[GRASS-SVN] r54099 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Thu Nov 29 01:01:41 PST 2012
Author: martinl
Date: 2012-11-29 01:01:40 -0800 (Thu, 29 Nov 2012)
New Revision: 54099
grass/trunk/lib/vector/Vlib/write_pg.c
vlib: allow writting PostGIS topological elements on level 1
Modified: grass/trunk/lib/vector/Vlib/write_pg.c
--- grass/trunk/lib/vector/Vlib/write_pg.c 2012-11-29 08:59:44 UTC (rev 54098)
+++ grass/trunk/lib/vector/Vlib/write_pg.c 2012-11-29 09:01:40 UTC (rev 54099)
@@ -94,12 +94,10 @@
return -1;
- if (pg_info->toposchema_name) {
- G_warning(_("PostGIS topology not supported on level 1"));
- return -1;
+ if (!pg_info->toposchema_name) { /* simple features */
+ return write_line_sf(Map, type, &points, 1, cats);
- return write_line_sf(Map, type, &points, 1, cats);
+ return write_line_tp(Map, type, FALSE, points, cats);
#else
G_fatal_error(_("GRASS is not compiled with PostgreSQL support"));
return -1;
