[GRASS-SVN] r53994 - grass/trunk/vector/v.overlay
svn_grass at osgeo.org
Fri Nov 23 08:08:37 PST 2012
Author: mmetz
Date: 2012-11-23 08:08:37 -0800 (Fri, 23 Nov 2012)
New Revision: 53994
grass/trunk/vector/v.overlay/main.c
grass/trunk/vector/v.overlay/v.overlay.html
v.overlay: snap by default with 1e-8
Modified: grass/trunk/vector/v.overlay/main.c
--- grass/trunk/vector/v.overlay/main.c 2012-11-23 15:42:31 UTC (rev 53993)
+++ grass/trunk/vector/v.overlay/main.c 2012-11-23 16:08:37 UTC (rev 53994)
@@ -127,7 +127,7 @@
snap_opt->label = _("Snapping threshold for boundaries");
snap_opt->description = _("Disable snapping with snap <= 0");
snap_opt->type = TYPE_DOUBLE;
- snap_opt->answer = "0";
+ snap_opt->answer = "1e-8";
table_flag = G_define_standard_flag(G_FLG_V_TABLE);
Modified: grass/trunk/vector/v.overlay/v.overlay.html
--- grass/trunk/vector/v.overlay/v.overlay.html 2012-11-23 15:42:31 UTC (rev 53993)
+++ grass/trunk/vector/v.overlay/v.overlay.html 2012-11-23 16:08:37 UTC (rev 53994)
@@ -8,10 +8,12 @@
If areas in <em>ainput</em> are overlaid with areas in <em>binput</em>,
it is sometimes necessary to snap areas of <em>binput</em> to those of
<em>ainput</em>, otherwise areas can go missing or many sliver areas
-can be created. Snapping can be enabled by setting the <em>snap</em>
-option to a value larger zero. Recommended are values between
-0.00000001 and 0.0001. Using larger values for snapping can have
-undesired side-effects.
+can be created. Snapping is enabled by default and can be disabled by
+setting the <em>snap</em> option to a negative value. Recommended values
+are between 0.00000001 and 0.0001. Using larger values for snapping can
+have undesired side-effects. Snapping modifies only boundaries in binput,
+which are snapped to boundaries in ainput. Boundaries in ainput are not
+modified.
<!-- This is outdated
There are 3 links attached to features in output map,
<ul>
