[GRASS-SVN] r54036 - in grass/trunk/gui/wxpython: gui_core nviz
svn_grass at osgeo.org
Sun Nov 25 10:26:59 PST 2012
Author: annakrat
Date: 2012-11-25 10:26:59 -0800 (Sun, 25 Nov 2012)
New Revision: 54036
grass/trunk/gui/wxpython/gui_core/mapwindow.py
grass/trunk/gui/wxpython/nviz/tools.py
wxGUI/mapwindow: remove method used in nviz only
Modified: grass/trunk/gui/wxpython/gui_core/mapwindow.py
--- grass/trunk/gui/wxpython/gui_core/mapwindow.py 2012-11-25 17:55:36 UTC (rev 54035)
+++ grass/trunk/gui/wxpython/gui_core/mapwindow.py 2012-11-25 18:26:59 UTC (rev 54036)
@@ -248,30 +248,3 @@
@see OnMotion
return self.lastEN
- def GetLayerByName(self, name, mapType, dataType = 'layer'):
- """!Get layer from layer tree by nam
- @param name layer name
- @param type 'item' / 'layer' / 'nviz'
- @return layer / map layer properties / nviz properties
- @return None
- if not self.tree:
- return None
- try:
- mapLayer = self.Map.GetListOfLayers(l_type = mapType, l_name = name)[0]
- except IndexError:
- return None
- if dataType == 'layer':
- return mapLayer
- item = self.tree.FindItemByData('maplayer', mapLayer)
- if not item:
- return None
- if dataType == 'nviz':
- return self.tree.GetLayerInfo(item, key = 'nviz')
- return item
Modified: grass/trunk/gui/wxpython/nviz/tools.py
--- grass/trunk/gui/wxpython/nviz/tools.py 2012-11-25 17:55:36 UTC (rev 54035)
+++ grass/trunk/gui/wxpython/nviz/tools.py 2012-11-25 18:26:59 UTC (rev 54036)
@@ -2030,14 +2030,38 @@
return name
if nvizType == 'surface' or nvizType == 'fringe':
- return self.mapWindow.GetLayerByName(name, mapType = 'raster', dataType = 'nviz')
+ return self._getLayerPropertiesByName(name, mapType = 'raster')
elif nvizType == 'vector':
- return self.mapWindow.GetLayerByName(name, mapType = 'vector', dataType = 'nviz')
+ return self._getLayerPropertiesByName(name, mapType = 'vector')
elif nvizType == 'volume':
- return self.mapWindow.GetLayerByName(name, mapType = '3d-raster', dataType = 'nviz')
+ return self._getLayerPropertiesByName(name, mapType = '3d-raster')
return None
+ def _getMapLayerByName(self, name, mapType):
+ """!Get layer (render.Layer) by name and type.
+ @param name layer name
+ @param mapType map type (raster, vector, 3d-raster)
+ layers = self.mapWindow.Map.GetListOfLayers(l_type = mapType, l_name = name)
+ if layers:
+ return layers[0]
+ return None
+ def _getLayerPropertiesByName(self, name, mapType):
+ """!Get nviz properties stored in layertree items by name and type.
+ tree = self.parent.GetLayerTree()
+ items = tree.FindItemByData(key = 'name', value = name)
+ for item in items:
+ if tree.GetLayerInfo(item, key = 'type') == mapType:
+ return tree.GetLayerInfo(item, key = 'nviz')
+ return None
def OnRecord(self, event):
"""!Animation: start recording"""
anim = self.mapWindow.GetAnimation()
@@ -2724,24 +2748,24 @@
"""!Surface selected, currently used for fringes"""
name = event.GetString()
try:
- data = self.mapWindow.GetLayerByName(name, mapType = 'raster', dataType = 'nviz')['surface']
+ data = self._getLayerPropertiesByName(name, mapType = 'raster')['surface']
except:
self.EnablePage('fringe', False)
return
- layer = self.mapWindow.GetLayerByName(name, mapType = 'raster')
+ layer = self._getMapLayerByName(name, mapType = 'raster')
self.EnablePage('fringe', True)
def OnSetRaster(self, event):
"""!Raster map selected, update surface page"""
try:
- except TypeError:
+ except TypeError, e:
self.EnablePage('surface', False)
return
self.EnablePage('surface', True)
self.UpdateSurfacePage(layer, data, updateName = False)
@@ -2749,11 +2773,11 @@
"""!Vector map selected, update properties page"""
try:
- data = self.mapWindow.GetLayerByName(name, mapType = 'vector', dataType = 'nviz')['vector']
+ data = self._getLayerPropertiesByName(name, mapType = 'vector')['vector']
except:
self.EnablePage('vector', False)
return
- layer = self.mapWindow.GetLayerByName(name, mapType = 'vector')
+ layer = self._getMapLayerByName(name, mapType = 'vector')
self.EnablePage('vector', True)
self.UpdateVectorPage(layer, data, updateName = False)
@@ -2761,12 +2785,12 @@
"""!3D Raster map selected, update surface page"""
try:
- data = self.mapWindow.GetLayerByName(name, mapType = '3d-raster', dataType = 'nviz')['volume']
+ data = self._getLayerPropertiesByName(name, mapType = '3d-raster')['volume']
except:
self.EnablePage('volume', False)
return
- layer = self.mapWindow.GetLayerByName(name, mapType = '3d-raster')
+ layer = self._getMapLayerByName(name, mapType = '3d-raster')
self.EnablePage('volume', True)
self.UpdateVolumePage(layer, data, updateName = False)
@@ -2965,12 +2989,12 @@
name = self.FindWindowById(self.win[nvizType]['map']).GetValue()
if nvizType == 'surface':
data[nvizType]['attribute'][attrb] = { 'map' : useMap,
'value' : str(value),
'update' : None }
else: # volume / isosurface
list = self.FindWindowById(self.win['volume']['isosurfs'])
id = list.GetSelection()
if id != -1:
@@ -3073,12 +3097,12 @@
if not self.pageChanging:
'update' : None }
else:
if id > -1:
@@ -3161,7 +3185,7 @@
for name in self.mapWindow.GetLayerNames(type = 'raster'):
if not data:
continue # shouldy no happen
@@ -3352,7 +3376,10 @@
checked = event.IsChecked()
name = self.FindWindowById(self.win['vector']['map']).GetValue()
- item = self.mapWindow.GetLayerByName(name, mapType = 'vector', dataType = 'item')
+ items = self.parent.GetLayerTree().FindItemByData(key = 'name', value = name)
+ if self.parent.GetLayerTree().GetLayerInfo(item, key = 'type') == 'vector':
+ break
data = self.GetLayerData('vector')['vector']
if checked:
@@ -3690,7 +3717,7 @@
if event:
name = self.FindWindowById(self.win['volume']['map']).GetValue()
sizer.Layout()
@@ -3843,7 +3870,7 @@
# update dialog
if mode == 'isosurf':
data = self.GetLayerData('volume')['volume']['isosurface'][selection]
@@ -3863,7 +3890,7 @@
list = self.FindWindowById(self.win['volume'][mode + 's'])
id = data['object']['id']
@@ -3938,7 +3965,7 @@
list.SetSelection(list.GetCount()-1)
vid = data['object']['id']
@@ -3982,7 +4009,7 @@
return # this should not happen
@@ -4023,7 +4050,7 @@
@@ -4464,13 +4491,13 @@
data = self.GetLayerData(pageId)
if data:
if pageId == 'surface':
self.UpdateSurfacePage(layer, data['surface'])
elif pageId == 'vector':
self.UpdateVectorPage(layer, data['vector'])
elif pageId == 'volume':
self.UpdateVolumePage(layer, data['volume'])
elif pageId == 'light':
zval = self.mapWindow.light['position']['z']
