[GRASS-SVN] r54008 - grass/trunk/gui/wxpython/core
svn_grass at osgeo.org
Sat Nov 24 04:03:02 PST 2012
Author: annakrat
Date: 2012-11-24 04:03:01 -0800 (Sat, 24 Nov 2012)
New Revision: 54008
grass/trunk/gui/wxpython/core/giface.py
wxGUI/interface: using GConsole for executing commands
Modified: grass/trunk/gui/wxpython/core/giface.py
--- grass/trunk/gui/wxpython/core/giface.py 2012-11-24 11:12:27 UTC (rev 54007)
+++ grass/trunk/gui/wxpython/core/giface.py 2012-11-24 12:03:01 UTC (rev 54008)
@@ -14,39 +14,80 @@
@author Anna Kratochvilova <kratochanna gmail.com>
@author Vaclav Petras <wenzeslaus gmail.com>
-from core.gcmd import RunCommand
-from core.utils import CmdToTuple
+import os
+from core.gconsole import GConsole, \
+ EVT_CMD_OUTPUT, EVT_CMD_PROGRESS, EVT_CMD_RUN, EVT_CMD_DONE, \
+ EVT_WRITE_LOG, EVT_WRITE_CMD_LOG, EVT_WRITE_WARNING, EVT_WRITE_ERROR
import grass.script as grass
class StandaloneGrassInterface():
- def RunCmd(self, command,
- onDone = None, onPrepare = None, userData = None, **kwargs):
- if onPrepare:
- onPrepare(userData)
+ def __init__(self):
+ self._gconsole = GConsole()
+ self._gconsole.Bind(EVT_CMD_PROGRESS, self._onCmdProgress)
+ self._gconsole.Bind(EVT_CMD_OUTPUT, self._onCmdOutput)
+ self._gconsole.Bind(EVT_WRITE_LOG,
+ lambda event:
+ self.WriteLog(text = event.text))
+ self._gconsole.Bind(EVT_WRITE_CMD_LOG,
+ lambda event:
+ self.WriteCmdLog(line = event.line))
+ self._gconsole.Bind(EVT_WRITE_WARNING,
+ lambda event:
+ self.WriteWarning(line = event.line))
+ self._gconsole.Bind(EVT_WRITE_ERROR,
+ lambda event:
+ self.WriteError(line = event.line))
- cmdTuple = CmdToTuple(command)
- returncode = RunCommand(cmdTuple[0], **cmdTuple[1])
+ def _onCmdOutput(self, event):
+ """!Print command output"""
+ message = event.text
+ style = event.type
- if onDone:
- onDone(cmd = command, returncode = returncode)
+ if style == 'warning':
+ self.WriteWarning(message)
+ elif style == 'error':
+ self.WriteError(message)
+ else:
+ self.WriteLog(message)
+ event.Skip()
+ def _onCmdProgress(self, event):
+ """!Update progress message info"""
+ grass.percent(event.value, 100, 1)
+ event.Skip()
+ def RunCmd(self, command, compReg=True, switchPage=False, skipInterface=False,
+ onDone=None, onPrepare=None, userData=None, priority=1):
+ self._gconsole.RunCmd(command=command, compReg=compReg, switchPage=switchPage,
+ skipInterface=skipInterface, onDone=onDone,
+ onPrepare=onPrepare, userData=userData, priority=priority)
def Help(self, entry):
- RunCommand('g.manual', quiet = True, entry = entry)
+ self._gconsole.RunCmd(['g.manual', 'entry=%s' % entry])
def WriteLog(self, text, wrap = None,
switchPage = False, priority = 1):
- grass.message(text)
+ self._write(grass.message, text)
def WriteCmdLog(self, line, pid = None, switchPage = True):
- grass.message(line)
+ if pid:
+ line = '(' + str(pid) + ') ' + line
+ self._write(grass.message, line)
def WriteWarning(self, line):
- grass.warning(line)
+ self._write(grass.warning, line)
def WriteError(self, line):
- grass.error(line)
+ self._write(grass.error, line)
+ def _write(self, function, text):
+ orig = os.getenv("GRASS_MESSAGE_FORMAT")
+ os.environ["GRASS_MESSAGE_FORMAT"] = 'standard'
+ function(text)
+ os.environ["GRASS_MESSAGE_FORMAT"] = orig
def GetLayerTree(self):
return None
@@ -58,4 +99,7 @@
def GetAllMapDisplays(self):
"""!Get list of all map displays.
- return []
\ No newline at end of file
+ return []
+ def GetMapWindow(self):
+ return None
