = None):
"""!Convert multiple DXF layers to GRASS vector map layers"""
- dlg = DxfImportDialog(parent = self)
+ dlg = DxfImportDialog(parent = self, giface = self._giface)
dlg.CentreOnScreen()
dlg.Show()
def OnImportGdalLayers(self, event, cmd = None):
"""!Convert multiple GDAL layers to GRASS raster map layers"""
- dlg = GdalImportDialog(parent = self)
+ dlg = GdalImportDialog(parent = self, giface = self._giface)
dlg.Show()
def OnLinkGdalLayers(self, event, cmd = None):
"""!Link multiple GDAL layers to GRASS raster map layers"""
- dlg = GdalImportDialog(parent = self, link = True)
+ dlg = GdalImportDialog(parent = self, giface = self._giface, link = True)
dlg.Show()
def OnImportOgrLayers(self, event, cmd = None):
"""!Convert multiple OGR layers to GRASS vector map layers"""
- dlg = GdalImportDialog(parent = self, ogr = True)
+ dlg = GdalImportDialog(parent = self, giface = self._giface, ogr = True)
dlg.Show()
def OnLinkOgrLayers(self, event, cmd = None):
"""!Links multiple OGR layers to GRASS vector map layers"""
- dlg = GdalImportDialog(parent = self, ogr = True, link = True)
+ dlg = GdalImportDialog(parent = self, giface = self._giface, ogr = True, link = True)
dlg.Show()
@@ -1569,7 +1567,8 @@
self.currentPage = self.notebookLayers.GetCurrentPage()
# create layer tree (tree control for managing GIS layers) and put on new notebook page
- self.currentPage.maptree = LayerTree(self.currentPage, id = wx.ID_ANY, pos = wx.DefaultPosition,
+ self.currentPage.maptree = LayerTree(self.currentPage, giface = self._giface,
+ id = wx.ID_ANY, pos = wx.DefaultPosition,
size = wx.DefaultSize, style = wx.TR_HAS_BUTTONS |
wx.TR_LINES_AT_ROOT| wx.TR_HIDE_ROOT |
wx.TR_DEFAULT_STYLE| wx.NO_BORDER | wx.FULL_REPAINT_ON_RESIZE,
@@ -1678,7 +1677,7 @@
if not self.currentPage:
self.AddMaps([mapName], grassType, check = True)
else:
- display = self.GetLayerTree().GetMapDisplay()
+ display = self.GetMapDisplay()
mapLayers = map(lambda x: x.GetName(),
display.GetMap().GetListOfLayers(l_type = ltype))
if mapName in mapLayers:
@@ -1784,12 +1783,12 @@
def OnAddRasterArrow(self, event):
"""!Add flow arrows raster map to the current layer tree"""
self.notebook.SetSelectionByName('layers')
- tree = self.GetLayerTree()
- resolution = tree.GetMapDisplay().GetProperty('resolution')
+ mapdisplay = self.GetMapDisplay()
+ resolution = mapdisplay.GetProperty('resolution')
if not resolution:
dlg = self.MsgDisplayResolution()
if dlg.ShowModal() == wx.ID_YES:
- tree.GetMapDisplay().SetProperty('resolution', True)
+ mapdisplay.SetProperty('resolution', True)
dlg.Destroy()
self.GetLayerTree().AddLayer('rastarrow')
@@ -1797,14 +1796,14 @@
def OnAddRasterNum(self, event):
"""!Add cell number raster map to the current layer tree"""
if not resolution:
limitText = _("Note that cell values can only be displayed for "
"regions of less than 10,000 cells.")
dlg = self.MsgDisplayResolution(limitText)
dlg.Destroy()
# region = tree.GetMap().GetCurrentRegion()
Added: grass/trunk/gui/wxpython/lmgr/giface.py
--- grass/trunk/gui/wxpython/lmgr/giface.py (rev 0)
+++ grass/trunk/gui/wxpython/lmgr/giface.py 2012-11-23 14:21:17 UTC (rev 53985)
@@ -0,0 +1,58 @@
+ at package lmgr.giface
+ at brief Layer Manager GRASS interface
+Classes:
+ - giface::LayerManagerGrassInterface
+class LayerManagerGrassInterface:
+ def __init__(self, lmgr):
+ self.lmgr = lmgr
+ def RunCmd(self, *args, **kwargs):
+ self.lmgr.goutput.RunCmd(*args, **kwargs)
+ cmdlist = ['g.manual', 'entry=%s' % entry]
+ self.RunCmd(cmdlist, compReg = False, switchPage = False)
+ self.lmgr.goutput.WriteLog(text = text, wrap = wrap, switchPage = switchPage,
+ priority = priority)
+ self.lmgr.goutput.WriteCmdLog(line = line, pid = pid, switchPage = switchPage)
+ self.lmgr.goutput.WriteWarning(line = line)
+ self.lmgr.goutput.WriteError(line = line)
+ return self.lmgr.GetLayerTree()
+ @return MapFrame instance
+ @return None no mapdisplay open
+ return self.lmgr.GetMapDisplay(onlyCurrent = True)
+ @return list of MapFrame instances
+ return self.lmgr.GetMapDisplay(onlyCurrent = False)
Property changes on: grass/trunk/gui/wxpython/lmgr/giface.py
+ text/x-python
+ native
Modified: grass/trunk/gui/wxpython/lmgr/layertree.py
--- grass/trunk/gui/wxpython/lmgr/layertree.py 2012-11-23 13:53:03 UTC (rev 53984)
+++ grass/trunk/gui/wxpython/lmgr/layertree.py 2012-11-23 14:21:17 UTC (rev 53985)
@@ -98,7 +98,7 @@
class LayerTree(treemixin.DragAndDrop, CT.CustomTreeCtrl):
"""!Creates layer tree structure
id = wx.ID_ANY, style = wx.SUNKEN_BORDER,
ctstyle = CT.TR_HAS_BUTTONS | CT.TR_HAS_VARIABLE_ROW_HEIGHT |
CT.TR_HIDE_ROOT | CT.TR_ROW_LINES | CT.TR_FULL_ROW_HIGHLIGHT |
@@ -115,6 +115,8 @@
del kwargs['notebook']
showMapDisplay = kwargs['showMapDisplay']
del kwargs['showMapDisplay']
self.treepg = parent # notebook page holding layer tree
self.Map = Map() # instance of render.Map to be associated with display
self.root = None # ID of layer tree root node
@@ -149,7 +151,7 @@
# init associated map display
pos = wx.Point((self.displayIndex + 1) * 25, (self.displayIndex + 1) * 25)
- self.mapdisplay = MapFrame(self, id = wx.ID_ANY, pos = pos,
+ self.mapdisplay = MapFrame(self, giface = self._giface, id = wx.ID_ANY, pos = pos,
size = globalvar.MAP_WINDOW_SIZE,
tree = self, notebook = self.notebook,
@@ -488,14 +490,14 @@
self.PopupMenu(self.popupMenu)
self.popupMenu.Destroy()
def OnTopology(self, event):
"""!Rebuild topology of selected vector map"""
mapLayer = self.GetPyData(self.layer_selected)[0]['maplayer']
cmd = ['v.build',
'map=%s' % mapLayer.GetName()]
- self.lmgr.goutput.RunCmd(cmd, switchPage = True)
+ self._giface.RunCmd(cmd, switchPage = True)
def OnSqlQuery(self, event):
"""!Show SQL query window for PostGIS layers
@@ -517,7 +519,7 @@
cmd.append('map=%s' % mapLayer.GetName())
# print output to command log area
def OnSetCompRegFromRaster(self, event):
"""!Set computational region from selected raster map (ignore NULLs)"""
@@ -528,8 +530,8 @@
'zoom=%s' % mapLayer.GetName()]
- self.lmgr.goutput.RunCmd(cmd)
+ self._giface.RunCmd(cmd)
def OnSetCompRegFromMap(self, event):
"""!Set computational region from selected raster/vector map
@@ -561,8 +563,8 @@
if len(cmd) > 1:
cmd.append('-p')
- self.lmgr.goutput.RunCmd(cmd, compReg = False)
+ self._giface.RunCmd(cmd, compReg = False)
def OnProfile(self, event):
"""!Plot profile of given raster map layer"""
@@ -621,8 +623,8 @@
def OnUnivariateStats(self, event):
"""!Univariate raster statistics"""
name = self.GetPyData(self.layer_selected)[0]['maplayer'].GetName()
- self.lmgr.goutput.RunCmd(['r.univar', 'map=%s' % name], switchPage = True)
+ self._giface.RunCmd(['r.univar', 'map=%s' % name], switchPage = True)
def OnStartEditing(self, event):
"""!Start editing vector map layer requested by the user
Modified: grass/trunk/gui/wxpython/mapdisp/frame.py
--- grass/trunk/gui/wxpython/mapdisp/frame.py 2012-11-23 13:53:03 UTC (rev 53984)
+++ grass/trunk/gui/wxpython/mapdisp/frame.py 2012-11-23 14:21:17 UTC (rev 53985)
@@ -62,7 +62,7 @@
- def __init__(self, parent = None, title = _("GRASS GIS - Map display"),
+ def __init__(self, parent, giface, title = _("GRASS GIS - Map display"),
toolbars = ["map"], tree = None, notebook = None, lmgr = None,
page = None, Map = None, auimgr = None, name = 'MapWindow', **kwargs):
@@ -81,6 +81,7 @@
@@ -128,7 +129,7 @@
- self.MapWindow2D = BufferedWindow(self, id = wx.ID_ANY,
+ self.MapWindow2D = BufferedWindow(self, giface = self._giface, id = wx.ID_ANY,
Map = self.Map, frame = self, tree = self.tree, lmgr = self._layerManager)
# default is 2D display mode
self.MapWindow = self.MapWindow2D
@@ -208,7 +209,8 @@
if not self.MapWindowVDigit:
from vdigit.mapwindow import VDigitWindow
- self.MapWindowVDigit = VDigitWindow(self, id = wx.ID_ANY, frame = self,
+ self.MapWindowVDigit = VDigitWindow(parent = self, giface = self._giface,
+ id = wx.ID_ANY, frame = self,
Map = self.Map, tree = self.tree,
self.MapWindowVDigit.Show()
@@ -278,13 +280,13 @@
# erase map window
self.MapWindow.EraseMap()
- self._layerManager.goutput.WriteCmdLog(_("Starting 3D view mode..."),
- switchPage = False)
+ self._giface.WriteCmdLog(_("Starting 3D view mode..."),
+ switchPage = False)
self.SetStatusText(_("Please wait, loading data..."), 0)
# create GL window
if not self.MapWindow3D:
- self.MapWindow3D = GLWindow(self, id = wx.ID_ANY, frame = self,
+ self.MapWindow3D = GLWindow(self, giface = self._giface, id = wx.ID_ANY, frame = self,
Map = self.Map, tree = self.tree, lmgr = self._layerManager)
self.MapWindow = self.MapWindow3D
self.MapWindow.SetCursor(self.cursors["default"])
@@ -341,8 +343,8 @@
key = 'statusbarMode',
subkey = 'selection'))
self.SetStatusText(_("Please wait, unloading data..."), 0)
- self._layerManager.goutput.WriteCmdLog(_("Switching back to 2D view mode..."),
+ self._giface.WriteCmdLog(_("Switching back to 2D view mode..."),
if self.MapWindow3D:
self.MapWindow3D.OnClose(event = None)
# switch from MapWindowGL to MapWindow
@@ -731,12 +733,12 @@
lmap = digitToolbar.GetLayer().GetName()
for name in vect:
if lmap == name:
- self._layerManager.goutput.WriteWarning(_("Vector map <%s> "
+ self._giface.WriteWarning(_("Vector map <%s> "
"opened for editing - skipped.") % map)
vect.remove(name)
if len(vect) < 1:
- self._layerManager.goutput.WriteCmdLog(_("Nothing to query."))
+ self._giface.WriteCmdLog(_("Nothing to query."))
return
vcmd.append('-a')
@@ -750,12 +752,11 @@
# parse query command(s)
if rast and not self.IsPaneShown('3d'):
- self._layerManager.goutput.RunCmd(rcmd,
- compReg = False,
- onDone = self._QueryMapDone)
+ self._giface.RunCmd(rcmd,
+ compReg = False,
+ onDone = self._QueryMapDone)
if vect:
- self._layerManager.goutput.RunCmd(vcmd,
+ self._giface.RunCmd(vcmd, onDone = self._QueryMapDone)
def _QueryMapDone(self, cmd, returncode):
"""!Restore settings after querying (restore GRASS_REGION)
@@ -805,7 +806,7 @@
self.dialogs['attributes'].UpdateDialog(query = ((east, north), qdist),
action = mode)
if not self.dialogs['attributes'].IsFound():
- self._layerManager.goutput.WriteLog(_('Nothing found.'))
+ self._giface.WriteLog(_('Nothing found.'))
cats = self.dialogs['attributes'].GetCats()
@@ -936,16 +937,16 @@
# initiating output
style = self._layerManager.goutput.cmdOutput.StyleWarning
- self._layerManager.goutput.WriteLog(_('Click and drag with left mouse button '
+ self._giface.WriteLog(_('Click and drag with left mouse button '
'to measure.%s'
'Double click with left button to clear.') % \
(os.linesep), style)
if self.Map.projinfo['proj'] != 'xy':
units = self.Map.projinfo['units']
- self._layerManager.goutput.WriteCmdLog(_('Measuring distance') + ' ('
- + units + '):')
+ self._giface.WriteCmdLog(_('Measuring distance') + ' ('
+ + units + '):')
else:
- self._layerManager.goutput.WriteCmdLog(_('Measuring distance:'))
+ self._giface.WriteCmdLog(_('Measuring distance:'))
if self.Map.projinfo['proj'] == 'll':
try:
@@ -955,7 +956,7 @@
gislib.G_begin_distance_calculations()
except ImportError, e:
- self._layerManager.goutput.WriteWarning(_('Geodesic distance is not yet '
+ self._giface.WriteWarning(_('Geodesic distance is not yet '
'supported by this tool.\n'
'Reason: %s' % e))
@@ -993,7 +994,7 @@
_('total distance'), strtotdist, tdunits,
'-' * 60)
- self._layerManager.goutput.WriteLog(mstring)
+ self._giface.WriteLog(mstring)
return dist
Modified: grass/trunk/gui/wxpython/mapdisp/mapwindow.py
--- grass/trunk/gui/wxpython/mapdisp/mapwindow.py 2012-11-23 13:53:03 UTC (rev 53984)
+++ grass/trunk/gui/wxpython/mapdisp/mapwindow.py 2012-11-23 14:21:17 UTC (rev 53985)
@@ -51,10 +51,10 @@
can also save the drawing to file by calling the
SaveToFile() method.
style = wx.NO_FULL_REPAINT_ON_RESIZE, **kwargs):
- MapWindow.__init__(self, parent = parent, id = id, Map = Map,
+ MapWindow.__init__(self, parent = parent, giface = giface, id = id, Map = Map,
frame = frame, tree = tree, lmgr = lmgr, **kwargs)
wx.Window.__init__(self, parent = parent, id = id, style = style, **kwargs)
Modified: grass/trunk/gui/wxpython/mapswipe/frame.py
--- grass/trunk/gui/wxpython/mapswipe/frame.py 2012-11-23 13:53:03 UTC (rev 53984)
+++ grass/trunk/gui/wxpython/mapswipe/frame.py 2012-11-23 14:21:17 UTC (rev 53985)
@@ -35,7 +35,8 @@
class SwipeMapFrame(DoubleMapFrame):
- def __init__(self, parent = None, title = _("GRASS GIS Map Swipe"), name = "swipe", **kwargs):
+ title = _("GRASS GIS Map Swipe"), name = "swipe", **kwargs):
DoubleMapFrame.__init__(self, parent = parent, title = title, name = name,
firstMap = Map(), secondMap = Map(), **kwargs)
Debug.msg (1, "SwipeMapFrame.__init__()")
@@ -50,7 +51,7 @@
self.AddToolbar(toolbars.pop(0))
for toolb in toolbars:
self.AddToolbar(toolb)
# create widgets
@@ -59,8 +60,10 @@
self.sliderH = wx.Slider(self, id = wx.ID_ANY, style = wx.SL_HORIZONTAL)
self.sliderV = wx.Slider(self, id = wx.ID_ANY, style = wx.SL_VERTICAL)
- self.firstMapWindow = SwipeBufferedWindow(parent = self.splitter, Map = self.firstMap, frame = self)
- self.secondMapWindow = SwipeBufferedWindow(parent = self.splitter, Map = self.secondMap, frame = self)
+ self.firstMapWindow = SwipeBufferedWindow(parent = self.splitter, giface = self._giface,
+ Map = self.firstMap, frame = self)
+ self.secondMapWindow = SwipeBufferedWindow(parent = self.splitter, giface = self._giface,
self.firstMap.region = self.secondMap.region
self.firstMapWindow.zoomhistory = self.secondMapWindow.zoomhistory
@@ -459,9 +462,7 @@
return True
- quiet = True,
- entry = 'wxGUI.MapSwipe')
+ self._giface.Help(entry = 'wxGUI.MapSwipe')
def OnCloseWindow(self, event):
self.GetFirstMap().Clean()
Modified: grass/trunk/gui/wxpython/mapswipe/g.gui.mapswipe.py
--- grass/trunk/gui/wxpython/mapswipe/g.gui.mapswipe.py 2012-11-23 13:53:03 UTC (rev 53984)
+++ grass/trunk/gui/wxpython/mapswipe/g.gui.mapswipe.py 2012-11-23 14:21:17 UTC (rev 53985)
@@ -45,7 +45,8 @@
if __name__ == '__main__':
-from core.settings import UserSettings
+from core.settings import UserSettings
from mapswipe.frame import SwipeMapFrame
@@ -72,7 +73,7 @@
- frame = SwipeMapFrame()
+ frame = SwipeMapFrame(parent = None, giface = StandaloneGrassInterface())
if first:
frame.SetFirstRaster(first)
Modified: grass/trunk/gui/wxpython/mapswipe/mapwindow.py
--- grass/trunk/gui/wxpython/mapswipe/mapwindow.py 2012-11-23 13:53:03 UTC (rev 53984)
+++ grass/trunk/gui/wxpython/mapswipe/mapwindow.py 2012-11-23 14:21:17 UTC (rev 53985)
@@ -35,9 +35,10 @@
Enables to draw the image translated.
Special mouse events with changed coordinates are used.
- BufferedWindow.__init__(self, parent = parent, Map = Map, frame = frame, tree = tree, lmgr = lmgr, **kwargs)
+ BufferedWindow.__init__(self, parent = parent, giface = giface,
+ Map = Map, frame = frame, tree = tree, lmgr = lmgr, **kwargs)
Debug.msg(2, "SwipeBufferedWindow.__init__()")
self.specialSize = super(SwipeBufferedWindow, self).GetClientSize()
Modified: grass/trunk/gui/wxpython/nviz/mapwindow.py
--- grass/trunk/gui/wxpython/nviz/mapwindow.py 2012-11-23 13:53:03 UTC (rev 53984)
+++ grass/trunk/gui/wxpython/nviz/mapwindow.py 2012-11-23 14:21:17 UTC (rev 53985)
@@ -67,12 +67,12 @@
class GLWindow(MapWindow, glcanvas.GLCanvas):
"""!OpenGL canvas for Map Display Window"""
- def __init__(self, parent, id = wx.ID_ANY, frame = None,
+ def __init__(self, parent, giface, id = wx.ID_ANY, frame = None,
Map = None, tree = None, lmgr = None):
glcanvas.GLCanvas.__init__(self, parent, id)
- MapWindow.__init__(self, parent = parent, id = id, frame = frame,
+ MapWindow.__init__(self, parent = parent, giface = giface, id = id, frame = frame,
Map = Map, tree = tree, lmgr = lmgr)
self.Hide()
Modified: grass/trunk/gui/wxpython/vdigit/mapwindow.py
--- grass/trunk/gui/wxpython/vdigit/mapwindow.py 2012-11-23 13:53:03 UTC (rev 53984)
+++ grass/trunk/gui/wxpython/vdigit/mapwindow.py 2012-11-23 14:21:17 UTC (rev 53985)
@@ -28,10 +28,10 @@
class VDigitWindow(BufferedWindow):
"""!A Buffered window extended for vector digitizer.
- BufferedWindow.__init__(self, parent = parent, id = id, Map = Map,
+ BufferedWindow.__init__(self, parent = parent, giface = giface, id = id, Map = Map,
frame = frame, tree = tree, lmgr = lmgr, style = style, **kwargs)
self.pdcVector = wx.PseudoDC()
