[GRASS-SVN] r54011 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Sat Nov 24 05:18:35 PST 2012
Author: martinl
Date: 2012-11-24 05:18:35 -0800 (Sat, 24 Nov 2012)
New Revision: 54011
grass/trunk/lib/vector/Vlib/write_pg.c
vlib/PostGIS Topology: insert topological element with defined id (=line)
Modified: grass/trunk/lib/vector/Vlib/write_pg.c
--- grass/trunk/lib/vector/Vlib/write_pg.c 2012-11-24 12:40:22 UTC (rev 54010)
+++ grass/trunk/lib/vector/Vlib/write_pg.c 2012-11-24 13:18:35 UTC (rev 54011)
@@ -55,7 +55,7 @@
const struct P_line *,
int, const struct field_info *);
static char *build_insert_stmt(const struct Format_info_pg *, const char *,
- int, const struct field_info *);
+ int, int, const struct field_info *);
static char *build_topo_stmt(struct Map_info *, int,
const struct P_line *, const char *);
static int execute_topo(PGconn *, const char *);
@@ -834,6 +834,7 @@
const struct P_line *Line,
int cat, const struct field_info *Fi)
+ int fid;
int byte_order, nbytes, nsize;
unsigned int sf_type;
unsigned char *wkb_data;
@@ -932,7 +933,12 @@
/* build INSERT statement
simple feature geometry + attributes
- stmt = build_insert_stmt(pg_info, text_data, cat, Fi);
+ fid = -1;
+ if (pg_info->toposchema_name) {
+ /* use defined fid (=line) for topological access */
+ fid = Vect_get_num_primitives(Map, type); /* write next fid */
+ stmt = build_insert_stmt(pg_info, text_data, fid, cat, Fi);
G_debug(2, "SQL: %s", stmt);
if (!pg_info->inTransaction) {
@@ -981,13 +987,14 @@
\param pg_info pointer to Format_info_pg structure
\param geom_data geometry data
+ \param fid feature id (=line)
\param cat category number (or -1 for no category)
\param Fi pointer to field_info structure (NULL for no attributes)
\return allocated string with INSERT statement
char *build_insert_stmt(const struct Format_info_pg *pg_info,
- const char *geom_data,
+ const char *geom_data, int fid,
char *stmt, buf[DB_SQL_MAX];
@@ -1106,13 +1113,14 @@
else {
/* PostGIS topology access, write geometry in
* topology schema, skip geometry at this point */
- G_asprintf(&stmt, "%s) VALUES (%s)",
- buf, buf_val);
+ G_asprintf(&stmt, "%s,%s) VALUES (%s,%d)",
+ buf, pg_info->fid_column, buf_val, fid);
else {
+ /* no attributes */
if (!pg_info->toposchema_name) {
/* no attributes (simple features access) */
G_asprintf(&stmt, "INSERT INTO \"%s\".\"%s\" (%s) VALUES "
@@ -1122,9 +1130,9 @@
else if (cat > 0)
/* no attributes (topology elements) */
- G_asprintf(&stmt, "INSERT INTO \"%s\".\"%s\" (%s) VALUES (NULL)",
+ G_asprintf(&stmt, "INSERT INTO \"%s\".\"%s\" (%s) VALUES (%d)",
pg_info->schema_name, pg_info->table_name,
- pg_info->geom_column);
+ pg_info->fid_column, fid);
return stmt;
