[GRASS-SVN] r54101 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Thu Nov 29 02:06:46 PST 2012
Author: martinl
Date: 2012-11-29 02:06:45 -0800 (Thu, 29 Nov 2012)
New Revision: 54101
grass/trunk/lib/vector/Vlib/build_pg.c
grass/trunk/lib/vector/Vlib/open_pg.c
grass/trunk/lib/vector/Vlib/write_pg.c
vlib/PostGIS Topology: report correct number of centroids and isles (work in progress)
Modified: grass/trunk/lib/vector/Vlib/build_pg.c
--- grass/trunk/lib/vector/Vlib/build_pg.c 2012-11-29 09:35:33 UTC (rev 54100)
+++ grass/trunk/lib/vector/Vlib/build_pg.c 2012-11-29 10:06:45 UTC (rev 54101)
@@ -122,7 +122,8 @@
int build_topo(struct Map_info *Map, int build)
- int line, type, topo_id, area, nareas, s;
+ int line, type, topo_id, s;
+ int area, nareas, isle, nisles;
int face[2];
char stmt[DB_SQL_MAX];
@@ -180,7 +181,7 @@
/* delete faces */
sprintf(stmt, "DELETE FROM \"%s\".face WHERE "
- "face_id > 0", pg_info->toposchema_name);
+ "face_id != 0", pg_info->toposchema_name);
G_debug(2, "SQL: %s", stmt);
if(Vect__execute_pg(pg_info->conn, stmt) == -1) {
Vect__execute_pg(pg_info->conn, "ROLLBACK");
@@ -215,6 +216,15 @@
+ if (build >= GV_BUILD_ATTACH_ISLES) {
+ /* insert isles as faces with negative face_id */
+ nisles = Vect_get_num_islands(Map);
+ for(isle = 1; isle <= nisles; isle++) {
+ Isle = plus->Isle[isle];
+ Vect__insert_face_pg(Map, -isle);
G_message(_("Updating TopoGeometry data..."));
for (line = 1; line <= plus->n_lines; line++) {
type = Vect_read_line(Map, NULL, NULL, line);
Modified: grass/trunk/lib/vector/Vlib/open_pg.c
--- grass/trunk/lib/vector/Vlib/open_pg.c 2012-11-29 09:35:33 UTC (rev 54100)
+++ grass/trunk/lib/vector/Vlib/open_pg.c 2012-11-29 10:06:45 UTC (rev 54101)
@@ -1389,9 +1389,11 @@
plus->n_areas = Vect__execute_get_value_pg(pg_info->conn, stmt);
G_debug(3, "Vect_open_topo_pg(): n_areas=%d", plus->n_areas);
- /* isles (faces with face_id <=0 in PostGIS Topology model) */
+ /* isles (faces with face_id <=0 in PostGIS Topology model)
+ note: universal face is represented in GRASS Topology model as isle (area=0)
sprintf(stmt,
- "SELECT COUNT(*) FROM \"%s\".face WHERE face_id < 1",
+ "SELECT COUNT(*) FROM \"%s\".face WHERE face_id < 0",
plus->n_isles = Vect__execute_get_value_pg(pg_info->conn, stmt);
G_debug(3, "Vect_open_topo_pg(): n_isles=%d", plus->n_isles);
@@ -1428,7 +1430,12 @@
/* centroids */
sprintf(stmt,
- "SELECT COUNT(*) FROM \"%s\".face WHERE mbr IS NOT NULL",
+ "SELECT COUNT(*) FROM \"%s\".node WHERE containing_face "
+ "IS NOT NULL AND node_id NOT IN "
+ "(SELECT node FROM (SELECT start_node AS node FROM \"%s\".edge "
+ "GROUP BY start_node UNION ALL SELECT end_node AS node FROM "
+ "\"%s\".edge GROUP BY end_node) AS foo)",
+ pg_info->toposchema_name, pg_info->toposchema_name,
plus->n_clines = Vect__execute_get_value_pg(pg_info->conn, stmt);
G_debug(3, "Vect_open_topo_pg(): n_clines=%d", plus->n_clines);
@@ -1599,7 +1606,7 @@
res = PQexec(pg_info->conn, stmt);
if (!res || PQresultStatus(res) != PGRES_TUPLES_OK ||
- PQntuples(res) > plus->n_clines) {
+ PQntuples(res) != plus->n_clines) {
G_warning(_("Inconsistency in topology: number of "
"centroids %d (should be %d)"),
PQntuples(res), plus->n_clines);
Modified: grass/trunk/lib/vector/Vlib/write_pg.c
--- grass/trunk/lib/vector/Vlib/write_pg.c 2012-11-29 09:35:33 UTC (rev 54100)
+++ grass/trunk/lib/vector/Vlib/write_pg.c 2012-11-29 10:06:45 UTC (rev 54101)
@@ -1354,7 +1354,7 @@
\brief Insert new face to the 'face' table (topo only)
\param Map pointer to Map_info struct
- \param area area id
+ \param area area id (negative id for isles)
\return 0 on error
\return area id on success (>0)
@@ -1366,7 +1366,7 @@
struct Format_info_pg *pg_info;
struct bound_box box;
- if (area <= 0)
+ if (area == 0)
return 0; /* universal face has id '0' in PostGIS Topology */
stmt = NULL;
@@ -1375,7 +1375,10 @@
/* check if face exists */
/* get mbr of the area */
- Vect_get_area_box(Map, area, &box);
+ if (area > 0)
+ Vect_get_area_box(Map, area, &box);
+ else
+ Vect_get_isle_box(Map, abs(area), &box);
/* insert face if not exists */
G_asprintf(&stmt, "INSERT INTO \"%s\".face (face_id, mbr) VALUES "
