[GRASS-SVN] r54024 - in grass/trunk/gui/wxpython: core lmgr
svn_grass at osgeo.org
Sun Nov 25 02:44:05 PST 2012
Author: wenzeslaus
Date: 2012-11-25 02:44:05 -0800 (Sun, 25 Nov 2012)
New Revision: 54024
grass/trunk/gui/wxpython/core/events.py
grass/trunk/gui/wxpython/core/gconsole.py
grass/trunk/gui/wxpython/lmgr/frame.py
wxGUI/GConsole: fixing usage of command event and fixing d commands without parameters (in Layer Manager)
Modified: grass/trunk/gui/wxpython/core/events.py
--- grass/trunk/gui/wxpython/core/events.py 2012-11-25 10:31:19 UTC (rev 54023)
+++ grass/trunk/gui/wxpython/core/events.py 2012-11-25 10:44:05 UTC (rev 54024)
@@ -5,12 +5,20 @@
Put here only truly general events. Once you find that your event can be
generated in more than one class, put your event here. Otherwise,
-leave it in your class file.
+leave it in your class file. Events are expected to be grass/gis related.
General notice:
-Command events are propagated to parent windows. However they do not propagate
+Command events are propagated to parent windows. However, they do not propagate
beyond dialogs. Events do not propagate at all.
+Command events works only with windows, not EvtHandlers, so for other objects
+than windows you need to have extra parameter - guiparent - which can be used
+for creating command events.
+\code
+mapEvent = gMapCreated(self._guiparent.GetId(), ...)
+wx.PostEvent(self._guiparent, mapEvent)
+\endcode
+ at todo naming conventions for events
(C) 2012 by the GRASS Development Team
Modified: grass/trunk/gui/wxpython/core/gconsole.py
--- grass/trunk/gui/wxpython/core/gconsole.py 2012-11-25 10:31:19 UTC (rev 54023)
+++ grass/trunk/gui/wxpython/core/gconsole.py 2012-11-25 10:44:05 UTC (rev 54024)
@@ -641,9 +641,9 @@
name = p.get('value')
if '@' not in name:
name = name + '@' + grass.gisenv()['MAPSET']
- mapEvent = gMapCreated(wx.ID_ANY,
+ mapEvent = gMapCreated(self._guiparent.GetId(),
name=name, ltype=prompt, add=None)
- wx.PostEvent(self, mapEvent)
+ wx.PostEvent(self._guiparent, mapEvent)
event.Skip()
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py 2012-11-25 10:31:19 UTC (rev 54023)
+++ grass/trunk/gui/wxpython/lmgr/frame.py 2012-11-25 10:44:05 UTC (rev 54024)
@@ -40,7 +40,7 @@
sys.path.append(os.path.join(globalvar.ETCDIR, "python"))
from grass.script import core as grass
-from core.gcmd import RunCommand, GError, GMessage
+from core.gcmd import RunCommand, GError, GMessage, GException
from core.settings import UserSettings, GetDisplayVectSettings
from core.utils import SetAddOnPath, GetLayerNameFromCmd
from core.events import EVT_SHOW_NOTIFICATION, EVT_MAP_CREATED
@@ -566,6 +566,9 @@
self.RunDisplayCmd(command)
elif re.compile('r[3]?\.mapcalc').search(command[0]):
self.OnMapCalculator(event = None, cmd = command)
+ else:
+ raise ValueError('Layer Manger special command (%s)'
+ ' not supported.' % ' '.join(command))
def RunDisplayCmd(self, command):
"""!Handles display commands.
@@ -610,10 +613,9 @@
# add layer into layer tree
lname, found = GetLayerNameFromCmd(command, fullyQualified = True,
layerType = layertype)
- if found:
- self.GetLayerTree().AddLayer(ltype = layertype,
- lname = lname,
- lcmd = command)
+ self.GetLayerTree().AddLayer(ltype = layertype,
+ lname = lname,
+ lcmd = command)
def GetLayerNotebook(self):
"""!Get Layers Notebook"""
@@ -1667,6 +1669,7 @@
lgroup = None)
def OnMapCreated(self, event):
+ """!Decides wheter the map should be added to layer tree."""
if event.add is None:
if UserSettings.Get(group = 'cmd',
key = 'addNewLayer', subkey = 'enabled'):
