[GRASS-SVN] r54021 - grass/trunk/gui/wxpython/lmgr
svn_grass at osgeo.org
Sun Nov 25 01:43:18 PST 2012
Author: annakrat
Date: 2012-11-25 01:43:17 -0800 (Sun, 25 Nov 2012)
New Revision: 54021
grass/trunk/gui/wxpython/lmgr/layertree.py
wxGUI: remove redundant code, fix icons for group
Modified: grass/trunk/gui/wxpython/lmgr/layertree.py
--- grass/trunk/gui/wxpython/lmgr/layertree.py 2012-11-25 07:25:59 UTC (rev 54020)
+++ grass/trunk/gui/wxpython/lmgr/layertree.py 2012-11-25 09:43:17 UTC (rev 54021)
@@ -174,7 +174,7 @@
# create image list to use with layer tree
il = wx.ImageList(16, 16, mask = False)
- trart = wx.ArtProvider.GetBitmap(wx.ART_FOLDER_OPEN, wx.ART_OTHER, (16, 16))
+ trart = wx.ArtProvider.GetBitmap(wx.ART_FILE_OPEN, wx.ART_OTHER, (16, 16))
self.folder_open = il.Add(trart)
trart = wx.ArtProvider.GetBitmap(wx.ART_FOLDER, wx.ART_OTHER, (16, 16))
self.folder = il.Add(trart)
@@ -226,9 +226,7 @@
self.cmd_icon = il.Add(trgif)
self.AssignImageList(il)
- self.Bind(wx.EVT_TREE_ITEM_EXPANDING, self.OnExpandNode)
- self.Bind(wx.EVT_TREE_ITEM_COLLAPSED, self.OnCollapseNode)
self.Bind(wx.EVT_TREE_ITEM_ACTIVATED, self.OnActivateLayer)
self.Bind(wx.EVT_TREE_SEL_CHANGED, self.OnChangeSel)
self.Bind(wx.EVT_TREE_SEL_CHANGING, self.OnChangingSel)
@@ -944,7 +942,8 @@
elif ltype == 'command':
self.SetItemImage(layer, self.cmd_icon)
elif ltype == 'group':
- self.SetItemImage(layer, self.folder)
+ self.SetItemImage(layer, self.folder, CT.TreeItemIcon_Normal)
+ self.SetItemImage(layer, self.folder_open, CT.TreeItemIcon_Expanded)
self.SetItemText(layer, grouptext)
self.first = False
@@ -1311,26 +1310,9 @@
self._setGradient()
else:
self._setGradient()
- try:
- if self.IsSelected(oldlayer):
- self.SetItemWindowEnabled(oldlayer, True)
- else:
- self.SetItemWindowEnabled(oldlayer, False)
- if self.IsSelected(layer):
- self.SetItemWindowEnabled(layer, True)
- else:
- self.SetItemWindowEnabled(layer, False)
- except:
- pass
+ self.RefreshLine(layer)
- try:
- self.RefreshLine(oldlayer)
- self.RefreshLine(layer)
- except:
- pass
# update statusbar -> show command string
if self.GetLayerInfo(layer, key = 'maplayer'):
cmd = self.GetLayerInfo(layer, key = 'maplayer').GetCmd(string = True)
@@ -1361,19 +1343,7 @@
elif type == '3d-raster':
self.lmgr.nviz.UpdatePage('volume')
self.lmgr.nviz.SetPage('volume')
- def OnCollapseNode(self, event):
- """!Collapse node
- if self.GetLayerInfo(self.layer_selected, key = 'type') == 'group':
- self.SetItemImage(self.layer_selected, self.folder)
- def OnExpandNode(self, event):
- """!Expand node
- self.SetItemImage(self.layer_selected, self.folder_open)
def OnEndDrag(self, event):
self.StopDragging()
dropTarget = event.GetItem()
