[GRASS-SVN] r54116 - grass/branches/releasebranch_6_4/lib/vector/Vlib
svn_grass at osgeo.org
Fri Nov 30 08:11:58 PST 2012
Author: martinl
Date: 2012-11-30 08:11:57 -0800 (Fri, 30 Nov 2012)
New Revision: 54116
grass/branches/releasebranch_6_4/lib/vector/Vlib/open_ogr.c
vlib: V1_open_old_ogr() fix for 3D data
Modified: grass/branches/releasebranch_6_4/lib/vector/Vlib/open_ogr.c
--- grass/branches/releasebranch_6_4/lib/vector/Vlib/open_ogr.c 2012-11-30 15:45:47 UTC (rev 54115)
+++ grass/branches/releasebranch_6_4/lib/vector/Vlib/open_ogr.c 2012-11-30 16:11:57 UTC (rev 54116)
@@ -48,7 +48,8 @@
OGRDataSourceH Ogr_ds;
OGRLayerH Ogr_layer = NULL;
OGRFeatureDefnH Ogr_featuredefn;
+ OGRwkbGeometryType Ogr_geom_type;
if (update) {
G_fatal_error(_("OGR format cannot be updated"));
return -1;
@@ -74,8 +75,8 @@
for (i = 0; i < nLayers; i++) {
Ogr_layer = OGR_DS_GetLayer(Ogr_ds, i);
Ogr_featuredefn = OGR_L_GetLayerDefn(Ogr_layer);
- if (strcmp(OGR_FD_GetName(Ogr_featuredefn), Map->fInfo.ogr.layer_name)
- == 0) {
+ if (strcmp(OGR_FD_GetName(Ogr_featuredefn), Map->fInfo.ogr.layer_name) == 0) {
+ Ogr_geom_type = OGR_FD_GetGeomType(Ogr_featuredefn);
layer = i;
break;
@@ -95,8 +96,17 @@
Map->fInfo.ogr.lines_num = 0;
Map->fInfo.ogr.lines_next = 0;
- Map->head.with_z = WITHOUT_Z; /* TODO: 3D */
+ switch(Ogr_geom_type) {
+ case wkbPoint25D: case wkbLineString25D: case wkbPolygon25D:
+ case wkbMultiPoint25D: case wkbMultiLineString25D: case wkbMultiPolygon25D:
+ case wkbGeometryCollection25D:
+ Map->head.with_z = WITH_Z;
+ break;
+ default:
+ Map->head.with_z = WITHOUT_Z;
+ break;
Map->fInfo.ogr.feature_cache = NULL;
Map->fInfo.ogr.feature_cache_id = -1; /* FID >= 0 */
