[GRASS-SVN] r54002 - grass/trunk/vector/v.generalize
svn_grass at osgeo.org
Fri Nov 23 12:41:06 PST 2012
Author: mmetz
Date: 2012-11-23 12:41:06 -0800 (Fri, 23 Nov 2012)
New Revision: 54002
grass/trunk/vector/v.generalize/displacement.c
grass/trunk/vector/v.generalize/main.c
grass/trunk/vector/v.generalize/misc.c
grass/trunk/vector/v.generalize/misc.h
grass/trunk/vector/v.generalize/operators.h
grass/trunk/vector/v.generalize/simplification.c
v.generalize: fix cats and where options
Modified: grass/trunk/vector/v.generalize/displacement.c
--- grass/trunk/vector/v.generalize/displacement.c 2012-11-23 20:02:56 UTC (rev 54001)
+++ grass/trunk/vector/v.generalize/displacement.c 2012-11-23 20:41:06 UTC (rev 54002)
@@ -32,14 +32,14 @@
int snakes_displacement(struct Map_info *In, struct Map_info *Out,
double threshold, double alpha, double beta,
double gama, double delta, int iterations,
- struct varray * varray)
+ struct cat_list *cat_list, int layer)
int n_points;
int n_lines;
int i, j, index, pindex, iter, type;
int with_z = 0;
- struct line_pnts *Points, *Write;
+ struct line_pnts *Points;
struct line_cats *Cats;
MATRIX k, dx, dy, fx, fy, kinv, dx_old, dy_old;
POINT *parray;
@@ -51,14 +51,13 @@
/* initialize structrures and read the number of points */
Points = Vect_new_line_struct();
- Write = Vect_new_line_struct();
Cats = Vect_new_cats_struct();
n_lines = Vect_get_num_lines(In);
n_points = 0;
for (i = 1; i <= n_lines; i++) {
- type = Vect_read_line(In, Points, NULL, i);
- if (varray && !varray->c[i])
+ type = Vect_read_line(In, Points, Cats, i);
+ if (layer > 0 && !Vect_cats_in_constraint(Cats, layer, cat_list))
continue;
if (type & GV_LINE)
n_points += Points->n_points;
@@ -81,9 +80,12 @@
pindex = 0;
G_percent(i, n_lines, 1);
- if (type != GV_LINE || (varray && !varray->c[i]))
+ if (type != GV_LINE)
continue;
+ continue;
for (j = 0; j < Points->n_points; j++) {
int q, findex;
POINT cur;
@@ -290,7 +292,8 @@
int type = Vect_read_line(In, Points, Cats, i);
- if (type != GV_LINE || (varray && !varray->c[i])) {
+ if (type != GV_LINE ||
+ (layer > 0 && !Vect_cats_in_constraint(Cats, layer, cat_list))) {
Vect_write_line(Out, type, Points, Cats);
continue;
@@ -318,5 +321,6 @@
matrix_free(fy);
matrix_free(dx_old);
matrix_free(dy_old);
return 0;
Modified: grass/trunk/vector/v.generalize/main.c
--- grass/trunk/vector/v.generalize/main.c 2012-11-23 20:02:56 UTC (rev 54001)
+++ grass/trunk/vector/v.generalize/main.c 2012-11-23 20:41:06 UTC (rev 54002)
@@ -61,11 +61,10 @@
double degree_thresh, closeness_thresh, betweeness_thresh;
int method;
int look_ahead, iterations;
- int chcat;
int layer;
int n_lines;
int simplification, mask_type;
- struct varray *varray;
+ struct cat_list *cat_list = NULL;
char *s, *descriptions;
/* initialize GIS environment */
@@ -326,20 +325,18 @@
total_input = total_output = 0;
- chcat = 0;
- varray = NULL;
layer = Vect_get_field_number(&In, field_opt->answer);
- /* parse filter option and select appropriate lines */
- if (method == DISPLACEMENT)
- varray = parse_filter_options(&In, layer, mask_type,
- where_opt->answer, cat_opt->answer, &chcat);
+ /* parse filter options */
+ if (layer > 0)
+ cat_list = Vect_cats_set_constraint(&In, layer,
+ where_opt->answer, cat_opt->answer);
if (method == DISPLACEMENT) {
/* modifies only lines, all other features including boundaries are preserved */
/* options where, cats, and layer are respected */
G_message(_("Displacement..."));
snakes_displacement(&In, &Out, thresh, alpha, beta, 1.0, 10.0,
- iterations, varray);
+ iterations, cat_list, layer);
/* TODO: rearrange code below. It's really messy */
@@ -373,11 +370,6 @@
Vect_copy_map_lines(&In, &Out);
Vect_build_partial(&Out, GV_BUILD_CENTROIDS);
- /* varray needs to be retrieved from Out vector and not from In vector
- * because identical lines can have different ids
- * if dead lines are still registered in topo of In */
- varray = parse_filter_options(&Out, layer, mask_type,
if ((mask_type & GV_AREA) && !(mask_type & GV_BOUNDARY))
mask_type |= GV_BOUNDARY;
@@ -398,28 +390,50 @@
if (!(type & GV_LINES) || !(mask_type & type))
continue;
- if ((type & GV_LINE) && chcat && !varray->c[i])
- continue;
- else if ((type & GV_BOUNDARY) && chcat) {
- int do_line = varray->c[i];
- if ((mask_type & GV_AREA) && !do_line) {
+ if (layer > 0) {
+ if ((type & GV_LINE) &&
+ !Vect_cats_in_constraint(Cats, layer, cat_list))
+ continue;
+ else if ((type & GV_BOUNDARY)) {
+ int do_line = 0;
int left, right;
- /* check if any of the centroids is selected */
- Vect_get_line_areas(&Out, i, &left, &right);
- if (left > 0) {
- left = Vect_get_area_centroid(&Out, left);
- do_line = varray->c[left];
+ do_line = Vect_cats_in_constraint(Cats, layer, cat_list);
+ if (!do_line) {
+ /* check if any of the centroids is selected */
+ Vect_get_line_areas(&Out, i, &left, &right);
+ if (left > 0) {
+ Vect_get_area_cats(&Out, left, Cats);
+ else if (left < 0) {
+ left = Vect_get_isle_area(&Out, abs(left));
+ if (left > 0) {
+ if (!do_line) {
+ if (right > 0) {
+ Vect_get_area_cats(&Out, right, Cats);
+ else if (right < 0) {
+ right = Vect_get_isle_area(&Out, abs(right));
+ if (right > 0) {
- if (!do_line && right > 0) {
- right = Vect_get_area_centroid(&Out, right);
- do_line = varray->c[right];
+ if (!do_line)
+ continue;
- if (!do_line)
- continue;
Vect_line_prune(APoints);
Modified: grass/trunk/vector/v.generalize/misc.c
--- grass/trunk/vector/v.generalize/misc.c 2012-11-23 20:02:56 UTC (rev 54001)
+++ grass/trunk/vector/v.generalize/misc.c 2012-11-23 20:41:06 UTC (rev 54002)
@@ -87,12 +87,10 @@
int ttype, ntabs = 0;
struct field_info *IFi, *OFi;
- struct line_pnts *Points;
int **ocats, *nocats, *fields;
int i;
/* Collect list of output cats */
- Points = Vect_new_line_struct();
nfields = Vect_cidx_get_num_fields(In);
ocats = (int **)G_malloc(nfields * sizeof(int *));
@@ -189,69 +187,6 @@
return 1;
-/* parse filter option and select appropriate lines */
-/* return array with selected lines or NULL */
-struct varray *parse_filter_options(struct Map_info *Map, int layer,
- int mask_type, char *where, char *cats, int *chcat)
- /* allow selection of areas and other types */
- if (mask_type & GV_AREA) {
- mask_type &= ~(GV_AREA);
- mask_type |= GV_CENTROID;
- if (where) {
- if (layer < 1)
- G_fatal_error(_("'%s' must be > 0 for '%s'"), "layer", "where");
- if (cats)
- G_warning(_("'where' and 'cats' parameters were supplied, cat will be ignored"));
- *chcat = 1;
- varray = Vect_new_varray(Vect_get_num_lines(Map));
- if (Vect_set_varray_from_db
- (Map, layer, where, mask_type, 1, varray) == -1) {
- G_warning(_("Unable to load data from database"));
- else if (cats) {
- if (layer < 1)
- G_fatal_error(_("'%s' must be > 0 for '%s'"), "layer", GV_KEY_COLUMN);
- *chcat = 1;
- if (Vect_set_varray_from_cat_string
- (Map, layer, cats, mask_type, 1, varray) == -1) {
- G_warning(_("Problem loading category values"));
- else if (layer > 0) {
- int i, type, cat, nlines;
- struct line_cats *Cats = Vect_new_cats_struct();
- nlines = Vect_get_num_lines(Map);
- varray = Vect_new_varray(nlines);
- *chcat = 1;
- for (i = 1; i <= nlines; i++) {
- varray->c[i] = 0;
- type = Vect_read_line(Map, NULL, Cats, i);
- if (!(type & mask_type))
- continue;
- if (Vect_cat_get(Cats, layer, &cat))
- varray->c[i] = 1;
- Vect_destroy_cats_struct(Cats);
- else
- return NULL;
- return varray;
/* check topology corruption by boundary modification
* return 0 on corruption, 1 if modification is ok */
int check_topo(struct Map_info *Out, int line, struct line_pnts *APoints,
Modified: grass/trunk/vector/v.generalize/misc.h
--- grass/trunk/vector/v.generalize/misc.h 2012-11-23 20:02:56 UTC (rev 54001)
+++ grass/trunk/vector/v.generalize/misc.h 2012-11-23 20:41:06 UTC (rev 54002)
@@ -19,11 +19,6 @@
/* returns 1 on success, 0 on failure */
extern int copy_tables_by_cats(struct Map_info *In, struct Map_info *Out);
- int mask_type, char *where, char *cats, int *chcat);
int check_topo(struct Map_info *, int, struct line_pnts *,
Modified: grass/trunk/vector/v.generalize/operators.h
--- grass/trunk/vector/v.generalize/operators.h 2012-11-23 20:02:56 UTC (rev 54001)
+++ grass/trunk/vector/v.generalize/operators.h 2012-11-23 20:41:06 UTC (rev 54002)
@@ -29,4 +29,4 @@
- struct varray * varray);
+ struct cat_list *cat_list, int layer);
Modified: grass/trunk/vector/v.generalize/simplification.c
--- grass/trunk/vector/v.generalize/simplification.c 2012-11-23 20:02:56 UTC (rev 54001)
+++ grass/trunk/vector/v.generalize/simplification.c 2012-11-23 20:41:06 UTC (rev 54002)
@@ -225,7 +225,6 @@
int reumann_witkam(struct line_pnts *Points, double thresh, int with_z)
- int seg1, seg2;
int i, count;
POINT x0, x1, x2, sub, diff;
double subd, diffd, sp, dist;
@@ -238,8 +237,6 @@
thresh *= thresh;
- seg1 = 0;
- seg2 = 1;
count = 1;
point_assign(Points, 0, with_z, &x1);
