[GRASS-SVN] r54000 - grass/trunk/lib/vector/diglib
svn_grass at osgeo.org
Fri Nov 23 11:39:25 PST 2012
Author: mmetz
Date: 2012-11-23 11:39:23 -0800 (Fri, 23 Nov 2012)
New Revision: 54000
grass/trunk/lib/vector/diglib/spindex_rw.c
diglib: add buffer for searching spatial index
Modified: grass/trunk/lib/vector/diglib/spindex_rw.c
--- grass/trunk/lib/vector/diglib/spindex_rw.c 2012-11-23 19:37:28 UTC (rev 53999)
+++ grass/trunk/lib/vector/diglib/spindex_rw.c 2012-11-23 19:39:23 UTC (rev 54000)
@@ -715,6 +715,8 @@
/* root node is written out last and its position returned */
while (top >= 0) {
+ if (s[top].sn == NULL)
+ G_fatal_error("NULL node ptr at top = %d", top);
n = s[top].sn;
writeout = 1;
/* this is an internal node in the RTree
@@ -1305,6 +1307,72 @@
return 0;
+/* read node from file */
+static void rtree_read_node(struct NodeBuffer *nb,
+ off_t nodepos, struct RTree *t, struct Plus_head *Plus)
+ int i, maxcard;
+ off_t pos;
+ struct gvfile *file = &(Plus->spidx_fp);
+ dig_fseek(file, nodepos, SEEK_SET);
+ /* read with dig__fread_port_* fns */
+ dig__fread_port_I(&(nb->n.count), 1, file);
+ dig__fread_port_I(&(nb->n.level), 1, file);
+ maxcard = nb->n.level ? t->nodecard : t->leafcard;
+ for (i = 0; i < maxcard; i++) {
+ dig__fread_port_D(nb->n.branch[i].rect.boundary, NUMSIDES,
+ file);
+ dig__fread_port_O(&pos, 1, file,
+ Plus->spidx_port.off_t_size);
+ /* leaf node: vector object IDs are stored in child.id */
+ if (nb->n.level == 0) {
+ nb->n.branch[i].child.id = (int)pos;
+ else {
+ nb->n.branch[i].child.pos = pos;
+/* get node from buffer or file */
+static struct RTree_Node *rtree_get_node(off_t nodepos, int level,
+ struct RTree *t,
+ struct Plus_head *Plus)
+ int which, i = 0;
+ /* check mru first */
+ while (t->nb[level][t->used[level][i]].pos != nodepos &&
+ t->nb[level][t->used[level][i]].pos >= 0 &&
+ i < NODE_BUFFER_SIZE - 1)
+ i++;
+ which = t->used[level][i];
+ if (t->nb[level][which].pos != nodepos) {
+ rtree_read_node(&(t->nb[level][which]), nodepos, t, Plus);
+ t->nb[level][which].pos = nodepos;
+ assert(t->nb[level][which].n.level == level);
+ /* make it mru */
+ if (i) { /* t->used[level][0] != which */
+#if 0
+ t->used[level][i] = t->used[level][0];
+ t->used[level][0] = which;
+#else
+ while (i) {
+ t->used[level][i] = t->used[level][i - 1];
+ i--;
+#endif
+ return &(t->nb[level][which].n);
\brief Search spatial index file
Can't use regular RTreeSearch() here because sidx must be read
@@ -1321,31 +1389,24 @@
int rtree_search(struct RTree *t, struct RTree_Rect *r,
SearchHitCallback shcb, void *cbarg, struct Plus_head *Plus)
- int hitCount = 0, found, maxcard;
- int i, j;
- struct spidxstack *last;
- static struct spidxstack s[MAXLEVEL];
- static int stack_init = 0;
- int top = 0;
+ int hitCount = 0, found;
+ /* int j, maxcard; */
+ int i;
+ struct spidxpstack s[MAXLEVEL];
+ int top = 0, level;
+ off_t lastpos;
assert(r);
assert(t);
- if (!stack_init) {
- for (i = 0; i < MAXLEVEL; i++) {
- for (j = 0; j < MAXCARD; j++) {
- s[i].sn.branch[j].rect.boundary = G_malloc(6 * sizeof(RectReal));
- stack_init = 1;
/* stack size of t->rootlevel + 1 is enough because of depth first search */
/* only one node per level on stack at any given time */
dig_set_cur_port(&(Plus->spidx_port));
/* add root node position to stack */
+ s[top].sn = rtree_get_node(t->rootpos, t->rootlevel, t, Plus);
+#if 0
dig_fseek(&(Plus->spidx_fp), t->rootpos, SEEK_SET);
dig__fread_port_I(&(s[top].sn.count), 1, &(Plus->spidx_fp));
@@ -1364,18 +1425,23 @@
s[top].sn.branch[j].child.pos = s[top].pos[j];
+#endif
s[top].branch_id = i = 0;
while (top >= 0) {
- last = &(s[top]);
- if (s[top].sn.level > 0) { /* this is an internal node in the tree */
+ level = s[top].sn->level;
+ if (level > 0) { /* this is an internal node in the tree */
found = 1;
for (i = s[top].branch_id; i < t->nodecard; i++) {
- if (s[top].pos[i] > 0 &&
- RTreeOverlap(r, &(s[top].sn.branch[i].rect), t)) {
+ lastpos = s[top].sn->branch[i].child.pos;
+ if (lastpos > 0 &&
+ RTreeOverlap(r, &(s[top].sn->branch[i].rect), t)) {
s[top++].branch_id = i + 1;
- dig_fseek(&(Plus->spidx_fp), last->pos[i], SEEK_SET);
+ s[top].sn = rtree_get_node(lastpos, level - 1, t, Plus);
+#if 0
+ dig_fseek(&(Plus->spidx_fp), lastpos, SEEK_SET);
&(Plus->spidx_fp));
@@ -1395,7 +1461,7 @@
+#endif
s[top].branch_id = 0;
found = 0;
break;
@@ -1409,12 +1475,12 @@
else { /* this is a leaf node */
for (i = 0; i < t->leafcard; i++) {
- if (s[top].sn.branch[i].child.id &&
+ if (s[top].sn->branch[i].child.id &&
hitCount++;
if (shcb) { /* call the user-provided callback */
- if (!shcb((int)s[top].sn.branch[i].child.id,
- &s[top].sn.branch[i].rect, cbarg)) {
+ if (!shcb((int)s[top].sn->branch[i].child.id,
+ &s[top].sn->branch[i].rect, cbarg)) {
/* callback wants to terminate search early */
return hitCount;
