[GRASS-SVN] r54059 - grass/trunk/db/drivers/sqlite
svn_grass at osgeo.org
Mon Nov 26 12:30:16 PST 2012
Author: neteler
Date: 2012-11-26 12:30:16 -0800 (Mon, 26 Nov 2012)
New Revision: 54059
grass/trunk/db/drivers/sqlite/grass-sqlite.html
updated to reflect new behaviour of storing sqlite DB in subdir
Modified: grass/trunk/db/drivers/sqlite/grass-sqlite.html
--- grass/trunk/db/drivers/sqlite/grass-sqlite.html 2012-11-26 20:21:24 UTC (rev 54058)
+++ grass/trunk/db/drivers/sqlite/grass-sqlite.html 2012-11-26 20:30:16 UTC (rev 54059)
@@ -29,7 +29,7 @@
<div class="code"><pre>
# example for storing DB in mapset directory (keep single quotes):
-db.connect driver=sqlite database='$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db'
+db.connect driver=sqlite database='$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db'
db.connect -p
</pre></div>
@@ -51,9 +51,10 @@
the following way is suggested (corresponds to above database connection):
+# fetch GRASS variables as shell environment variables:
eval `g.gisenv`
# use double quotes:
-sqlitebrowser "$GISDBASE/$LOCATION_NAME/$MAPSET"/sqlite.db
+sqlitebrowser "$GISDBASE/$LOCATION_NAME/$MAPSET"/sqlite/sqlite.db
</pre></div>
<!-- doesnt work yet, why?:
