[GRASS-SVN] r54033 - grass/trunk/gui/wxpython/core
Sun Nov 25 05:52:43 PST 2012
Author: annakrat
Date: 2012-11-25 05:52:42 -0800 (Sun, 25 Nov 2012)
New Revision: 54033
   grass/trunk/gui/wxpython/core/gcmd.py
   grass/trunk/gui/wxpython/core/render.py
   grass/trunk/gui/wxpython/core/settings.py
   grass/trunk/gui/wxpython/core/utils.py
   grass/trunk/gui/wxpython/core/workspace.py
wxGUI: fix indentation, remove unused code
Modified: grass/trunk/gui/wxpython/core/gcmd.py
--- grass/trunk/gui/wxpython/core/gcmd.py	2012-11-25 13:27:20 UTC (rev 54032)
+++ grass/trunk/gui/wxpython/core/gcmd.py	2012-11-25 13:52:42 UTC (rev 54033)
@@ -188,7 +188,7 @@
             import win32api
             handle = win32api.OpenProcess(1, 0, self.pid)
             return (0 != win32api.TerminateProcess(handle, 0))
-	else:
+        else:
             try:
                 os.kill(-self.pid, signal.SIGTERM) # kill whole group
             except OSError:
@@ -342,7 +342,7 @@
         Debug.msg(1, "gcmd.Command(): %s" % ' '.join(cmd))
         self.cmd = cmd
         self.stderr = stderr
         # set verbosity level
@@ -561,14 +561,14 @@
         if self.stdout:
             # make module stdout/stderr non-blocking
             out_fileno = self.module.stdout.fileno()
-	    if not subprocess.mswindows:
+            if not subprocess.mswindows:
                 flags = fcntl.fcntl(out_fileno, fcntl.F_GETFL)
                 fcntl.fcntl(out_fileno, fcntl.F_SETFL, flags| os.O_NONBLOCK)
         if self.stderr:
             out_fileno = self.module.stderr.fileno()
Modified: grass/trunk/gui/wxpython/core/render.py
--- grass/trunk/gui/wxpython/core/render.py	2012-11-25 13:27:20 UTC (rev 54032)
+++ grass/trunk/gui/wxpython/core/render.py	2012-11-25 13:52:42 UTC (rev 54033)
@@ -127,8 +127,8 @@
                                  {'type' : self.type, 'name' : self.name})
         # start monitor
-	if self.mapfile:
-	    os.environ["GRASS_PNGFILE"] = self.mapfile
+        if self.mapfile:
+            os.environ["GRASS_PNGFILE"] = self.mapfile
         # execute command
         try:
@@ -482,7 +482,7 @@
         # new values to use for saving to region file
         new = {}
         n = s = e = w = 0.0
-        nwres = ewres = 0.0
+        nsres = ewres = 0.0
         # Get current values for region and display
         reg = self.GetRegion()
@@ -540,7 +540,7 @@
         try:
             self.width  = int(width)
             self.height = int(height)
-        except:
+        except ValueError:
             self.width  = 640
             self.height = 480
@@ -871,7 +871,7 @@
         return maps, masks, opacities
-    def GetMapsMasksAndOpacities(self, force, guiFrame, windres):
+    def GetMapsMasksAndOpacities(self, force, guiFrame):
         Used by Render function.
@@ -907,23 +907,21 @@
         else:
             os.environ["GRASS_RENDER_IMMEDIATE"] = "cairo"
-        maps, masks, opacities = self.GetMapsMasksAndOpacities(force, mapWindow, windres)
+        maps, masks, opacities = self.GetMapsMasksAndOpacities(force, mapWindow)
         # ugly hack for MSYS
         if sys.platform != 'win32':
             mapstr = ",".join(maps)
             maskstr = ",".join(masks)
-            mapoutstr = self.mapfile
         else:
             mapstr = ""
             for item in maps:
-                mapstr += item.replace('\\', '/')
+                mapstr += item.replace('\\', '/')
             mapstr = mapstr.rstrip(',')
             maskstr = ""
             for item in masks:
                 maskstr += item.replace('\\', '/')
             maskstr = maskstr.rstrip(',')
-            mapoutstr = self.mapfile.replace('\\', '/')
         # run g.pngcomp to get composite image
         bgcolor = ':'.join(map(str, UserSettings.Get(group = 'display', key = 'bgcolor',
@@ -1093,7 +1091,7 @@
         if render and not layer.Render():
             raise GException(_("Unable to render map layer <%s>.") %
-                             name)
+                             layer.GetName())
         return layer
@@ -1152,7 +1150,7 @@
                     os.remove(layer.mapfile)
                     os.remove(layer.maskfile)
                     self.layers.remove(layer)
-                    return layer
+                    return retlayer
         # del by id
         elif id != None:
             return self.layers.pop(id)
@@ -1169,7 +1167,7 @@
         @return -1 if layer not found
         if overlay:
-            list = self.overlay
+            list = self.overlays
         else:
             list = self.layers
@@ -1202,7 +1200,7 @@
         if l_render and command != '' and not overlay.Render():
             raise GException(_("Unable to render overlay <%s>.") %
-                             name)
+                             type)
         return self.overlays[-1]
@@ -1241,7 +1239,7 @@
         if render and overlay.GetCmd() != [] and not overlay.Render():
-                             name)
+                             overlay.GetType())
         return overlay
Modified: grass/trunk/gui/wxpython/core/settings.py
--- grass/trunk/gui/wxpython/core/settings.py	2012-11-25 13:27:20 UTC (rev 54032)
+++ grass/trunk/gui/wxpython/core/settings.py	2012-11-25 13:52:42 UTC (rev 54033)
@@ -23,7 +23,6 @@
 import sys
 import copy
 import types
-import locale
 from core       import globalvar
 from core.gcmd  import GException, GError
@@ -54,8 +53,6 @@
     def _generateLocale(self):
         """!Generate locales
-        import os
         try:
             self.locs = os.listdir(os.path.join(os.environ['GISBASE'], 'locale'))
             self.locs.append('en') # GRASS doesn't ship EN po files
@@ -1168,8 +1165,8 @@
     settings.append('size=%s' % UserSettings.Get(group = 'vectorLayer', key = 'point', subkey = 'size'))
     types = []
     for ftype in ['point', 'line', 'boundary', 'centroid', 'area', 'face']:
-         if UserSettings.Get(group = 'vectorLayer', key = 'showType', subkey = [ftype, 'enabled']):
-             types.append(ftype)
+        if UserSettings.Get(group = 'vectorLayer', key = 'showType', subkey = [ftype, 'enabled']):
+            types.append(ftype)
     settings.append('type=%s' % ','.join(types))
     return settings
Modified: grass/trunk/gui/wxpython/core/utils.py
--- grass/trunk/gui/wxpython/core/utils.py	2012-11-25 13:27:20 UTC (rev 54032)
+++ grass/trunk/gui/wxpython/core/utils.py	2012-11-25 13:52:42 UTC (rev 54033)
@@ -61,13 +61,13 @@
     # FIXME
     # ugly hack for MSYS (MS Windows)
     if platform.system() == 'Windows':
-	tempfile = tempfile.replace("/", "\\")
+        tempfile = tempfile.replace("/", "\\")
     try:
         path, file = os.path.split(tempfile)
         if pref:
             return os.path.join(pref, file)
-	else:
-	    return tempfile
+        else:
+            return tempfile
     except:
         return None
@@ -147,7 +147,7 @@
                         else:
                             findType = layerType
                         mapset = grass.find_file(mapname, element = findType)['mapset']
-                    except AttributeError, e: # not found
+                    except AttributeError: # not found
                         return '', False
                     if not mapset:
                         found = False
@@ -292,7 +292,7 @@
     """!Sort list items (not case-sensitive)"""
     list.sort(cmp=lambda x, y: cmp(x.lower(), y.lower()))
-def GetVectorNumberOfLayers(parent, vector):
+def GetVectorNumberOfLayers(vector):
     """!Get list of vector layers"""
     layers = list()
     if not vector:
@@ -536,8 +536,7 @@
             f = open(path, "r")
         except IOError:
             return _("failed to open '%s'" % path)
-        i = 0
         code = None
         for line in f.readlines():
             line = line.strip()
@@ -550,13 +549,12 @@
                 code, params = line.split(" ", 1)
                 try:
                     code = int(code.replace('<', '').replace('>', ''))
-                except ValueError:
+                except ValueError, e:
                     return e
             if code is not None:
                 epsgCodeDict[code] = (descr, params)
                 code = None
-            i += 1
         f.close()
     except StandardError, e:
Modified: grass/trunk/gui/wxpython/core/workspace.py
--- grass/trunk/gui/wxpython/core/workspace.py	2012-11-25 13:27:20 UTC (rev 54032)
+++ grass/trunk/gui/wxpython/core/workspace.py	2012-11-25 13:52:42 UTC (rev 54033)
@@ -545,7 +545,7 @@
         node_constants = node_state.find('constant_planes')
         constants = []
         if node_constants:
-            for i, node_plane in enumerate(node_constants.findall('plane')):
+            for node_plane in node_constants.findall('plane'):
                 plane = {}
                 plane['color'] = self.__processLayerNvizNode(node_plane, 'color', str)
                 plane['resolution'] = self.__processLayerNvizNode(node_plane, 'fine_resolution', int)
@@ -671,12 +671,12 @@
             if type == 'command':
                 cmd = mapTree.GetLayerInfo(item, key = 'maplayer').GetCmd(string=True)
                 self.file.write('%s<layer type="%s" name="%s" checked="%d">\n' % \
-                               (' ' * self.indent, type, EncodeString(cmd), checked));
-                self.file.write('%s</layer>\n' % (' ' * self.indent));
+                               (' ' * self.indent, type, EncodeString(cmd), checked))
+                self.file.write('%s</layer>\n' % (' ' * self.indent))
             elif type == 'group':
                 name = mapTree.GetItemText(item)
                 self.file.write('%s<group name="%s" checked="%d">\n' % \
-                               (' ' * self.indent, EncodeString(name), checked));
+                               (' ' * self.indent, EncodeString(name), checked))
                 self.indent += 4
                 subItem = mapTree.GetFirstChild(item)[0]
                 self.__writeLayer(mapTree, subItem)
@@ -714,9 +714,9 @@
                         self.file.write('%s<value>%s</value>\n' %
                                         (' ' * self.indent, self.__filterValue(val)))
                         self.indent -= 4
-                        self.file.write('%s</parameter>\n' % (' ' * self.indent));
+                        self.file.write('%s</parameter>\n' % (' ' * self.indent))
                 self.indent -= 4
-                self.file.write('%s</task>\n' % (' ' * self.indent));
+                self.file.write('%s</task>\n' % (' ' * self.indent))
                 # vector digitizer
                 vdigit = mapTree.GetLayerInfo(item, key = 'vdigit')
                 if vdigit:
@@ -804,12 +804,10 @@
             # position
             elif attrb == 'position':
                 self.file.write('%s<%s>\n' %(' ' * self.indent, attrb))
-                i = 0
                 for tag in ('x', 'y', 'z'):
                     self.indent += 4
                     self.file.write('%s<%s>%d</%s>\n' % (' ' * self.indent, tag,
                                                         data[attrb][tag], tag))
-                    i += 1
                     self.indent -= 4
             if attrb != 'attribute':
