[GRASS-SVN] r53305 - grass/trunk/general/g.proj
svn_grass at osgeo.org
Wed Oct 3 05:56:00 PDT 2012
Author: pkelly
Date: 2012-10-03 05:55:59 -0700 (Wed, 03 Oct 2012)
New Revision: 53305
grass/trunk/general/g.proj/Makefile
grass/trunk/general/g.proj/datumtrans.c
grass/trunk/general/g.proj/g.proj.html
grass/trunk/general/g.proj/local_proto.h
grass/trunk/general/g.proj/main.c
Always also change the ellipsoid when overriding the datum
Modified: grass/trunk/general/g.proj/Makefile
--- grass/trunk/general/g.proj/Makefile 2012-10-03 12:26:25 UTC (rev 53304)
+++ grass/trunk/general/g.proj/Makefile 2012-10-03 12:55:59 UTC (rev 53305)
@@ -2,7 +2,7 @@
PGM = g.proj
-EXTRA_INC = $(PROJINC)
+EXTRA_INC = $(PROJINC) -Wall
LIBES = $(GPROJLIB) $(GISLIB) $(GDALLIBS) $(PROJLIB)
DEPENDENCIES = $(GPROJDEP) $(GISDEP)
Modified: grass/trunk/general/g.proj/datumtrans.c
--- grass/trunk/general/g.proj/datumtrans.c 2012-10-03 12:26:25 UTC (rev 53304)
+++ grass/trunk/general/g.proj/datumtrans.c 2012-10-03 12:55:59 UTC (rev 53305)
@@ -25,12 +25,71 @@
- * \brief Add or replace datum transformation parameters to the current
- * co-ordinate system definition
+ * \brief Add or replace datum to the current co-ordinate system definition
* \param datum Use this datum (overrides any datum found in the
* current co-ordinate system definition).
+ * \return 1 if a change was made, 0 if not.
+int set_datum(char *datum)
+ struct gpj_datum dstruct;
+ struct Key_Value *temp_projinfo;
+ int i;
+ if (cellhd.proj == PROJECTION_XY)
+ return 0;
+ if (!datum || GPJ_get_datum_by_name(datum, &dstruct) < 0)
+ G_fatal_error(_("Invalid datum code <%s>"), datum);
+ return 0;
+ temp_projinfo = G_create_key_value();
+ /* Copy old PROJ_INFO, skipping out any keys related
+ * to datum or ellipsoid parameters */
+ for (i = 0; i < projinfo->nitems; i++) {
+ if (strcmp(projinfo->key[i], "datum") == 0
+ || strcmp(projinfo->key[i], "dx") == 0
+ || strcmp(projinfo->key[i], "dy") == 0
+ || strcmp(projinfo->key[i], "dz") == 0
+ || strcmp(projinfo->key[i], "datumparams") == 0
+ || strcmp(projinfo->key[i], "nadgrids") == 0
+ || strcmp(projinfo->key[i], "towgs84") == 0
+ || strcmp(projinfo->key[i], "ellps") == 0
+ || strcmp(projinfo->key[i], "a") == 0
+ || strcmp(projinfo->key[i], "b") == 0
+ || strcmp(projinfo->key[i], "es") == 0
+ || strcmp(projinfo->key[i], "f") == 0
+ || strcmp(projinfo->key[i], "rf") == 0)
+ continue;
+ G_set_key_value(projinfo->key[i], projinfo->value[i],
+ temp_projinfo);
+ /* Finally add datum and ellipsoid names */
+ G_set_key_value("datum", dstruct.name, temp_projinfo);
+ G_message(_("Datum set to <%s>"), dstruct.name);
+ G_set_key_value("ellps", dstruct.ellps, temp_projinfo);
+ G_message(_("Ellipsoid set to <%s>"), dstruct.ellps);
+ /* Destroy original key/value structure and replace with new one */
+ G_free_key_value(projinfo);
+ projinfo = temp_projinfo;
+ return 1;
+ * \brief Add or replace datum transformation parameters to the current
+ * co-ordinate system definition
* \param datumtrans Index number of parameter set to use, 0 to leave
* unspecifed (or remove specific parameters, leaving just
* the datum name), -1 to list the available parameter
@@ -42,25 +101,18 @@
-int set_datumtrans(char *datum, int datumtrans, int force)
+int set_datumtrans(int datumtrans, int force)
+ char *params, *datum = NULL;
int paramsets, status;
return 0;
- if (datum)
- /* datum name provided; set status to 1 to indicate no parameters available */
- status = 1;
- else {
- /* extract datum name and parameter status from input co-ordinate system */
- char *params;
+ status = GPJ__get_datum_params(projinfo, &datum, ¶ms);
+ G_debug(3, "set_datumtrans(): GPJ__get_datum_params() status=%d", status);
+ G_free(params);
- status = GPJ__get_datum_params(projinfo, &datum, ¶ms);
- G_debug(3, "set_datumtrans(): GPJ__get_datum_params() status=%d", status);
- G_free(params);
if (datum) {
/* A datum name is specified; need to determine if
* there are parameters to choose from for this datum */
@@ -147,8 +199,7 @@
* to datum parameters */
- if (strcmp(projinfo->key[i], "datum") == 0
- || strcmp(projinfo->key[i], "dx") == 0
+ if (strcmp(projinfo->key[i], "dx") == 0
@@ -160,9 +211,7 @@
temp_projinfo);
- /* Finally (re-)add datum name and add new parameters (if we have them) */
- G_set_key_value("datum", datum, temp_projinfo);
- G_message(_("Datum set to <%s>"), datum);
+ /* Finally add new parameters (if we have them) */
if (chosenparams != NULL) {
/* Now split 'chosenparams' into key/value format */
paramkey = strtok(chosenparams, "=");
Modified: grass/trunk/general/g.proj/g.proj.html
--- grass/trunk/general/g.proj/g.proj.html 2012-10-03 12:26:25 UTC (rev 53304)
+++ grass/trunk/general/g.proj/g.proj.html 2012-10-03 12:55:59 UTC (rev 53305)
@@ -53,8 +53,7 @@
supplied using the <em>datum</em> parameter. This will override any
datum contained in the input co-ordinate system, and discard
any datum transformation parameters. Enter datum=<em>list</em> to return a
-list of all the datums supported by GRASS. Note that the -t flag is
-implicit when a value for <em>datum</em> is specified. Since any
+list of all the datums supported by GRASS. Since any
existing datum transformation parameters will have been discarded, the
<em>datumtrans</em> parameter should in general always be used in
conjunction with <em>datum</em>.
Modified: grass/trunk/general/g.proj/local_proto.h
--- grass/trunk/general/g.proj/local_proto.h 2012-10-03 12:26:25 UTC (rev 53304)
+++ grass/trunk/general/g.proj/local_proto.h 2012-10-03 12:55:59 UTC (rev 53305)
@@ -21,7 +21,8 @@
#endif
/* datumtrans.c */
-int set_datumtrans(char *, int, int);
+int set_datum(char *);
+int set_datumtrans(int, int);
/* create.c */
void create_location(char *);
Modified: grass/trunk/general/g.proj/main.c
--- grass/trunk/general/g.proj/main.c 2012-10-03 12:26:25 UTC (rev 53304)
+++ grass/trunk/general/g.proj/main.c 2012-10-03 12:55:59 UTC (rev 53305)
@@ -258,8 +258,12 @@
&& (projinfo == NULL || projunits == NULL))
G_fatal_error(_("Projection files missing"));
+ /* Override input datum if requested */
+ if(datum->answer)
+ set_datum(datum->answer);
/* Set Datum Parameters if necessary or requested */
- set_datumtrans(datum->answer, atoi(dtrans->answer), forcedatumtrans->answer);
+ set_datumtrans(atoi(dtrans->answer), forcedatumtrans->answer);
/* Output */
