[GRASS-SVN] r54091 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Wed Nov 28 08:51:26 PST 2012
Author: martinl
Date: 2012-11-28 08:51:25 -0800 (Wed, 28 Nov 2012)
New Revision: 54091
grass/trunk/lib/vector/Vlib/open_pg.c
grass/trunk/lib/vector/Vlib/read_pg.c
grass/trunk/lib/vector/Vlib/write_pg.c
vlib/PostGIS Topo: better support for areas (work in progress)
Modified: grass/trunk/lib/vector/Vlib/open_pg.c
--- grass/trunk/lib/vector/Vlib/open_pg.c 2012-11-28 16:34:03 UTC (rev 54090)
+++ grass/trunk/lib/vector/Vlib/open_pg.c 2012-11-28 16:51:25 UTC (rev 54091)
@@ -43,7 +43,6 @@
static void connect_db(struct Format_info_pg *);
static int check_topo(struct Format_info_pg *, struct Plus_head *);
static int parse_bbox(const char *, struct bound_box *);
-static int num_of_records(const struct Format_info_pg *, const char *);
static struct P_node *read_p_node(struct Plus_head *, int, int,
const char *, struct Format_info_pg *);
static struct P_line *read_p_line(struct Plus_head *, int,
@@ -442,6 +441,7 @@
/* free and init plus structure */
dig_init_plus(plus);
+ plus->Spidx_new = TRUE;
return Vect__load_plus_pg(Map, head_only);
#else
@@ -1104,35 +1104,6 @@
- \brief Get number of records for given SQL statement
- \param stmt string buffer with SQL statement
- \return number of returned records
- \return -1 on error
-int num_of_records(const struct Format_info_pg *pg_info,
- const char *stmt)
- int result;
- PGresult *res;
- G_debug(2, "SQL: %s", stmt);
- res = PQexec(pg_info->conn, stmt);
- if (!res || PQresultStatus(res) != PGRES_TUPLES_OK ||
- PQntuples(res) != 1) {
- G_warning(_("Unable to get number of records for:\n%s"), stmt);
- if (res)
- PQclear(res);
- return -1;
- result = atoi(PQgetvalue(res, 0, 0));
- PQclear(res);
- return result;
\brief Read P_node structure
See dig_Rd_P_node() for reference.
@@ -1172,7 +1143,7 @@
if (!res || PQresultStatus(res) != PGRES_TUPLES_OK) {
- G_warning(_("Unable to read node %d"), id);
+ G_warning(_("Inconsistency in topology: unable to read node %d"), id);
if (res)
PQclear(res);
return NULL;
@@ -1212,7 +1183,7 @@
/* get node coordinates */
if (SF_POINT != Vect__cache_feature_pg(wkb_data, FALSE, FALSE,
&(pg_info->cache), NULL))
- G_warning(_("Node %d: unexpected feature type %d"),
+ G_warning(_("Inconsistency in topology: node %d - unexpected feature type %d"),
n, pg_info->cache.sf_type);
points = pg_info->cache.lines[0];
@@ -1226,6 +1197,10 @@
/* update spatial index */
dig_spidx_add_node(plus, n, node->x, node->y, node->z);
+ if (plus->uplist.do_uplist)
+ /* collect updated nodes if requested */
+ dig_node_add_updated(plus, n);
plus->Node[n] = node;
return node;
@@ -1315,7 +1290,6 @@
topo->area = data->left_face;
- /* TODO: faces | kernels */
@@ -1323,11 +1297,17 @@
itype = cache->lines_types[0];
if ((line->type & GV_POINTS && itype != GV_POINT) ||
(line->type & GV_LINES && itype != GV_LINE))
- G_warning(_("Line %d: unexpected feature type"), n);
+ G_warning(_("Inconsistency in topology: line %d - unexpected feature type"), n);
points = cache->lines[0];
dig_line_box(points, &box);
dig_spidx_add_line(plus, n, &box);
+ if (plus->uplist.do_uplist) {
+ /* collect updated lines if requested */
+ dig_line_add_updated(plus, n);
+ plus->uplist.uplines_offset[plus->uplist.n_uplines - 1] = line->offset;
plus->Line[n] = line;
@@ -1335,7 +1315,7 @@
- \brief Read topo (from PostGIS topology schema) header info only
+ \brief Read topo from PostGIS topology schema -- header info only
\param[in,out] plus pointer to Plus_head struct
@@ -1350,7 +1330,8 @@
plus->off_t_size = -1;
- /* fisrt try to get info from 'topology.grass */
+ /* get map bounding box
+ fisrt try to get info from 'topology.grass' table */
sprintf(stmt,
"SELECT %s FROM \"%s\".\"%s\" WHERE %s = %d",
TOPO_BBOX, TOPO_SCHEMA, TOPO_TABLE, TOPO_ID, pg_info->toposchema_id);
@@ -1360,7 +1341,7 @@
PQclear(res);
- /* try to calculate bbox from TopoGeometry elements */
+ /* otherwise try to calculate bbox from TopoGeometry elements */
sprintf(stmt,
"SELECT ST_3DExtent(%s) FROM \"%s\".\"%s\"",
pg_info->topogeom_column, pg_info->schema_name, pg_info->table_name);
@@ -1381,7 +1362,8 @@
PQclear(res);
- /* number of topological primitives */
+ /* get number of topological elements */
/* nodes
note: isolated nodes are registered in GRASS Topology model */
sprintf(stmt,
@@ -1389,25 +1371,33 @@
"FROM \"%s\".edge GROUP BY start_node UNION ALL SELECT end_node "
"AS node FROM \"%s\".edge GROUP BY end_node) AS foo",
pg_info->toposchema_name, pg_info->toposchema_name);
- plus->n_nodes = num_of_records(pg_info, stmt);
+ plus->n_nodes = Vect__execute_get_value_pg(pg_info->conn, stmt);
G_debug(3, "Vect_open_topo_pg(): n_nodes=%d", plus->n_nodes);
/* lines (edges in PostGIS Topology model) */
sprintf(stmt,
"SELECT COUNT(*) FROM \"%s\".edge",
/* + isolated nodes as points
+ centroids */
- plus->n_lines = num_of_records(pg_info, stmt);
- /* areas (faces in PostGIS Topology model)
+ plus->n_lines = Vect__execute_get_value_pg(pg_info->conn, stmt);
+ /* areas (faces with face_id > 0 in PostGIS Topology model) */
sprintf(stmt,
- "SELECT COUNT(*) FROM \"%s\".face WHERE mbr IS NOT NULL",
+ "SELECT COUNT(*) FROM \"%s\".face WHERE face_id > 0",
- plus->n_areas = num_of_records(pg_info, stmt);
+ plus->n_areas = Vect__execute_get_value_pg(pg_info->conn, stmt);
G_debug(3, "Vect_open_topo_pg(): n_areas=%d", plus->n_areas);
- /* TODO: n_isles | n_volumes | n_holes */
+ /* isles (faces with face_id <=0 in PostGIS Topology model) */
+ sprintf(stmt,
+ "SELECT COUNT(*) FROM \"%s\".face WHERE face_id < 1",
+ pg_info->toposchema_name);
+ plus->n_isles = Vect__execute_get_value_pg(pg_info->conn, stmt);
+ G_debug(3, "Vect_open_topo_pg(): n_isles=%d", plus->n_isles);
- /* number of features group by type */
+ /* number of features according the type */
/* points */
sprintf(stmt,
"SELECT COUNT(*) FROM \"%s\".node WHERE containing_face "
@@ -1417,31 +1407,33 @@
"\"%s\".edge GROUP BY end_node) AS foo)",
pg_info->toposchema_name, pg_info->toposchema_name,
- plus->n_plines = num_of_records(pg_info, stmt);
+ plus->n_plines = Vect__execute_get_value_pg(pg_info->conn, stmt);
G_debug(3, "Vect_open_topo_pg(): n_plines=%d", plus->n_plines);
/* lines */
sprintf(stmt,
"SELECT COUNT(*) FROM \"%s\".edge WHERE "
"left_face = 0 AND right_face = 0",
- plus->n_llines = num_of_records(pg_info, stmt);
+ plus->n_llines = Vect__execute_get_value_pg(pg_info->conn, stmt);
G_debug(3, "Vect_open_topo_pg(): n_llines=%d", plus->n_llines);
/* boundaries */
sprintf(stmt,
"left_face != 0 OR right_face != 0",
- plus->n_blines = num_of_records(pg_info, stmt);
+ plus->n_blines = Vect__execute_get_value_pg(pg_info->conn, stmt);
G_debug(3, "Vect_open_topo_pg(): n_blines=%d", plus->n_blines);
/* centroids */
sprintf(stmt,
- plus->n_clines = num_of_records(pg_info, stmt);
+ plus->n_clines = Vect__execute_get_value_pg(pg_info->conn, stmt);
G_debug(3, "Vect_open_topo_pg(): n_clines=%d", plus->n_clines);
- /* TODO: nflines | n_klines */
- /* lines - register isolated nodes as points and centroids */
+ /* update number of lines - add points and centroids */
plus->n_lines += plus->n_plines + plus->n_clines;
G_debug(3, "Vect_open_topo_pg(): n_lines=%d", plus->n_lines);
@@ -1449,7 +1441,7 @@
- \brief Read topo info (from PostGIS topology schema)
+ \brief Read topo info from PostGIS topology schema
\param pg_info pointer to Format_info_pg
@@ -1460,14 +1452,16 @@
int Vect__load_plus_pg(struct Map_info *Map, int head_only)
- int i, id, ntuples;
+ int i, side, line, id, ntuples, area;
char stmt[DB_SQL_MAX];
struct edge_data line_data;
struct Format_info_pg *pg_info;
struct Plus_head *plus;
- struct P_line *line;
- struct P_area *area;
+ struct P_line *Line;
+ struct P_area *Area;
+ struct line_pnts *Points;
+ struct ilist *List;
PGresult *res;
@@ -1480,8 +1474,11 @@
if (head_only)
return 0;
+ Points = Vect_new_line_struct();
+ List = Vect_new_list();
/* read nodes (GRASS Topo)
- note: standalone nodes are ignored
+ note: standalone nodes (ie. points/centroids) are ignored
sprintf(stmt,
"SELECT node_id,geom FROM \"%s\".node WHERE node_id IN "
@@ -1494,7 +1491,9 @@
PQntuples(res) != plus->n_nodes) {
- G_warning(_("Unable to read nodes"));
+ G_warning(_("Inconsistency in topology: number of "
+ "nodes %d (should be %d)"),
+ PQntuples(res), plus->n_nodes);
if (res)
PQclear(res);
return -1;
@@ -1510,17 +1509,19 @@
PQclear(res);
/* read lines (GRASS Topo)
- - standalone nodes -> points
+ - standalone nodes -> points|centroids
- edges -> lines/boundaries
G_debug(3, "load_plus(): n_lines = %d", plus->n_lines);
dig_alloc_lines(plus, plus->n_lines);
+ G_zero(plus->Line, sizeof(struct P_line *) * (plus->n_lines + 1)); /* index starts at 1 */
- /* read PostGIS Topo standalone nodes
+ /* read PostGIS Topo standalone nodes (containing_face is null)
-> points
sprintf(stmt,
- "SELECT node_id,geom FROM \"%s\".node WHERE node_id NOT IN "
+ "SELECT node_id,geom FROM \"%s\".node WHERE containing_face "
+ "IS NULL AND node_id NOT IN "
"(SELECT node FROM (SELECT start_node AS node FROM \"%s\".edge "
"GROUP BY start_node UNION ALL SELECT end_node AS node FROM "
"\"%s\".edge GROUP BY end_node) AS foo) ORDER BY node_id",
@@ -1530,7 +1531,9 @@
PQntuples(res) > plus->n_plines) {
- G_warning(_("Unable to read lines"));
+ "points %d (should be %d)"),
+ PQntuples(res), plus->n_plines);
if (res)
PQclear(res);
return -1;
@@ -1558,15 +1561,17 @@
PQntuples(res) > plus->n_lines) {
+ "lines %d (should be %d)"),
+ PQntuples(res), plus->n_lines);
if (res)
PQclear(res);
return -1;
+ /* process edges (PostGIS Topo) */
ntuples = PQntuples(res);
for (i = 0; i < ntuples; i++) {
- /* process edges (PostGIS Topo) */
line_data.id = atoi(PQgetvalue(res, i, 0));
line_data.start_node = atoi(PQgetvalue(res, i, 1));
line_data.end_node = atoi(PQgetvalue(res, i, 2));
@@ -1575,77 +1580,92 @@
line_data.wkb_geom = (char *) PQgetvalue(res, i, 5);
id = plus->n_plines + i + 1; /* points already registered */
- line = read_p_line(plus, id, &line_data, &(pg_info->cache));
- if (line_data.left_face != 0 || line_data.right_face != 0) {
- /* boundary detected -> build area/isle on left and right*/
- int s, side;
- for (s = 0; s < 2; s++) {
- if (s == 0)
- side = GV_LEFT;
- else
- side = GV_RIGHT;
- G_debug(3, "Build area for line = %d, side = %d",
- id, side);
- Vect_build_line_area(Map, id, side);
- if (line->type == GV_BOUNDARY) {
- struct P_topo_b *topo;
+ read_p_line(plus, id, &line_data, &(pg_info->cache));
+ /* TODO: update category index */
+ PQclear(res);
- if (line_data.left_face == 0)
- line_data.left_face = -1;
- if (line_data.right_face == 0)
- line_data.right_face = -1;
+ /* read PostGIS Topo standalone nodes (containing_face is not null)
+ -> centroids
+ sprintf(stmt,
+ "SELECT node_id,geom,containing_face FROM \"%s\".node WHERE containing_face "
+ "IS NOT NULL AND node_id NOT IN "
+ "(SELECT node FROM (SELECT start_node AS node FROM \"%s\".edge "
+ "GROUP BY start_node UNION ALL SELECT end_node AS node FROM "
+ "\"%s\".edge GROUP BY end_node) AS foo) ORDER BY node_id",
+ pg_info->toposchema_name, pg_info->toposchema_name,
+ G_debug(2, "SQL: %s", stmt);
+ res = PQexec(pg_info->conn, stmt);
+ if (!res || PQresultStatus(res) != PGRES_TUPLES_OK ||
+ PQntuples(res) > plus->n_clines) {
+ "centroids %d (should be %d)"),
+ PQntuples(res), plus->n_clines);
+ if (res)
+ PQclear(res);
+ return -1;
+ G_zero(&line_data, sizeof(struct edge_data));
+ id = plus->n_plines + plus->n_llines + plus->n_blines + 1;
+ for (i = 0; i < plus->n_clines; i++) {
+ line_data.id = atoi(PQgetvalue(res, i, 0));
+ line_data.wkb_geom = (char *)PQgetvalue(res, i, 1);
+ line_data.left_face = atoi(PQgetvalue(res, i, 2)); /* face id */
+ /* area id and face id can be different */
+ read_p_line(plus, id + i, &line_data, &(pg_info->cache));
+ PQclear(res);
+ /* build areas for boundaries
+ reset values -> build from scratch */
+ plus->n_areas = plus->n_isles = 0;
+ for (line = 1; line <= plus->n_lines; line++) {
+ Line = plus->Line[line]; /* centroids: Line is NULL */
+ if (!Line || Line->type != GV_BOUNDARY)
+ continue;
+ for (i = 0; i < 2; i++) { /* for both sides build an area/isle */
+ side = i == 0 ? GV_LEFT : GV_RIGHT;
- /* check topo - left / right areas */
- topo = (struct P_topo_b *)line->topo;
- if (topo->left != line_data.left_face)
- G_warning(_("Left area detected as %d (should be %d"),
- topo->left, line_data.left_face);
- if (topo->right != line_data.right_face)
- G_warning(_("Right area detected as %d (should be %d"),
- topo->right, line_data.right_face);
+ G_debug(3, "Build area for line = %d, side = %d",
+ id, side);
+ Vect_build_line_area(Map, line, side);
- PQclear(res);
+ plus->built = GV_BUILD_AREAS;
+ /* TODO: attach isles */
+ plus->built = GV_BUILD_ATTACH_ISLES;
- /* read PostGIS Topo standalone nodes (containing_face is not null)
- -> centroids
+ /* attach centroids */
if (plus->n_areas > 0) {
- sprintf(stmt,
- "SELECT node_id,geom FROM \"%s\".node WHERE containing_face "
- "IS NOT NULL AND node_id NOT IN "
- "(SELECT node FROM (SELECT start_node AS node FROM \"%s\".edge "
- "GROUP BY start_node UNION ALL SELECT end_node AS node FROM "
- "\"%s\".edge GROUP BY end_node) AS foo) ORDER BY node_id",
- pg_info->toposchema_name, pg_info->toposchema_name,
- pg_info->toposchema_name);
- PQntuples(res) > plus->n_areas) {
- G_warning(_("Unable to attach centroids"));
- if (res)
- PQclear(res);
- return -1;
+ struct P_topo_c *topo;
- G_zero(&line_data, sizeof(struct edge_data));
- for (i = 1; i <= plus->n_areas; i++) {
- area = plus->Area[i];
+ if (Line->type != GV_CENTROID)
+ continue;
- id = plus->n_lines - plus->n_clines + i;
- line_data.id = line_data.left_face = i;
- line_data.wkb_geom = (char *)PQgetvalue(res, 0, 0);
- read_p_line(plus, id, &line_data, &(pg_info->cache));
- area->centroid = line_data.id;
+ Vect_read_line(Map, Points, NULL, line);
+ area = Vect_find_area(Map, Points->x[0], Points->y[0]);
+ topo = (struct P_topo_c *)Line->topo;
+ topo->area = area;
+ Area = plus->Area[topo->area];
+ Area->centroid = Line->offset;
+ plus->built = GV_BUILD_CENTROIDS;
+ /* done */
+ plus->built = GV_BUILD_ALL;
+ Vect_destroy_line_struct(Points);
+ Vect_destroy_list(List);
return 0;
Modified: grass/trunk/lib/vector/Vlib/read_pg.c
--- grass/trunk/lib/vector/Vlib/read_pg.c 2012-11-28 16:34:03 UTC (rev 54090)
+++ grass/trunk/lib/vector/Vlib/read_pg.c 2012-11-28 16:51:25 UTC (rev 54091)
@@ -137,8 +137,6 @@
if (Line->type == GV_CENTROID) {
G_debug(4, "Centroid");
- Map->next_line++;
if (line_p != NULL) {
int i, found;
struct bound_box box;
@@ -174,10 +172,10 @@
ret = GV_CENTROID;
else {
- /* ignore constraints, Map->next_line incremented */
+ /* ignore constraints */
ret = read_next_line_pg(Map, line_p, line_c, TRUE);
if (ret != Line->type)
- G_fatal_error(_("Unexpected feature type (%s) - should be (%d)"),
+ G_fatal_error(_("Unexpected feature type (%d) - should be (%d)"),
ret, Line->type);
@@ -185,12 +183,15 @@
/* skip by region */
Vect_line_box(line_p, &lbox);
if (!Vect_box_overlap(&lbox, &mbox)) {
+ Map->next_line++;
continue;
/* skip by field ignored */
+ Map->next_line++; /* read next */
return ret;
#else
@@ -479,7 +480,7 @@
else {
/* random access */
- if (!pg_info->fid_column) {
+ if (!pg_info->fid_column && !pg_info->toposchema_name) {
G_warning(_("Random access not supported. "
"Primary key not defined."));
return -1;
@@ -1189,7 +1190,7 @@
pg_info->toposchema_name, pg_info->toposchema_name, pg_info->toposchema_name);
- G_debug(3, "SQL: %s", stmt);
if (Vect__execute_pg(pg_info->conn, stmt) == -1) {
Vect__execute_pg(pg_info->conn, "ROLLBACK");
Modified: grass/trunk/lib/vector/Vlib/write_pg.c
--- grass/trunk/lib/vector/Vlib/write_pg.c 2012-11-28 16:34:03 UTC (rev 54090)
+++ grass/trunk/lib/vector/Vlib/write_pg.c 2012-11-28 16:51:25 UTC (rev 54091)
@@ -1487,12 +1487,12 @@
pg_info = &(Map->fInfo.pg);
if (line < 1 || line > Vect_get_num_lines(Map)) {
- G_warning(_("Inconsistency in topology detected"));
+ G_warning(_("Inconsistency in topology: invalid feature id"));
return -1;
Line = Map->plus.Line[line];
if (!Line) {
+ G_warning(_("Inconsistency in topology: dead line found"));
return -1;
@@ -1518,8 +1518,8 @@
nle = next_edge; /* update next left edge for end node */
else {
- G_warning(_("Inconsistency in topology detected. "
- "Unable to determine next left/right edge."));
+ G_warning(_("Inconsistency in topology detected: "
+ "unable to determine next left/right edge."));
return -1;
@@ -1585,12 +1585,12 @@
+ G_warning(_("Inconsistency in topology detected: invalid feature id"));
return -1;
if (!Line) {
+ G_warning(_("Inconsistency in topology detected: dead line found"));
return -1;
