[GRASS-SVN] r54047 - in grass/branches/releasebranch_6_4/scripts: v.db.update v.what.vect
svn_grass at osgeo.org
Mon Nov 26 03:49:24 PST 2012
Author: neteler
Date: 2012-11-26 03:49:24 -0800 (Mon, 26 Nov 2012)
New Revision: 54047
grass/branches/releasebranch_6_4/scripts/v.db.update/description.html
grass/branches/releasebranch_6_4/scripts/v.what.vect/description.html
fix broken HTML url
Modified: grass/branches/releasebranch_6_4/scripts/v.db.update/description.html
--- grass/branches/releasebranch_6_4/scripts/v.db.update/description.html 2012-11-26 11:48:05 UTC (rev 54046)
+++ grass/branches/releasebranch_6_4/scripts/v.db.update/description.html 2012-11-26 11:49:24 UTC (rev 54047)
@@ -55,7 +55,7 @@
<em>
<a href="db.execute.html">db.execute</a>,
-<a href="v.db.addcolumn.html">v.db.addcolumn</a>,
+<a href="v.db.addcol.html">v.db.addcol</a>,
<a href="v.db.addtable.html">v.db.addtable</a>,
<a href="v.db.connect.html">v.db.connect</a>,
<a href="v.db.droptable.html">v.db.droptable</a>,
Modified: grass/branches/releasebranch_6_4/scripts/v.what.vect/description.html
--- grass/branches/releasebranch_6_4/scripts/v.what.vect/description.html 2012-11-26 11:48:05 UTC (rev 54046)
+++ grass/branches/releasebranch_6_4/scripts/v.what.vect/description.html 2012-11-26 11:49:24 UTC (rev 54047)
@@ -59,7 +59,7 @@
<h2>SEE ALSO</h2>
<em>
<a href="v.db.select.html">v.db.select</a>,
<a href="v.distance.html">v.distance</a>,
<a href="v.rast.stats.html">v.rast.stats</a>,
