[GRASS-SVN] r54118 - grass/trunk/vector/v.external
svn_grass at osgeo.org
Fri Nov 30 08:36:10 PST 2012
Author: martinl
Date: 2012-11-30 08:36:09 -0800 (Fri, 30 Nov 2012)
New Revision: 54118
grass/trunk/vector/v.external/list.c
grass/trunk/vector/v.external/local_proto.h
grass/trunk/vector/v.external/main.c
v.external: dimension is set later from data source
Modified: grass/trunk/vector/v.external/list.c
--- grass/trunk/vector/v.external/list.c 2012-11-30 16:17:36 UTC (rev 54117)
+++ grass/trunk/vector/v.external/list.c 2012-11-30 16:36:09 UTC (rev 54118)
@@ -17,10 +17,10 @@
static char **format_list(int *, size_t *);
static char *feature_type(const char *);
#ifdef HAVE_OGR
-static int list_layers_ogr(FILE *, const char *, const char *, int, int *);
+static int list_layers_ogr(FILE *, const char *, const char *, int);
#endif /* HAVE_OGR */
#ifdef HAVE_POSTGRES
-static int list_layers_pg(FILE *, const char *, const char *, int, int *);
+static int list_layers_pg(FILE *, const char *, const char *, int);
#endif /* HAVE_POSTGRES */
int cmp(const void *a, const void *b)
@@ -101,17 +101,17 @@
G_free(list);
-int list_layers(FILE *fd, const char *dsn, const char *layer, int print_types, int use_ogr, int *is3D)
+int list_layers(FILE *fd, const char *dsn, const char *layer, int print_types, int use_ogr)
if (!use_ogr) {
- return list_layers_pg(fd, dsn, layer, print_types, is3D);
+ return list_layers_pg(fd, dsn, layer, print_types);
#else
G_fatal_error(_("GRASS is not compiled with PostgreSQL support"));
#endif
#ifdef HAVE_OGR
- return list_layers_ogr(fd, dsn, layer, print_types, is3D);
+ return list_layers_ogr(fd, dsn, layer, print_types);
#else
G_fatal_error(_("GRASS is not compiled with OGR support"));
#endif
@@ -138,7 +138,7 @@
-int list_layers_pg(FILE *fd, const char *conninfo, const char *table, int print_types, int *is3D)
+int list_layers_pg(FILE *fd, const char *conninfo, const char *table, int print_types)
int row, ntables, ret, print_schema;
char *value_schema, *value_table;
@@ -214,7 +214,6 @@
if ((!schema_name || strcmp(value_schema, schema_name) == 0) &&
table_name && strcmp(value_table, table_name) == 0) {
ret = row;
- *is3D = WITHOUT_Z;
@@ -232,7 +231,7 @@
#ifdef HAVE_OGR
-int list_layers_ogr(FILE *fd, const char *dsn, const char *layer, int print_types, int *is3D)
+int list_layers_ogr(FILE *fd, const char *dsn, const char *layer, int print_types)
int i, ret;
int nlayers;
@@ -274,18 +273,6 @@
if (layer)
if (strcmp(layer_name, layer) == 0) {
- if (is3D) {
- switch(Ogr_geom_type) {
- case wkbPoint25D: case wkbLineString25D: case wkbPolygon25D:
- case wkbMultiPoint25D: case wkbMultiLineString25D: case wkbMultiPolygon25D:
- case wkbGeometryCollection25D:
- *is3D = WITH_Z;
- break;
- default:
- break;
ret = i;
Modified: grass/trunk/vector/v.external/local_proto.h
--- grass/trunk/vector/v.external/local_proto.h 2012-11-30 16:17:36 UTC (rev 54117)
+++ grass/trunk/vector/v.external/local_proto.h 2012-11-30 16:36:09 UTC (rev 54118)
@@ -15,7 +15,7 @@
/* list.c */
void list_formats();
-int list_layers(FILE *, const char *, const char *, int, int, int *);
+int list_layers(FILE *, const char *, const char *, int, int);
void get_table_name(const char *, char **, char **);
#endif
Modified: grass/trunk/vector/v.external/main.c
--- grass/trunk/vector/v.external/main.c 2012-11-30 16:17:36 UTC (rev 54117)
+++ grass/trunk/vector/v.external/main.c 2012-11-30 16:36:09 UTC (rev 54118)
@@ -38,7 +38,7 @@
FILE *fd;
- int ilayer, is3D, use_ogr;
+ int ilayer, use_ogr;
char buf[GPATH_MAX], *dsn;
const char *output;
@@ -116,8 +116,7 @@
if (!dsn)
G_fatal_error(_("Required parameter <%s> not set"), options.dsn->key);
list_layers(stdout, dsn, NULL,
- flags.tlist->answer ? TRUE : FALSE,
- use_ogr, NULL);
+ flags.tlist->answer ? TRUE : FALSE, use_ogr);
exit(EXIT_SUCCESS);
@@ -130,7 +129,7 @@
/* get layer index */
ilayer = list_layers(NULL, dsn, options.layer->answer,
- FALSE, use_ogr, &is3D);
+ FALSE, use_ogr);
if (ilayer == -1) {
G_fatal_error(_("Layer <%s> not available"), options.layer->answer);
@@ -143,7 +142,7 @@
/* create new vector map */
- Vect_open_new(&Map, output, is3D);
+ Vect_open_new(&Map, output, WITHOUT_Z); /* dimension is set later from data source */
Vect_set_error_handler_io(NULL, &Map);
Vect_hist_command(&Map);
