[GRASS-SVN] r54014 - grass/trunk/gui/wxpython/lmgr
svn_grass at osgeo.org
Sat Nov 24 12:26:03 PST 2012
Author: annakrat
Date: 2012-11-24 12:26:02 -0800 (Sat, 24 Nov 2012)
New Revision: 54014
grass/trunk/gui/wxpython/lmgr/layertree.py
wxGUI/layertree: better access to layer info (part 1)
Modified: grass/trunk/gui/wxpython/lmgr/layertree.py
--- grass/trunk/gui/wxpython/lmgr/layertree.py 2012-11-24 18:27:37 UTC (rev 54013)
+++ grass/trunk/gui/wxpython/lmgr/layertree.py 2012-11-24 20:26:02 UTC (rev 54014)
@@ -253,8 +253,13 @@
return layers[0]
return None
+ # for compatibility
layer_selected = property(fget = GetSelectedLayer)
+ def GetSelectedLayers(self):
+ """!Get selected layers as a list.
+ return self.GetSelections()
def _setGradient(self, iType = None):
"""!Set gradient for items
@@ -294,7 +299,33 @@
def GetMapDisplay(self):
"""!Get associated MapFrame"""
return self.mapdisplay
+ def GetLayerInfo(self, layer, key = None):
+ """!Get layer info.
+ @param layer GenericTreeItem instance
+ @param key cmd, type, ctrl, label, maplayer, propwin, vdigit, nviz
+ (vdigit, nviz for map layers only)
+ if key:
+ return self.GetPyData(layer)[0][key]
+ def SetLayerInfo(self, layer, key, value):
+ """!Set layer info.
+ @param value value
+ info = self.GetPyData(layer)[0]
+ info[key] = value
+ def GetLayerParams(self, layer):
+ """!Get layer command params"""
+ return self.GetPyData(layer)[1]
def OnIdle(self, event):
"""!Only re-order and re-render a composite map image from GRASS during
idle time instead of multiple times during layer changing.
@@ -328,8 +359,8 @@
event.Skip()
return
- ltype = self.GetPyData(self.layer_selected)[0]['type']
- mapLayer = self.GetPyData(self.layer_selected)[0]['maplayer']
+ ltype = self.GetLayerInfo(self.layer_selected, key = 'type')
+ mapLayer = self.GetLayerInfo(self.layer_selected, key = 'maplayer')
Debug.msg (4, "LayerTree.OnContextMenu: layertype=%s" % \
ltype)
@@ -379,7 +410,7 @@
# specific items
try:
- mltype = self.GetPyData(self.layer_selected)[0]['type']
+ mltype = self.GetLayerInfo(self.layer_selected, key = 'type')
except:
mltype = None
@@ -405,7 +436,7 @@
self.Bind (wx.EVT_MENU, self.OnStartEditing, id = self.popupID['edit0'])
self.Bind (wx.EVT_MENU, self.OnStopEditing, id = self.popupID['edit1'])
- layer = self.GetPyData(self.layer_selected)[0]['maplayer']
+ layer = self.GetLayerInfo(self.layer_selected, key = 'maplayer')
# enable editing only for vector map layers available in the current mapset
digitToolbar = self.mapdisplay.GetToolbar('vdigit')
if digitToolbar:
@@ -423,12 +454,12 @@
# determine format
if layer and layer.GetType() == 'vector':
- if 'info' not in self.GetPyData(self.layer_selected)[0]:
+ if 'info' not in self.GetLayerInfo(self.layer_selected):
info = grass.parse_command('v.info',
flags = 'e',
map = layer.GetName())
- self.GetPyData(self.layer_selected)[0]['info'] = info
- info = self.GetPyData(self.layer_selected)[0]['info']
+ self.SetLayerInfo(self.layer_selected, key = 'info', value = info)
+ info = self.GetLayerInfo(self.layer_selected, key = 'info')
if info and info['format'] != 'native' and \
info['format'].split(',')[1] == 'PostgreSQL':
self.popupMenu.Append(self.popupID['sql'], text = _("SQL Spatial Query"))
@@ -506,7 +537,7 @@
def OnTopology(self, event):
"""!Rebuild topology of selected vector map"""
cmd = ['v.build',
'map=%s' % mapLayer.GetName()]
self._giface.RunCmd(cmd, switchPage = True)
@@ -522,8 +553,8 @@
"""!Print metadata of raster/vector map layer
TODO: Dialog to modify metadata
+ mltype = self.GetLayerInfo(self.layer_selected,key = 'type')
if mltype == 'raster':
cmd = ['r.info']
@@ -536,7 +567,7 @@
def OnSetCompRegFromRaster(self, event):
"""!Set computational region from selected raster map (ignore NULLs)"""
cmd = ['g.region',
'-p',
@@ -552,8 +583,8 @@
vect = []
rast3d = []
for layer in self.GetSelections():
- mapLayer = self.GetPyData(layer)[0]['maplayer']
- mltype = self.GetPyData(layer)[0]['type']
rast.append(mapLayer.GetName())
@@ -580,7 +611,7 @@
def OnProfile(self, event):
"""!Plot profile of given raster map layer"""
if not mapLayer.GetName():
wx.MessageBox(parent = self,
message = _("Unable to create profile of "
@@ -602,7 +633,7 @@
def OnRasterColorTable(self, event):
"""!Set color table for raster map"""
- name = self.GetPyData(self.layer_selected)[0]['maplayer'].GetName()
+ name = self.GetLayerInfo(self.layer_selected, key = 'maplayer').GetName()
ctable = RasterColorTable(self, layerTree = self)
ctable.SetMap(name)
ctable.Show()
@@ -610,14 +641,14 @@
def OnVectorColorTable(self, event):
"""!Set color table for vector map"""
GUI(parent = self, centreOnParent = False).ParseCommand(['v.colors',
'map=%s' % name])
def OnHistogram(self, event):
"""!Plot histogram for given raster map layer
GError(parent = self,
message = _("Unable to display histogram of "
@@ -635,14 +666,14 @@
def OnUnivariateStats(self, event):
"""!Univariate raster statistics"""
self._giface.RunCmd(['r.univar', 'map=%s' % name], switchPage = True)
def OnStartEditing(self, event):
"""!Start editing vector map layer requested by the user
try:
- maplayer = self.GetPyData(self.layer_selected)[0]['maplayer']
+ maplayer = self.GetLayerInfo(self.layer_selected, key = 'maplayer')
except:
event.Skip()
return
@@ -670,7 +701,7 @@
def OnStopEditing(self, event):
"""!Stop editing the current vector map layer
self.mapdisplay.toolbars['vdigit'].OnExit()
if self.lmgr:
@@ -683,7 +714,7 @@
"""!Set background vector map for editing sesstion"""
digit = self.mapdisplay.GetWindow().digit
if event.IsChecked():
- mapName = self.GetPyData(self.layer_selected)[0]['maplayer'].GetName()
+ mapName = self.GetLayerInfo(self.layer_selected, key = 'maplayer').GetName()
UserSettings.Set(group = 'vdigit', key = 'bgmap', subkey = 'value',
value = str(mapName), internal = True)
digit.OpenBackgroundMap(mapName)
@@ -702,10 +733,10 @@
def OnPopupOpacityLevel(self, event):
"""!Popup opacity level indicator"""
- if not self.GetPyData(self.layer_selected)[0]['ctrl']:
+ if not self.GetLayerInfo(self.layer_selected, key = 'ctrl'):
return
current_opacity = maplayer.GetOpacity()
dlg = SetOpacityDialog(self, opacity = current_opacity,
@@ -726,7 +757,7 @@
@param layer layer for which to change (item in layertree)
@param value opacity value (float between 0 and 1)
- maplayer = self.GetPyData(layer)[0]['maplayer']
+ maplayer = self.GetLayerInfo(layer, key = 'maplayer')
self.Map.ChangeOpacity(maplayer, value)
maplayer.SetOpacity(value)
self.SetItemText(layer,
@@ -750,7 +781,7 @@
@todo vector/volume
self.lmgr.notebook.SetSelectionByName('nviz')
if ltype == 'raster':
self.lmgr.nviz.SetPage('surface')
elif ltype == 'vector':
@@ -770,7 +801,7 @@
return
item = self.layer_selected
- self.GetPyData(item)[0]['label'] = event.GetLabel()
+ self.SetLayerInfo(item, key = 'label', value = event.GetLabel())
self.SetItemText(item, self._getLayerName(item))
event.Skip()
@@ -794,8 +825,8 @@
# check for duplicates
item = self.GetFirstVisibleItem()
while item and item.IsOk():
- if self.GetPyData(item)[0]['type'] == 'vector':
- name = self.GetPyData(item)[0]['maplayer'].GetName()
+ if self.GetLayerInfo(item, key = 'type') == 'vector':
+ name = self.GetLayerInfo(item, key = 'maplayer').GetName()
if name == lname:
return
item = self.GetNextVisible(item)
@@ -829,7 +860,7 @@
self.Bind(wx.EVT_BUTTON, self.OnLayerContextMenu, ctrl)
# add layer to the layer tree
if self.layer_selected and self.layer_selected != self.GetRootItem():
- if self.GetPyData(self.layer_selected)[0]['type'] == 'group' \
+ if self.GetLayerInfo(self.layer_selected, key = 'type') == 'group' \
and self.IsExpanded(self.layer_selected):
# add to group (first child of self.layer_selected) if group expanded
layer = self.PrependItem(parent = self.layer_selected,
@@ -953,8 +984,8 @@
prevMapLayer = None
pos = -1
while prevItem and prevItem.IsOk() and prevItem != layer:
- if self.GetPyData(prevItem)[0]['maplayer']:
- prevMapLayer = self.GetPyData(prevItem)[0]['maplayer']
+ if self.GetLayerInfo(prevItem, key = 'maplayer'):
+ prevMapLayer = self.GetLayerInfo(prevItem, key = 'maplayer')
prevItem = self.GetNextSibling(prevItem)
@@ -964,10 +995,10 @@
pos = -1
maplayer = self.Map.AddLayer(pos = pos,
- type = ltype, command = self.GetPyData(layer)[0]['cmd'], name = name,
+ type = ltype, command = self.GetLayerInfo(prevItem, key = 'cmd'), name = name,
l_active = checked, l_hidden = False,
l_opacity = lopacity, l_render = render)
- self.GetPyData(layer)[0]['maplayer'] = maplayer
+ self.SetLayerInfo(layer, key = 'maplayer', value = maplayer)
# run properties dialog if no properties given
if len(cmd) == 0:
@@ -1005,10 +1036,10 @@
def PropertiesDialog(self, layer, show = True):
"""!Launch the properties dialog"""
- if 'propwin' in self.GetPyData(layer)[0] and \
- self.GetPyData(layer)[0]['propwin'] is not None:
+ if 'propwin' in self.GetLayerInfo(layer) and \
+ self.GetLayerInfo(layer, key = 'propwin') is not None:
# recycle GUI dialogs
- win = self.GetPyData(layer)[0]['propwin']
+ win = self.GetLayerInfo(layer, key = 'propwin')
# update properties (columns, layers)
win.notebookpanel.OnUpdateSelection(None)
if win.IsShown():
@@ -1019,19 +1050,19 @@
return
completed = ''
- params = self.GetPyData(layer)[1]
- ltype = self.GetPyData(layer)[0]['type']
+ params = self.GetLayerParams(layer)
+ ltype = self.GetLayerInfo(layer, key = 'type')
Debug.msg (3, "LayerTree.PropertiesDialog(): ltype=%s" % \
ltype)
cmd = None
- if self.GetPyData(layer)[0]['cmd']:
+ if self.GetLayerInfo(layer, key = 'cmd'):
module = GUI(parent = self, show = show, centreOnParent = False)
- module.ParseCommand(self.GetPyData(layer)[0]['cmd'],
+ module.ParseCommand(self.GetLayerInfo(layer, key = 'cmd'),
completed = (self.GetOptData,layer,params))
- self.GetPyData(layer)[0]['cmd'] = module.GetCmd()
+ self.SetLayerInfo(layer, key = 'cmd', value = module.GetCmd())
elif ltype == 'raster':
cmd = ['d.rast']
if UserSettings.Get(group = 'rasterLayer', key = 'opaque', subkey = 'enabled'):
@@ -1093,7 +1124,7 @@
self.PropertiesDialog(layer)
- if self.GetPyData(layer)[0]['type'] == 'group':
+ if self.GetLayerInfo(layer, key = 'type') == 'group':
if self.IsExpanded(layer):
self.Collapse(layer)
else:
@@ -1119,8 +1150,8 @@
self.Unselect()
try:
- if self.GetPyData(item)[0]['type'] != 'group':
- self.Map.DeleteLayer( self.GetPyData(item)[0]['maplayer'])
+ if self.GetLayerInfo(item, key = 'type') != 'group':
+ self.Map.DeleteLayer(self.GetLayerInfo(item, key = 'maplayer'))
except:
pass
@@ -1138,9 +1169,9 @@
# nviz
if self.lmgr.IsPaneShown('toolbarNviz') and \
- self.GetPyData(item) is not None and not self.rerender:
+ self.GetLayerInfo(item) is not None and not self.rerender:
# nviz - load/unload data layer
- mapLayer = self.GetPyData(item)[0]['maplayer']
+ mapLayer = self.GetLayerInfo(item, key = 'maplayer')
self.mapdisplay.SetStatusText(_("Please wait, updating data..."), 0)
if mapLayer.type == 'raster':
self.mapdisplay.MapWindow.UnloadRaster(item)
@@ -1173,19 +1204,19 @@
if not self.first:
# change active parameter for item in layers list in render.Map
- if self.GetPyData(item)[0]['type'] == 'group':
+ if self.GetLayerInfo(item, key = 'type') == 'group':
child, cookie = self.GetFirstChild(item)
while child:
self.forceCheck = True
self.CheckItem(child, checked)
- mapLayer = self.GetPyData(child)[0]['maplayer']
+ mapLayer = self.GetLayerInfo(child, key = 'maplayer')
if not digitToolbar or \
(digitToolbar and digitToolbar.GetLayer() != mapLayer):
# ignore when map layer is edited
self.Map.ChangeLayerActive(mapLayer, checked)
child = self.GetNextSibling(child)
else:
@@ -1196,9 +1227,9 @@
# nviz
- self.GetPyData(item) is not None:
+ self.GetLayerInfo(item) is not None:
@@ -1236,7 +1267,7 @@
# find layer tree item by ctrl
layer = self.GetFirstVisibleItem()
while layer and layer.IsOk():
- if self.GetPyData(layer)[0]['ctrl'] == ctrl:
+ if self.GetLayerInfo(layer, key = 'ctrl') == ctrl:
break
layer = self.GetNextVisible(layer)
@@ -1273,7 +1304,7 @@
layer = event.GetItem()
if digitToolbar:
+ mapLayer = self.GetLayerInfo(layer, key = 'maplayer')
bgmap = UserSettings.Get(group = 'vdigit', key = 'bgmap', subkey = 'value',
internal = True)
@@ -1306,15 +1337,15 @@
pass
# update statusbar -> show command string
- if self.GetPyData(layer) and self.GetPyData(layer)[0]['maplayer']:
- cmd = self.GetPyData(layer)[0]['maplayer'].GetCmd(string = True)
+ if self.GetLayerInfo(layer) and self.GetLayerInfo(layer, key = 'maplayer'):
+ cmd = self.GetLayerInfo(layer, key = 'maplayer').GetCmd(string = True)
if len(cmd) > 0:
self.lmgr.SetStatusText(cmd)
# set region if auto-zooming is enabled
- if self.GetPyData(layer) and self.GetPyData(layer)[0]['cmd'] and \
+ if self.GetLayerInfo(layer) and self.GetLayerInfo(layer, key = 'cmd') and \
UserSettings.Get(group = 'display', key = 'autoZooming', subkey = 'enabled'):
if mapLayer.GetType() in ('raster', 'vector'):
render = self.mapdisplay.IsAutoRendered()
self.mapdisplay.MapWindow.ZoomToMap(layers = [mapLayer,],
@@ -1322,10 +1353,10 @@
# update nviz tools
- self.GetPyData(self.layer_selected) is not None:
+ self.GetLayerInfo(self.layer_selected) is not None:
if self.layer_selected.IsChecked():
# update Nviz tool window
- type = self.GetPyData(self.layer_selected)[0]['maplayer'].type
+ type = self.GetLayerInfo(self.layer_selected, key = 'maplayer').type
if type == 'raster':
self.lmgr.nviz.UpdatePage('surface')
@@ -1340,13 +1371,13 @@
def OnCollapseNode(self, event):
"""!Collapse node
- if self.GetPyData(self.layer_selected)[0]['type'] == 'group':
+ if self.GetLayerInfo(self.layer_selected, key = 'type') == 'group':
self.SetItemImage(self.layer_selected, self.folder)
def OnExpandNode(self, event):
"""!Expand node
self.SetItemImage(self.layer_selected, self.folder_open)
def OnEndDrag(self, event):
@@ -1377,7 +1408,7 @@
newItem = self.RecreateItem (dragItem, dropTarget)
# if recreated layer is a group, also recreate its children
- if self.GetPyData(newItem)[0]['type'] == 'group':
+ if self.GetLayerInfo(newItem, key = 'type') == 'group':
(child, cookie) = self.GetFirstChild(dragItem)
if child:
while child:
@@ -1408,29 +1439,29 @@
checked = self.IsItemChecked(dragItem)
image = self.GetItemImage(dragItem, 0)
text = self.GetItemText(dragItem)
- if self.GetPyData(dragItem)[0]['ctrl']:
+ if self.GetLayerInfo(dragItem, key = 'ctrl'):
# recreate data layer
btnbmp = LMIcons["layerOptions"].GetBitmap((16,16))
newctrl = buttons.GenBitmapButton(self, id = wx.ID_ANY, bitmap = btnbmp, size = (24, 24))
newctrl.SetToolTipString(_("Click to edit layer settings"))
self.Bind(wx.EVT_BUTTON, self.OnLayerContextMenu, newctrl)
- data = self.GetPyData(dragItem)
+ data = self.GetLayerInfo(dragItem)
- elif self.GetPyData(dragItem)[0]['type'] == 'command':
+ elif self.GetLayerInfo(dragItem, key = 'type') == 'command':
# recreate command layer
oldctrl = None
newctrl = wx.TextCtrl(self, id = wx.ID_ANY, value = '',
pos = wx.DefaultPosition, size = (250,25),
style = wx.TE_MULTILINE|wx.TE_WORDWRAP)
try:
- newctrl.SetValue(self.GetPyData(dragItem)[0]['maplayer'].GetCmd(string = True))
+ newctrl.SetValue(self.GetLayerInfo(dragItem, key = 'maplayer').GetCmd(string = True))
except:
pass
newctrl.Bind(wx.EVT_TEXT_ENTER, self.OnCmdChanged)
newctrl.Bind(wx.EVT_TEXT, self.OnCmdChanged)
- elif self.GetPyData(dragItem)[0]['type'] == 'group':
+ elif self.GetLayerInfo(dragItem, key = 'type') == 'group':
# recreate group
newctrl = None
data = None
@@ -1445,7 +1476,7 @@
afteritem = dropTarget
# dragItem dropped on group
- if self.GetPyData(afteritem)[0]['type'] == 'group':
+ if self.GetLayerInfo(afteritem, key = 'type') == 'group':
newItem = self.PrependItem(afteritem, text = text, \
ct_type = 1, wnd = newctrl, image = image, \
data = data)
@@ -1471,9 +1502,9 @@
#update new layer
self.SetPyData(newItem, self.GetPyData(dragItem))
if newctrl:
- self.GetPyData(newItem)[0]['ctrl'] = newctrl.GetId()
+ self.SetLayerInfo(newItem, key = 'ctrl', value = newctrl.GetId())
else:
- self.GetPyData(newItem)[0]['ctrl'] = None
+ self.SetLayerInfo(newItem, key = 'ctrl', value = None)
self.CheckItem(newItem, checked = checked) # causes a new render
@@ -1485,15 +1516,15 @@
@param lname optional layer name
if not mapLayer:
return lname
if not lname:
- lname = self.GetPyData(item)[0]['label']
+ lname = self.GetLayerInfo(item, key = 'label')
opacity = int(mapLayer.GetOpacity(float = True) * 100)
if not lname:
- dcmd = self.GetPyData(item)[0]['cmd']
+ dcmd = self.GetLayerInfo(item, key = 'cmd')
lname, found = GetLayerNameFromCmd(dcmd, layerType = mapLayer.GetType(),
fullyQualified = True)
if not found:
@@ -1509,10 +1540,10 @@
# set layer text to map name
if dcmd:
- self.GetPyData(layer)[0]['cmd'] = dcmd
+ self.SetLayerInfo(layer, key = 'cmd', value = dcmd)
mapText = self._getLayerName(layer)
mapName, found = GetLayerNameFromCmd(dcmd)
self.SetItemText(layer, mapName)
if not mapText or not found:
@@ -1523,15 +1554,15 @@
# update layer data
if params:
- self.SetPyData(layer, (self.GetPyData(layer)[0], params))
- self.GetPyData(layer)[0]['propwin'] = propwin
+ self.SetPyData(layer, (self.GetLayerInfo(layer), params))
+ self.SetLayerInfo(layer, key = 'propwin', value = propwin)
# change parameters for item in layers list in render.Map
self.ChangeLayer(layer)
if dcmd and UserSettings.Get(group = 'display', key = 'autoZooming', subkey = 'enabled'):
render = UserSettings.Get(group = 'display', key = 'autoRendering', subkey = 'enabled')
@@ -1539,7 +1570,7 @@
# update nviz session
if self.lmgr.IsPaneShown('toolbarNviz') and dcmd:
mapWin = self.mapdisplay.MapWindow
if len(mapLayer.GetCmd()) > 0:
id = -1
@@ -1577,15 +1608,15 @@
vislayer = self.GetFirstVisibleItem()
- if not vislayer or self.GetPyData(vislayer) is None:
+ if not vislayer or self.GetLayerInfo(vislayer) is None:
return
itemList = ""
for item in range(self.GetCount()):
itemList += self.GetItemText(vislayer) + ','
- if self.GetPyData(vislayer)[0]['type'] != 'group':
- treelayers.append(self.GetPyData(vislayer)[0]['maplayer'])
+ if self.GetLayerInfo(vislayer, key = 'type') != 'group':
+ treelayers.append(self.GetLayerInfo(vislayer, key = 'maplayer'))
if not self.GetNextVisible(vislayer):
break
@@ -1602,11 +1633,11 @@
def ChangeLayer(self, item):
"""!Change layer"""
- type = self.GetPyData(item)[0]['type']
+ type = self.GetLayerInfo(item, key = 'type')
layerName = None
if type == 'command':
- win = self.FindWindowById(self.GetPyData(item)[0]['ctrl'])
+ win = self.FindWindowById(self.GetLayerInfo(item, key = 'ctrl'))
if win.GetValue() != None:
cmd = win.GetValue().split(';')
cmdlist = []
@@ -1616,9 +1647,9 @@
chk = self.IsItemChecked(item)
hidden = not self.IsVisible(item)
elif type != 'group':
- if self.GetPyData(item)[0] is not None:
- cmdlist = self.GetPyData(item)[0]['cmd']
- opac = self.GetPyData(item)[0]['maplayer'].GetOpacity(float = True)
+ if self.GetLayerInfo(item) is not None:
+ cmdlist = self.GetLayerInfo(item, key = 'cmd')
+ opac = self.GetLayerInfo(item, key = 'maplayer').GetOpacity(float = True)
# determine layer name
@@ -1626,11 +1657,11 @@
if not found:
layerName = self.GetItemText(item)
- maplayer = self.Map.ChangeLayer(layer = self.GetPyData(item)[0]['maplayer'], type = type,
+ maplayer = self.Map.ChangeLayer(layer = self.GetLayerInfo(item, key = 'maplayer'), type = type,
command = cmdlist, name = layerName,
l_active = chk, l_hidden = hidden, l_opacity = opac, l_render = False)
- self.GetPyData(item)[0]['maplayer'] = maplayer
+ self.SetLayerInfo(item, key = 'maplayer', value = maplayer)
# if digitization tool enabled -> update list of available vector map layers
if self.mapdisplay.GetToolbar('vdigit'):
@@ -1678,7 +1709,7 @@
"""!Enable/disable items in layer tree"""
item = self.GetFirstChild(self.root)[0]
if mapLayer and type == mapLayer.type:
self.EnableItem(item, enable)
@@ -1688,13 +1719,13 @@
"""!Support method for FindItemByData"""
try:
- itemValue = self.GetPyData(item)[0][key]
+ itemValue = self.GetLayerInfo(item, key = 'key')
except KeyError:
return None
if value == itemValue:
return item
subItem = self.GetFirstChild(item)[0]
found = self.__FindSubItemByData(subItem, key, value)
if found:
@@ -1708,13 +1739,13 @@
items = []
try:
- itemLayer = self.GetPyData(item)[0]['maplayer']
+ itemLayer = self.GetLayerInfo(item, key = 'maplayer')
except KeyError:
return None
if value == itemLayer.GetName():
items.append(item)
found = self.__FindSubItemByName(subItem, name)
if found:
